Author Topic: New Theme: Nostalgia  (Read 23832 times)
Offline rknize
    • metaruss
« on: Fri, 20 July 2012, 00:21:11 »
Pining for the look and feel of the Geekhack of old?  Give the "Nostalgia" theme a try!
« Last Edit: Fri, 20 July 2012, 21:59:53 by rknize »
Russ
Offline The_Beast
  • I like wood ಠ_๏
Re: New Theme: Nostalgic
« Reply #1 on: Fri, 20 July 2012, 00:27:52 »
It looks similar but isn't quite the same. The grays and blacks are too harsh, maybe lighten them up.
I'm not complaining, it's still better than whatever the default was
Offline rknize
    • metaruss
« Reply #2 on: Fri, 20 July 2012, 00:30:45 »
I matched the hex codes exactly to parts of the old forum (which I still have a static copy of).  What's different is the layout and how/where the SMF default theme uses some of the colors.  It's not exact, by any means, but it should help some people feel more at home.  :)
Russ
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Fri, 20 July 2012, 00:34:11 »
I feel like there's a lot of wasted space on the sides.  Otherwise A+!
Offline rknize
    • metaruss
« Reply #4 on: Fri, 20 July 2012, 00:40:59 »
Better?
Russ
Offline sth
  • 2 girls 1 cuprubber
« Reply #5 on: Fri, 20 July 2012, 00:43:25 »
Ahh, feeling like home again  :D
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #6 on: Fri, 20 July 2012, 00:56:05 »
Ahh, that's much easier to look at. Thanks!
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Thagarr
    • Pirates Ahoy!
« Reply #7 on: Fri, 20 July 2012, 03:51:46 »
Very nice, much better than the default theme!
Offline YMSNoms
« Reply #8 on: Fri, 20 July 2012, 05:58:33 »
Absolutely awesome
Leopold FC700R
Filco Majestouch-2 Multicamo
Korean FR4-87 Lambo Orange Custom
Offline jonnybastard
« Reply #9 on: Fri, 20 July 2012, 07:12:59 »
feelsgoodman  8)
KMAC    -    HHKB Type-S    -    Filco TKL LineaR    -    Poker X    -    KBT Race LE
flickr
Offline imersa
  • clickclack's #1 fan
« Reply #10 on: Fri, 20 July 2012, 07:26:29 »
I'm pretty into both so far, cheers for the tip
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #11 on: Fri, 20 July 2012, 09:30:44 »
LOVE the new theme!!  Thanks!!
Offline reaper
« Reply #12 on: Fri, 20 July 2012, 10:23:34 »
Yah, very cool.  Thanks Russ!
Din Eli
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #13 on: Fri, 20 July 2012, 10:33:26 »
Much better! This should be default. :D
Offline Glissant
« Reply #14 on: Fri, 20 July 2012, 12:10:47 »
This is more like it for me :D. Thanks for setting it up!
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #15 on: Fri, 20 July 2012, 12:25:06 »
yea.........i'm liking it, but the "old logo" i was diggin more 8)
the color scheme (old logo) matches this theme if i recall pretty good? this them seems to be a little easier to read i guess.
HOWEVER..........just happy to have GH back up and running so kudo's and thank you.
we know you're still tweakin...........
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline rknize
    • metaruss
« Reply #16 on: Fri, 20 July 2012, 13:19:07 »
Switched logos.  I'll put it to a vote.  New or old logo for Nostalgic?
Russ
  • techkeys.us
    • TechKeys
« Reply #17 on: Fri, 20 July 2012, 13:19:28 »
I vote old! :)
Offline reaper
« Reply #18 on: Fri, 20 July 2012, 13:20:32 »
Definitely old logo.
Din Eli
Offline rknize
    • metaruss
« Reply #19 on: Fri, 20 July 2012, 13:22:47 »
OK...that's too much orange again.  I need to stop doing that.
Russ
Offline rknize
    • metaruss
« Reply #20 on: Fri, 20 July 2012, 13:25:11 »
You were right.  The logo makes it real.
Russ
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #21 on: Fri, 20 July 2012, 13:32:00 »
hee-hee.........can i vote again?
let the masses speak!
Offline doubletap
« Reply #22 on: Fri, 20 July 2012, 14:08:32 »
 ;D
Offline D3avy
« Reply #23 on: Fri, 20 July 2012, 14:20:04 »
Didn't realize you can change theme, switched to nostalgia but it doesn't feel like the old GH, I think I'm gonna stay on this new theme, all that white on DT messed up everything :)
Offline rknize
    • metaruss
« Reply #24 on: Fri, 20 July 2012, 14:20:06 »
Nostalgic with the logo from Thoriated:
Russ
Offline D3avy
« Reply #25 on: Fri, 20 July 2012, 14:24:04 »
That logo looks much better but why does text and forums look bigger on nostalgia?
Offline rknize
    • metaruss
« Reply #26 on: Fri, 20 July 2012, 14:38:18 »
I think someone changed the default template that these themes inherit from.  I really didn't touch font sizes, except in the menu bar.  Also, Firefox renders things larger than Chrome for some reason.
Russ
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #27 on: Fri, 20 July 2012, 14:56:05 »
i would think because the old template has the border around the outside pushing everything more center.
makes it a little busier imop, clashier i guess would be the verbage- but i'm sure it will be settled on what the majority wants.
Offline pyro
Re: New Theme: Nostalgia
« Reply #28 on: Sat, 21 July 2012, 18:57:11 »
Offline Tranquilite
« Reply #29 on: Sun, 22 July 2012, 17:58:16 »
This theme makes me happy :D
« Reply #30 on: Sun, 22 July 2012, 18:36:33 »
Much better :)
« Reply #31 on: Sun, 22 July 2012, 18:39:57 »
White on bright reddish orange does not go well with my eyes.
Offline kimtj
« Reply #32 on: Mon, 23 July 2012, 07:31:19 »
Very nice!
Offline Okita
« Reply #33 on: Tue, 24 July 2012, 18:11:49 »
I  like the new theme.
Offline hasu
  • @tmk
« Reply #34 on: Tue, 24 July 2012, 18:21:03 »
Thank you. I regained peace of mind now.
