Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009029 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #10600 on: Mon, 17 November 2014, 23:38:09 »
2x3x4 is brighter and, IMO, has a better diffuse glow.  The 1.8mm has a weird heavy concentric glow with heavy falloff on the edges.  That said, both are nice, but it you want bright, 2x3x4 is the way to go.
And, for the record, I've used TA PBT, Cherry caps, and others with no issue with 2x3x4.  I think it's mainly Imsto that has issues with it.
Thanks for the reply. I will definitely go with 2x3x4 ones then :P
Gotta have max glows + pair it up with clear switch tops!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10601 on: Mon, 17 November 2014, 23:46:02 »
Use soarers on the XT or the BigFoot?  I was under the impression that it won't work on the bigfoot due to not having a controller on board.
edit: here
https://geekhack.org/index.php?topic=48950.msg1224258#msg1224258
He says he got it working with soarers.
It does not have a controller on the board but does have a thing that helps to interpret the capacitive matrix, so it was easy for him to convert.
side note: the schematic of this KB was instrumental in figuring out how to make a capacitive controller for general model F use.
edit: note this is his KB controller code, not protocol converter code.
So essentially all I need for hardware is a teensy, some wire and a cable from teensy to PC then, correct?  Just wire it up, load the firmware and away I go.  Or is it a touch more involved than that?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10602 on: Tue, 18 November 2014, 05:21:23 »
When desoldering plate mount Cherry MX switches, what's the best way to get the switches out without damaging the plate or switch housing?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline SavvyBird
  • Savvy Caps
« Reply #10603 on: Tue, 18 November 2014, 05:22:13 »
Why is the hhkb called the "happy hacking" keyboard.
hi
« Reply #10604 on: Tue, 18 November 2014, 06:16:02 »
I flip the plate over and push out the switches with my thumbs.
That's what PFU and Wada decided to name it?
Offline KeyZero
  • Lovin' clear keys
« Reply #10605 on: Tue, 18 November 2014, 08:30:16 »
For the Poker II, is it possible to map arrow keys where Right Alt/Right Win/Menu/ Ctrl is and move caps lock around? I presume other buttons like media control on my V60 (Back/Play/Pause/Forward) can be mapped as well as Print Screen and other keys too? I see there's a certain key limit but I don't think I'll hit/need that for mapping but it's good to know.
KBV60 (Clear) User
« Reply #10606 on: Tue, 18 November 2014, 08:33:34 »
To save thumbs I use a rubberized screwdriver (or other small tool) handle to push them out.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10607 on: Tue, 18 November 2014, 09:49:24 »
What about the little  plastic latches that hold the switches to the plate? Trying to pinch those in is going to scratch the top of the plate.
WTB/WTS/WTT ---->
« Reply #10608 on: Tue, 18 November 2014, 09:53:41 »
It's just pressure fit and just pops out. I've never seen damage done to the top of the plate. Also depending on the plate some switches almost fall out on there own.
« Reply #10609 on: Tue, 18 November 2014, 09:58:56 »
As Ray mentioned, a lot of plates are thick enough that those latches don't actually snap in, but I know that GON notches his plates in the back to make the plate thinner and thus allow them to actually snap in.  He also makes a neat little tool that can be used to remove switches easily.  I suspect this is what you're looking for.  If you aren't buying a keyboard from him, shipping will be really expensive, so you may have to look into building your own or some other alternative.
« Reply #10610 on: Tue, 18 November 2014, 09:59:23 »
Pinch? You just push them out. It's a press fit. I doubt that plastic will scratch the plate and I've never scratched a plate like that.
« Last Edit: Tue, 18 November 2014, 10:03:26 by CPTBadAss »
« Reply #10611 on: Tue, 18 November 2014, 10:02:25 »
Another thing to add to my list to buy one day, even though I doubt I need it. Thanks for the info Hoff, hadn't seen this before.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10612 on: Tue, 18 November 2014, 10:09:42 »
Pinch? You just push them out. It's a press fit. I doubt that plastic will scratch the plate and I've never scratched a plate likt hat.
So once the switch is desoldered it will just slide out without having to push in those plastic latches on the top side of the plate?
After I desoldered the switches those little plastic clips still held the switches in pretty strong.
WTB/WTS/WTT ---->
« Reply #10613 on: Tue, 18 November 2014, 10:11:55 »
I've desoldered at least three boards with plates now? I desolder them, separate the plate/switches from the PCB, then push all the switches out by hand. I don't pinch or push anything in terms of the switches.
