Author Topic: What did you get in the mail today?  (Read 25577656 times)
« Reply #30750 on: Fri, 27 March 2015, 15:57:29 »
stop posting pepe you aren't worthy
Stop telling people what to do you bossy prick.
« Reply #30751 on: Fri, 27 March 2015, 16:01:34 »
OHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!  :eek:
Offline Sed8op8
  • Keyboard Padawan
« Reply #30752 on: Fri, 27 March 2015, 16:16:20 »
Its gorgeous You must be super excited. I really need to find an easy/beginner DIY custom to cut my teeth on any ideas?
winkeyless.kr/en for sure... so many choices and pretty affordable as far as Korean customs go.
Otherwise, the Duck Orion V2 and the TX87 are both coming soon-ish so you might want to keep your eyes peeled for those two GBs.
The duck orion is the tkl right. I believe punks was mentioning that he was excited about it I'll check that out guys is there an IC right now ?
Offline Sygaldry
  • Edema Ruh
« Reply #30753 on: Fri, 27 March 2015, 16:27:58 »
Well the gb should starting soon but you can find a thread all about it called "Orion V2"
null
« Reply #30754 on: Fri, 27 March 2015, 16:43:57 »
I got a Logitech DiNovo without the base station. It has the nicest scissor switches, I think, with ~3 mm key travel. The idea is to rebuild it into a smaller keyboard with USB.
« Reply #30755 on: Fri, 27 March 2015, 17:42:46 »
MG Sazabi Ver Ka and all the tools you need for Gunpla building :D
Offline Zeal
    • Zeal Generation Inc.
« Reply #30756 on: Fri, 27 March 2015, 17:47:12 »
Offline trizkut
« Reply #30757 on: Fri, 27 March 2015, 17:48:42 »
Offline jonathanyu
« Reply #30758 on: Fri, 27 March 2015, 17:54:18 »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #30759 on: Fri, 27 March 2015, 17:54:32 »
Offline azhdar
  • Praise the AZERTY god
« Reply #30761 on: Fri, 27 March 2015, 17:56:10 »
look like you've been blessed by the azerty god :o
Azerty Propagandiste
Offline meow a cat
  • Resistance is futile.
« Reply #30762 on: Fri, 27 March 2015, 18:06:54 »
Deep Space, dirty SSK, and some KBD Mania caps from Webwit.
Boards:
Offline ideus
  • Björkö.
« Reply #30763 on: Fri, 27 March 2015, 18:09:02 »
An awesome GON's Nerd60 PCB; later, I will post some pics as it gets some assembly progress. Soldering SMD components again, after a long, long, long time.
Offline Sed8op8
  • Keyboard Padawan
« Reply #30764 on: Fri, 27 March 2015, 19:48:21 »
for added effect play this and wait for the beat to drop before looking at photos...
no time to clean up the dust, im a filthy filthy animal
Nice full metal jacket hell freaking ya. I love how they did the brass weights in that . Cannot wait to see what you put in it  :eek:
Offline Sed8op8
  • Keyboard Padawan
« Reply #30765 on: Fri, 27 March 2015, 19:54:20 »
That's SSK dosent look that dirty at all man very nice. Where does everybody keep scoring these SSKs and roughly what do they sell for. I have heard elec plus but I guess there is a list and I'm not sure if I'm way to late for the party or not. Anyways great mail day for you sir  ;)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #30766 on: Fri, 27 March 2015, 20:02:16 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #30767 on: Fri, 27 March 2015, 20:04:42 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #30768 on: Fri, 27 March 2015, 20:05:57 »
Offline meow a cat
« Reply #30769 on: Fri, 27 March 2015, 20:26:49 »
If you hurry, you might be able to snag one of Cindys still. She has them up for sale off of the list now, because I don't think many people responded to her when she PM'd them.
http://www.elecshopper.com/ibm-1391472-space-saving-keyboard-used.html
I pointed Apocalypsemaow to this link earlier today, and he purchased one. She has them up for $75 + shipping, which is a steal if you ask me. Just don't expect it to be perfect.
It is dirty, just not that dirty looking at the top. Underneath, the barrel plate is totally filthy (like a good centimetre of dust and gross stuff), and the sides of the caps look disgusting. It also has a few sticky stabilizers, a broken spacebar, and it needs a bolt mod. Nothing that can't be fixed though!  ;D
And thanks, I have had a few good mail days this week.  :thumb:
Boards:
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #30770 on: Fri, 27 March 2015, 20:28:30 »
You'd never guess what I got today in the mail....
It was actually SENT this way.
Offline SpaceGhost
« Reply #30771 on: Fri, 27 March 2015, 20:37:18 »
When it comes to packing these properly, idiots abound. Buyer beware and always insist that seller double-box in a sturdy outer box with plenty of large-diameter bubble wrap for cushioning. Here's what I received a while back, due to absolutely retarded packing:
95450-0
Offline Snowdog993
« Reply #30772 on: Fri, 27 March 2015, 20:38:53 »
MORE?
Offline SpaceGhost
« Reply #30773 on: Fri, 27 March 2015, 20:47:27 »
MORE?
Looks like you really lucked out, considering that there was only one thin layer of corrugated cardboard between the underside of the keyboard and the (sometimes brutal) outside world. I can't imagine IBM ever shipping them exactly that way, i.e., without a heavier outer box.
Offline Snowdog993
« Reply #30774 on: Fri, 27 March 2015, 20:54:37 »
Yep.  It turned out just fine.  In case you are wondering about around the ESC key, there was just bits of box and fluff from inside the box including the damaged styrofoam in the corner which I taped back into place.  Keyboard is 100% fine.
Offline Snowdog993
« Reply #30775 on: Fri, 27 March 2015, 21:11:07 »
What about the rivets?  I had to check that too.
100%.  All rivets are intact and the keyboard is solid.
Offline njbair
    • nickbair.net
« Reply #30776 on: Fri, 27 March 2015, 21:15:24 »
Awesome! My Model M came with no broken rivets, too.
Have you considered bolt modding it anyway?
My boards:
Offline Snowdog993
« Reply #30777 on: Fri, 27 March 2015, 21:26:49 »
I have tried a bolt mod myself, and ended up with a broken keyboard and several other broken parts.
I have had several already done by Phosphorglow.  The ones I send to him are ones that actually do have to be done.  The exception (ironically) was my SSK.  All he had to do on that was the keyboard underlay and the LED mod.  If I need it done, I will definitely go to him to do it.  He is a very meticulous person, and does it right.
Bolt modding is only necessary if the keyboard actually needs it.  That's the way I look at it.  Enjoy and use the keyboard until you actually need it done!
Offline just1n
« Reply #30778 on: Fri, 27 March 2015, 21:51:10 »
 :) 95456-0
95458-1
95460-2
Offline hwood34
  • underwater squad
  • #1 CL stan
Offline Jokrik
« Reply #30780 on: Fri, 27 March 2015, 21:59:47 »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #30781 on: Fri, 27 March 2015, 22:08:32 »
 :) (Attachment Link)
Beautiful!
What board is that? Kmac 1?
That cable is killer too...
pretty sure it's a kmac case, not sure on the PCB though
  • Frenzy Classic.
« Reply #30782 on: Fri, 27 March 2015, 22:29:28 »
Offline hwood34
  • underwater squad
  • #1 CL stan
Offline Booper
    • omniclectic.com
« Reply #30784 on: Fri, 27 March 2015, 22:43:08 »
Got a nice surprise in the mail today! My first Binge cap - Courtesy of the super awesome JoeyQuinn! The photo doesn't quite do the design justice.. it's a difficult color to photograph!
boop!
  • Frenzy Classic.
« Reply #30785 on: Fri, 27 March 2015, 22:43:14 »
Sure not KMAC.Corners is very sharp-pointed.
silver 456 then?
No, hwood. It is notched plate, pcb is quite strange even case. Maybe it is china keyboard.
Offline just1n
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #30788 on: Fri, 27 March 2015, 23:22:02 »
I like buying dumb stuff
Offline Snowdog993
« Reply #30789 on: Fri, 27 March 2015, 23:30:24 »
I sincerely sympathize with you too.  That computer is absolute torture.
Offline FoC_Tow
  • Brokehlicious
« Reply #30790 on: Fri, 27 March 2015, 23:45:15 »
Got my Six Shooter PCBs thx to bpiphany!  :)
Not today but didn't get time to take pics the last days...
Offline Snowdog993
« Reply #30791 on: Sat, 28 March 2015, 00:07:25 »
That SSK will clean up nicely.  Very nice keyboard.
Offline just1n
« Reply #30792 on: Sat, 28 March 2015, 03:26:36 »
silver 456 then?
Yes, this is the Chinese players friends of their own design case. And pcb.
I would like to redo the anode. Purple should be good.
95473-0
« Reply #30793 on: Sat, 28 March 2015, 03:36:20 »
Sky Blue ;)
Offline minhtri
« Reply #30794 on: Sat, 28 March 2015, 03:40:34 »
Come back home and receive this  ;D ;D ;D
My topre collection
« Reply #30795 on: Sat, 28 March 2015, 03:42:03 »
My topre collection
Whoaaaaaaaa
  • Frenzy Classic.
« Reply #30796 on: Sat, 28 March 2015, 03:50:19 »
silver 456 then?
Oh awesome. I guessed exactly  :eek: I am genius? :p
Offline Ngt
« Reply #30797 on: Sat, 28 March 2015, 04:25:07 »
My topre collection
Show us that HiPro!
Offline minhtri
« Reply #30798 on: Sat, 28 March 2015, 06:08:21 »
Show us that HiPro!
i bought it 1 year ago
here is my old pic when it delivered that day
Offline strict
  • TKL Zealot
« Reply #30799 on: Sat, 28 March 2015, 06:46:26 »
My topre collection
Nice! I love that red and grey color combo!
