Author Topic: What did you get in the mail today?  (Read 25781516 times)
0 Members and 10 Guests are viewing this topic.
Offline baldgye
  • Will Smith Disciple
« Reply #5250 on: Thu, 07 March 2013, 17:00:53 »
Potato!
P1 Purple gamer set.
are those CC wasd/arrow clusters?
Offline Tarzan
  • formerly known as Greystoke
« Reply #5251 on: Thu, 07 March 2013, 17:01:55 »
greystroke, the transformer like object is most likely a solenoid (like in a doorbell) to generate a noise when keys are pressed.
I should post pictures of my hall effect keyboard with tripleshots here sometime.
I was thinking it looked like a doorbell transformer, couldn't figure out why a keyboard would need one!  Took off a couple of the key-switch blanks, looks like watch batteries under each port.  Those must be the magnets for each sensor.
15173-0  15175-1
Now all I've got to do is figure out an adapter for a 24-wire (I counted...) cable connector, some sort of interface to deal with the undoubtedly custom key codes, and I'll have a state-of-the-art 1987 91-key keyboard.  Yeah, this is going to be a project, all right.
Heh!
Edit: Looking up Key Tronic turned up the following Wiki entry;
"In 1978, Key Tronic Corporation introduced keyboards with capacitive-based switches, one of the first keyboard technologies to not use self-contained switches. There was simply a sponge pad with a conductive-coated Mylar plastic sheet on the switch plunger, and two half-moon trace patterns on the printed circuit board below. As the key was depressed, the capacitance between the plunger pad and the patterns on the PCB below changed, which was detected by integrated circuits (IC). These keyboards were claimed to have the same reliability as the other "solid-state switch" keyboards such as inductive and Hall-Effect, but competitive with direct-contact keyboards. "
So, not Hall-Effect, after all...  Hrm.  The investigation continues.
« Last Edit: Thu, 07 March 2013, 17:09:00 by Greystoke »
Offline Turbo Slaab
« Reply #5252 on: Thu, 07 March 2013, 17:22:12 »
Looking for CC's!
Offline electrogeek007
« Reply #5253 on: Thu, 07 March 2013, 17:55:53 »
Received the Choc Mini and Rebel 1.2 modifier kit that I purchased from Calavera.  :D Pictures were taken with the best quality potato I could find.
« Reply #5254 on: Thu, 07 March 2013, 18:02:52 »
Unf, dat poker is so hot. Loving the pink/purple LEDs. And are those clears or whites?
Clears w/gold 62g springs. Now all I need is a set of something Imsto thick PBT :)
I'm typing on some now, they're amazing. And you should post pics of the board with your caps and everything else when its complete!
Potato!
WIKI DAT ****! We need more gamer sets, we have Gupgup's set, so now P1 Purple to add to the mix! (if you have access to a bit better camera, that'd be nice, but I'm not picky! Beggars can't be choosers! :P)
I was going to, but I'm having technical difficulties with my camera at the moment. The lens won't retract and an error pops up when I turn it on. As soon as I figure that out, I'll send the pics.
Thank you! :D
Offline Turbo Slaab
« Reply #5255 on: Thu, 07 March 2013, 18:20:47 »
No doubt!
Looking for CC's!
Offline Lunartuna
  • Good bye money!
« Reply #5256 on: Thu, 07 March 2013, 18:22:12 »
   ;D
Shine 2 TKL - Choc Mini
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #5257 on: Thu, 07 March 2013, 18:51:45 »
March Keys (double shot PBT) and Center Stem Step Cap Lock from Tech Keys
Also White on Black double shots earlier this week
Offline sleepy916
« Reply #5258 on: Thu, 07 March 2013, 19:10:56 »
Rubber feet for my Model F.  :D
Offline orlando
« Reply #5259 on: Thu, 07 March 2013, 20:02:18 »
Just received my green WASD from EK and a MiMic cable to match.  ;D
Now waiting for my Limited Pure from Mechanicalkeyboards ...
Offline baldgye
Offline Muffet
  • Man of many paths
« Reply #5261 on: Thu, 07 March 2013, 20:15:28 »
Package from a fellow GH member today, must say I am in love with this new mouse.
     Painted QFR    Cherry ML for Work
Offline LastAndroid
« Reply #5262 on: Thu, 07 March 2013, 21:00:09 »
I received my first custom keycaps from TechKeys. They look great in person.
15184-0
Still waiting for 1saleaday to ship my Trigger, it's already been more then 2 weeks.
Offline Turbo Slaab
« Reply #5263 on: Fri, 08 March 2013, 06:24:10 »
Looking for CC's!
Offline deSheol
  • Thorpe
« Reply #5264 on: Fri, 08 March 2013, 08:00:17 »
Offline baldgye
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5266 on: Fri, 08 March 2013, 12:29:00 »
GMK samples :)
Offline baldgye
« Reply #5267 on: Fri, 08 March 2013, 12:30:12 »
holy ****, that teal.... THAT PINK....... MMMIIIIAAAAAAAMMMMMMIIIIIIIIIIIIIII!!!!!!!!
Offline esoomenona
  • Gnillort?
« Reply #5268 on: Fri, 08 March 2013, 12:30:44 »
I just got something from lysol's mail
Offline blueasjim
« Reply #5269 on: Fri, 08 March 2013, 12:31:07 »
I really like that purple and pink. :D
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
Offline rknize
    • metaruss
« Reply #5270 on: Fri, 08 March 2013, 13:15:58 »
Just in time for Easter?
