Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009194 times)
« Reply #10750 on: Sun, 30 November 2014, 20:33:52 »
In terms of feel, are there any differences though? Thanks for your input!
To me the metal case makes the typing experience feel more solid. The polycarbonate can flex and yield while typing, which to me feels less solid.
Offline Dreamre
    • kbdlife
« Reply #10751 on: Sun, 30 November 2014, 22:03:16 »
Ah okay, thanks! I was curious as I'm complementing whether if I should get a poly carb plate for my KMAC.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10752 on: Sun, 30 November 2014, 22:09:30 »
Ah okay, thanks! I was curious as I'm contemplating whether if I should get a poly carb plate for my KMAC.
Definitely go for a metal plate if you're dropping that much on a nice keyboard
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10753 on: Sun, 30 November 2014, 22:18:58 »
I second this motion and would like to add if going with a KMAC I would go with a steel/stainless plate over aluminum, though with a TKL the difference isn't as noticeable as on a full sized board
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10754 on: Sun, 30 November 2014, 22:26:56 »
Or if you want to go all out: titanium
Offline MGH
« Reply #10755 on: Tue, 02 December 2014, 01:39:13 »
Is Ducky Shine Zero TKL and Ducky Shine TKL 2/3 the only backlit TKL keyboards that fit in those aluminum cases? Also does anyone know if the Novatouch can fit in a Aluminum case?
Offline intelli78
« Reply #10756 on: Tue, 02 December 2014, 02:14:16 »
What is the stem spacing like on a 6x Cherry spacebar? If I put Novatouch parts in a FC660C, will a Cherry 6x work?
« Reply #10757 on: Tue, 02 December 2014, 02:22:42 »
Three keymounts, one middle mount 0.5 units (9.525mm) right from centre, left 3 units (57.15mm) and right 2 units (38.1mm) apart from middle mount.
« Reply #10758 on: Tue, 02 December 2014, 08:12:15 »
1) Is Ducky Shine Zero TKL and Ducky Shine TKL 2/3 the only backlit TKL keyboards that fit in those aluminum cases?
2) Also does anyone know if the Novatouch can fit in a Aluminum case?
1) I think the rapid I would fit into a TEX TKL set.
2) I don't know offhand. I don't have a TKL case to test this idea with. But I wonder if it would fit into a digilog case or if it was similar enough to a QFR that it'd fit a QFR compatible case.
Offline intelli78
« Reply #10759 on: Wed, 03 December 2014, 03:46:44 »
Thanks... sounds like it won't work, since Topre has equidistant stem spacing.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10760 on: Wed, 03 December 2014, 16:55:59 »
I might be getting a mech with a 4P4C connector soon. I know you can use a Teensy with Soarer's firmware, but are there any easier ways to convert it? Ideally I'd like to do so without soldering since I don't really have the time or availability (can't solder in my dorm without setting off fire alarm). I don't know much about the board other than it is an Altos using Cherry MX Blacks with a 4P4C modular connector.
« Reply #10761 on: Wed, 03 December 2014, 16:58:42 »
those won't fit IIRC
and no the novatouch doesn't have any alu case options yet
Offline MGH
« Reply #10762 on: Wed, 03 December 2014, 17:19:06 »
Hmm ok, I will look out for a rapid I
Aww, guess Rapid I is my only option
« Reply #10763 on: Wed, 03 December 2014, 17:33:50 »
I have a beautiful board with a 4P4C connector that I would love to somehow rig up.
Since I have limited time, I have not delved into it too deeply, yet, but I would love to know how you do it, if you are successful.
I have a multimeter, but I have some doubts that I would trust your pinout. Mine is a Televideo.
- Franklin Roosevelt 1933
« Reply #10764 on: Wed, 03 December 2014, 22:54:38 »
I have same 4p4c televideo. WYSE also used 4p4c as well as (I think) IBM.
anyway: I can't think of a way to get it working unless you solder. Most likely a WYSE board under a different brand though. (there's lots).
