Author Topic: Elitekeyboards to stock tenderness MX clear and red keyboards  (Read 41539 times)
Offline jpm804
  • KeyCap Assasin
« Reply #150 on: Thu, 13 October 2011, 22:24:27 »
Quote from: tsangan;430710
^ But can you checkout with them? That's the real question
Will say OOS when you try to checkout... I found that out 30 minutes ago, so i went with the black version
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #151 on: Thu, 13 October 2011, 22:25:42 »
Wow.  I wonder how many they had available in the first run.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #152 on: Thu, 13 October 2011, 22:26:07 »
Quote from: jpm804;430712
glad i got my order in when i did then
Offline tsangan
  • 1000/600
« Reply #153 on: Thu, 13 October 2011, 22:26:15 »
Knowing you, you'll just get the white one in the 2nd run, rofl
Keyboardless
« Reply #154 on: Thu, 13 October 2011, 22:26:49 »
Quote from: hashbaz;430713
was wondering the same
Offline mmmty
  • bang! bang!
« Reply #155 on: Thu, 13 October 2011, 22:26:54 »
Quote from: tsangan;430698
Blacks are still avail mmmty, it's not a metal casing but you know you wannnnnnnaaaaaaa
I would buy blacks with metal casing and mod it browns or reds.
Keyboardless
Offline reaper
« Reply #156 on: Thu, 13 October 2011, 22:27:43 »
25 - 30?  Just guessing. =P
Din Eli
Offline jpm804
  • KeyCap Assasin
« Reply #157 on: Thu, 13 October 2011, 22:29:01 »
Quote from: tsangan;430715
hahaha..you read my mind. :becky:
I'm an impatient person and just wanted to try out clears anyways.
Offline tsangan
  • 1000/600
« Reply #158 on: Thu, 13 October 2011, 22:32:02 »
Quote from: reaper;430718
How many of those were bought by GeekHack users ;o
Keyboardless
Offline NormaJean
« Reply #159 on: Thu, 13 October 2011, 23:32:53 »
I'm glad I was fast :D
Offline noodles256
  • le legendary
« Reply #160 on: Fri, 14 October 2011, 00:11:02 »
got my white with clears! but I ordered like 4 hours ago haha
AF | Ducky YOTD |
Offline hashbaz
  • Grand Ancient One
« Reply #161 on: Fri, 14 October 2011, 00:42:04 »
Ordered a white cloud of boobs.
Offline hcry4
  • HHKB Hoarder
« Reply #162 on: Fri, 14 October 2011, 01:05:34 »
****...I had to go work. Missed the whites with clears. Had to settle for regular clears. Got a white otaku with reds along with a variety of those cherry mx caps as well. Another $300...damn you GH...
Offline Index
« Reply #163 on: Fri, 14 October 2011, 02:12:55 »
Are you kidding me? I missed the Leopold w/ Cherry Reds. I'm going to go shoot myself now.
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline hcry4
  • HHKB Hoarder
« Reply #164 on: Fri, 14 October 2011, 02:17:17 »
Go checkout, reds should still be available. I think only white with clears not available when you try to checkout.
Offline F u r u y á
« Reply #165 on: Fri, 14 October 2011, 03:23:49 »
They really should overprice the MX Clears. 25% more at least.
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline hcry4
  • HHKB Hoarder
« Reply #166 on: Fri, 14 October 2011, 03:28:06 »
No, I think it should have been $99 like the first batches of Leopolds earlier this year...
But even at the 25% premium you suggested, they would sell just fine to GH...
Offline F u r u y á
« Reply #167 on: Fri, 14 October 2011, 04:04:19 »
And that's why they have to up by 25%, at least. As you said, they would still sell just fine...
Offline Clickey
« Reply #168 on: Fri, 14 October 2011, 05:04:31 »
Quote from: hcry4;430784
Hey I can still order the white tenkeyless with clears, are you sure it was not just an error you had? Might want to try again.
"we are on Geekhack not Lazy****" - The Solutor
Offline hcry4
  • HHKB Hoarder
« Reply #169 on: Fri, 14 October 2011, 05:18:57 »
I see that they changed that to 2nd batch Nov. 10th...
Offline Clickey
« Reply #170 on: Fri, 14 October 2011, 05:22:16 »
I dont get it though, they are pre-orders ffs, how do you run out on a pre-order? The whole point of the pre-order is that it lets you gaurantee you have enough time to meet demand....
