Author Topic: Phantom Custom Keyboard Group Buy (CLOSED)  (Read 484945 times)
Offline digitalleftovers
« Reply #1000 on: Tue, 24 January 2012, 16:59:38 »
Quote from: JesuswasaZombie;497853
Not sure if this was already suggested or not but what about a thinner aluminum case for this similar to the Vortex Pure?
I think this would be an excellent suggestion for Vortex.  The case they're making for the pure is generic to both the Poker and the Pure, and there would be a much larger market to produce a generic tenkeyless case for.
There's a steel TKL case interest check, but no final prototypes yet.  Still hard to say if it will take off, but its worth keeping an eye on:
Interest-check-Metal-case-for-TKL-Filcos/page14
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #1001 on: Wed, 25 January 2012, 02:08:55 »
I tried to put on a marketing hat, and see what feature list I could come up with.  Some of the features of Phantom are new since we started the project.
  • Supports vintage Cherry double shot, laser, and dye sub keycaps
    • 1.5x Ctrl and Alt vintage Cherry keycaps (PHANSI and PHISO plate options)
    • With 1.5x modifiers, you can also use Cherry’s 7x spacebars
    • Supports centered-stem and offset-stem Capslock (also from vintage Cherry Keyboards)
    • Also support modern keyboard layout with 1.25x Ctrl and Alt modifiers (PHANSIWIN and PHISOWIN plate options)
  • Supports both Costar and Cherry stabilizers
  • Supports in-switch LED at Capslock and Scroll Lock locations, as well as Filco style LED locations between PrintScrn-ScrollLock-Break and Insert-Home-PageUp
  • Plate design allows Cherry MX switch top removal without de-soldering the switch first
    • Perfect for easy switch lubing, repair, or modding
    • Excluding switches with in-switch LED
  • Supports 5 extra keys between 6-pack and arrow keys (case modification required)
  • Supports 6KRO over USB with current Teensy firmware
    • potentially NKRO over USB in the future with new Teensy firmware
  • All keys can be remapped via firmware source code changes (currently a recompile of source is required)
  • LED brightness adjustable in firmware source code
  • Fits inside Filco Tenkeyless cases
    • PLU cases could also work
  • Community support on Geekhack.org and Deskthority.net
Am I missing anything?
Offline riffautae
« Reply #1002 on: Wed, 25 January 2012, 11:06:27 »
Other potentials with the new firmware
  • Multiple layouts via switching
  • Fn style extra keys
  • Media/power keys
  • Virtual mouse!
Macros are something I am looking at. Some sort of key intercept framework to make it easier to add features. Also we have plenty of eeprom so it wouldn't be that hard to load the layouts from that instead of hard coding them.
As a side note, the only thing I think that would make this even cooler would be a more egro layout. Even just moving the top alpha keys so they are half offset from the next row down rather then 1/4 offset. Not for this group buy of course, but it would be cool if there was enough interest later for an ergo phantom
« Last Edit: Wed, 25 January 2012, 12:13:59 by riffautae »
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1003 on: Wed, 25 January 2012, 11:41:32 »
as I need the special plate when I find someone to make it what thickness do I ask for again was it 1/16" ?
Offline litster
« Reply #1004 on: Wed, 25 January 2012, 12:14:31 »
Yes, 1/16 inch.
Offline 7bit
  • MX1A-G1DW
« Reply #1005 on: Wed, 25 January 2012, 12:25:00 »
Quote from: hazeluff;497701
If you're talking about R4 GB, that ones just a mess. This ones moving on properly.
What makes you thing I'm incapable of messing the this up too?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1006 on: Wed, 25 January 2012, 12:46:23 »
Quote from: 7bit;498758
Its always possible:
http://en.wikipedia.org/wiki/Murphy's_law
Fight For Freedom. Stand with Hong Kongers
Offline litster
« Reply #1007 on: Wed, 25 January 2012, 13:46:01 »
A new invoice has been sent to your email address.  You should be getting it very shortly if you haven't received it already.  If you don't receive it later today, please check that you did include an email address in your order PM to PHANTOM.  If you didn't, please PM PHANTOM with your email address in the message body.  If you did include your email address in your order but don't receive your invoice later today, please let me know.
