Author Topic: Phantom Custom Keyboard Group Buy (CLOSED)  (Read 484950 times)
Offline 7bit
  • MX1A-G1DW
« Reply #1150 on: Sun, 29 January 2012, 13:35:27 »
Quote from: hazeluff;502422
Litster is doing an acrylic case for TKL. It's not really specific to this.
Probably I'll edit the usb_keyboard.c file then...
Also @Litster: I don't want to cut up your nice case for 7bit = (
You should not do that.
Your keyboard spits out key codes and you map them to whatever you need.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline riffautae
« Reply #1151 on: Sun, 29 January 2012, 14:03:32 »
Quote from: hazeluff;502413
Has anyone looked into writing the firmware for a keyboard with media keys? I'm having troubles figuring out how to implement Pause/Play, Next Track and Prev. Track. They aren't simple keys with keycodes defined in the USB HID standard. There are values for Vol. Up and Vol. Down tho.
The tmk code can do this. I was working on it but then my tool chain suddenly stopped working so it is delayed.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1152 on: Sun, 29 January 2012, 14:34:06 »
Demik. Im not quite sure. There is a bandwidth limit. But i dont eecall off the top of my jead. Im out for a couple hours atm. Ill get back with it when im back and someone cant answer.
Litster: i see. Ill just map those keys to like f13 onward and remap on my pc.
Fight For Freedom. Stand with Hong Kongers
Offline Zehkul
« Reply #1153 on: Sun, 29 January 2012, 14:57:23 »
AFAIK it's mandatory that the board operates as a second USB device for the PC to sends the media signals (don't ask me why though, I've got no idea :P)... So probably not all that easy to do.
« Reply #1154 on: Sun, 29 January 2012, 15:44:39 »
Quote from: digitalleftovers;502450
This will be my first adventure in soldering, too.  I went to my local thrift store and grabbed some cheap stuff to practice on.  Even radio/alarm clocks have PBCs inside.  Its good to note as you practice what condition you leave the bored in during soldering/desoldering since that is what you are worried about.  If you don't have enough heat in about 2 seconds, let it cool and start over because you could damage the board.  That is what I've been told.
Yes, you can damage the PCB, and lifting traces is common. Really, soldering/time only becomes an issue if you are soldering to a huge ground plane, which will absorb a lot of heat. If you have temperature control, heat up the iron more, and go quick.
I managed to lift a trace on an ALPS RK27 (potentiometer) breakout board, but I ended up just soldering directly to the pin anyway on that one.
Anyway, I'd recommend getting some sort of copper braid / solder sucker for mistakes, it really helps. There are some really good tutorials online for soldering. I liked the tangentsoft ones a lot:
http://tangentsoft.net/elec/movies/
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #1155 on: Sun, 29 January 2012, 16:16:59 »
speaking of tangent, the DIY audio community has a wealth of information for electronics hobbyist supplies and techniques. this is also how i got my start
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #1156 on: Sun, 29 January 2012, 16:35:27 »
Any objection if we start a separate thread on firmware mods and building the kit?  I think we will have a lot of posts about ordering, paying, shipping and such.  Separate threads for ordering/shipping and modding and building could be helpful.  Thoughts?
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1157 on: Sun, 29 January 2012, 17:13:44 »
Quote from: litster;502588
Sounds good to me stick it in the mods section or your welcome to make as many threads as you like in my subforum.
Offline maoiste
« Reply #1158 on: Sun, 29 January 2012, 18:07:45 »
Hey, i am still thinking about buying a phantom but i need to know if it is possible to have the FN keys to toggle between different layers with the teensy. I would be willing to tinker around with the firmware myself to make those changes but i would need to know if it is possible before i buy everything.
« Reply #1159 on: Sun, 29 January 2012, 18:15:55 »
Quote from: maoiste;502638
It should be possible but it hasnt been done. I am currently going to use a locking switch to bypass this.
