Author Topic: Skeldon-GH Phantom Case  (Read 71053 times)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« on: Tue, 22 January 2013, 12:56:03 »
Info:
I've always wanted a phantom with aluminum case because aluminum is just awesome :P.
My father and I started to build a case and he is doing most of the work since I'm pretty much useless in CAD -_-. With the help from The_beast, JD, and acetek we sent the top half of the case to get prototyped.
The plate design is done and prototyped has been created(Thanks bpiphany for making the original phantom plate). Current plate I have is winkeyless ANSI
We are currently working on the bottom half of the case which is almost done in CAD then needs to be 3D'ed.
Plate:
Top Case:
Bottom Case:
Testing the tolerance of the CNC shop. Everything is in .0005 to .001 which is awesome.
Color:
To do list:
Finish the bottom half of the case
Modify the plate to fix the issue removing switch top housing.
decide on 8 or 9 degree angle
« Last Edit: Wed, 10 April 2013, 14:57:54 by boost »
-Enzo Ferrari
Re: Skeldon-GH Phantom Case
« Reply #1 on: Tue, 22 January 2013, 12:58:36 »
Awesome work!! Props to everyone involved in this!
Will this case work with the current GB for phantom plates? Or a new custom plate design? Err after looking at the case, I guess it will only fit the new plate due to a few things.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Tue, 22 January 2013, 12:59:42 »
So the plate is being screwed to the top of the case?
If you need anything else, you know who to call. I should have a bit of free time at the beginning of the semester if you need a bit of design help
Offline djmattm
« Reply #3 on: Tue, 22 January 2013, 12:59:56 »
Amazing project!!
Razer BlackWidow Tournament Stealth Edition
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #4 on: Tue, 22 January 2013, 13:00:26 »
It will not work since the plate will bolt onto the bottom half of the case.
Don't worry, case will come with plate :)
-Enzo Ferrari
« Reply #5 on: Tue, 22 January 2013, 13:01:36 »
The question is, should I cancel my phantom plate order now? hehe. Hate to ask so early, but any potential cost/eta of finish?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Tue, 22 January 2013, 13:02:45 »
Those are screw head clearance holes.
Filco w/ Imsto thick PBT
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Tue, 22 January 2013, 13:03:10 »
^^^ I see it now
I can always run a bro a plate. However it will be lister style, not WFD
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #8 on: Tue, 22 January 2013, 13:03:16 »
I don't you should cancel your plate order.
Got a rough guess and don't hold me to this but looking at $200-$300 for case/plate
-Enzo Ferrari
« Reply #9 on: Tue, 22 January 2013, 13:06:02 »
Thanks Beast :D
Ahh yea small run aluminum wouldn't be cheap. May have to suffice with my cardboard/duct tape case for now. Specially with so many metal boards in the upcoming times. MKC/LZ specifically.
Offline rknize
    • metaruss
« Reply #10 on: Tue, 22 January 2013, 13:09:55 »
Looks good so far.  We really could use some high-end cases here on GH to rival those from across the pond(s).
Russ
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #11 on: Tue, 22 January 2013, 13:10:09 »
Added pic of the color.
-Enzo Ferrari
« Reply #12 on: Tue, 22 January 2013, 13:11:47 »
Will this baby be easy to re-anodize from that colour? Well not easy, but a viable option.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Tue, 22 January 2013, 13:18:46 »
re-anodizing should be easy since the first step is typically stripping/cleaning the metal in a bath anyways
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Tue, 22 January 2013, 13:20:38 »
Making these bolt head clearance in the top seems over complex. I would just make a threaded hole in those locations and pass bolts through the bottom piece and the plate (could thread those holes too for added lock in) into the threaded top. It would sandwich in the plate and fasten the top and bottom all at once.
Offline 4LI4Z
« Reply #15 on: Tue, 22 January 2013, 13:22:03 »
Looks good. But for me there's one question, do you think you could also make a Filco compatible version of this? It would be a dream if there was a universal aluminium case.
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #16 on: Tue, 22 January 2013, 13:31:04 »
IMO, you'll just need a new plate which can be made(Maybe like $30 for a 1off plate). Something I will look into
-Enzo Ferrari
Offline nebo
« Reply #17 on: Tue, 22 January 2013, 13:31:17 »
I'm a huge fan of the color. Any idea how thick the top cover will be and if you would allow for user submitted plates? Really want a nice case with the 5 keys opened up. I'd be fine hacking the cover myself it it is thin enough.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #18 on: Tue, 22 January 2013, 13:33:32 »
just chopping off the 1.x block and making a new plates will make this open to all the layouts
-Enzo Ferrari
Offline nebo
« Reply #19 on: Tue, 22 January 2013, 13:40:59 »
Thanks, though I'd keep the 1x block. I'm stupid about what keys I want. :D
« Reply #20 on: Tue, 22 January 2013, 13:42:19 »
Exactly. Modular case design. If you wanted, when you start taking orders for these, you could offer different top case and plates for different layouts. For example, a top case with no 1x tabs, the area between the cursor arrows and the six pack cut out, and a fully open f-row. That with a Prof plate would be an appealing option. Not sure how complicated you want to get with ordering options. :)
Offline alaricljs
« Reply #21 on: Tue, 22 January 2013, 13:43:36 »
The issue being the cost of low Q runs.
Offline nebo
« Reply #22 on: Tue, 22 January 2013, 13:47:39 »
Note: I know nothing about CNCing
I wouldn't imagine using the same overall layout but removing straight cuts could change the cost all that much. At least for the case. Since this isn't compatible with the other plates that would add a bit.