Also: I know from lots of experience (and 2 years in the society of Fire protection enginnering club) that you can indeed solder inside the dorms without setting off the fire alarm. Or just go to someone's apartment.
« Last Edit: Wed, 03 December 2014, 22:57:35 by dorkvader »
« Reply #10765 on: Wed, 03 December 2014, 22:58:00 »
Does anyone know how to change the lighting mode on a Leeku PCB? I tried using Esc + Home. I have my Leeku 1800 in hand but I don't know how to change the lighting.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #10766 on: Thu, 04 December 2014, 00:15:33 »
Try this CPT:
FN = Pause
Pause = FN + Scroll Lock
LED Control = FN + Esc
« Reply #10767 on: Thu, 04 December 2014, 06:16:09 »
Try this CPT:
FN = Pause
This works like a charm. Thanks infiniti!
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10768 on: Thu, 04 December 2014, 10:23:31 »
Yeah, at the same time the smoke detector is right over my desk... And I don't wanna have to move my bed, dresser, and desk to fix that. Plus I'm not very experienced with solder.
Offline Geoph
« Reply #10769 on: Thu, 04 December 2014, 18:29:41 »
Could cigarette smoke/ash cause problems with cherry switches? At random some of my keys start becoming unresponsive so I clean them with some 99% isopropyl and everything works just fine for a while. Also, should I re-lube my switches after using isopropyl?
Offline Melvang
« Reply #10770 on: Thu, 04 December 2014, 21:30:10 »
It is possible.  I have replaced CPU fans from a computer that was in a bar for a few years.  The fan was so gummed up with tar that it wouldn't spin at all.  I refused to even allow bar computers into my house after that cause it took 3 weeks for the smell to vacate my house and I smoked at the time though not in my house.  Cigarette smoke will also destroy pretty much any electronics that have active cooling fans as well.
« Reply #10771 on: Thu, 04 December 2014, 21:33:23 »
absolutely possible
like you said, 99% isopropyl will clean it out to some degree
you shouldn't be smoking at your keyboard anyway though, it yellows white plastics, and the ash gets all up in your fans
Offline Melvang
« Reply #10772 on: Thu, 04 December 2014, 21:34:45 »
absolutely possible
Not to mention the tar makes the ash stick to everything that much more.
« Reply #10773 on: Thu, 04 December 2014, 21:35:54 »
absolutely possible
yeah, it's not nice to computer
i'm not gonna say don't smoke, make your own choices and all that
just don't do it in front of a computer
Offline Melvang
« Reply #10774 on: Thu, 04 December 2014, 21:41:52 »
absolutely possible
Pretty much my sentiments as well.  I personally recently quit smoking myself using a good e-cig after smoking for 15+ years.  In those years I never smoked in my own home.  Couldn't stand my house smelling like that.
« Reply #10775 on: Thu, 04 December 2014, 21:51:34 »
a few of my friends smoke, but i don't because i don't want my clothes to smell
that's literally the only reason, but it's important to me
Offline yasuo
  • spanengan puyeng newbie
« Reply #10776 on: Thu, 04 December 2014, 22:38:18 »
how to apply file to teensy w/ soarer controller
Soarers/docs/index/tools something like that. What I am telling you is incomplete from my memory.
When you run Teensy.exe (from pjrc) it will ask you for a hex file. If you point it to soarers "atmega32" it should take care of the rest automatically.
This is all in Soarer's excellent documentation but you may have to dig around a bit.
once the soarer's code is on the teensy, you add the file with the following
open a command line
make sure the file is the layout and options you want
navigate the the /tools directory (where scinfo, scdis scas and scwr are locatied)
run scas <filename.sc>
run scwr <filename>
If you are in windows you can just run scaswr <filename.sc>
I put my layout.sc file in the/tools directory of the soarer install to make things easy.