Offline mkawa
« Reply #1160 on: Sun, 29 January 2012, 18:20:05 »
looking at the teensy code, it looks like it's possible; easy even. no guarantees though.
Offline mkawa
« Reply #1161 on: Sun, 29 January 2012, 18:20:30 »
+1
Offline tsangan
  • 1000/600
« Reply #1162 on: Sun, 29 January 2012, 18:55:59 »
Just placed in my order for the 5th time, man this is one expensive GB :E
I shouldn't bother with these GB till the end, I always end up changing it like 5-6 times
Keyboardless
Offline maoiste
« Reply #1163 on: Sun, 29 January 2012, 19:11:28 »
I am for dedicated threads for the firmware, so ppl can post modifications for their setups and ppl won't have to scroll through this thread for suggestions/questions regarding the stock phantom firmware.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1164 on: Sun, 29 January 2012, 19:43:41 »
Be a good idea to use Profosists' forum so he can help moderate the threads.  Off-topic and banter can get shunted over after the sub-thread dies down to keep the main thread easier to follow.
Filco w/ Imsto thick PBT
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1165 on: Sun, 29 January 2012, 19:47:02 »
Should be possible. Since FN keys don't actually send anything to the computer. You just use this key to change a variable/state in your keyboard. I'm doing that with some of my keys.
Yes, I agree with custom firmware thread in TheProfosist forum. I'll be lurking there helping out and asking questions = D
Offline tsangan
  • 1000/600
« Reply #1166 on: Sun, 29 January 2012, 19:59:05 »
I will be there getting help :rofl:
Keyboardless
« Reply #1167 on: Sun, 29 January 2012, 20:03:22 »
Quote from: hazeluff;502706
Well who ever is going to create it go for it and ill sticky it.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1168 on: Sun, 29 January 2012, 20:16:53 »
http://geekhack.org/showthread.php?26730-Teensy-Keyboard-Firmware-Discussion&p=502738
Go TheProfosist, Sticky it.
And for everyone else who has firmware questions, Pop in there instead of posting here (there's like 10-20 pages of just firmware discussion here already)
« Reply #1169 on: Sun, 29 January 2012, 20:24:46 »
Quote from: hazeluff;502742
done!
Offline litster
« Reply #1170 on: Mon, 30 January 2012, 04:23:18 »
I started a new wiki/mod post here: Building Phantom Hardware and Firmware Mods
I have put in a bunch of relevant information there, and a link to the Phantom soldering instruction.  Please use the discussion area to discussion phantom soldering, phantom firmware mod, ask questions, and help each other out.
Please continue to use the thread on order and parts related topics.  Thanks.
Offline trax
« Reply #1171 on: Mon, 30 January 2012, 06:47:31 »
Do we have to add the shipping to the order?
Switches tried so far
Cherry MX Red Blue Black Clear
ALPS White Black (fake)Blue
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline 7bit
  • MX1A-G1DW
« Reply #1172 on: Mon, 30 January 2012, 06:49:40 »
Quote from: trax;503081
I will add the shipping costs based on your locations. No need to add something on your own.
2 days left for the Phantom and just a few more days for switches!!!
BTW: blue switches get now the lower volume price ($0.6 instead of $0.8).
http://deskthority.net/wiki/Phantom_Group_Buy#Pricelist
« Last Edit: Mon, 30 January 2012, 07:07:24 by 7bit »
Offline Saviant
« Reply #1173 on: Mon, 30 January 2012, 08:30:39 »
I have been on the fences about ordering one of these kits, but at the moment I am waiting on some money for work I have done. Is there going to be another group run later down the track?
« Reply #1174 on: Mon, 30 January 2012, 08:44:33 »
just to make sure I have enough... how many switches are on the 7bit layout?