What plastic latches are you referring to on the plate? Can you take a picture?
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10614 on: Tue, 18 November 2014, 10:18:28 »
Okay thanks.
I'm not separating the plate from the PCB. I'm trying to take them out one at a time right after a switch is desoldered.
WTB/WTS/WTT ---->
Offline Hzza
« Reply #10615 on: Tue, 18 November 2014, 10:29:18 »
I use an IC extractor (I think that's what the tool was called) to pull Cherry switches, using it to pop the tabs on the top/bottom of the switch and pull the switch out through the plate. I've used it on about 3 boards so far and not damaged a single plate (2x anodised Phantom plates and 1 stock Filco plate). I guess if you were worried about scratching the plate you could wrap the ends of the tool in masking tape or something? Or even mask the plate I guess.
The reason I don't poke them through the plate once the board has been desoldered anymore is that one time I put a screwdriver through the palm of my hand trying to get a particularly stubborn switch out...
edit - this is the tool I use
http://www.maplin.co.uk/p/ic-extraction-tool-fd54j
« Last Edit: Tue, 18 November 2014, 10:31:44 by Hzza »
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10616 on: Tue, 18 November 2014, 12:01:00 »
I actually think I have some of those.
Thanks for the tip.
WTB/WTS/WTT ---->
« Reply #10617 on: Tue, 18 November 2014, 12:08:31 »
I would love to hear back from you as to which method worked best for you. Just because I did it one way doesn't make that the ideal way. :)
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10618 on: Tue, 18 November 2014, 14:18:02 »
Okay, will do  :)
WTB/WTS/WTT ---->
Offline asgeirtj
« Reply #10619 on: Tue, 18 November 2014, 14:24:55 »
Is it possible to replace costar stabilizers on a board with cherry stabilizers?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #10620 on: Tue, 18 November 2014, 14:36:15 »
It might be a little hard. Jdcarpe has custom plates which have both the Costar and Cherry stabilizer holes. The Costar slots are a bit thinner and longer than the Cherry ones. If you could weld/epoxy enough material for the stabilizers to sit in, you might be able to do it. I'm leaning towards a probably not worth the time but it's definitely possible.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10621 on: Wed, 19 November 2014, 02:58:19 »
Well I did happen to have an old IC extractor, and I have to say it was the easiest method for me.
I just couldn't get the switches to pop out with out pressing those little plastic tabs that secure them to the plate.  I probably could have, but I didn't feel comfortable using that much force.
Still ended up getting a few scratches on the top of the plate though.
WTB/WTS/WTT ---->
« Reply #10622 on: Wed, 19 November 2014, 06:19:46 »
I still don't understand what plastic tabs you're referring to. Did you happen to take a picture?
Offline Hzza
« Reply #10623 on: Wed, 19 November 2014, 06:25:29 »
Above the "Cherry" logo and below the LED slot on the sides of the switch are 2 little plastic tabs that click into (I think) 1.6mm thick plates to hold the switches in place.
You can see the front one in that picture.
« Reply #10624 on: Wed, 19 November 2014, 06:31:12 »
Ohhh, you mean those little legs that you solder into the PCB?
Offline Hzza
« Reply #10625 on: Wed, 19 November 2014, 07:11:38 »
Nope, circled.
82125-0
« Reply #10626 on: Wed, 19 November 2014, 07:18:19 »
Nope, circled.
Huh...I've never had a problem with those. That's interesting though. Thanks Hzza.
« Reply #10627 on: Wed, 19 November 2014, 07:52:07 »
Nope, circled.
As I said above, some plates are thick enough that those never actually snap around the plate, and it ends up being a "press fit" as you described.  On a plate slightly thinner (GON plates with the notches, for example), they will snap in and make it harder to get the switch out.  I would say that *most* custom plates that we order in steel and aluminum end up being on the thicker end, but that's conjecture / my experiences only.
« Reply #10628 on: Wed, 19 November 2014, 08:12:05 »
I know that you posted that but I didn't comprehend what exactly was being snapped in until Hzza posted the picture.
« Reply #10629 on: Wed, 19 November 2014, 08:13:37 »
This helped me understand what was going on
« Reply #10630 on: Wed, 19 November 2014, 08:20:39 »
Thanks :). Wish that youtube workaround would happen soon.
