Author Topic: [IC] GMK CYL Prussian Alert | May 15th - June 12th  (Read 140826 times)
Offline Gtour
  • Just a random guy passionate about keyboards.
« on: Sun, 25 February 2024, 06:54:14 »
Check out the group buy thread for the latest information!
IC Form Closed | Discord
Scroll through the first comment to see the kitting changes.
If you can’t see Imgur images, or if you’d like to view higher-resolution renders, you can check them out on my portfolio site: Link
Colors
I'm happy to announce that GMK CYL Prussian Alert will use the same RAL 230 20 20 color sample used in GMK CYL Prussian Blue.
You can check the samples on NoPun site, he did an amazing job capturing all the different color shifts in various lighting conditions:
https://nopunin10did.com/gmk-prussian-blue/#gmk-color-samples
People asked me to do a few Shadow White & Mortar Grey sample photos in indirect natural daylight (indoors), here they are:
Vendors
GB Date: May 15th - June 12th
Intro & Specs
Hello good lads, this is my first keycap IC.
This set was inspired by a keyboard friend of mine whose favorite shade of blue is Prussian Blue. He was looking forward to GMK Prussian Blue GB, but it got indefinitely postponed. To troll him, I started designing something with the same blue and a simple idea came to my mind – what about an *insert color here* Alert set? At the same time, I wanted to do something a little different and I didn’t like how it looked with the often-used beige as a base, so instead I ultimately chose to use white and grey.
GMK CYL Prussian Alert uses three RAL Design colors:
RAL 230 20 20 – Prussian Blue
RAL 000 65 00 – Mortar Grey
RAL 000 85 00 – Shadow White
Profile:
Cherry Profile Doubleshot ABS (UV Printed Sublegends for Alpha Kit)
If you are interested in being a vendor, want to collaborate or have further suggestions, feel free to contact me on Discord (g_tour).
I’m more than happy to have a chat with anyone.
Kitting Renders
Base Kit
Extension Kit
Alpha Kit
Colors are inverted for a more muted look.
You can build two keyboards (Two ANSI or One ANSI/One ISO) when bought with the Base Kit.
The Cyrillic Sublegends will be the same as GMK WoB Red Cyrillic - Thanks Qarmaa for your kindness!
Non-Alert Kit
NorDEUK Kit
Keyboard Renders
Packaging Design
I want to thank Zucanio (The guy who likes Prussian Blue), Zlobin, Khor, Dan, Pigiamons, il Pino and all the people of MechBoutique.
« Last Edit: Mon, 18 May 2026, 07:11:56 by Gtour »
Offline Gtour
Re: [IC] GMK CYL Prussian Alert
« Reply #1 on: Sun, 25 February 2024, 07:08:24 »
Update [01 May 2026]
Kitting Changes
R5 → R4 bottom row
I know a few of you won’t love this, but most buyers prefer R4 (me included) and I completely understand why. R5 works great on TKL+ boards with 9°+ typing angle, but on smaller boards it can feel awkward.
Base Kit
Removed R5 1U Fn
Removed R1 1U End / PgDn → moved to Alertless (One drawback of including the Alert row in the Base Kit is that proper 1800 support — both Classic and Compact — requires some Alertless keys [Mainly Home and Page Up]. Without them, certain keys above the numpad would be mismatched in color. For this reason, I moved these two keys to the Alertless Kit, as they serve no purpose without it.)
Extension Kit
Removed R1 1U Backspace (rarely used, only really makes sense in combo with BAE Enter)
Removed R3 1.75U Stepped Control (cool vintage touch but Control is a hold key, stepped doesn’t add much practicality)
Alpha Kit
No changes.
Alertless Kit
Added R1 1U End
Added R1 1U PgDn
« Last Edit: Wed, 13 May 2026, 15:29:51 by Gtour »
Offline baekihyun
« Reply #2 on: Sun, 25 February 2024, 07:21:31 »
forced alert :cool: I like the look of the inverted cyrillic kit but never a fan of UV printed legends personally--would prefer this with kkb if you're set on having different colored subs
Offline Thevenny
« Reply #3 on: Sun, 25 February 2024, 08:19:53 »
ah gitur gitur! Nice project!
Offline nu_types
  • Formerly Iredeus
« Reply #4 on: Sun, 25 February 2024, 08:51:46 »
Why is there a Cyrillic alphas kit? Prussia did not use the Cyrillic alphabet. Its fine if you just really want Cyrillic. Also, by omitting the number row the Cyrillic alpha kit is incomplete.
« Last Edit: Sun, 25 February 2024, 08:56:11 by nu_types »
Offline Fraaaan
« Reply #5 on: Sun, 25 February 2024, 09:04:59 »
Finally an alert set with the alert in base. :thumb:
Kitting looks pretty good. LED NumLock should probably be blue. I'd just put some size labels on the spacebars and the shift in the addon kit.