In the invoice, there is instruction to submit your snail mail mailing address for shipment.  Please follow the instruction to submit your mailing address.
Please also double check your ordered items.  Thanks.
« Reply #1008 on: Wed, 25 January 2012, 14:17:27 »
Got mine, will pm info when I get home :)
« Reply #1009 on: Wed, 25 January 2012, 17:35:50 »
So, in this latest mail, my request for MX Greens came back with a pretty reasonable figure (in euros).  Does that mean a source was found?
Keyboards:
Offline litster
« Reply #1010 on: Wed, 25 January 2012, 17:57:47 »
Quote from: digitalleftovers;499016
It all depends on 7bit's switch-Fu.  Availability and pricing could still be changed.  No news is good news for now.
Offline Forin
« Reply #1011 on: Wed, 25 January 2012, 18:20:43 »
As I recently bought Filco and keycaps for it, I can't afford this Phantom, but I don't need a crystal ball to know that I will regret this in the future.
It is possible to make a keyboard with right ALT placed more in the center than ISO, with PH7BIT, isn't it?(narrower space).
Ducky DK1087 MX Brown, Filco MJ1 Tenkeyless MX Blue, CM Storm MX Blue
Offline litster
« Reply #1012 on: Wed, 25 January 2012, 19:02:10 »
Added higher res picture of the front and back of PCB to the first post.  It is shrunk down to 1/16 of its original size, but it is still pretty high res :-)  It is pretty amazing to look at, in that it can support so many variations.  Look at all the holes...
Offline riffautae
« Reply #1013 on: Wed, 25 January 2012, 19:07:41 »
It looks like you put the extra function key special holes in after all! This means any stem could break and its an easy repair right?
[edit] are you sure you have enough holes around the right alt? :P
« Last Edit: Wed, 25 January 2012, 19:11:18 by riffautae »
Offline litster
« Reply #1014 on: Wed, 25 January 2012, 19:24:17 »
Quote from: riffautae;499071
The 4 holes on the PCB to allow for unclipping the top switch case for each switch wasn't necessary after all.  See this youtube video on how to open up the switch with PrinsValium's Special Phantom Mounting Plate design(TM).  The magic is all on the mounting plate.  The holes on the PCB was the extra insurance.
[video=youtube;HysRQnJiupQ]http://www.youtube.com/watch?v=HysRQnJiupQ[/video]
Offline mtl
« Reply #1015 on: Wed, 25 January 2012, 20:50:16 »
Are MXDARKBLUE switches available?
MX13 SpaceSaver | Phantom | Tactoblack Filco -10 | Realforce 103U-UW | Variable Clicky Deck 82 | Deck Legend
Offline litster
« Reply #1016 on: Wed, 25 January 2012, 21:16:20 »
Quote from: mtl;499174
I believe it was mystical and not available for order, and it has been removed from the price list.
http://deskthority.net/wiki/Phantom
Offline mtl
« Reply #1017 on: Wed, 25 January 2012, 22:28:51 »
Thanks litster.. Still chasing the dream. :)
Offline F u r u y á
« Reply #1018 on: Wed, 25 January 2012, 22:51:06 »
Quote from: 7bit;448105
Get the 7BIT layout and never ever worry about stabilisers again!
The advantages:
- You don't have a rediculously large anachronistic space bar, just a modern 1.5 units space bar at the position of your choice!
haha. that's true and I have never thought about it.
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline F u r u y á
« Reply #1019 on: Thu, 26 January 2012, 03:22:18 »
Will you provide this: adapter for Filco cable?
It would be nice if you provide it so that we wouldn't need to buy the parts and build it on our own.
Offline litster
« Reply #1020 on: Thu, 26 January 2012, 03:49:46 »
Quote from: F u r u y á;499388
Hi Furuya.  Sorry, no plan to make this available at this time.  Not sure how much demand it would have.  If there is a lot of demand, and if the parts are easy to find on digikey (probably, as PrinsValium got his part from mouser I think) we could add that to our big order to digikey.  I would also love to be able to find some place to buy a Filco-like cable.
