Author Topic: Phantom Custom Keyboard Group Buy (CLOSED)  (Read 484827 times)
« Reply #1250 on: Tue, 31 January 2012, 13:34:47 »
Gah! I almost forgot to order DIODE 88 !
Offline maoiste
« Reply #1251 on: Tue, 31 January 2012, 13:36:28 »
I did clearall at 14:52 and send my updated order at 14:55 and got a email this evening:
Dear maoiste,
here is your updated pre-order:
in order to come forward with this group buy, I need your shipping address!
So my order did not get processed yet and the bot only got clearall ?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1252 on: Tue, 31 January 2012, 13:40:07 »
Also, what value resistors are being shipped with those white LEDs?  :)
Filco w/ Imsto thick PBT
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #1253 on: Tue, 31 January 2012, 13:42:45 »
my order seems to have been munged. no longer includes a pcb or diodes. also, if greys are going to be significantly less, i guess i'll jump on the gray bandwagon ;)
eta: nvm. seems to have been fixed. one more change incoming to switch to greys
Offline 7bit
  • MX1A-G1DW
« Reply #1254 on: Tue, 31 January 2012, 13:53:28 »
Quote from: mkawa;504451
Price for grey went down again to 0.5 EUR or $0.65 .
0.5*1.3176==.65880
:shock:
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline digitalleftovers
« Reply #1255 on: Tue, 31 January 2012, 13:54:28 »
What is the status of the 'case' option?  Previously, there was discussion that the acrylic wasn't very cost effective to produce, but I'm wondering if any increased interest may have changed that?
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline alaricljs
« Reply #1256 on: Tue, 31 January 2012, 13:55:11 »
Litster is working on that as completely separate from this.  It may or may not materialize, or it may be a 'here are the plans/specs, good luck'.
Offline 7bit
  • MX1A-G1DW
« Reply #1257 on: Tue, 31 January 2012, 13:59:31 »
OK, MX grey is now as cheap as any other switch.
Now comes the green switch:
479
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1258 on: Tue, 31 January 2012, 14:04:34 »
Quote from: 7bit;504479
479
What are the green ones like? I've ordered 2 of them...
Fight For Freedom. Stand with Hong Kongers
Offline maoiste
« Reply #1259 on: Tue, 31 January 2012, 14:05:03 »
is it the grey switch linear or tactile ?
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #1260 on: Tue, 31 January 2012, 14:06:49 »
Quote from: hazeluff;504485
Extra stiff blue.
« Reply #1261 on: Tue, 31 January 2012, 14:12:24 »
Lighter than grey, stiffer than blue. Possibly the greatest switch ever.
Offline 7bit
  • MX1A-G1DW
« Reply #1262 on: Tue, 31 January 2012, 14:14:54 »
Quote from: demik;504498
So you think we should better order a set of 100 or two?
« Reply #1263 on: Tue, 31 January 2012, 14:25:05 »
Unless someone at OTD has done it, we might be there first people with all-mx green boards.
Keyboards:
« Reply #1264 on: Tue, 31 January 2012, 14:26:49 »
Cherry says 2.3 oz, so ~65g click action switch.
Keyboards:
Offline maoiste
« Reply #1265 on: Tue, 31 January 2012, 14:31:57 »
Quote from: digitalleftovers;504511
http://deskthority.net/viewtopic.php?f=8&t=1040&hilit=wood
« Reply #1266 on: Tue, 31 January 2012, 14:34:24 »
Quote from: 7bit;504500
I'm thinking of switching my order from blue to green. I don't think I can spend money on both
Actually, I might get the greens to mod my poker to all greens instead of the browns it has.
How do I order again? Also, I just got an email asking me for my shipping again.. Was that an accident?
« Last Edit: Tue, 31 January 2012, 14:37:34 by demik »
« Reply #1267 on: Tue, 31 January 2012, 14:52:18 »
Quote from: maoiste;504522
LOL. Thats pretty awesome.
Keyboards:
Offline 7bit
  • MX1A-G1DW
« Reply #1268 on: Tue, 31 January 2012, 14:56:40 »
Quote from: demik;504524
No it updates the next time, unless something went wrong.
Just set the quantity of what you want to remove to 0.
