Author Topic: [IC] Snake60 - Fossil Edition - Raffle is live  (Read 19051 times)
fem and 1 Guest are viewing this topic.
Offline kentdo10
« on: Thu, 04 September 2025, 02:49:30 »
Hi everyone, this is Kent from Toro Studio. Today, I would love to show you our latest project, the Snake60 Fossil Edition.
It is a collaboration effort between Toro Studio and un*defined Studio.
About Snake60 - Fossil edition
Introducing Fossil.
Inspired by a snake trapped in amber, Fossil feels discovered, not made. Snake is reimagined as a skeleton trapped in a brown patina brass weight, giving the feeling of earth and soil. The skeleton is encased in amber PEI (Ultem), preserved like a fossil.
Why did we make Fossil?
Because of you, Snake's story was never ours alone. Fossil is a thank you to the many friends, family, and members of this community who have embraced and shaped Snake. Write the next chapter with us. Fossil is a story written together.
Specifications
Case: Uni-body PEI (Ultem) Case
Weight: Brown Patina Brass weight
Mount: O-ring, PCBsnap by NuxrosKB
Typing angle: 6 degrees
Front height: 19.35mm
Size: 302.75mm x 117.4mm
Weight: ~1.3kg unbuilt, ~1.5kg built
Layout: WK/WKL/HHKB
PCB: Hotswap (might support Solder if there is interest)/1.6mm Blackcore/ VIA & QMK supported (VIA merging is in the process)
Plate: Aluminium (by default). PEI (Ultem)/CF/PP/POM/FR4/PC are available as an extra add-on
Designed by Toro Studio in collaboration with un*defined Studio
Manufactured by Kezewa
Package content
Unibody PEI (Ultem) Case
Brass weight
Aluminum plate
Hotswap PCB (Pending support for Solder depends on IC feedback)
Daughterboard and Cable
O-ring
Carrying case
Protective cloth bag
1 set of stabilisers
1 set of PCBsnap
Other accessories (Feets, screws, etc.)
Estimate price
Limited to 111 units at USD $500. The project will be run as a GB, so people can choose the layout and extra add-ons based on their preference.
Full Pricing (in USD):
Kit: $500
Hotswap PCB: $45
Solder PCB: $45
PC/PP/POM Plate: $30
FR4 Plate: $35
CF/PEI Plate: $40
Alu Plate: $20
Price is exclusive of Shipping + Regional taxes and fees that might be applicable
Quantity
Limited to 111 units. 60% unit allocation is reserved (hard cap) for Friends and Family. 40% allocation is reserved (might be more depends on how many units are allocated to friends and family) for the Public. 11 units will be ordered as extra in case we need something to cover for lost or damage during transit (If everything goes smoothly, these units will be released to the public at the same GB price with no extra cost on top)
Extra Plate Options
PEI (Ultem)/CF/PP/POM/PC/FR4/Aluminium
How to buy?
WORLDWIDE: TORO Studio
Due to the nature of the project. Toro Studio will be the sole platform to handle this project. This is to ensure a smooth logistics and QC.
Render
Disclaimer: Renders are used for visualisation purposes only. It is not 100% accurate in representing the final product. We will upload more photos when the prototypes arrive.
Photos
More videos on the progress are uploaded in Discord. Please check it out there
More photos will be updated when the prototypes arrive
Sound Test:
PEI Plate - MX Nixies (L +F)
Showcase video
More sound tests will be uploaded as reels on our Instagram. Please follow our instagram for all the sound tests.
To-do-list
- Testing prototypes and adjusting the design if needed.
- Making a proper sound test.
- Taking photos to present the product better.
- More sound tests and photos
Credit
Thanks to all family and friends for their support. This project is ultimately made for them.
Thanks @gvb. for all the help with BTS work and writing this IC.
Thanks @nuxroskb, for sharing the idea of making a fossil keyboard, which then led us to this project
Thanks for reading the whole IC. We really appreciate your time. Please help fill out the IC form. In the meantime, you can join our Discord to discuss further on this project.
IC FORM      DISCORD      INSTAGRAM
« Last Edit: Tue, 21 October 2025, 23:41:13 by kentdo10 »
Offline Gemmmmmmmmmmmmmy
Re: [IC] Snake60 - Fossil Edition
« Reply #1 on: Thu, 04 September 2025, 02:54:23 »
creamed
Life seems so much smaller
Swim to the moon
Offline Zhenyu Li
« Reply #2 on: Thu, 04 September 2025, 02:58:55 »
bury me with this keybort and leave future archeologists confused
Offline yz
« Reply #3 on: Thu, 04 September 2025, 03:11:12 »
absolute HEAT, yall killed it with this one
Offline DirtyGingy
« Reply #4 on: Thu, 04 September 2025, 03:27:23 »
Renders: Amber, elegant
Samples: freeze-dried urine.
Man item/PEI always looks weird. I hope it sounds good
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #5 on: Thu, 04 September 2025, 03:51:34 »
SNEK SNEK SNEK SNEK 🐍
Offline lucastr
« Reply #6 on: Thu, 04 September 2025, 04:37:43 »
oh kent just give it to me already :p :p
Offline sauvieng
« Reply #7 on: Thu, 04 September 2025, 09:42:07 »
banger.
Offline kentdo10
« Reply #8 on: Thu, 04 September 2025, 18:43:45 »
It is actually the first time we work with this material (as well as the manufacturer) so we did not really know what to expect during the render phase.
These were the sources we referred to for our render:
It is also worth mentioning that the amber colour of PEI will vary based on the thickness of the object. As you can see in the photo, some areas are more amber than others because they were thicker.
Offline kentdo10
« Reply #9 on: Thu, 04 September 2025, 18:47:52 »
creamed
Thank guys <3 this means a lot to our hard work
Offline The0rigina1
  • fumoposting
« Reply #10 on: Fri, 05 September 2025, 14:25:11 »
Is this parallel keyboards
Offline kentdo10
« Reply #11 on: Fri, 05 September 2025, 17:43:23 »
Snake60 R1 was run by Parallel. Since R2, it was run directly by the un*defined studio (designer of the Snake60) and managed by Toro Studio.
Offline coffeeaddict
« Reply #12 on: Tue, 09 September 2025, 22:12:59 »
GLWIC Kent!
Offline kentdo10
« Reply #13 on: Fri, 12 September 2025, 19:02:15 »
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #14 on: Tue, 23 September 2025, 07:41:30 »
GLWIC!
Offline dantambok
« Reply #15 on: Fri, 26 September 2025, 11:40:24 »
holy **** that's hot
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline BossKeebs
« Reply #16 on: Sun, 28 September 2025, 04:41:53 »
love the polycarb
Offline kentdo10
« Reply #17 on: Sun, 28 September 2025, 20:42:28 »
Offline kentdo10
« Reply #18 on: Sun, 28 September 2025, 20:43:19 »
love the polycarb
It's not polycarb, its PEI (Ultem to be more specific)
Offline kentdo10
« Reply #19 on: Thu, 02 October 2025, 17:45:13 »
Sound test uploaded
Offline kentdo10
« Reply #20 on: Sat, 04 October 2025, 18:01:24 »
IC updated with real photos
Offline KOBO ISSHI
« Reply #21 on: Mon, 06 October 2025, 00:41:41 »
This is really well done. Congrats guys. Top work.
Offline kentdo10
« Reply #22 on: Mon, 06 October 2025, 18:08:07 »
Thanks brother
Offline kentdo10
« Reply #23 on: Tue, 21 October 2025, 23:40:50 »