The above info is also in the HTML documentation, but it's a little hard to understand sometimes.
my teensy broken i use pro micro now
i cant open scas/scwr when i click its not showup
yup im in windows i open scawr i drag/drop <filename.sc>
my bad its run in cmd :))
C:\Users\User 7>Desktop>tools> run scas <myfilename.sc> run scwr <myfilename>
right?
but always show
The syntax of the command is incorrect.
what's wrong?
i tried drag n drop
and show like this
Code: [Select]
error at line 5: invalid command
« Last Edit: Fri, 05 December 2014, 04:54:15 by yasuo »
Logitech MK220 Colemak DH
Offline argcargv
  • tempting the banhammer
« Reply #10777 on: Fri, 05 December 2014, 16:50:17 »
Question about Ducky year of the horse:
1. does it have a plate?
2. Will the pcb fit into one of the custom 60% cases? for example the FMJ case?
watching the production video here at 1m47s mark, the pcb looks to have red circle marked holes for the standoffs.
t=1m47s
Thanks in advance!
« Reply #10778 on: Fri, 05 December 2014, 17:52:55 »
t=1m47s
Thanks in advance!
1) yes
2) not 100% sure but I think so. Never actually tried it myself but I'd assume so.
Offline Moralless
« Reply #10779 on: Fri, 05 December 2014, 18:05:01 »
t=1m47s
Thanks in advance!
1) yes
I don't think it would fit, since the mini USB placement for most aftermarket 60% cases are at the back where as on the ducky mini is on the side.
« Reply #10780 on: Fri, 05 December 2014, 21:12:46 »
That makes a lot of sense. My guess was totally wrong haha. Thanks!
Offline argcargv
« Reply #10781 on: Fri, 05 December 2014, 22:48:27 »
Thanks for the answers guys!
as for question number 2.
please take a look at the video, the side mini usb is actually connected by a pretty long wire to the pcb, so I'm thinking I could make it work by just gluing the mini usb to the back of the fmj case.
the only thing I'm worried about is the screw placement for the pcb/plate will not match the standoffs on a FMJ
« Reply #10782 on: Fri, 05 December 2014, 23:00:41 »
FMJ Case
Ducky Mini PCB
Looks like there's a third stand off on the FMJ case that will interfere with the Ducky PCB. The Mini looks to have 4 holes and the FMJ has three stand offs; one being offset.
And you're right. There's a little daughter board where the USB port is so you can move it around as is.
« Last Edit: Fri, 05 December 2014, 23:02:12 by CPTBadAss »
Offline argcargv
« Reply #10783 on: Fri, 05 December 2014, 23:08:57 »
It would be really helpful if we could find a picture of the bottom case of the ducky year of the horse, and see if the standoffs on that matches the FMJ case.
Offline jackalope
  • Now with 20% more soul.
« Reply #10784 on: Sat, 06 December 2014, 01:28:11 »
Any one know if it's possible to just buy novatouch stems, or do they have to be harvested.
eh o well
Offline byker
  • Literally Canada
« Reply #10785 on: Sat, 06 December 2014, 01:44:08 »
Right now, they have to be harvested. I could see them potentially being available in the future. If you only want one or two, then matt3o has a design that can be 3d printed that he has been working on.
Offline jackalope
« Reply #10786 on: Sat, 06 December 2014, 01:50:27 »
Thanks, I may just have to buy a novatouch and swap stems with my HHKB.  Determined to have miami on my HHKB.
eh o well
Offline byker
  • Literally Canada
« Reply #10787 on: Sat, 06 December 2014, 01:52:46 »
No worries, check amazon, they were $160 with prime shipping at one point in time, and you can always resell it with regular topre stems. The "novabrid" as tj calls it..
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10788 on: Sat, 06 December 2014, 02:02:24 »
$177.37 at the time of this post.
http://www.amazon.com/gp/product/B00MY3S288/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline jackalope
« Reply #10789 on: Sat, 06 December 2014, 02:07:48 »
Thank you.