Offline bpiphany
« Reply #1021 on: Thu, 26 January 2012, 05:41:22 »
It would be really sweet if there are receptacles that fit the Molex/Filco plug, that is possible to just crimp onto a cable instead of the through hole solder ones I got. But there are 10000's different receptacles/plugs at mouser and I don't really know where to start looking... But those receptacles are from mouser, and the strip board is nothing fancy. The pitch on the strip board is 2.54mm and the receptacle is 2mm so a little bit of bending is required but it's not a lot with only five leads.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1022 on: Thu, 26 January 2012, 08:33:38 »
Quote from: PrinsValium;499422
When I went through the JST catalog of matching parts the only receptacles were PCB mount.  I expect the Molex version to have the same limitation.  Here's the PDF.
Filco w/ Imsto thick PBT
Offline litster
« Reply #1023 on: Fri, 27 January 2012, 03:21:23 »
Kits include the following:
1 PCB (includes 2 white LEDs and2 resistors)
1 Plate
1 Teensy (includes 1 40-pin pin header)
100 switches
100 diodes
4 2x stabilizers for ANSI or 3 2x stabilizers for ISO or 0 for PH7BIT
1 7x or 1 6.25x stabilizer set for spacebar or 0 for PH7BIT
Pricing will be the same as if you order them separately.  Finally pricing is not completely locked yet.  7bit will adjust pricing in his script later when we finalize it.
Offline 7bit
  • MX1A-G1DW
« Reply #1024 on: Fri, 27 January 2012, 03:52:25 »
If someone experienced that he sent an order but got something totally different, please contact me!
Offline mtl
« Reply #1025 on: Fri, 27 January 2012, 06:18:36 »
Does the Phantom fit Filco v1 cases, v2 cases or both? Not sure if there's a difference. Thanks.
Offline alaricljs
« Reply #1026 on: Fri, 27 January 2012, 08:15:16 »
There's no difference in the cases between revs of Filco
Offline byFd
« Reply #1027 on: Fri, 27 January 2012, 09:09:55 »
about how much is a total kit?
also i don't need anything extra if i order a kit right? (besides case and caps)
also is there someone who can/will do assembly in EU?
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline alaricljs
« Reply #1028 on: Fri, 27 January 2012, 09:13:40 »
According to the OP Half-Saint is in EU willing to do assembly.  And the kit contains everything you need except caps and case, correct.
« Reply #1029 on: Fri, 27 January 2012, 09:19:51 »
I can do Assembly and ship to the EU contact me in my subforum or via pm if interested.
Offline Sojik
« Reply #1030 on: Fri, 27 January 2012, 11:20:08 »
I want to buy but I'm still trying to figure out how fancy I want to go. The 7bit layout seems like a good idea but is it too extreme? Is anyone else going to use this layout and have their own ideas on how they're going to layout their keys other than the example in the wiki?
« Reply #1031 on: Fri, 27 January 2012, 11:42:26 »
Quote from: Sojik;500698
I have a layout that took me a bit to work out take a look at the thread in my subforum.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1032 on: Fri, 27 January 2012, 11:48:02 »
I'm going to be using a Ansi layout, but use the "7bit" right side.
[ Attachment Invalid Or Does Not Exist ] 38774[/ATTACH]
« Last Edit: Fri, 27 January 2012, 13:18:57 by hazeluff »
Offline litster
« Reply #1033 on: Fri, 27 January 2012, 16:28:03 »
Great idea to have the media keys there!!!
Offline litster
« Reply #1034 on: Fri, 27 January 2012, 16:30:46 »
Here is picture of the backside of the PCB, with interesting areas highlighted.  I also highlighted diode locations that are no the same as the majority ones.  Need to make sure your diodes are at the right polarity.  Check it out.
Bandwidth warning!  Giant 2MB picture!
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #1035 on: Fri, 27 January 2012, 17:39:18 »
At least one of my extra 7bit keys will be middle mouse button, so I can paste-click under Linux without touching the mouse.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1036 on: Fri, 27 January 2012, 18:00:29 »
Quote from: litster;500983
Oh hmm... There are two LED_A and LED_B. Are they in parallel?