« Last Edit: Tue, 22 January 2013, 13:49:23 by nebo »
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #23 on: Tue, 22 January 2013, 13:49:53 »
way too many options to hit the MOQ -_-
Top case will be with or without block and 3-5 different plate designs
-Enzo Ferrari
Offline The_Beast
  • I like wood ಠ_๏
« Reply #24 on: Tue, 22 January 2013, 13:50:57 »
The base should be the same, two tops (one with blocks, one without) and however many plate designs their are
Offline rknize
    • metaruss
« Reply #25 on: Tue, 22 January 2013, 13:52:08 »
It just depends on how the shop charges for it.  It would use the same fixture.  Just a modified path.  For what it will cost, I probably would pass if 86 key was not an option.  The plate has holes for meta, so it's just the top cover.
Russ
Offline rknize
    • metaruss
« Reply #26 on: Tue, 22 January 2013, 13:53:01 »
Perfect.
Russ
Offline 4LI4Z
« Reply #27 on: Tue, 22 January 2013, 13:53:08 »
Great! A friend of me got a small CNC mill, he could produce a plate for me. But would the higher controller of a Filco be no problem? Also, dou you plan to have ISO layout available?
« Reply #28 on: Tue, 22 January 2013, 13:56:31 »
Would love a no space F row top case, that would be hawt :)
Don't listen to me,. simple is best hah
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #29 on: Tue, 22 January 2013, 13:58:08 »
Yay~
Offline nebo
« Reply #30 on: Tue, 22 January 2013, 13:58:59 »
Perfect.
By block are we referring to the 5key block or the winkey block?
We have dremels....
Also, on price, $300 is still good IMO with the few layout offerings and being block cut.
« Last Edit: Tue, 22 January 2013, 14:01:13 by nebo »
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #31 on: Tue, 22 January 2013, 14:01:04 »
Winkey blocks
Offline nebo
« Reply #32 on: Tue, 22 January 2013, 14:06:25 »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #33 on: Tue, 22 January 2013, 14:09:48 »
Winkey blocks
Please, for the love this puppy make the 1x blockers integrated into the case. Not like the Kmac 2
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #34 on: Tue, 22 January 2013, 14:10:41 »
The plates are laser cut not CNC and plate will need to have the controller cutout
-Enzo Ferrari
Offline WhiteFireDragon
    • youtube
« Reply #35 on: Tue, 22 January 2013, 14:15:00 »
Nice! We finally have a TKL case in the works. This time, it looks like it'll actually come through production phase. Just make sure for the bottom piece, the controller area is a recessed cut to fit the teensy.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #36 on: Tue, 22 January 2013, 14:17:08 »
As shown in the pics boost posted, WKL layout top cover will be integrated into the case ;D But outside of WKL and WK top cover options, I don't think any other top cover cases are being considered right now. The problem lies in hitting the MOQ for each different options.
Offline 4LI4Z
« Reply #37 on: Tue, 22 January 2013, 14:22:16 »
Nice, can't wait for it.  :p
Offline korne
    • comscan
« Reply #38 on: Tue, 22 January 2013, 15:08:39 »
I'm in :P
Offline AKIMbO
  • HHKBro
« Reply #39 on: Tue, 22 January 2013, 15:09:40 »
OMG...take my money....all of it.
Winkey blocks
Yes, please!  I hate the KMAC 2 look.  Also, cute puppy!
« Last Edit: Tue, 22 January 2013, 15:19:44 by AKIMbO »
| KBD75 (box reds)
Offline rindorbrot
AW: Skeldon-GH Phantom Case
« Reply #40 on: Wed, 23 January 2013, 00:45:36 »
Want Alu case!
Hoping for many plate options. ISO 1.5x and short right shigt ftw.
Offline KuhnTang
  • Game of Thrones
« Reply #41 on: Thu, 24 January 2013, 12:57:12 »
Just to be perfectly clear.  If we want this case we SHOULD cancel our plate orders with prof? (yes | no)
Thanks
Offline The_Beast
  • I like wood ಠ_๏
« Reply #42 on: Thu, 24 January 2013, 12:59:01 »
yes
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #43 on: Thu, 24 January 2013, 13:05:56 »
Thanks
umm, the plate i'm using will not fit in the OEM filco case.
Don't have an ETA on this project right now, it might be 1-4 months before I get a complete prototype.
-Enzo Ferrari
Offline KuhnTang
  • Game of Thrones
« Reply #44 on: Thu, 24 January 2013, 13:06:25 »
I forgot, one last question.
What about the switches from prof.  Are we still good there with the plate mount switches?
« Reply #45 on: Thu, 24 January 2013, 13:08:00 »
Phantom PCB has no holes for PCB mount switches, so plate mount is your only option.
Offline alaricljs
« Reply #46 on: Thu, 24 January 2013, 13:08:43 »
Or PCB mount and some personal time with flush cutters.
Offline KuhnTang
  • Game of Thrones
« Reply #47 on: Thu, 24 January 2013, 13:09:26 »
Thank you as always jdcarpe
Offline inteli722
« Reply #48 on: Thu, 24 January 2013, 15:58:37 »
Perfect.
Just to be clear, this means the block between the Delete Block and the Inverted-T keys?
I think the winkeyless boards look cool, and they have a certain flow going for them, but I use the left windows key a lot to turn off my computer (LWinKey then right arrow then enter), and I do enjoy the menu key...
Waiting for: Phantom Plate
Offline alaricljs
« Reply #49 on: Thu, 24 January 2013, 16:04:24 »
To be clear, this means with or without 1x winkeys in the bottom row.  And the "with winkey" version can then be used for 1.25x mods as well.