MXGREEN 100
MXBLUE 0
Offline tsangan
  • 1000/600
« Reply #1269 on: Tue, 31 January 2012, 14:57:55 »
when i send the address do I need to put my email?
Keyboardless
Offline 7bit
  • MX1A-G1DW
« Reply #1270 on: Tue, 31 January 2012, 15:12:16 »
Quote from: tsangan;504551
No.
Just ADDR would be helpful in the line above (or ADDRESS).
Code: [Select]
PHANTOM.........81
TEENSY..........85
PH7BIT..........18
PHANSI..........29
PHANSIWIN.......18
PHISO............7
PHISOWIN.........9
DIODE.........8342
MXBLACK........448
MXBLUE........1032
MXBROWN.......2191
MXCLEAR.......4222
MXDARKGREY......53
MXGREEN........611
MXGREY........1042
MXRED.........3626
Not bad!
More than 80 Phantom PCBs.
Let's make it 100!
« Reply #1271 on: Tue, 31 January 2012, 15:13:27 »
I did the first time. Is anybody near a poker and would be kind enough to let me know how many switches I'd need order not counting ones with LEDs?
Offline kaiserreich
  • HHKB Elite
« Reply #1272 on: Tue, 31 January 2012, 15:14:51 »
Poker has 61 switches.
There are total of 7 keys with LEDs.
« Reply #1273 on: Tue, 31 January 2012, 15:20:44 »
So I'd need 54. Thank you!
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1274 on: Tue, 31 January 2012, 15:32:54 »
I think that my order may have been screwed up as I got a email saying I ordered nothing I shall resubmit and see what happens.
Offline tsangan
  • 1000/600
« Reply #1275 on: Tue, 31 January 2012, 15:34:55 »
I still don't know if I want 2 or not!!!!! :faint:
Keyboardless
« Reply #1276 on: Tue, 31 January 2012, 15:39:59 »
Quote from: tsangan;504583
Ill gladly build you 2 ;) If i could get a acrylic case I would make one with greens with a standard layout.
« Reply #1277 on: Tue, 31 January 2012, 15:41:39 »
You can build me a Dox!
Offline eth0s
  • Peace & Love
« Reply #1278 on: Tue, 31 January 2012, 15:42:15 »
I know it's late, but will this work?
Phansigreenkit 1
« Reply #1279 on: Tue, 31 January 2012, 15:43:02 »
Quote from: demik;504593
would be glad to more info is here
Offline alaricljs
« Reply #1280 on: Tue, 31 January 2012, 15:43:48 »
As of 3 days ago, no green kit code.  I'm guessing you'll have to part it out.
Offline 7bit
  • MX1A-G1DW
« Reply #1281 on: Tue, 31 January 2012, 15:51:08 »
Quote from: eth0s;504595
Phansigreenkit 1
Added GREEN and GREY options for kits.
Offline eth0s
  • Peace & Love
« Reply #1282 on: Tue, 31 January 2012, 15:52:38 »
OK, so i'm ordering the PHANSIGREENKIT 1, and nothing else.  I hope it has everything I need.  Thx for the quick reply 7bit.
Offline 7bit
  • MX1A-G1DW
« Reply #1283 on: Tue, 31 January 2012, 16:13:03 »
Quote from: eth0s;504612
It will.
Code: [Select]
PHANTOM.........86
TEENSY..........92
PH7BIT..........19
PHANSI..........29
PHANSIWIN.......19
PHISO............7
PHISOWIN.........9
DIODE.........9127
MXBLACK........458
MXBLUE........1150
MXBROWN.......2081
MXCLEAR.......4612
MXDARKGREY......67
MXGREEN........792
MXGREY........1159
MXRED.........3636
Offline mkawa
« Reply #1284 on: Tue, 31 January 2012, 16:23:21 »
blurk, ok, looks like i'm just getting a PHANSIWINGREYKIT then, since that's all my order was.
actually, 7bit, can you give us an update on what the unit prices for grey/green switches are up to now?