Russ
Offline Michael
  • Formerly Bro Caps
« Reply #5271 on: Fri, 08 March 2013, 13:17:10 »
« Reply #5272 on: Fri, 08 March 2013, 13:19:16 »
DOUBLE THE **** YEAHHH!!!!
Revive it *****es!!!!
« Reply #5273 on: Fri, 08 March 2013, 13:21:07 »
LOL. I laughed aloud at work. :P
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5274 on: Fri, 08 March 2013, 13:21:26 »
GMK samples :)
On a scale of 1-10 of how much I hate you
 it's hitler
Offline esoomenona
  • Gnillort?
« Reply #5275 on: Fri, 08 March 2013, 13:22:53 »
Offline missalaire
  • Great Finder of Great Finds
« Reply #5276 on: Fri, 08 March 2013, 13:29:02 »
Ducky DK9087G2 PRO TKL PBT Keyboard (Brown Cherry MX)
Vortex PBT Dye Sub Black on Black keyset
Offline calavera
« Reply #5277 on: Fri, 08 March 2013, 13:39:37 »
ahhhhhhhhhhhhhhh yeahhhhhhhhhhhhhhhhhh
Offline SmallFry
« Reply #5278 on: Fri, 08 March 2013, 13:42:43 »
D'aw YEAH! ALPS!
Offline calavera
« Reply #5279 on: Fri, 08 March 2013, 15:22:37 »
Offline Gupgup
« Reply #5280 on: Fri, 08 March 2013, 15:31:13 »
15265-0
15267-1
15269-2
Got the Topre Prototype keychain in the mail! Looks amazing, and it is my first topre key ever typed on, it feels even more amazing! I must have a topre board NOW! :p
Thanks kmiller!
Offline lazerpointer
  • ya gotta stay phresh
« Reply #5281 on: Fri, 08 March 2013, 15:52:19 »
Looking good! Excited for the clear ones!
i type, therefore i geekhack
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #5282 on: Fri, 08 March 2013, 16:04:39 »
Offline stilus
« Reply #5283 on: Fri, 08 March 2013, 16:19:51 »
Aww yiss
First mech w/ blues
Das Model S Professional (mx browns) | Magicforce 68 (outemu blues)
Offline L4yercake
« Reply #5284 on: Fri, 08 March 2013, 16:37:41 »
Today wasn't a great day. I purchased a HHKB a couple days ago because I wanted to be a Topre fanboy but I guess its just not meant to be  :'( Maybe one day...
Offline L4yercake
« Reply #5285 on: Fri, 08 March 2013, 17:25:10 »
edit: these just arrived from feng
Offline Tarzan
« Reply #5286 on: Fri, 08 March 2013, 17:28:24 »
Unicomp Model M and Magitronic FK-2001 (clicky white Alps).  Apologies in advance for the cell phone pics!
15272-0
15274-1
Some double-shot goodness on those Alps key-caps!
15276-2  15278-3
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #5287 on: Fri, 08 March 2013, 17:51:13 »
From my monthly, oh jeebus I hope I can keep it to only being once a month, TechKeys.us purchase.
Offline ValerieV
« Reply #5288 on: Fri, 08 March 2013, 17:53:19 »
I just got an Apple Bus keyboard with the orange alps. I love the compact style and the sound of the keys. The keyboard is in near mint condition. It's probably the best keyboard i have ever typed on. I love it!!!   ;)
Offline calavera
« Reply #5289 on: Fri, 08 March 2013, 18:02:28 »
D'aw YEAH! ALPS!
Look lighter than ALPs, Monterey?
Hell no, thats the sunlight. It's complicated blue alps.
This is monterey I believe.
« Last Edit: Fri, 08 March 2013, 18:04:39 by calavera »
« Reply #5290 on: Fri, 08 March 2013, 18:02:42 »
Deeze goodies. GH Feb Cap from Binge. Thanks again bro :D
Offline deSheol
  • Thorpe
« Reply #5291 on: Sat, 09 March 2013, 03:17:44 »
Is that a Ducky?
Offline jwaz
  • * based mod
« Reply #5292 on: Sat, 09 March 2013, 03:20:11 »
Very nice! how are they?
Offline L4yercake
« Reply #5293 on: Sat, 09 March 2013, 03:23:52 »
Is that a Ducky?
It is indeed a Ducky. YOTD Reds.
Offline FabsSpeed
« Reply #5294 on: Sat, 09 March 2013, 03:50:29 »
Got my Cheat :)
| Wanted: KMAC  & KMAC 1.2, 356 Mini, 456 GT |
Offline deSheol
  • Thorpe
« Reply #5295 on: Sat, 09 March 2013, 04:09:19 »
« Reply #5296 on: Sat, 09 March 2013, 14:20:07 »
Yesterday, but I got the most wonderful items inside a package!! Alas, it does remind me of the fountain pens and ink I ordered online about a month ago, that are yet to arrive...:( **** it though! Just morph into a dragonzord and **** **** up!
« Last Edit: Sat, 09 March 2013, 14:22:58 by Halverson »
« Reply #5297 on: Sat, 09 March 2013, 14:20:36 »
Ok those are really big.....wth imgur! All is well, bah.
« Last Edit: Sat, 09 March 2013, 14:23:18 by Halverson »
« Reply #5298 on: Sat, 09 March 2013, 14:24:10 »
Nice handwriting and drawings haha
Offline rknize
    • metaruss
« Reply #5299 on: Sat, 09 March 2013, 14:34:17 »
You can just set the width, if you don't want to deal with figuring out the full dimensions.
Russ
