Author Topic: Post your Poker!  (Read 1373298 times)
Offline KH
    • My fotki pics
Re: Post your Poker!
« Reply #2700 on: Tue, 24 February 2015, 10:54:07 »
Extra grainy just for hoffman, gotta reshoot had the wiggles!
Damn. I fell in love. :confused:
Offline Gordy
« Reply #2701 on: Tue, 24 February 2015, 13:52:58 »
A quick pic of my Poker II as it stands now.
Nice! The red space looks surprisingly good. Red alucase would look good in this. :rolleyes:
I'm wanting to get an alucase at some point.
Offline wlhlm
« Reply #2702 on: Tue, 24 February 2015, 15:44:36 »
Hi, I got a suggestion in the newbie section to post here, so here you go: my first mechanical keyboard.
With Ergo Clears. Here is a "mod log" (WARNING!! SHOE INSIDE).
Offline Tyrosh22
« Reply #2703 on: Tue, 24 February 2015, 15:49:37 »
Nice job, the keyboard looks great. Nice to see that you went straight for modding your board. :)
Meow.
Offline wlhlm
« Reply #2704 on: Tue, 24 February 2015, 15:50:49 »
Or I just became mad while lurking ;).
Thank you.
Offline Ngt
« Reply #2705 on: Tue, 24 February 2015, 15:54:16 »
Nice work. Damn I bought mecklube 2 for the same reason. I thought it was a good lube for it. I'm disappointed :'(.
How was your first desoldering operation? Was it hard to do?
Offline wlhlm
« Reply #2706 on: Tue, 24 February 2015, 16:06:31 »
I did some desoldering before, so I already had the right tools, but the work on the keyboard itself was pretty intensive since I got a board with LEDs and so I had to desolder them first. LEDs are heat sensitive and so I was worried about damaging them, but it all turned out fine.
Conclusion: I really like the Ergo Clears, but I hope that someday there would be a switch with the same characteristics directly from a manufacturer, to save me some labor.
Offline Ngt
« Reply #2707 on: Tue, 24 February 2015, 16:30:20 »
If you went on desoldering all the LED, you could have SIP socket them as well.
Maybe Gateron hears your prayers.
Offline wlhlm
« Reply #2708 on: Tue, 24 February 2015, 16:32:56 »
I heard that Greetech Browns (like the ones on the Das 4C) are more tactile than MX Browns.
Offline Ngt
« Reply #2709 on: Tue, 24 February 2015, 16:34:02 »
Never heard of Greetech. What does more tactile mean? More tactile like Clear or something in between browns and clear?
Offline wlhlm
« Reply #2710 on: Tue, 24 February 2015, 16:45:37 »
AFAIK, the 4C currently is the only keyboard with Greetech switches.
Source: WARNING!! - RIPSTER CONTENT
Ripster did a review of the Das 4C. And I asked him, no definitive answer though.
Offline Ngt
« Reply #2711 on: Tue, 24 February 2015, 16:47:12 »
Thanks for the links. At least his review looks pretty thorough.
Offline KH
    • My fotki pics
« Reply #2712 on: Tue, 24 February 2015, 22:45:04 »
Cool, I like you modded it straight away. Like the caps also. :cool:
Offline wlhlm
« Reply #2713 on: Wed, 25 February 2015, 01:53:13 »
Thank you!
Offline hking0036
« Reply #2714 on: Sat, 28 February 2015, 14:03:36 »
mmm, potato.
62g ergo clears got here today, may well be the best thing ever. Thanks to drhubblephd for free mods :D
Out of the Vault Series 2 and Noxious BBV2 coming.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline NotAPrune
  • Switch Racist
« Reply #2715 on: Sun, 01 March 2015, 03:51:19 »
So in a recent Massdrop I finally took the plunge and bought a keyboard I have wanted in my collection for a long time, a KBC Poker II.
The particular variant going was a white one with MX Clear switches which isn't really to my liking, but the time was right, the price was right so I bought it anyway. It arrived this week and as soon as I picked it up yesterday I set about modding it. Instead of buying new key caps right away I decided to try an experiment instead. So I ran out and bought 2 cans of Plasti-Dip. One in red for the keycaps and one in anthracite for the case. I have been wanting to try Plasti-Dip on something for a while and figured this was a good enough excuse to do it.