This is why I shouldn't drink and browse GH, think im about to pick that up, lol.
eh o well
Offline asgeirtj
« Reply #10790 on: Sun, 07 December 2014, 13:12:32 »
Is there anywhere a guide to opening the IKBC F-104? Or at least of opening a keyboard similar to it?  This is the first keyboard that I open.  I plan to replace the switch springs.  I understand that this board has some special modability for leds, I don't intend to install any leds however.  Will this led function be in my way in any way?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #10791 on: Sun, 07 December 2014, 21:34:19 »
I had to look up some pictures.
Top "case" clips on to bottom. There are likely some screws holding it on as well.
step one: find all the screws. There might be one under a label or a QC sticker. Take them out.
Step two: get a butterknife, credit card, guitor pick, nylon stick, fingernail, etc to pry the top case off.
For additional info look up a guide on removing a filco top case, as it is very likely similar.
as to the LED: it was really hard to find PCB photos but it looks like all you need to do is remove the solder from the LED holes and install an LED.
Note: if you don't want LEDs then it won't get in your way at all.
Also note: to change springs you will have to desolder. The KB I found pictures of is plate-mounted.
Just desolder the switches, open them up, change springs, solder them back and you're good to go!
« Last Edit: Sun, 07 December 2014, 21:36:25 by dorkvader »
Offline cypherzion751
« Reply #10792 on: Sun, 07 December 2014, 22:54:52 »
I have two questions for you guys:
1) Where can you buy a KBC Poker II PBT with Brown cherry MX switches?
-Hoping to buy two of them
-I know I missed the massdrop
-Mechanicalkeyboards.com is out of stock
-Newegg has two? One made by five star and the other listed as generic? Where are the Vortex boards at?  :confused:
2) I know that single color led backlighting is an easy mod on the poker II but has anyone tried to put multicolor leds in them instead?
-Hoping to switch between red, green and blue.  I don't need mixed colors so that would make it easier.
Thanks for the help guys.
Offline yasuo
« Reply #10793 on: Mon, 08 December 2014, 05:02:13 »
the position two month is same as usually?
« Reply #10794 on: Mon, 08 December 2014, 10:25:44 »
The English here is hard to understand, so I will attempt my best.
Are you asking "it this was 2unit keycaps should look like?", or maybe "why do these look this way?"
If either of those are close, I can say that those 2u keycaps are from a POS board, which used two switches to provide stabilization, instead of using one switch in the middle and a stabilizer bar connecting to two outer points on the keycap.
Hopefully that answers your question, but if not, an alternate translation might help.  :)
« Reply #10795 on: Mon, 08 December 2014, 10:32:27 »
1) I'd wait for MK.com to restock. Vortex is known for odd supply issues. They're out of China.
2) IIRC Jixr has a Poker 2 that looks like an American flag with the LEDs. It's possible.
Offline intelli78
« Reply #10796 on: Mon, 08 December 2014, 10:52:13 »
What does a beam spring keyboard feel like?  :)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10797 on: Mon, 08 December 2014, 15:27:21 »
Magical
« Reply #10798 on: Mon, 08 December 2014, 15:58:14 »
1. I recommend just waiting for the next drop.
2. You can put different colour LEDs in it like red on some green on some, etc. You can also get LEDs that change colour over time, (check it) but you can't put in LEDs that can be multiple colours (like bipolar bicolour LEDs and RGBLEDS)
Usually 2-unit keys have three stems, one in the middle. Those keycaps are for a POS keyboard and are designed to fit over two separate switches. They are common on matrix POS boards.
They tried to get the feel of the selectric typewriter. The beamspring is similar but with a soft click rather than a loud thunk.
Offline yasuo
« Reply #10799 on: Mon, 08 December 2014, 18:49:40 »
yup, the 2month position is same as like 3month just leave one month in middle, right?
or different spacing?