Offline Gtour
« Reply #6 on: Sun, 25 February 2024, 09:09:54 »
Thanks for letting me know what I already knew. You answered your question yourself: I just like the look of Cyrillic subs. The Num Row is not there because it would interfere with the Alert theme of the set, but I'm always open to suggestions and if that's what people want I could eventually figure out a way to add it.
Offline Dmitri
« Reply #7 on: Sun, 25 February 2024, 09:11:14 »
Clean clean, i only like the classic version more instead of alert, like classic blue or classic red, i also dig the cryllic alpha’s
« Last Edit: Sun, 25 February 2024, 09:16:10 by Dmitri »
Offline Gtour
« Reply #8 on: Sun, 25 February 2024, 09:13:06 »
Yes, it should definitely be blue. I'm fixing this ASAP, thanks!
« Reply #9 on: Sun, 25 February 2024, 09:29:02 »
Prussian Blue really does need more love. This set looks amazing
Sent from my Pixel 7 Pro using Tapatalk
Offline mmayhem17
    • Steam profile
« Reply #10 on: Sun, 25 February 2024, 09:41:46 »
Ditching the beige OGs for custom colors is a mistake imho.
Not a fan of the inverted subs, and also didn't understand the choice for cyrillic subs instead of regional ones, but I guess it's ok?
Offline nu_types
  • Formerly Iredeus
« Reply #11 on: Sun, 25 February 2024, 09:50:15 »
You could just add an alert row to the alphas with the appropriate sublegends?
Edit: I guess that wouldn't work with the two tone legends, unless you wanted to use the beige gray or something for the sublegends.
« Last Edit: Sun, 25 February 2024, 10:04:21 by nu_types »
Offline LMarci
« Reply #12 on: Sun, 25 February 2024, 10:15:20 »
Cool set but would've been better if you used standard beige imo
Offline Piperaceae
« Reply #13 on: Sun, 25 February 2024, 10:19:12 »
Love this. Please don't go with beige, keep the custom greys! Beige is severely overused.
Offline mr_foggy
  • neue = nope
« Reply #14 on: Sun, 25 February 2024, 11:03:06 »
lol cya
« Last Edit: Fri, 17 January 2025, 04:04:05 by mr_foggy »
Offline involuntarysoul
« Reply #15 on: Sun, 25 February 2024, 11:04:08 »
alpha is way too bright
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #16 on: Sun, 25 February 2024, 13:37:35 »
I love *spinning circle of colors* alert
Offline IOVERCALLHISTIOCYTES
« Reply #17 on: Sun, 25 February 2024, 14:04:08 »
I like it.
Have pics of the RAL color standards?
Nopun, hopefully someday ill buy yours too
Offline mr_foggy
  • neue = nope
« Reply #18 on: Sun, 25 February 2024, 14:41:29 »
« Last Edit: Fri, 17 January 2025, 04:05:09 by mr_foggy »
Offline ankit
  • Formerly ankit-sachdeva
« Reply #19 on: Sun, 25 February 2024, 15:44:05 »
Honestly pretty nice, I like the kitting but will echo the same sentiments about numrow sublegends in the alpha kit.
My bigger concern is that GMK Blue Alert R2/V2 has already been announced by Diego/Lightning Keyboards and has been confirmed to be running later this year. I think running both would cannibalize each other set's sales w/ how similar they are.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #20 on: Sun, 25 February 2024, 18:51:16 »
Where can I get more info on GMK Blue Alert R2? Is there an IC? Couldn't find anything on https://www.lightningkeyboards.com/
Offline aicyborg
« Reply #21 on: Sun, 25 February 2024, 19:36:45 »
i resent this on the basis it gives NoPun an excuse to delay GMK Prussian Blue for another year, which is something i want very much
Offline Lysol_
« Reply #22 on: Mon, 26 February 2024, 01:23:43 »
I have enough beige, seeing a play(albeit a minor one) on the standard beige + alert theme could be a nice change of pace. also a fan of Cyrillic in general.
Offline offbrandbiscuit
« Reply #23 on: Mon, 26 February 2024, 04:14:00 »
I want it
i like fire trucks and moster trucks
Offline tactilesbad
« Reply #24 on: Mon, 26 February 2024, 07:53:55 »
sign me up
not keen on the alt alphas but the basekit looks smashing
Offline garrdub
« Reply #25 on: Mon, 26 February 2024, 07:57:21 »
2024, the year of the alert.
i am a fan of the forced alert in the base kit. why else would you get an alert set if you were not going to get the alert row?
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #26 on: Mon, 26 February 2024, 08:28:32 »
Okay, I get it, I get it, it's time to try running GMK Prussian Blue again.
Maybe we can coordinate so that you can reuse the color once it's been matched.
This is a fun idea. Personally I'd love it if the Cyrillic was the Ukrainian layout instead of the Russian one, but neither of them is Prussian, so whatchagonnado.
Offline Gtour
« Reply #27 on: Mon, 26 February 2024, 16:29:24 »
Please do it so that Zucanio can finally stop waiting. I'm in for a set as well.