If you prefer to use the clear board, you could always just switch the cases/caps with your red, so you have a white otaku with clears. This would void the warrenty though, since you would have to break that little seal.
« Last Edit: Fri, 14 October 2011, 05:28:25 by Clickey »
Offline hcry4
  • HHKB Hoarder
« Reply #171 on: Fri, 14 October 2011, 06:07:24 »
I'm fine with my order. Don't really want to wait. I have some blank keycaps anyway if I feel like swapping them out.
Offline N8N
« Reply #172 on: Fri, 14 October 2011, 06:13:55 »
yup, keycaps are gonna get swapped eventually if you keep a board long enough anyway.
Two questions:  will really old windowed Cherry keys replace Leopold keys (caps lock etc.) or is there a good home mod for replicating those (round Lexan rod?)  Also, is the spacing on the space bar posts the same as a Choc Pro or is it different yet?  (I now have one space bar with six posts on it...)
Not that it makes any difference to a purchasing decision; I already ordered one (black/clears) last night.  I think that was less money than I paid for the Filco which I then had to mod with the stems and springs from a POS board.  Not sure if I'll like tenkeyless, but only one way to find out.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #173 on: Fri, 14 October 2011, 07:29:27 »
Drill a hole and fill it with clear epoxy.
Filco w/ Imsto thick PBT
Offline keyboardlover
« Reply #174 on: Fri, 14 October 2011, 07:43:30 »
I officially dub these new Leopolds the "Geekhack limited/custom keyboards". Because, a tenkeyless Leopold with reds or clears was the original idea for the Geekhack custom keyboard. EK kind of killed the idea though.
Now we know why.
Offline spill
« Reply #175 on: Fri, 14 October 2011, 08:14:21 »
Hi.  I'm new.
Been researching/searching for a good replacment board for the past couple of weeks.  Blindly went ahead and ordered a tenkeyless in reds from EK.  No issues with payment so far, so I assume now the wait begins.
Haven't bought a "new" mech keyboard in awhile.  Still have an M13 in my pile, but it's gotten harder with Win7 to get around not having a win key on a daily basis.  Same for a trusty old AT-101 I managed to grab from a previous job.  Really wish there were a way to sample the various switches in a local manner, but whatevo.  Returned a Razer BWU this week... mainly because the left side macro row really threw off my touch typing... guess I'm used to my pinky being on the outside of the keybank, which with the BWU turns "A"s into caps lock and a nonstop expletive stream coming out of my office as a result.  That and I think I'd drive myself insane eventually with the clicks... not as cool as they were when I couldn't type as fast as I do now I think.
Tempted to order a Filco tenkeyless brown in addition since I haven't felt up anything of that flavor yet....
Offline ironman31
« Reply #176 on: Fri, 14 October 2011, 08:37:24 »
Quote from: F u r u y á;430799
I would not have bought one if it was not 109
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline N8N
« Reply #177 on: Fri, 14 October 2011, 08:50:14 »
Quote from: alaricljs;430854
Have you done this?  How do you do it?  I'm imagining drilling the hole, then putting a piece of tape (what kind) on the top of the keycap and dripping the epoxy in from underneath, with the cap upside down on a flat surface.  Is that the correct procedure?  Any recommendations for particular brands/types of tape and epoxy?
Offline alaricljs
« Reply #178 on: Fri, 14 October 2011, 09:04:46 »
Haven't done it myself on keycaps, but I've seen pics of it here or at deskthority and have done it in aluminum panels.  Some have used putty, others tape, I'd go with a nice painters tape.  Drill a nice clean hole, chamfer the edges a bit.  Put the tape on the top side of the cap, burnish the tape against the cap around the hole.  Fill with clear hardening 2 part epoxy.  I have whatever random brand was sold by the hobby shop I was getting other stuff from.
Offline jpm804
  • KeyCap Assasin
« Reply #179 on: Fri, 14 October 2011, 09:17:14 »
Quote from: dante;430899
Anyone else want to confirm this?  I just tried ordering a white clear keyboard and now it is letting me order it again?  Did they extend purchasing?
Nope looks like its available again.. ordered it. Figured worse case EK cancels my order.
If not will cancel the black one I ordered previously....
Offline noodles256
  • le legendary
« Reply #180 on: Fri, 14 October 2011, 09:32:57 »
the white clears are for the next batch if i am not mistaken
AF | Ducky YOTD |
Offline Khenra
« Reply #181 on: Fri, 14 October 2011, 09:33:53 »
Whaaaat 51 dollars shipping&handling to Europe... That's 50% of the keyboard price lol...
[SIGPIC][/SIGPIC]
Filco Majestouch-2 Tenkeyless Cherry MX Brown
Offline Clickey
« Reply #182 on: Fri, 14 October 2011, 09:56:35 »
For some reason shipping to europe is more expensive than shipping anywhere else, I guess its to keep people paying the premium for high labor costs on things made there.
Offline noodles256
  • le legendary
« Reply #183 on: Fri, 14 October 2011, 10:07:08 »
did you get some clears rip?
AF | Ducky YOTD |
Offline Chobopants
« Reply #184 on: Fri, 14 October 2011, 10:39:47 »
The white board is so pretty I had to order one even though I had a bad experience with the cherry blues in a Leopold. God save me. I need to try clears.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline magictoaster
« Reply #185 on: Fri, 14 October 2011, 10:48:02 »
Quote from: Chobopants;431016
Not to derail the thread, but what was the issue with your Leopold Cherry Blue?
Offline pycho
« Reply #186 on: Fri, 14 October 2011, 11:17:20 »
omg i would totally buy one but they want me to pay 50% of the price of the keyboard for shipping -.-.- 51$
any idea if it will be avalible somewhere with decent shipping price?
Offline suprsmo
  • Sydney, Australia
« Reply #187 on: Fri, 14 October 2011, 12:04:18 »
$56 Postage to Aus :l Do you think I can wait until thursday?
Poker
QFR
Offline Chobopants
« Reply #188 on: Fri, 14 October 2011, 13:12:35 »
Quote from: magictoaster;431023
The Cherry Corp style stabilizers totally didn't work for me. The larger keys, most specifically right shift and backspace, felt mushy and actually caused me some tendon pain after a while because of the lack of crisp actuation. I'm hoping that this is much less of an issue with non-clicky keys. I'm kind of hoping that this board works out as a traveling SC2 board or something.
Offline ishtob
« Reply #189 on: Fri, 14 October 2011, 13:35:12 »
Quote from: dante;431029
I'm very grateful white clears are reordered in the 2nd shipment; I just ordered mine \o/
wait what second shipment?!
Offline noodles256
  • le legendary
« Reply #190 on: Fri, 14 October 2011, 14:01:12 »
nov 10
AF | Ducky YOTD |
Offline kingqway
« Reply #191 on: Fri, 14 October 2011, 16:05:09 »
Damn, I really wish they sold full-sized white's. I think I would buy one of those in a heartbeat. I'm getting a filco tenkeyless from Qtan, so this will be my first chance to see how tenkeyless feels/looks. Too bad they don't plan on any full-sized white's anytime soon.
Das Professional Silent || White Filco TKL MX Blue || Leopold FC500R MX Brown
« Reply #192 on: Sat, 15 October 2011, 00:00:37 »
Quote from: N8N;430906
yes i was wondering about this as well has anyone done the mod and started a thread about it?
Offline ironman31
« Reply #193 on: Fri, 21 October 2011, 23:19:39 »
Just got an email saying my order has been shipped :D
Hope I don't hate it
Keyboards:
Pointing Devices:
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #194 on: Fri, 21 October 2011, 23:28:34 »
Just got the email as well, really excited for my first mech keyboard! Whats shipping time usually like from EK?
Offline ironman31
« Reply #195 on: Fri, 21 October 2011, 23:29:22 »
less than 5 days to Tallahassee
Keyboards:
Pointing Devices:
Offline jwaz
  • * based mod
« Reply #196 on: Fri, 21 October 2011, 23:36:42 »
Expecting it to get to Seattle about Wednesday. Beyond stoked.
Offline ruiner17
« Reply #197 on: Sat, 22 October 2011, 02:29:24 »
wooo! estimated delivery date: Oct 25, 2011
Offline Clickey
« Reply #198 on: Sat, 22 October 2011, 03:19:26 »
I live 30mins away from EK, hope it gets here tomorrow :first:
« Reply #199 on: Sat, 22 October 2011, 10:35:06 »
ETA: 10/27. Woot!
