Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5668261 times)
Offline jil_jil32
  • Tokyo Press <3
« Reply #4500 on: Thu, 25 July 2013, 00:56:09 »
Added a home made sand cast cap to my QFR:
Unique :D
« Reply #4501 on: Thu, 25 July 2013, 01:24:35 »
That actually look s surprisingly good! :)
« Reply #4502 on: Thu, 25 July 2013, 02:20:57 »
Thanks.  I've been trying to figure out ways of getting a good sand cast since I love the way it looks.
Offline rurushu
« Reply #4503 on: Thu, 25 July 2013, 02:23:37 »
My first time ever soldering, desoldering, opening switches, lubing switches, swapping springs, taking keyboard out of case... everything went smoothly!
wow... that is one hell of a smooth ride for a first timer!!!! congrats!!! and they look good too!!!  ;)
Offline Grim Fandango
« Reply #4504 on: Thu, 25 July 2013, 02:57:21 »
Looks like a sponge. Looks good with the blue though.
Offline iAmAhab
  • Established member
« Reply #4505 on: Thu, 25 July 2013, 08:30:25 »
Finally got around to modding my off centered caps lock and added it to my poker:
Moved the stem and placed it "at center" by free hand, turned out pretty good
Sure is nice when everything is matching, the cap is sitting a bit to high for that row because there is glue inside the stem that is blocking the switchstem.
Does not bother me to much as the "A" key is also the wrong profile for some odd reason and it matches that one.
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #4506 on: Thu, 25 July 2013, 12:51:44 »
nice mod sir  :)
Offline codyeatworld
« Reply #4507 on: Thu, 25 July 2013, 12:57:24 »
Assembled my LZ-GH finally! I would of took more pics but I didn't have my phone at the time.
The workstation.
I lubed and stickered vintage blacks from whiskeytango.
And serval hours later....
Offline Michael
  • Formerly Bro Caps
« Reply #4508 on: Thu, 25 July 2013, 12:58:30 »
Is that the new ultra translucent space bar I have been hearing about?
Offline Tym
« Reply #4509 on: Thu, 25 July 2013, 13:02:21 »
HueHueHue :))
« Reply #4510 on: Thu, 25 July 2013, 13:04:06 »
Yeah but its MX only! hehe
Offline cyberwave
« Reply #4511 on: Thu, 25 July 2013, 14:40:04 »
not added but removed from my keyboard  :))
adding would be another time (hopefully tmr if i can find time :)
Filco MJ1
« Reply #4512 on: Thu, 25 July 2013, 21:30:15 »
Done
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #4513 on: Thu, 25 July 2013, 21:34:36 »
Done
Nice :) soldering is fun stuff :)
« Reply #4514 on: Thu, 25 July 2013, 21:36:22 »
Done
Awesome! Now Elton can have multicolored LEDs to go with his multicolored key caps!
Offline oaklandishh
« Reply #4515 on: Thu, 25 July 2013, 21:49:57 »
I could hang that on my wall as art :o
Offline Michael
  • Formerly Bro Caps
« Reply #4516 on: Thu, 25 July 2013, 21:58:53 »
Offline domoaligato
« Reply #4517 on: Thu, 25 July 2013, 22:09:07 »
29444-0
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #4518 on: Thu, 25 July 2013, 23:05:22 »
« Reply #4519 on: Thu, 25 July 2013, 23:06:28 »
That has to be one of the hardest to read gifs I've ever seen.
Offline elton5354
« Reply #4520 on: Thu, 25 July 2013, 23:11:54 »
Ya'll like?
Offline naokira
  • The King in the North
« Reply #4521 on: Fri, 26 July 2013, 03:49:17 »
Russian Dyesub from Zenuty!
29455-0
Thanks for the goodies man!
29457-1
« Last Edit: Fri, 26 July 2013, 03:52:40 by naokira »
FaceW in LZ-CE
Offline iAmAhab
« Reply #4522 on: Fri, 26 July 2013, 04:25:58 »
Those strawberry crackes are of the chain son!
Offline naokira
« Reply #4523 on: Fri, 26 July 2013, 04:29:53 »
It taste so good I want more. Gotta find a Korean grocery store here!