Offline 7bit
  • MX1A-G1DW
« Reply #1175 on: Mon, 30 January 2012, 09:04:21 »
Quote from: dorkvader;503116
[size=12]
101[/b][/size]
Offline litster
« Reply #1176 on: Mon, 30 January 2012, 11:14:21 »
Quote from: Saviant;503109
There is a possibility for another round.  But if there is ever another one, it will be at least 6 months to a year from now.  If we do another one, I don't think it will be the same design.  So it will take quite a bit of time to do another one using the experience we learned so far and will learn later throughout the building process.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1177 on: Mon, 30 January 2012, 11:41:40 »
Quote from: litster;503227
Full sized/Dox like keyboard next? Or maybe a design so that we can use more pins for LEDs/Backlighting (I love lights).
^_^I love this forum and all the **** we do here.
Offline alaricljs
« Reply #1178 on: Mon, 30 January 2012, 11:47:30 »
If you would like to help me out... I have a Filco replacement design with full backlighting (using a couple extra chips).  Biggest stall for me has been not having time to work out how to do the LED control so I can finalize the design.  I have an LED test board, but haven't done any attempt at firmware.  Wouldn't be able to go crazy with the options like the current design because of all the extra traces, but I think ISO and stepped Caps may be possible.  Currently it's plain vanilla ANSIWIN layout.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1179 on: Mon, 30 January 2012, 11:50:49 »
Quote from: alaricljs;503252
Depends on what you want to do with your LEDs. Are you maybe just going to keep them all on? Trying to make it give people with epilepsy seizures?
Offline digitalleftovers
« Reply #1180 on: Mon, 30 January 2012, 12:05:27 »
Not to go too far off topic, but I had an idea to mod one of those matrix cherry POS boards so that the each key would light as you typed (as computers do in most cinematic representations of the future).  It should also make random blinky patterns when you aren't using it and it is "working."  So, yes, a controller that could handle a ton of lights, layers and behaviors is a win for me!
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline alaricljs
« Reply #1181 on: Mon, 30 January 2012, 12:12:12 »
Quote from: hazeluff;503258
LOL.... the hardware is setup so that it's fully programmable and controllable.  Full individual LED control w/ teensy managed single LED PWM brightness.  I did the design back in July/August, so it's not fresh in my mind, but the LED chips are 2x CAT4016 (Mouser) shift registers cascaded off of the teensy's MOSI/MISO pins.  I need to get some sort of firmware working on it so I can validate my design and transistor/resistor choices.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1182 on: Mon, 30 January 2012, 12:15:32 »
Quote from: digitalleftovers;503260
There was a discussion somewhere about getting a LED per switch and having them light up as  you type on them.  Something like the first 10 seconds of this video
http://www.youtube.com/watch?v=5_hEQT1aziQ
The one problem I have with this, is that when you type, you're fingers are gonna be over that key that lights up...But anyway the concept is really cool.
I think it could be implemented with medium/hard difficulty. The thing is that there will be a lot of wires flying around underneath the PCB (There is almost no way to get so many lines on a PCB).
Offline alaricljs
« Reply #1183 on: Mon, 30 January 2012, 12:19:10 »
Quote from: hazeluff;503270
That's the PCB design I put together. Fully individual controlled LEDs, no extra layers or wires.  All it would take is the programming to manage the LEDs, I haven't gotten that far yet.
Here's another project using these parts.  Vid included in the page.
« Last Edit: Mon, 30 January 2012, 12:21:41 by alaricljs »
Offline jil_jil32
  • Tokyo Press <3
« Reply #1184 on: Mon, 30 January 2012, 12:22:29 »
Offline alaricljs
« Reply #1185 on: Mon, 30 January 2012, 12:29:13 »
Quote from: alaricljs;503271
And I just got back in touch with the fine gentleman that did that mod and he is working toward open-sourcing the project.  Soooo, enjoy the vid it could be a reality for the next round.
Offline mkawa
« Reply #1186 on: Mon, 30 January 2012, 12:30:15 »
you don't need a controller to do this. all you need is to wire the switches so that closing them triggers current through the diode
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1187 on: Mon, 30 January 2012, 12:32:33 »
I'm a bit confused about the no extra layers/wires. Since in the link the guys flies a ton of wires across the back of the board.
