Author Topic: What did you get in the mail today?  (Read 25427844 times)
0 Members and 8 Guests are viewing this topic.
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #30600 on: Wed, 25 March 2015, 13:49:57 »
This came in today.
mmmm well butter my buns i am officially jelly
Offline cmadrid
« Reply #30601 on: Wed, 25 March 2015, 14:04:14 »
New family members have arrived!
« Reply #30602 on: Wed, 25 March 2015, 14:20:54 »
Got some mail from Sifo, thanks Sifo.
No problem, anytime.
Offline Vulshinn
« Reply #30603 on: Wed, 25 March 2015, 15:15:08 »
Finally here! Typing on it now and loving it!  ;D    Sorry for the potato pic, hope to get some better shots later.
Offline ghostjuggernaut
« Reply #30604 on: Wed, 25 March 2015, 15:25:13 »
Looking good man. Glad it all worked out. I received my caps from Rakuten today, and was blown away by Tenso's speed.
Offline Vulshinn
« Reply #30605 on: Wed, 25 March 2015, 15:44:30 »
I actually used Zenmarket, you pay them and they buy and ship the stuff for you.  Was a really easy process and their shipping price was a little lower then Tenso.
I need to pick me up some dye now, that's why I got an extra set of white caps.  :thumb:
« Reply #30606 on: Wed, 25 March 2015, 15:56:51 »
It's always good to see things made it.  How you enjoy them.
Offline missalaire
  • Great Finder of Great Finds
« Reply #30607 on: Wed, 25 March 2015, 16:36:39 »
Dragon Age: Inquisition Deluxe Edition
Right in time for the new DLC that just came out too.
« Reply #30608 on: Wed, 25 March 2015, 16:39:22 »
That's my plan as well, for my white set.  I'm waiting to figure out a color scheme before I purchase.  Let me know how it goes, It will probably be another couple weeks before I order some dye.
Offline strict
  • TKL Zealot
« Reply #30609 on: Wed, 25 March 2015, 17:43:49 »
Time to properly silence the 55g  :)
Offline Ngt
« Reply #30610 on: Wed, 25 March 2015, 18:15:31 »
What kind of o-ring are they? Are they circular landing pads?
Offline Willyc277
« Reply #30611 on: Wed, 25 March 2015, 18:57:55 »
Not sure when I'll have time to start the assembly process, but it's all here finally!!
Offline HPE1000
  • Keycap Paparazzo
« Reply #30612 on: Wed, 25 March 2015, 19:06:26 »
Exciting!
Offline strict
  • TKL Zealot
« Reply #30613 on: Wed, 25 March 2015, 20:32:32 »
http://imgur.com/0pLq1qK.jpg
OEM Topre sliders with foam ring   :)
Offline Willyc277
« Reply #30614 on: Wed, 25 March 2015, 20:55:14 »
Exciting!
I'm very excited, but also a bit anxious! I've only ever soldered a Techkeys business card so this will be an adventure for me!
« Reply #30615 on: Wed, 25 March 2015, 21:04:45 »
My $30 Topre find.  Plate mounted, feels like 45-55g to me.  Definitely stiffer feeling than my HHKB, but that could be a result of the plate.
Offline HPE1000
  • Keycap Paparazzo
« Reply #30616 on: Wed, 25 March 2015, 21:08:04 »
That is really awesome even ignoring the low price.
Offline Sed8op8
  • Keyboard Padawan
« Reply #30617 on: Wed, 25 March 2015, 21:10:55 »
What's the mod your doing?
« Reply #30618 on: Wed, 25 March 2015, 21:11:44 »
Yours is so much cleaner than mine.
« Reply #30619 on: Wed, 25 March 2015, 21:24:33 »
Hells yeah :)
Offline Willyc277
« Reply #30620 on: Wed, 25 March 2015, 21:36:49 »
Picked up a Duck mini PCB and plate, some clears, 62g springs, thick lube, stickers, and an aluminum low-profile 60% case from a few people/vendors. Everything came disassembled so I'll have to throw it all together!
Offline Ngt
« Reply #30621 on: Thu, 26 March 2015, 05:16:11 »
Where did you get the foam ring from? How thick are they?
Offline strict
  • TKL Zealot
« Reply #30622 on: Thu, 26 March 2015, 08:38:28 »
I traded one of my BBv2's for them. The foam rings are about as thick as a sheet of card-stock, or maybe like 2-3 sheets of cheap printer paper. The magic is the purple sliders though, they have a slightly different height that allows the foam rings to quiet the upstroke without reducing key travel at all. You can find some pictures of the differences between the silent purple sliders and the normal black sliders here  :thumb:
Offline Ngt
« Reply #30623 on: Thu, 26 March 2015, 09:15:49 »
Fair enough thank you. I wish they did the same for the Novatouch slider!