Offline tsangan
  • 1000/600
« Reply #1037 on: Fri, 27 January 2012, 18:08:22 »
love the layout hazeluff, but I'm waiting for litster's acrylic case so gotta stick with 1.5x WIN version
Keyboardless
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1038 on: Fri, 27 January 2012, 18:16:33 »
Quote from: tsangan;501060
I Love those cases too. The look so beautiful. But it's a bit expensive for a case to me. Also I like my number pad. The only reason I went for the phantom board was cos you could do 7Bit layout. I may get one of his cases for the hell of it if it weren't over say $50-60.
Or
I may DYI my own one.
Or
I may check out some Acrylic crafters back in Hong Kong. I'm pretty sure they can slap me together something similar for a good price. My mom had a store for a while and had Acrylic display shelves and they were pretty nice. So I'll see.
Or
Cardboard case!
Just one thing I wanna ask, It doens't have to be 1.5x Win does it to work with litsters case, does it? It should fit any as long as you dont have those 5 keys above the arrows?
Offline litster
« Reply #1039 on: Fri, 27 January 2012, 18:19:12 »
Quote from: hashbaz;501031
Paste-click?  Does Ctrl-V not work in Linux?
Offline litster
« Reply #1040 on: Fri, 27 January 2012, 18:21:57 »
1.5x WIN version?  PHANSI uses 1.5x modifiers.  PHANSIWIN uses 1.25x modifiers.  Terminologies overloaded.  :-)
Offline litster
« Reply #1041 on: Fri, 27 January 2012, 18:25:19 »
Quote from: hazeluff;501067
Right.  It is just a rectangular cut out for the main cluster.  What's on the front row doesn't matter as long as you have switches and keycaps to fill up the whole row.
Offline tsangan
  • 1000/600
« Reply #1042 on: Fri, 27 January 2012, 18:29:54 »
Quote from: litster;501073
The old terminology was easier haha whenever I see PHANSIWIN I think 1.5x WIN, but yes I meant the PHANSI version
Can I technically get the PH7BIT but make the PHANSI layout and just keep all the other spots switchless?
Keyboardless
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1043 on: Fri, 27 January 2012, 18:37:03 »
Quote from: tsangan;501083
I don't see why not.
But the one the thing I've wondered is, is it still possible to put in a long spacebar like the one for PHANSI.
Offline hashbaz
  • Grand Ancient One
« Reply #1044 on: Fri, 27 January 2012, 18:41:52 »
What I'm wondering is if the bottom row of the 7bit plate is compatible (or near-compatible) with any other layouts.  Could I fit a standard 1.25x-modifier bottom row on a 7bit Phantom?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1045 on: Fri, 27 January 2012, 18:44:33 »
Quote from: hashbaz;501099
TheProfosist is doing that.
You can but it'll leave a small gap right at the ends of the row.
Also 1000!
Offline tsangan
  • 1000/600
« Reply #1046 on: Fri, 27 January 2012, 18:45:33 »
I think they fit 1.5x and not 1.25x from looking at the image
Keyboardless
Offline RiGS
« Reply #1047 on: Fri, 27 January 2012, 18:48:31 »
@litster, any chance you can take a high def picture of a single switch mounted in that plate? I wonder if there is any visible gap near the switch what leaves the pcb exposed.
« Last Edit: Fri, 27 January 2012, 18:53:12 by RiGS »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1048 on: Fri, 27 January 2012, 19:02:06 »
Oh I want to ask you for some feedback on my layout.
I have that Fn key on the bottom Mod row. But I don't really need it since I'll be using numlock to swap between the layers of my "numpad".
What should I replace it with (image and function)?
Offline litster
« Reply #1049 on: Fri, 27 January 2012, 19:06:15 »
Quote from: RiGS;501104
I can take a picture.  I have a yet-to-be-mounted PH7BIT plate.  But I am not sure if I understand what you want me to shoot.  Can you give me more description?