Offline 7bit
  • MX1A-G1DW
« Reply #1285 on: Tue, 31 January 2012, 16:50:15 »
Quote from: mkawa;504637
Code: [Select]
MXRED            |  0.6|MX red   plate mount switch (0.45 EUR)
MXBLUE           |  0.6|MX blue  plate mount switch (0.45 EUR)
MXBROWN          |  0.6|MX brown plate mount switch (0.45 EUR)
MXCLEAR          |  0.6|MX clear plate mount switch (0.45 EUR)
MXBLACK          |  0.9|MX black plate mount switch (0.7  EUR)
MXGREEN          |  0.6|MX green plate mount switch (0.45 EUR)
MXGREY           |  0.6|MX grey  plate mount switch (0.45 EUR)
MXDARKGREY       |  1  |MX grey  plate mount switch (0.8  EUR)
Offline mkawa
« Reply #1286 on: Tue, 31 January 2012, 17:26:07 »
gah! ok, you've got me; i'm loading up on greens too.
Offline F u r u y á
« Reply #1287 on: Tue, 31 January 2012, 17:38:50 »
Quote from: slueth;449348
Alright screw the other layouts, I'm going with 7bit's
:rockon:
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline Autolyze
« Reply #1288 on: Tue, 31 January 2012, 17:57:52 »
Hmm... I'm a little tempted to go green as well. Right now I've got a 7Bit layout with clears and an ANSI with blues, but all of the switches are so nice...
Offline mkawa
« Reply #1289 on: Tue, 31 January 2012, 18:06:32 »
get the greens. you know you want them
Offline Autolyze
« Reply #1290 on: Tue, 31 January 2012, 18:11:32 »
I was hoping to test out the green switch a little by putting a single unit keycap on my blue Leopold's space once I got home from work, but as soon as I sat down and popped the spacebar off, I remembered that the Leopold actually uses a blue switch for space. Dammit.
Offline hashbaz
  • Grand Ancient One
« Reply #1291 on: Tue, 31 January 2012, 19:00:13 »
Totally in for greens.
« Reply #1292 on: Tue, 31 January 2012, 19:01:28 »
Quote from: hashbaz;504741
Its a revolution!
Keyboards:
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #1293 on: Tue, 31 January 2012, 19:25:43 »
Quote from: alaricljs;504448
Right now the resistors I am using on the prototype is 75ohm for a 3.5v LED.  It is too bright as is withouth the firmware change.  But with firmware change it is fine.  We could probably go with a more resistive resistor.  Any suggestion.
I just got out of an all-day meeting as work.  It is amazing to see there are like 3 new pages of posts!  Nothing like trying to get in before a deadline!!!
Offline alaricljs
« Reply #1294 on: Tue, 31 January 2012, 19:28:34 »
Wanted to know since I have some special LEDs for someone and they need 100ohms which I do not as yet have.  Any chance you have 4 of those you could throw into the package headed my way ?  ;)
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1295 on: Tue, 31 January 2012, 19:36:53 »
Quote from: litster;504767
Why more resistance?
Offline alaricljs
« Reply #1296 on: Tue, 31 January 2012, 19:38:17 »
Lower voltage LEDs like mine :)   The series of LEDs I picked from run from 2.8 to 3.4 volts depending on color, with all of them functioning properly at 3.1 volts which works nicely with 100 Ohms.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1297 on: Tue, 31 January 2012, 19:43:00 »
Quote from: alaricljs;504779
Well I know that! But I is that what he meant?
Its hard to cater to everyone. Since resistance required is dependent on Voltage and Current of the LEDs.
Offline alaricljs
« Reply #1298 on: Tue, 31 January 2012, 19:43:57 »
Using the higher resistance with the same LEDs he is distributing will mean the particular LEDs he has will be a little dimmer at MAX brightness.  He's already said that level of brightness is a bit extreme.
Also it will mean that people can buy cheapass LEDs on ebay from this dude:  ebay and have Litster's resistors ready to go.  (if they are 100Ohms)
« Last Edit: Tue, 31 January 2012, 19:48:23 by alaricljs »
Offline litster
« Reply #1299 on: Tue, 31 January 2012, 20:18:36 »
Yes, strong resistors will lower the brightness of the LEDs.  So right now I am using 75ohm resistors.  It would be a lot of work to de-solder all the switches to replace the 75ohm resistor with another resistor.  Could just just solder another resistor on the other side of the PCB to increase resistance?  What is the right resistance to add to the back to make 100ohm?  I can probably get one locally t test with, and if 100ohm works with the current LEDs, maybe we can just change all resistors to 100ohm.