I'd love to write something using the teensy, but I have to wait for my phantom order to come with my 2 teensys.
Start another thread about lighting controller in the mod section to discuss this. I feel like I've derailed this thread too much.
Quote from: mkawa;503283
I'm not 100% sure about this. (need to have a look, but I'll take your word for this for now). But this doesn't allow the flexibility of doing crazy cool stuff like a Wave of lights going across your keyboard when you idle.
« Last Edit: Mon, 30 January 2012, 12:35:19 by hazeluff »
Offline Parak
« Reply #1188 on: Mon, 30 January 2012, 12:34:41 »
Quote from: alaricljs;503281
Yeah, I'd do some rather questionable deeds to see those schematics and firmware source. I'd probably totally put in the time to build a pcb based on such schematics, considering I need such a controller for my project as well.
Offline mkawa
« Reply #1189 on: Mon, 30 January 2012, 12:37:14 »
Quote from: 7bit;503083
GUH? 25 shipping for CONUS? what th-?! why?
Offline alaricljs
« Reply #1190 on: Mon, 30 January 2012, 12:38:38 »
Quote from: hazeluff;503287
Quote from: Parak;503289
His project was a mod to an existing backlit KB.  I was trying to take it to the next level with a complete PCB replacement for the Filco 87key and did the PCB schematic for it.  If my transistor choices are correct then it's fab ready, but I wanted to test my design and component choices before committing to a full board.  I did a mini-board with just LEDs and the shift register and transistors for testing, but never made it to the coding stage.
I'll dupe this info into a new thread in our good friend TheProfosist's forum.
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1191 on: Mon, 30 January 2012, 12:40:21 »
Quote from: alaricljs;503295
I will enjoy the discussion there. = ) Cos for Phantom v2 I would love to see some awesome LED features ; p
Quote from: mkawa;503293
Omg Shipping to EU is 22. For once something cheaper for us EU people ><
Offline mkawa
« Reply #1192 on: Mon, 30 January 2012, 12:45:41 »
and yet shipping to DE is 9. HMMM I THINK I SEE WHERE THIS IS GOING
Offline trax
« Reply #1193 on: Mon, 30 January 2012, 12:47:08 »
I live in EU but need shipping to US (alaricljs     )
y0
Montereys
ACER
White Black
Futaba
Buckling Sprin
Offline kps
« Reply #1194 on: Mon, 30 January 2012, 13:00:24 »
You need to ensure that the diode voltage drop is not so high that it prevents the keypress being recognized. Red LEDs might work; others probably won't.
Offline litster
« Reply #1195 on: Mon, 30 January 2012, 13:01:22 »
We also need to pay for boxes (if not using USPS priority mail boxes), packaging, and shipping cost to get the items shipped to the distributors in EU and USA.  We also will be ordering items in EU and ship half of them to the US for distribution, and ordering items in the USA and ship half of them to EU for distribution there.
Offline 7bit
  • MX1A-G1DW
« Reply #1196 on: Mon, 30 January 2012, 14:11:49 »
Quote from: trax;503303
y0
I will add the GIFT option.
Should it be wrapped in some specific paper etc?
Offline 7bit
  • MX1A-G1DW
« Reply #1197 on: Mon, 30 January 2012, 14:14:54 »
Quote from: litster;503316
I might get boxes from Ascaii (the ones from the scary cellar). Also, I've got some boxes myself, so I don't think I need to buy anything.
Offline 7bit
  • MX1A-G1DW
« Reply #1198 on: Mon, 30 January 2012, 14:30:46 »
I'm not responsible for the shipping costs. I'm quite sure it is insured shipping.
« Reply #1199 on: Mon, 30 January 2012, 14:31:51 »
Quick question, in the email we got for shipping address do we put ours or where we want it shipped?