Offline asgeirtj
« Reply #10631 on: Wed, 19 November 2014, 10:18:37 »
What is the advantage of a programmable keyboard?  I use autohotkey to change the function of some keys, seems good enough.  Only drawback I can think is that if I'm using my keyboard on another computer it's not already preconfigured.  So what is the draw of programmable keyboards?
« Reply #10632 on: Wed, 19 November 2014, 10:36:22 »
I've never used Autohotkey myself but I think autohotkey doesn't have every function a programmable board could have. For example, I can setup multiple layers on my 6019284. Apparently, as I understand it, you cannot program function layers in Autohotkey?
Offline BlueBär
« Reply #10633 on: Wed, 19 November 2014, 10:37:31 »
That's exactly what the advantage is. You also don't need to run any other software in the background and often program LEDs which is kinda cool.
You can kind of. It works better on a hardware layer though.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10634 on: Wed, 19 November 2014, 14:55:43 »
Nope, circled.
Yep,  those things  :thumb:
WTB/WTS/WTT ---->
« Reply #10635 on: Wed, 19 November 2014, 15:20:17 »
Nope, circled.
I had some issues with them on my QFR.
Offline MGH
« Reply #10636 on: Wed, 19 November 2014, 19:32:28 »
Anybody know what dimensions the bottom row of a Filco Minila is?
« Reply #10637 on: Wed, 19 November 2014, 21:17:58 »
1.75x -> 1.25x -> 1.25x -> 1.25x -> 3x -> 1.25x -> 1.25x -> 1x -> 1x -> 1x ->1x
Offline MGH
« Reply #10638 on: Wed, 19 November 2014, 21:26:42 »
Gracias
Offline minho
  • i'm kind of back
« Reply #10639 on: Thu, 20 November 2014, 01:21:05 »
Does the color/profile/thickness of Ivan R2 match that of a IMSTO classic beige PBT set?
Offline henz
  • What?
« Reply #10640 on: Thu, 20 November 2014, 03:27:36 »
Can i get retail mx lock switches form anywhere?
« Reply #10641 on: Thu, 20 November 2014, 06:24:41 »
I honestly thought that imsto made those caps but I'm mistaken.
I thought online-components had them for sale.
« Reply #10642 on: Thu, 20 November 2014, 06:30:17 »
Am I missing something?
Imsto did make Ivan's R2
« Reply #10643 on: Thu, 20 November 2014, 06:32:08 »
Is that post referring to that R2 buy or another discussion within the thread? I only glanced through that page before posting and could have misunderstood. And thanks...I knew I wasn't going crazy.
« Reply #10644 on: Thu, 20 November 2014, 06:34:11 »
It's referring to requests for beige fulltouch caps locks made by imsto, I think.
« Reply #10645 on: Thu, 20 November 2014, 06:36:27 »
That discussion was about getting the correct color fulltouch capslock key re-ran/remade since they made it in the wrong color but the factory/imsto wasn't interested in doing it.
ninja'd by photekq but posting anyways as confirmation  8)
« Reply #10646 on: Thu, 20 November 2014, 06:36:52 »
Ok. So then my initial gut thought is correct according to photekq. imsto made Ivan's R2 so it will match imsto's classic beige PBT set. Thanks photekq for confirming that I'm not crazy yet ;).
Offline yasuo
  • spanengan puyeng newbie
« Reply #10647 on: Thu, 20 November 2014, 06:40:21 »
can i get cherry spring retail anywhere?
how make switch smooth not friction sst, can i use oil tamiya?
Logitech MK220 Colemak DH
« Reply #10648 on: Thu, 20 November 2014, 06:42:37 »
1) can i get cherry spring retail anywhere?
2) how make switch smooth not friction sst,
3) can i use oil tamiya?
1) Just the spring? No.
2) A quick Google search yields:
https://geekhack.org/index.php?topic=59041.0
https://geekhack.org/index.php?topic=34332.0
3) Can you use that specific oil? I don't know. But you can do an experiment and tell us what you think of it.
« Last Edit: Thu, 20 November 2014, 06:45:58 by CPTBadAss »
Offline yasuo
« Reply #10649 on: Thu, 20 November 2014, 06:48:44 »
2) how make switch smooth not friction sst, can i use oil tamiya?
yes, why? what size spring cherry(dimension)?
 :thumb:
