Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009030 times)
« Reply #10700 on: Wed, 26 November 2014, 08:40:46 »
Big problem, your diodes are in series but they need to be in parallell.
Yep.  To put that in layman's terms, the diode leads should connect "after" the diodes, not before.  If that makes sense.
« Reply #10701 on: Wed, 26 November 2014, 08:43:36 »
Please disregard my previous post. Thanks for the info guys :)
Offline Euf0ria
« Reply #10702 on: Wed, 26 November 2014, 08:44:37 »
Take a look at this and copy it and you'll be fine.
All your base are belong to us
Offline yasuo
  • spanengan puyeng newbie
« Reply #10703 on: Wed, 26 November 2014, 08:45:35 »
is this handwiring no problem?
As long as the diodes look like these from matt3o, I don't see why the diodes can't be horizontal instead of vertical.
yup, finally i use matt3o style
but its already soldered :-X its no problem when in firmware?
  thk info btw the problem is diode light gray(picture) soldered in front switch
Logitech MK220 Colemak DH
« Reply #10704 on: Wed, 26 November 2014, 08:46:59 »
thk info btw the problem is diode light soldered in front switch
What do you mean by this? It doesn't make much sense to me.
Better desolder it because it will cause problems.
« Last Edit: Wed, 26 November 2014, 08:49:18 by CPTBadAss »
Offline spremino
« Reply #10705 on: Wed, 26 November 2014, 09:35:18 »
Does the Cherry eVolution STREAM XT have scissor-switch keys?
A long space bar... what a waste of space!
« Reply #10706 on: Wed, 26 November 2014, 09:47:53 »
It sure looks and sounds like it does. I would guess yes based on the youtube videos I found.
  • Live long and prosper
« Reply #10707 on: Wed, 26 November 2014, 12:01:26 »
« Last Edit: Sun, 30 November 2014, 20:57:54 by Computer-Lab in Basement »
tp thread is tp thread
« Reply #10708 on: Wed, 26 November 2014, 12:12:43 »
Yes, it does.
Offline crunch
« Reply #10709 on: Wed, 26 November 2014, 18:26:11 »
Could this be mechanical. Chicony KB-6011
« Reply #10710 on: Wed, 26 November 2014, 22:01:44 »
Entirely possible. DT wiki doesn't have an article on it so I can't say if you don't take off a keycap.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10711 on: Wed, 26 November 2014, 22:18:45 »
Is a MX or ALPS switch still usable if one of the pins breaks half way off?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Moralless
« Reply #10712 on: Wed, 26 November 2014, 22:23:18 »
If you mean the length of the pin is shortened by half then it should still work, it just needs to be able to have contact to the pad. But this is assuming that the inside of the switch is still fine if the pin broke from being moved too violently.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10713 on: Wed, 26 November 2014, 23:36:40 »
Okay thanks. So as long as there is enough of the pin in the hole for the solder to reach it should be fine?
When I desoldered some ALPS switches  some of them were bent over, and after getting them out some broke where the bend was.
WTB/WTS/WTT ---->
« Reply #10714 on: Thu, 27 November 2014, 06:02:02 »
Yup, that's correct. You could try "extending" the leg by putting in a clipped diode leg or something similar. But I've had the exact same thing happen to me and it worked out fine.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10715 on: Thu, 27 November 2014, 07:43:05 »
Cool, thanks  :)
WTB/WTS/WTT ---->
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10716 on: Thu, 27 November 2014, 18:52:49 »
Cool, thanks  :)
If there is enough leg to reach into the hole I wouldn't worry about trying to solder an extension in.  The reason being when you go to solder the switch in the solder from the leg to the extension will probably let go.  I think my suggestion would probably be just fill the hole.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10717 on: Thu, 27 November 2014, 23:58:30 »
Cool, thanks  :)
Yeah I was just going to just fill the hole.   I don't have any diodes.  What else would work for extending the pins?
WTB/WTS/WTT ---->
Offline yasuo
« Reply #10718 on: Fri, 28 November 2014, 01:47:40 »
how to make keycap yellowing at least like cream chesee?
« Reply #10719 on: Fri, 28 November 2014, 04:45:02 »
Dye?  Although not as much as in that thread.
« Reply #10720 on: Fri, 28 November 2014, 09:14:04 »
Completely stripped wire.
I'm assuming you're asking to de-yellow caps. Retro Brite or dye may work.
Offline yasuo
« Reply #10721 on: Fri, 28 November 2014, 10:52:16 »
interisting, though so yellow
is smoke can make yellowing?
[/quote]yup, i want make yellowing caps at least like ccng color
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10722 on: Sat, 29 November 2014, 01:53:32 »
I have some old useless wallwart and telephone cables lying around.  If I cut and strip one of them would that work?
WTB/WTS/WTT ---->
« Reply #10723 on: Sat, 29 November 2014, 09:27:39 »
It's possible, but much easier with solid core wire like a paperclip.
« Last Edit: Sat, 29 November 2014, 10:17:44 by dorkvader »
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #10724 on: Sat, 29 November 2014, 13:58:13 »
It's the same FCC ID as the Unikey KWD-601:
http://deskthority.net/wiki/Unikey_KWD-601
I don't know what happened there — either Chicony bought out Nan Tan's keyboard assets when Clevo acquired them, or Chicony cloned the Nan Tan KB-6251, as it's exactly the same (shape, feet, screw holes, everything) but just with Chicony's choice of switches and a Chicony controller, and registered to Unikey Electronics Co Ltd with the FCC instead of Nan Tan (or Chicony for that matter).
Bore Awards
Offline crunch
« Reply #10725 on: Sat, 29 November 2014, 14:17:18 »
Yes thank you Beardsmore, I just found out my self about it. Here is a video that looks like the same keyboard.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10726 on: Sat, 29 November 2014, 14:49:25 »
What gauge wire would you recommend?   I can really just use a paperclip?
WTB/WTS/WTT ---->
« Reply #10727 on: Sat, 29 November 2014, 15:09:10 »
If you're having this much trouble finding something to use, I can just send you some hookup wire.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10728 on: Sat, 29 November 2014, 16:28:27 »
Knowing the exact name and gauge wire to get would help me more in case I have to get some in the future.
Or if you could post a link to something you recommend.   Thanks.
WTB/WTS/WTT ---->
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10729 on: Sat, 29 November 2014, 18:40:16 »
Where can one buy one of those cardboard keyset boxes? I can't remember for the life of me remember where I bought it the first time
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10730 on: Sat, 29 November 2014, 19:46:49 »
Are you talking about these  http://www.keypop.net/product/keycap-display-case
WTB/WTS/WTT ---->
« Reply #10731 on: Sat, 29 November 2014, 22:06:59 »
I think I've got 18 gauge or awg hookup wire. Sold at various stores that sell electronics, microcenter, Radio Shack, Home Depot, and Lowes.
« Last Edit: Sat, 29 November 2014, 22:48:06 by CPTBadAss »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10732 on: Sat, 29 November 2014, 22:12:31 »
Yes! Thank you
« Reply #10733 on: Sat, 29 November 2014, 23:23:48 »
that one is foam / cardboard. I have one (from Boost, I think there was a GB) that is only cardboard.
Thanks for that bytheway, I think I'll have to pick up one or two (depending on shipping) to better display the sets I'm not using.
Offline yasuo
« Reply #10734 on: Sun, 30 November 2014, 02:09:55 »
how to apply file to teensy w/ soarer controller
« Reply #10735 on: Sun, 30 November 2014, 09:03:13 »
Soarers/docs/index/tools something like that. What I am telling you is incomplete from my memory.
When you run Teensy.exe (from pjrc) it will ask you for a hex file. If you point it to soarers "atmega32" it should take care of the rest automatically.
This is all in Soarer's excellent documentation but you may have to dig around a bit.