So I set about pulling the keyboard apart and used double sided tape to stick the keys down on some cardboard. I also tried this with the case, but realised I would be missing the top lip of the case that way so I made a little X bipod out of cardboard to suspend it up in the air a bit so I could spray all the surfaces needed (Not pictured, sorry). I made sure to put some tape over the threaded screw holes inside the case however so that they didn't get all filled up.
For my thoughts and observations on the process. I am very happy with how the colours of the keyboard came out now that it's all together, but as you can see in some of the last pictures, the edges on the bottoms of the keycaps isn't all that great after being pulled from the cardboard. In the future I would get a bunch of switch stems and glue them to a wooden board to allow the bottom edges of the keycaps to remain suspended in the air, I would also space them out more so it's easier to get the needed coverage per keycap without adjacent ones blocking the spray.
Another thing I was really curious about was how Plasti-Dip would feel on the keycaps while typing. It has a sort of rubbery feeling that is quite grippy, very different to plain keycaps. Also, with all this Plasti-Dip on them the keycaps are really quiet now, they almost seem to reduce the sound of the rebound on the key after hitting it, one of the shortcomings of O-rings. I have a couple of sample O-rings in a box somewhere, I might have to get them out and see how it sounds with reduced compression and rebound noise. :D
Future Plans - I would like to do either Ergo Clear modded switches or convert them to blues. I'm also probably going to pick up a low profile aluminium case for it.
« Last Edit: Sun, 01 March 2015, 03:57:56 by NotAPrune »
I came to chew keycaps and ask dumb questions, and I'm all out of keycaps.
Offline heedpantsnow
  • Old enough to know better
« Reply #2716 on: Sun, 01 March 2015, 07:23:20 »
Cool, thx for sharing!  How long do you think the finish will last?
I'm back.
Offline Fnzzy
« Reply #2717 on: Sun, 01 March 2015, 08:42:32 »
Holy crap, your desk has such an amazing color and pattern!  :eek: Nice keyboard as well of course.  :rolleyes:
Offline wlhlm
« Reply #2718 on: Sun, 01 March 2015, 08:59:14 »
It's printed chipboard I found in a corner of my dad's carpentry.
Bonus image:
Offline Vibex
  • Love y'all
« Reply #2719 on: Sun, 01 March 2015, 12:45:29 »
****, I really thought that the toxic set was pretty ****ty when it was in GB (no offense, I'm just not usually fond of that color green), but it looks fantastic in that pic.
Offline NotAPrune
  • Switch Racist
« Reply #2720 on: Sun, 01 March 2015, 17:08:07 »
I have no idea honestly. I've never used Plasti-Dip before and have been wanting to try it. This is really just a big experiment for me haha. I'm using it as my daily driver at work so it should see some good use and I'll try remember to report back in a couple of months on how it's holding up.
Offline snipars
« Reply #2721 on: Sun, 01 March 2015, 19:12:55 »
that's the nicest-looking green keyboard i've ever seen
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Offline ghostjuggernaut
« Reply #2722 on: Sun, 01 March 2015, 21:42:19 »
I've heard that plasti-dip does not stand up well to the oils in your skin. Most people say that after a week it begins to wear off. Hopefully it works well for you.
Offline NotAPrune
  • Switch Racist
« Reply #2723 on: Mon, 02 March 2015, 02:00:08 »
Ah, bummer. Ohwell, I'll see how it goes. I did wonder how it would stand to oils.
« Reply #2724 on: Mon, 02 March 2015, 02:53:32 »
Dat Toxic stripe though! Nice matching LEDs!
Offline kurukato
  • Cars>Keyboards
« Reply #2725 on: Mon, 02 March 2015, 23:23:05 »
Just got these in to hold me over till 1976 keys are done. Really awesome for the price.
Offline KH
    • My fotki pics
« Reply #2726 on: Mon, 02 March 2015, 23:30:33 »
Yesterday the long wait was, again, gone. Vortex alucase to Poker II. It feels sooo good!
Offline Sed8op8
  • Keyboard Padawan
« Reply #2727 on: Tue, 03 March 2015, 04:09:23 »
If you don't mind me asking where did you find the Miami blanks? Anyways looking good man!
Offline kurukato
  • Cars>Keyboards
« Reply #2728 on: Wed, 04 March 2015, 22:09:48 »
sadly not blanks. got them from the geekkeys sale.