I'm down for sure :thumb:
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Prussian Alert - A little update
« Reply #28 on: Thu, 29 February 2024, 12:47:16 »
Blue
Offline DeMechanica
« Reply #29 on: Thu, 29 February 2024, 19:13:06 »
I too am crying about GMK Prussian Blue to this day. Nice to not feel alone!
Offline irithyll
Re: [IC] GMK CYL Prussian Alert - Kitting Changes & News
« Reply #30 on: Fri, 01 March 2024, 07:43:12 »
I’m a fan of the decision to go with white and grey!
Offline m202307
« Reply #31 on: Sun, 03 March 2024, 08:59:46 »
I'd be in for the base kit and alt Russian Cyrillic alphas if it ran with Key Kobo.  If it's GMK I'd pick it up in stock only, if it were on sale for ~$80ish and the alt alphas were also available and on sale.
« Reply #32 on: Mon, 04 March 2024, 02:09:58 »
need a set of 20 relegendable for full f-row coverage
Offline Gtour
« Reply #33 on: Mon, 04 March 2024, 07:08:27 »
I would love to, but I don't think it's ever going to reach MOQ as it's not requested at all. The two Relegendables in the Extension kit are there as a bonus, they act like a sort of Artisan for places like F13 or to use on boards that need R1 1U Backspace for example.
Offline firimp
« Reply #34 on: Mon, 04 March 2024, 07:28:05 »
The lighter gray definitely looks better than the original alert beige. Looking forward to seeing the manufactur switched to KKB. Although the fulfillment date of GMK has been significantly improved, I just don't want to see bent spacebars and potentially crooked modifiers anymore.
Offline Zeus501
« Reply #35 on: Mon, 04 March 2024, 07:33:17 »
Looking forward to this!
Offline Robert.Lussier5
« Reply #36 on: Tue, 05 March 2024, 21:34:21 »
Cyrillic numpad to add to the alpha kit? please and thanks!
Austin R3 - Green // Austin R3 - Purple // Custom Acrylic Austin - Clear // Rekt1800 - Blue // Cypher r4 - Black // Boston - Sparkle Black // Balance - White // Glitch - Green // Shelby80 - Navy // Odin - Silver // Zoom65  Red // QK65 - Black // Link65 - Lilac
Offline tactilesbad
« Reply #37 on: Wed, 06 March 2024, 16:57:11 »
-- forget it im dumb
Offline mr_foggy
  • neue = nope
« Reply #38 on: Wed, 06 March 2024, 21:34:36 »
« Last Edit: Fri, 17 January 2025, 04:06:45 by mr_foggy »
Offline AMZ
« Reply #39 on: Thu, 07 March 2024, 15:14:27 »
Count me in!
Offline FrostyR
« Reply #40 on: Fri, 08 March 2024, 07:40:58 »
Looks awesome.
Only thing is runner must do a good job color matching. Why not make it easier to achieve success by using standard(or previously used colors) for the white and the grey.
Blue of course must be a custom color.
GLWIC!
Offline saferider4969
« Reply #41 on: Fri, 08 March 2024, 10:16:58 »
Really nice set, I am in
Offline mr_foggy
  • neue = nope
« Reply #42 on: Sun, 10 March 2024, 19:34:27 »
« Last Edit: Fri, 17 January 2025, 04:06:21 by mr_foggy »
Offline Gtour
« Reply #43 on: Mon, 11 March 2024, 02:24:21 »
Looks awesome.
GLWIC!
Like Foggy said, it's what I'm currently doing. I tried using standard colors and imo it doesn't look as good. The color sampling will take some time, but I'm sure it will be worth it. I will update the IC when I have more news about it. :thumb:
Offline FrostyR
« Reply #44 on: Mon, 11 March 2024, 13:03:28 »
Brilliant! Let’s go!
Offline whysoda
« Reply #45 on: Tue, 12 March 2024, 13:25:56 »
Looks awesome.
GLWIC!
Color matching is always super tricky, although I do think the cooler toned hues of the white and grey you have in your renders looks great as is! I have full confidence that you'll get the right color samples though, and can't wait for this set so I can burn a larger hole in my wallet :D
Offline Gtour
« Reply #46 on: Wed, 13 March 2024, 07:41:24 »
I'm glad you like the set! You did a fantastic job with WS Akuamarin :D
Offline Gtour
Re: [IC] GMK CYL Prussian Alert - Cyrillic Sub-legends Updated
« Reply #47 on: Sun, 17 March 2024, 06:01:48 »
New update: The Cyrillic sub-legends on the Alpha Kit will be the same as GMK WoB Red Cyrillic. Thanks Qarmaa for your kindness! ;)
Offline Faraday
  • a toofpick changes everythang
« Reply #48 on: Fri, 22 March 2024, 14:38:29 »
Very pretty colors, I dig it!
Offline ppatches24
« Reply #49 on: Mon, 25 March 2024, 11:08:48 »
Ok i need this
