Author Topic: Phantom Custom Keyboard Group Buy (CLOSED)  (Read 484987 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #950 on: Thu, 19 January 2012, 17:22:41 »
Good news! WASDkeyboards can help us with Costar 2x stabilizers. I will still have to bend 30 7x stabilizers, but good that we have a source for 2x stabilizers, inserts, and clips.
Totally unrelated, but here is a picture of the Phantom prototype dressed in Cherry dye sub keycaps, plus Cherry RGB dye sub modifiers, plus Tarkoon's Blue Esc keycap and handbag capslock.
I have been just having the prototype sitting on the bottom half of a Filco case. The exposed white-colored plate makes it pleasant to look at. It is nice and free. Like surfing the web in your underwear!  :-)
Offline TheProfosist
  • Custom Layouts Only!
« Reply #951 on: Thu, 19 January 2012, 17:26:04 »
great to hear wanting it even more
Offline tsangan
  • 1000/600
« Reply #952 on: Thu, 19 January 2012, 17:28:05 »
You need a red esc in there litster!
Keyboardless
Offline litster
« Reply #953 on: Thu, 19 January 2012, 17:29:50 »
It is coming... ;-)
Offline digitalleftovers
« Reply #954 on: Thu, 19 January 2012, 18:49:14 »
Ok.  I put an order in.  I know we have no source for mx greens, and I certainly haven't found one yet on my own, but I thought I would throw it in there just to express interest.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
« Reply #955 on: Thu, 19 January 2012, 18:53:41 »
Quote from: digitalleftovers;494413
There is going to be a groupbuy or you could do getto greens
Offline tsangan
  • 1000/600
« Reply #956 on: Thu, 19 January 2012, 19:16:49 »
Quote from: TheProfosist;494417
Even if you find it, it would be a lot much more affordable to go with the ghetto green mod instead
Keyboardless
Offline NumberJ
« Reply #957 on: Thu, 19 January 2012, 20:43:28 »
Quote from: tsangan;494429
How exactly does the ghetto green mod work again? Is it just a blue switch with a black spring?
« Reply #958 on: Fri, 20 January 2012, 00:04:46 »
That is what I was considering (blue with black spring).  I did see prices on grey switches, and yeah, if green is similar than it won't be worth it.  But, as I said, consider it interest until we know for sure.
I also noticed that Cherry lists two types of grey switches.  A linear 2.8oz (MX1A-2XXX), and a tactile 2.8 oz (MX1A-DXXX).  But, I haven't seen those either so probably in the same boat with greens.  The reason for the greens was an attempt at more of an alps-like feel.  I've got some black switches in the mail, so I'll see what I can do.
Keyboards:
Offline bpiphany
« Reply #959 on: Fri, 20 January 2012, 03:04:12 »
I ordered a bunch of the linear MX gray from mouser a while back (MX1A-21NW). I thought I should try them out on a keyboard, but they are way too heavy for me to put on an entire board... So I've got plenty of them to get rid of. Some I've pulled the stem and spring from already to combine PCB/plate mount switches as I've needed them. So I could reassemble both PCB and plate mount switches if anyone is interested. I paid $1.80 each and would only want to get that back.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #960 on: Fri, 20 January 2012, 08:56:16 »
I've suddenly pursuaded myself to get one of these:
TEENSY 1
PHANTOM 1
PHANSIWIN 1
DIODE 100
MXBROWN 100
MXCLEAR 2 --just cos i want to mess with some switches
MXBLACK 2
MXBLUE 2
MXRED 2
MXDARKBLUE 2
But just wondering about the stabilizers for like shift/enter/space...Can I order them, or do I have to get them myself? Also LEDs.
« Last Edit: Fri, 20 January 2012, 09:01:40 by hazeluff »
Fight For Freedom. Stand with Hong Kongers
Offline bpiphany
« Reply #961 on: Fri, 20 January 2012, 09:03:40 »
Quote from: harrison;494786
the ONLY reason for buying an actual green switch is for the novelty of having the green stem under the key... for some, it's worth it.
Gotta catch them all... I would certainly want to have a few only to have them =)
It's also sort of like 0 ohm resistors, sorta stupid, why not use a jumper.. but it looks nice.