Offline Sed8op8
  • Keyboard Padawan
« Reply #2729 on: Thu, 05 March 2015, 01:02:39 »
Hey guys and gals
Sorry about the pictures! The only camera I had available was from a freaking iPad mini  :( anyways my new Dolch DSA arrived
Offline Pemdas
« Reply #2730 on: Thu, 12 March 2015, 00:00:44 »
Just got Deep Space put on my poker and it looks amazing in person.
My package was missing a period key so tilde had to come and save the day  :))
Som artsy fartsy angled shots incoming.
« Reply #2731 on: Thu, 12 March 2015, 00:22:14 »
Looks great, what is the blue Bro? It looks like a faded Essence of Kirkle.
Offline Pemdas
« Reply #2732 on: Thu, 12 March 2015, 00:36:50 »
Yup it's an Essence of Kirkle, don't know why it looks so faded in the picture it's much bluer in real life :confused:
Offline Ngt
« Reply #2733 on: Thu, 12 March 2015, 03:28:28 »
Your poker is definitely nice. I love it. I didn't like the deep space when I saw it on the GB but once it is on a real keyboard it is really nice looking.
Offline KH
    • My fotki pics
« Reply #2734 on: Thu, 12 March 2015, 12:45:21 »
Dat Poker :-*
« Last Edit: Thu, 12 March 2015, 12:54:38 by KH »
Offline Prelim
« Reply #2735 on: Thu, 12 March 2015, 12:54:20 »
what blank keyset is that?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline KH
    • My fotki pics
« Reply #2736 on: Thu, 12 March 2015, 12:54:58 »
WASD ABS.
Offline Ngt
« Reply #2737 on: Thu, 12 March 2015, 18:39:34 »
Dat Poker :-*
That's one nice looking Poker! When I uses the LED of my poker on a WASD set they glow but not yours. Perhaps that's due to the dark color.
Offline Tyrosh22
« Reply #2738 on: Thu, 12 March 2015, 18:58:13 »
Will you be looking for a PBT set? :D
Meow.
Offline KH
    • My fotki pics
« Reply #2739 on: Fri, 13 March 2015, 01:38:21 »
Dat Poker :-*
They do glow with WASD white blanks. Black is so dark so it won't glow through, as you said.
Not for now. I haven't known what I should do with keycaps and so got white and black blanks from WASD for cheap. They're good set for the time when I get good idea for the right keycap set. I know only that, that Toxic set would be cool. :cool:
Offline Ngt
« Reply #2740 on: Fri, 13 March 2015, 03:26:59 »
Dat Poker :-*
Not for now. I haven't known what I should do with keycaps and so got white and black blanks from WASD for cheap. They're good set for the time when I get good idea for the right keycap set. I know only that, that Toxic set would be cool. 8)
Damn if I knew! Anyway I'm not using it anymore. :D
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #2741 on: Wed, 18 March 2015, 22:38:27 »
Dat Poker :-*
What case? Original?
Offline KH
    • My fotki pics
« Reply #2742 on: Wed, 18 March 2015, 23:39:18 »
Dat Poker :-*
Vortex Alucase from Pexon.
Offline janlonden
« Reply #2743 on: Sun, 22 March 2015, 20:07:16 »
Poor man's blanks:
94900-0
That's with stock key caps, sandpapered  ;D
« Reply #2744 on: Sun, 22 March 2015, 21:46:02 »
Dat Poker :-*
Nice ISO Poker!! ;)
Offline KH
    • My fotki pics
« Reply #2745 on: Sun, 22 March 2015, 23:50:53 »
Dat Poker :-*
Nice ISO Poker!! ;)
Thanks ;D
Offline Fnzzy
« Reply #2746 on: Mon, 23 March 2015, 10:54:19 »
Offline KH
    • My fotki pics
« Reply #2747 on: Mon, 23 March 2015, 12:21:38 »
Nice.  :cool: And ISO. :thumb: Would want some doubleshot keycaps. :-X Toxic set, please appear on my desk. Maybe Bumblebee would be worth considering. This blank black set is cool but backspace has minor shine. Maybe because drunk friends touched it with dirty hands, and backspace was most used key for a reason. :))
EDIT: I saw Toxic set on TechKeys.  :eek: Had to order it. :-X There's was no ISO set but going to catch it later somewhere. :'(
« Last Edit: Mon, 23 March 2015, 12:49:31 by KH »
« Reply #2748 on: Mon, 23 March 2015, 13:09:44 »
Offline janlonden
« Reply #2749 on: Mon, 23 March 2015, 13:55:56 »
Took off the rough edges and surfaces from the sanding with the help of a candle light :)
94949-0