FaceW in LZ-CE
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #4524 on: Fri, 26 July 2013, 04:38:45 »
Nice job, looks sweet :D
Offline zenuty
« Reply #4525 on: Fri, 26 July 2013, 06:48:40 »
I Saw Cute Princess  :-*
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline tadbitnerdy
« Reply #4526 on: Fri, 26 July 2013, 07:00:02 »
Done
« Reply #4527 on: Fri, 26 July 2013, 08:29:06 »
This makes everything better.  ;D
Offline jil_jil32
  • Tokyo Press <3
« Reply #4528 on: Fri, 26 July 2013, 08:58:47 »
Agree!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4529 on: Fri, 26 July 2013, 09:04:20 »
Some red stems to my $14 franken-dolch. I also modded the cherry PCB mount stabilizers
Offline baldgye
  • Will Smith Disciple
« Reply #4530 on: Fri, 26 July 2013, 09:58:34 »
really like that mod, did you use a guide you could link me too?? I want to do the same thing with the purple stepped caps lock I have
« Reply #4531 on: Fri, 26 July 2013, 13:27:21 »
Offline Photoelectric
« Reply #4532 on: Fri, 26 July 2013, 13:52:16 »
Haha, nice piano look :D  Great idea!
Offline iAmAhab
« Reply #4533 on: Fri, 26 July 2013, 14:20:15 »
I did have a look at this by ripster: http://imgur.com/a/3mWPe, but I ended up doing quite differently.
I reused the stem from the actual caps lock, used a small piece of a razor to get it loose. Unfortunately I didn't manage to perfectly retain the angle of the stem, but some extra glue fixed that.
Opted to not use a jig because I was to lazy to make one and just placed the stem by free hand. Used cyanoacrylate to glue it in place, not really optimal for this application, but it was what I had available.
If you are feeling very confident you could use pure acetone to meld the pieces together permanently assuming that the cap is made out of abs plastic.
Offline Neal
  • Skype: iNewbcake
« Reply #4534 on: Fri, 26 July 2013, 15:13:55 »
I added a few key caps, just a few...
« Reply #4535 on: Fri, 26 July 2013, 15:29:54 »
I want the pink ones.
That looks like you got a big ole bag o' crap.
Offline baldgye
« Reply #4536 on: Fri, 26 July 2013, 15:54:50 »
you used a razor blade to cut the stem from its original cap?
Offline iAmAhab
« Reply #4537 on: Fri, 26 July 2013, 16:24:13 »
Yup, the old school type you use to line up cocaine or cut your wrists with. Had to modify it a bit to make it fit inside the cap, then I used a plier and pushed it through the base of the stem. It was not like a hot knife through butter, but manageable. Would probably be a lot easier to just harvest a stem from another cap, I just ocd'ed a bit and wanted to use the original one.
Offline Xenderwind
« Reply #4538 on: Fri, 26 July 2013, 16:25:51 »
Got some mail today.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline baldgye
« Reply #4539 on: Fri, 26 July 2013, 16:26:15 »
Alright then, cheers :)
Offline calavera
« Reply #4540 on: Fri, 26 July 2013, 18:41:13 »
Offline Sniping
« Reply #4541 on: Fri, 26 July 2013, 18:42:00 »
Man the skullsicle looks nice.
Offline Ultratude
    • Ultratude's Blog
« Reply #4542 on: Sat, 27 July 2013, 02:10:40 »
« Reply #4543 on: Sat, 27 July 2013, 03:40:04 »
You buried your keyboard!!
« Reply #4544 on: Sat, 27 July 2013, 06:59:21 »
I think it's like one of those spa treatments when they cover the body in towels and mud or whatever it comes out renewed and refreshed!! ;)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #4545 on: Sat, 27 July 2013, 07:38:53 »
LOL. Spa for keyboard.
« Reply #4546 on: Sat, 27 July 2013, 08:31:01 »
29574-0
Offline Dubsgalore
« Reply #4547 on: Sat, 27 July 2013, 10:46:14 »
congrats calavera!!
looks better then i originally thought ;)
Offline GeorgeK
« Reply #4548 on: Sat, 27 July 2013, 12:31:14 »
Been having a bit of a switch around...  Apologies for the crap photos - post wedding / honeymoon I'm going to get some decent photos of all of my stuff - might even cobble together a ghetto light box for the occasion :D
Also the novelties collection has grown :D
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #4549 on: Sat, 27 July 2013, 16:11:23 »
George -- what case if your Poker in? It looks fantastic!