- Franklin Roosevelt 1933
Offline Kblavkalash
« Reply #10736 on: Sun, 30 November 2014, 09:18:39 »
In my KBC Poker II from time to time (like once in a week of so) some keys become completely unresponsive for no apparent reason, and the only way to sove is to replug the keyboard. Or maybe I am just accidentally hitting some PN or similar key..?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10737 on: Sun, 30 November 2014, 10:21:53 »
It might just be a problem with the soldering and unplugging and re-plugging is just a coincidence
Offline Kblavkalash
« Reply #10738 on: Sun, 30 November 2014, 10:52:29 »
What you mean coincidence? If I unplug and re-plug keyboard, then it will work fine again. I am not really sure what you mean.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10739 on: Sun, 30 November 2014, 10:55:42 »
Like every single time that is what absolutely corrects it without a doubt? I was just saying that it might be a problem with the soldering and the keys might work for a little bit after unplugging it by coincidence. Though if that's what's fixing it, I'm not really sure. Does your hand ever accidentally rest on the FN key?
« Reply #10740 on: Sun, 30 November 2014, 11:23:09 »
once the soarer's code is on the teensy, you add the file with the following
open a command line
make sure the file is the layout and options you want
navigate the the /tools directory (where scinfo, scdis scas and scwr are locatied)
run scas <filename.sc>
run scwr <filename>
If you are in windows you can just run scaswr <filename.sc>
I put my layout.sc file in the/tools directory of the soarer install to make things easy.
The above info is also in the HTML documentation, but it's a little hard to understand sometimes.
Offline Kblavkalash
« Reply #10741 on: Sun, 30 November 2014, 11:24:40 »
Ahh that's what you mean. I am 100% sure something is messed up and re-plugging resets keyboard or whatever it does and everything works again every single time. I use FN key a lot for everything, so yes I may hit it many times even accidentally. But I think maybe it's because I accidentally press PN key and turn on programming mode or something. I mean I don't really care, just want to make sure it's not a defective keyboard.
Offline rainb1ood
  • so pretty so plastic
« Reply #10742 on: Sun, 30 November 2014, 13:14:02 »
Hi, I'm trying to find an up to date (or latest) information regarding which lube/oil to use for Ergoclear mod with 62g gold korean spring, is it still the krytox GPL-205 or will the lube kit by mkawa be enough
« Reply #10743 on: Sun, 30 November 2014, 13:36:44 »
Mkawa's kit is krytox. So either option will be fine
Offline rainb1ood
« Reply #10744 on: Sun, 30 November 2014, 13:41:23 »
Thanks Cap! Also last question:
This kit is made for switches to enhance your typing experience. There are 2 different mixes: Thick and Thin. Thick lube is made for tactile switches where as thin lube is made for linear switches.
In mkawa's kit sold at techkeys, it says thin is made for linear switches while thick is made for tactile, since thick is out of stock, is the Thin kit going to have a different effect on ergoclear or is it just the same thing?
« Last Edit: Sun, 30 November 2014, 13:44:05 by rainb1ood »
« Reply #10745 on: Sun, 30 November 2014, 18:00:22 »
They're different viscosities so they're not the same. MK.com and ctrl alt sells the kits too.
Offline Dreamre
    • kbdlife
« Reply #10746 on: Sun, 30 November 2014, 18:51:53 »
Are there any differences with a polycarb plate as opposed to a metal plate? Does one feel better than the other?
Offline rainb1ood
« Reply #10747 on: Sun, 30 November 2014, 19:56:46 »
Yep, my only problem now is that both techkeys, mk.com, ctrlalt are out of stock on 'Thick' kits (for tactile switches)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10748 on: Sun, 30 November 2014, 20:05:04 »
The main difference would be in metal's weight (heavier) and less flex than polycarb
Offline Dreamre
    • kbdlife
« Reply #10749 on: Sun, 30 November 2014, 20:26:23 »
In terms of feel, are there any differences though? Thanks for your input!