Quote from: hazeluff;494798
The intention is that there will be stabilizers included in the group buy. Probably some LEDs too, one or two colors perhaps. There are tons of different LEDs, and they are cheap enough for everyone to be bought with fitting resistors on their own. That way there are more options for the ones who like to customize.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #962 on: Fri, 20 January 2012, 09:07:02 »
Quote from: PrinsValium;494803
So I'll wait till these are added to the list?
Offline litster
« Reply #963 on: Fri, 20 January 2012, 10:51:03 »
Stabilizers are already there, I don't know for sure whether they are Cherry or Costar.  WASDkeyboards.com is going to help us with stabilizers clips, inserts, and 2x and 6.25x stabilizer bars.  For PHANSI and PHISO plates, I will bend 7x stabilizer bars for the group buy.  I think I will need to bend over 30 of them, and then later mail them to BiNiaRiS and 7bit for final delivery!!!!
For LEDs and resistors, I am thinking to just order LEDs of 2 colors, and bunch of matching resistors, and just throw them in with each PCB order.  I think we will have money to cover the parts since they are so cheap.
I really like the white LEDs because they are cool looking and unique for keyboards.  Anyone want to pick out another color?  Please post a link to digikey and mouser for the parts.  The white LEDs I chose is 3.5v and paired with 75 ohm resistors.
I still need to lock down on the pricing.
« Reply #964 on: Fri, 20 January 2012, 10:59:22 »
White is good maybe red and not too bright most leds on keyboards scorch my eyes.
Offline bpiphany
« Reply #965 on: Fri, 20 January 2012, 11:13:26 »
Quote from: TheProfosist;494882
PWM for beginners.
« Reply #966 on: Fri, 20 January 2012, 11:18:24 »
Quote from: PrinsValium;494895
PWM for beginners.
O yea forgot about the PWM that was implemented. Then, buy the brightest LED so that people who want to scorch their eyes really can and have a setting for people like me where its noticeable but not glaring right in your eye.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #967 on: Fri, 20 January 2012, 11:49:22 »
Quote from: litster;494877
Alright, thats cool. So should I expect a email back from the bot when I order?
I love purple, http://search.digikey.com/uk/en/products/UV3TZ-395-30/492-1319-ND/2407230. But I don't mind it being blue/red.
PWM for beginners.
Let me explain it:
We turn the LED on and off really fast and control the length of how long it is 'on' and 'off'. Don't worry it doesn't damage it. We won't see it flashing on and off, since of the high frequency, but we'll see a change in brightness. The more often it is 'on', the brighter.
« Last Edit: Fri, 20 January 2012, 11:56:50 by hazeluff »
Offline riffautae
« Reply #968 on: Fri, 20 January 2012, 14:25:10 »
:) Look what just arrived
[ Attachment Invalid Or Does Not Exist ] 38084[/ATTACH]
Offline litster
« Reply #969 on: Fri, 20 January 2012, 14:26:29 »
That's fast!  It ships from Oregon.  Where are you at?  Look forward to testing your new firmware builds!
Offline riffautae
« Reply #970 on: Fri, 20 January 2012, 15:23:48 »
I'm east coast. And yea I am setting up the in chip debug tools as we speak.
Offline bpiphany
« Reply #971 on: Mon, 23 January 2012, 07:29:11 »
Adapter to be able to use the stock Filco cable without modifying it. I never manage to solder wires neatly =P I made the miniUSB cable part too short, the gland on the Filco cable doesn't reach all the way to the hole in the case... The stump I used was too short to start with, so no loss really, I just need to cut a new one.
Offline litster
« Reply #972 on: Mon, 23 January 2012, 17:20:35 »
We would like to close this Phantom group buy by January 31st.  Please get your orders in now.  7bit is updating the price list and will send new invoices to all buyers soon.  Thanks.
Offline F u r u y á
« Reply #973 on: Mon, 23 January 2012, 19:52:31 »
Will the controller come with a basic functional firmware? Or will we have to either build our own or wait for someone to write one?
Also, I see that 7bit layout is the only one with place for an extra key in the Shift row. Is that correct? If so, I assume that it allows to build a PT-BR layout (it's ISO with an extra key next to the right Shift).
Still, it would be weird because 7bit layout it's weird by design (1.25 key not in the rightmost place! :tongue1:)
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline litster
« Reply #974 on: Mon, 23 January 2012, 20:01:35 »
If the shift row you want is just like the 7bit layout, then the PCB can support it, but we don't have a plate layout like that (extra keys on the shift row with normal PHANSIWIN front row.  Maybe PrinsValium can create a special layout for you so you can cut your own plate.
Offline tsangan
  • 1000/600
« Reply #975 on: Mon, 23 January 2012, 20:09:23 »
Quote from: litster;497110
Awesome to hear!
Any update on the acrylic casing group buy? Would they end approximately the same time?
Keyboardless
Offline litster
« Reply #976 on: Mon, 23 January 2012, 20:10:30 »
BTW, I have had over 1,600 clicks on my Phantom signature :-)
Offline F u r u y á
« Reply #977 on: Mon, 23 January 2012, 20:10:59 »
Quote from: litster;497208
PH7BIT doesn't do it?
Code: [Select]
PH7BIT          |  1|   35|mount plate 7BIT
Offline litster
« Reply #978 on: Mon, 23 January 2012, 20:13:28 »
Quote from: F u r u y á;497215
Code: [Select]
Sure, if you want your spacebar be broken into a few tiny ones.
Offline litster
« Reply #979 on: Mon, 23 January 2012, 20:19:38 »
Quote from: F u r u y á;497200
Didn't reply to this part.  6KRO firmware is already working, perfectly I must say.  Flashing firmware onto Teensy is very easy.  We will provide the firmware .hex files for all layouts.  You just need to download the upload software that runs on Linux, Windows, and Mac and it takes no time to do it.
You all should get yourselves familiar with how to do it so you can flash your firmware when you receive your Phantom kit, and then later upgrade to NKRO over USB if/when it becomes available.  If you use one of the soldering service providers, contact them about flashing firmware for you.  If you are going to solder yourselves, I believe you won't need any help flashing firmware.
Offline F u r u y á
« Reply #980 on: Mon, 23 January 2012, 20:26:16 »
Quote from: litster;497225
Thanks.
I was interested in this because I have all the tools for soldering and I've implemented a firmware before (actually I'm electrical engineer), so building a Phantom should be no problem for me. But I guess I'll pass it for now (I didn't realize that about the spacebar with PH7BIT).
Trying to stick to my "natural" layout only complicates things. sigh
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #981 on: Mon, 23 January 2012, 22:25:10 »
Snap, looks like I need to get off the fence and decide what I want.
Offline Tranquilite
« Reply #982 on: Tue, 24 January 2012, 00:48:16 »
Welp, looks like I will be buying one of these, however I have one question before submitting my order. I have a Donor board with Cherry PCB mount stabilizers. Are these compatible with the phantom? If not is there some place I can just get the plate mounting clips, or should I just suck it up and order some costar stabilizers?
Edit: Did some reading, looks like pcb mount stabilizers are a no-go, and I can get cherry plate mount stabilizers from mouser. Depending on the updated price list I may just go with that.
« Last Edit: Tue, 24 January 2012, 01:09:41 by Tranquilite »
Offline litster
« Reply #983 on: Tue, 24 January 2012, 02:06:48 »
PCB-mount switches could be used, if you take the time to cut off the two little pins off of each switch's bottom case.  If you do that, you will want to do a very good job and make sure the bottom is flush or the switch won't sit properly on the PCB.
Offline Tarkoon
« Reply #984 on: Tue, 24 January 2012, 02:44:25 »
That's exactly what I asked for much earlier! An ISOWIN with split right shift... And I am still sure that there are more who would like that!
Offline F u r u y á
« Reply #985 on: Tue, 24 January 2012, 03:41:30 »
Quote from: Tarkoon;497448
I asked BiNiaRiS about that, let's see what he says.
Offline 7bit
  • MX1A-G1DW
« Reply #986 on: Tue, 24 January 2012, 08:06:46 »
The reason for Shift being at their inner-most positions is that on ANSI-layouts you can hit shift at the same places. Left and right of them are the extra keys. My layout is not made for ISO layout which seems quite weird to me.
If you find a way to mount the stabilisers, you can fit a 7 units space bar to a 7BIT layout keyboard.
« Last Edit: Tue, 24 January 2012, 08:17:38 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline OkGold
« Reply #987 on: Tue, 24 January 2012, 08:08:32 »
what a neat project! wish I could get in on it, but con season approaches.
hope we'll see lots of cool keyboards when you guys get rolling~!
Offline scrubadub
« Reply #988 on: Tue, 24 January 2012, 09:34:31 »
Alright, I'm in!
Code: [Select]
TEENSY 1
PHANTOM 1
PHANSI 1
MXRED 90
DIODE 100
STAB200 4
STAB700 1
Hopefully my order was right, I pretty much cut and paste it from the front page. Now I just need to find the keycaps to actually put on the board.
Realforce 87UB45 & 87UW45, Leopold FC200 Red
Offline alaricljs
  • I be WOT'ing all day...
« Reply #989 on: Tue, 24 January 2012, 09:35:10 »
What's your fancy for keycaps?
Filco w/ Imsto thick PBT
Offline scrubadub
« Reply #990 on: Tue, 24 January 2012, 09:56:06 »
Quote from: alaricljs;497563
I'd like to find a nice set of black on white doubleshots with beige modifiers. I'm camping out Ascaii's leftovers thread on DT (or wait for GB3). I'd also like to track down a 7x black space bar and 1.5 Control/Alt keys in white on black to complete my existing set (which has a bunch of 1.25x keys). I'll probably also order some custom keys via WASD to replace the unused Scroll Lock, Pause, etc.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #991 on: Tue, 24 January 2012, 12:56:30 »
what is the projected delivery date for these (for the US)? i'd like to buy into the boards in particular, but if i'm going to build up a project around the board, i don't want to have to deal with a floating deadline like eg the key gbs
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #992 on: Tue, 24 January 2012, 12:58:56 »
Quote from: mkawa;497699
If you're talking about R4 GB, that ones just a mess. This ones moving on properly.
Offline mkawa
« Reply #993 on: Tue, 24 January 2012, 13:08:41 »
does that mean there's a projected delivery date? ;)
Offline alaricljs
« Reply #994 on: Tue, 24 January 2012, 13:33:04 »
Litster wants to close the GB Jan 31st.  As for projected delivery that depends on everyone paying and a number of different vendors manufacturing and delivering product.  Not the easiest thing to predict.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #995 on: Tue, 24 January 2012, 13:38:34 »
Quote from: mkawa;497714
Maybe not a projected delivery date. But its running into less issues/detours than R4 is.
Offline litster
« Reply #996 on: Tue, 24 January 2012, 13:50:30 »
Quote from: alaricljs;497743
alaricljs is correct.  Any date I give you now other than the closing date is going to be wrong.  We still have a few things to close out, but we are on the right track though.
Offline Sojik
« Reply #997 on: Tue, 24 January 2012, 14:28:33 »
Everything we need to build this keyboard can be purchased from this group buy besides the Filco case and keycaps, correct?
Secondly, will the 7bit layout allow for those 5 buttons above the arrow keys (to make it a 3x5 block of keys)? If so the Filco case would need to be modified to fit, yeah? How hard was it to make your own case? Did it require any special equipment?
« Last Edit: Tue, 24 January 2012, 14:31:16 by Sojik »
Offline litster
« Reply #998 on: Tue, 24 January 2012, 14:39:00 »
yes, besides case and keycaps, you should be able to get everything you need in this group buy.  every plate and PCB combination lets you create a 3x5 block on the right.  You just need to figure out what to do with the case.  If you already have a Filco case, you can just put the Phantom onto the bottom shell of the Filco case.
This cardboard case is pretty easy to make :D  You just need some cardboards, a cutter, a ruler and an hour or two.  LOL!!!
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #999 on: Tue, 24 January 2012, 15:11:43 »
Not sure if this was already suggested or not but what about a thinner aluminum case for this similar to the Vortex Pure?