Offline btctopre
« Reply #30624 on: Thu, 26 March 2015, 09:26:46 »
They're just a hair taller, most of the space to accommodate for the ring actually comes from the thinner base. So someone could technically turn stock sliders into similar silent sliders by sanding(?) down the base, but consistency would be an issue and I imagine that'd take an insane amount of time to do.
Another thing to note is that both sides of the base also have cuts in them (as apposed to a single side on the stock slider) to ensure air doesn't trap the ring above the base. This is possibly what creates the "whistle" that people hear on their Type-S (and why it's so inconsistent), it's a ring that slid up the slider on the way down of the key press (they don't stay in place very well), then was pushed back into the base as the key reached its peak.
Offline btctopre
« Reply #30625 on: Thu, 26 March 2015, 11:51:48 »
The other half of that purple slider trade, my first BBv2  :thumb::
Offline Flyersfan1
  • Hi!
« Reply #30626 on: Thu, 26 March 2015, 11:56:24 »
Damn son, you are the master of topre aesthetics.  That BBv2 will go perfectly with 10ae caps!
Quote from: Photekq
Offline FoC_Tow
  • Brokehlicious
« Reply #30627 on: Thu, 26 March 2015, 12:02:22 »
Beautiful, Congratz! And great match btc!  :)
Whats the name of this color, is it a Interference Metallic?
Offline strict
  • TKL Zealot
« Reply #30628 on: Thu, 26 March 2015, 12:50:43 »
http://i.imgur.com/2Gpp7f4.png
Glad to see it arrived safely! That guy is going to look sweet with those JIS AE keys  :thumb:
Fauxluminum
Offline epzy
  • HHKB Fiend
  • ded
« Reply #30629 on: Thu, 26 March 2015, 13:35:33 »
skullsicle :d
« Reply #30630 on: Thu, 26 March 2015, 13:40:59 »
skullsicle :d
My favorite skull.  :eek:
How'd you know I love pink and purple Nubb!  :-* :-*
95288-0
Offline Sygaldry
  • Edema Ruh
« Reply #30631 on: Thu, 26 March 2015, 14:05:03 »
95292-0
95294-1
95296-2
Yeee my first binge package art.
+Mellow pearl keyng v3 lion!
null
« Reply #30632 on: Thu, 26 March 2015, 14:52:59 »
skullsicle :d
Nice one bro!   :thumb:
« Reply #30633 on: Thu, 26 March 2015, 14:58:59 »
skullsicle :d
sigh.... it's very nice epzy
« Reply #30634 on: Thu, 26 March 2015, 15:00:21 »
skullsicle :d
ah can't wait to get mine. right....??? :*
Offline epzy
  • HHKB Fiend
  • ded
« Reply #30635 on: Thu, 26 March 2015, 15:17:24 »
skullsicle :d
riiiight '^'
Offline Alex92
« Reply #30636 on: Thu, 26 March 2015, 15:50:21 »
Offline Sygaldry
  • Edema Ruh
« Reply #30637 on: Thu, 26 March 2015, 15:52:05 »
Best toilet picture I've seen yet.
What's inside??
null
« Reply #30638 on: Thu, 26 March 2015, 15:53:14 »
Ok I'd totally just buy that by itself.
« Reply #30639 on: Thu, 26 March 2015, 15:54:15 »
What's inside??
I've got an idea...
« Reply #30640 on: Thu, 26 March 2015, 15:58:18 »
« Reply #30641 on: Thu, 26 March 2015, 15:58:40 »
What's inside??
Whatever it is... it's the ****.
Offline Alex92
« Reply #30642 on: Thu, 26 March 2015, 16:00:41 »
What's inside??
I'm in the process of getting pictures  :p
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #30643 on: Thu, 26 March 2015, 16:04:13 »
Had a taste of some curious cola today at a coffee house. Imported UK sodas.
Bought a few of them. :P
Fentimans Tonic Water, Curiosity Cola, Rose Lemonade and Ginger Beer. :thumb:
|||My other keyboards :
x
Offline Alex92
« Reply #30644 on: Thu, 26 March 2015, 16:16:24 »
Here we go...my initial pictures didn't turn out too well, so I had to retake them  :))
More pictures in the relevant thread.
« Reply #30645 on: Thu, 26 March 2015, 16:17:14 »
holy ****
« Reply #30646 on: Thu, 26 March 2015, 16:23:03 »
 :eek:
Offline cmadrid
« Reply #30647 on: Thu, 26 March 2015, 16:24:53 »
For my son!
Picked him up from kindergarten with it in the back and he goes.. Can we go to the park?? I've got to try this baby out.
« Reply #30648 on: Thu, 26 March 2015, 16:25:41 »
For my son!
dang I had/have the exact same one.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #30649 on: Thu, 26 March 2015, 16:46:26 »
Bought a few of them. :p
YES. Fentimans is very close to where I am originally from! I recommend getting some Hendricks gin (Scottish) and a slice o' cucumber to go with the tonic  :thumb:
