Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6227442 times)
Offline asgeirtj
« Reply #10950 on: Sat, 27 December 2014, 10:00:24 »
http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
Is this lube similar to geekhack "thick" lube?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #10951 on: Sat, 27 December 2014, 10:08:21 »
Nope.  That's stabilizer lube, it's not for lubing the inside of switches.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #10952 on: Sat, 27 December 2014, 11:37:46 »
I think they claim that their other lube (one with the red label) can be used for swiich sliders. Not sure how well it works though.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10953 on: Sat, 27 December 2014, 23:33:03 »
Any suggestions for font settings for use at http://www.keyboard-layout-editor.com/ to simulate DSA font the closest?  I am asking because I am going to use that tool for initial mockups for my most recent IC.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10954 on: Sun, 28 December 2014, 00:52:40 »
Any ideas how to load .hex files onto an Arudino Leonardo? I've been using a Teensy which comes with the software but I went with Leonardos since they are a whole lot cheaper.
Offline hasu
  • @tmk
« Reply #10955 on: Sun, 28 December 2014, 06:56:02 »
Press reset button and then run avrdude with correct serial device name  *within 8 seconds*. Note that serial port name may be changed often.
https://geekhack.org/index.php?topic=14290.msg1563867#msg1563867
Offline MGH
« Reply #10956 on: Mon, 29 December 2014, 00:12:33 »
Are there center stemmed black on beige doubleshot cherry caps locks?
« Reply #10957 on: Mon, 29 December 2014, 14:03:45 »
Nope. Techkeys had something similar from SP for a while, but I don't know if they still do.
Offline billnye
  • ability man
« Reply #10958 on: Mon, 29 December 2014, 14:06:13 »
Yes there are.
Look for a board such as a G80-3190 HPU
« Reply #10959 on: Mon, 29 December 2014, 14:11:39 »
Oh, I assumed he meant stepped.
« Reply #10960 on: Mon, 29 December 2014, 14:12:40 »
Or G80-3181HPU.. there's a bunch.
« Last Edit: Mon, 29 December 2014, 14:26:39 by Photekq »
Offline loudaslife
« Reply #10961 on: Mon, 29 December 2014, 18:07:05 »
Is there any reason that most common Mechs can't be modded for NKRO? By that I mean cutting solder traces in the matrix and connecting diodes in their place. Obviously the controller has to support NKRO, but aside from that is there any reason it wouldn't work?
« Reply #10962 on: Mon, 29 December 2014, 19:04:38 »
The only part that knows about NKRO is the controller so there is no reason you can't mod any keyboard with diodes and a new controller as you are suggesting.  Sounds like you're jumping in at the deep end much like I did not long ago, see you in the "making stuff together!" section :)
Unrelated to the above I have some questions.
I've had a week or so using my first real keyboard (a Ducky Zero with red MX switches and ABS keycaps) and have two issues with it.
First, it's noisy.  I went with non clicky switches in the hope it wouldn't be, but it's still much louder than my old Cherry membrane keyboard.  From what I've read this is probably because I'm bottoming out the switches - would O rings help?  Or perhaps getting some thicker (PBT?) keycaps would dampen the sound?
Second, it's very sensitive so I keep clipping the corner of the key next to the one I want resulting in unwanted keypresses.  I think this is because the switches are too light for me but is there anything I can do about it?  It's plate mount so a spring transplant is not an option.
Seems likely both problems would be solved if I learned to type better but I still have to use a cheap keyboard at work so that's going to be hard, instead I'm going to take the easy option and throw money at the problem in the hope it goes away!  (If this board can't be made suitable I'll buy another one...)
Offline MGH
« Reply #10963 on: Mon, 29 December 2014, 21:41:55 »
Is there a list of custom keyboards (or just aluminum cases) where the slant of the keyboard is small (not exactly sure measurements but somewhere between 0 and 5 degrees)? Somewhere around the slant that most stock keyboards have without the feet lifted.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10964 on: Tue, 30 December 2014, 01:35:39 »
Is there anywhere that gives discounts on bulk orders of MX switches?
« Reply #10965 on: Tue, 30 December 2014, 01:56:32 »
Only ones you will find like that are ones which use aluminium feet, but with the feet removed. Like KMAC 1, Kingsaver.
Offline MGH
« Reply #10966 on: Tue, 30 December 2014, 02:23:57 »
Bleh, I doubt I'll ever find one of those. Stock board with tex case it is :(
« Reply #10967 on: Tue, 30 December 2014, 13:54:20 »
cherry
and i think conrad does it as well
no idea tho
« Reply #10968 on: Tue, 30 December 2014, 13:57:31 »
cherry
no idea tho
Cherry definitely does, but the qty is something like 20,000 units or something.
Offline Melvang
« Reply #10969 on: Tue, 30 December 2014, 14:04:54 »
Digikey.com and mouser.com do as well I believe, though i think it is for smaller orders and less of a discount than ordering from cherry but no MOQ.
Offline kohi
« Reply #10970 on: Tue, 30 December 2014, 15:08:26 »
is there a big difference between the thick and very thick krytox switch lubricant formulas sold on techkeys. im trying to find thick formula to lube mx clears but it seems to be out of stock everywhere
Offline crunch
« Reply #10971 on: Tue, 30 December 2014, 15:12:10 »
I only have this picture of a white space invader switch. I've read that it exits both a linear and clicky version, can you tell which one this is.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10972 on: Tue, 30 December 2014, 15:14:40 »
Both the linear and the clicky versions come in white color and with the two "eyes" on the top. Outside of that, I'm not sure there's any other way to distinguish them
Offline Bakgrund
« Reply #10973 on: Tue, 30 December 2014, 15:34:17 »
Is the tactile bump on browns as big as they are on blues?
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline Melvang
« Reply #10974 on: Tue, 30 December 2014, 15:35:10 »
Physically on the stem yes, but in feel, I don't feel like it is the same.
« Reply #10975 on: Tue, 30 December 2014, 15:57:37 »
this
« Reply #10976 on: Tue, 30 December 2014, 17:41:32 »
cherry
no idea tho
Would 7bit offer any discount?
« Reply #10977 on: Tue, 30 December 2014, 18:52:44 »
cherry
no idea tho
i dunno
ask him
Offline Bakgrund
« Reply #10978 on: Wed, 31 December 2014, 16:57:39 »
Not really keyboard related but how do you make these small keyboard pics that everybody has in their signatures? like here: https://geekhack.org/index.php?topic=67195.msg1577835#msg1577835
Mx Browns          Mx Reds
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #10979 on: Wed, 31 December 2014, 17:50:06 »
Are you asking about how to actually make these? Or where to find them?
I'm not sure how they're made but it's called pixel art if that helps, maybe Google it?
Sorry I'm on mobile right now so I can't link it but we have a thread somewhere where you can find or request pixel art keyboard pictures.
GON NerD TKL DTA Edition
Offline Bakgrund
« Reply #10980 on: Wed, 31 December 2014, 18:06:57 »
Oh, I thought that it was like a site you could make them on, as they are all so similar and well-made, but I guess I'll just have to spend some time in MS paint.
Edit: Ok, I took sealcouch's filco pixelart and edited it a bit, here's the final result:
« Last Edit: Wed, 31 December 2014, 18:29:30 by Bakgrund »
Mx Browns          Mx Reds
Offline MGH
« Reply #10981 on: Wed, 31 December 2014, 22:23:43 »
Just want to make sure, is this the cheapest non DIY wire keycap puller?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=949
« Reply #10982 on: Wed, 31 December 2014, 22:33:17 »
pretty much
Offline malganis
« Reply #10983 on: Thu, 01 January 2015, 05:11:25 »
Hey guys.
Any idea about where in Europe I could get a CM Storm QuickFire Rapid-I with MX Brown and ANSI layout?
Offline Pemdas
« Reply #10984 on: Thu, 01 January 2015, 16:51:15 »
Does a metal DSA set exist?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10985 on: Thu, 01 January 2015, 16:57:23 »
Nope, zinc has only been done in DCS
« Reply #10986 on: Thu, 01 January 2015, 19:08:26 »
Actually it was OEM, not DCS
I think it was based originally off of vortex's caps
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10987 on: Thu, 01 January 2015, 22:47:11 »
So what does this"diffuser" do in relation the actual case
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #10988 on: Fri, 02 January 2015, 01:51:09 »
I wasn't aware the Koreans had picked up on my design using two flat heads screws and a hex stand-off. Achievement unlocked.
Offline byker
  • Literally Canada
« Reply #10989 on: Fri, 02 January 2015, 02:17:17 »
That is a very nice case. Any idea if this would fit a GHpad pcb? If you want to do a mini-group buy for a couple, I would be interested!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10990 on: Fri, 02 January 2015, 02:28:11 »
with these cases, there is some space between the numbers and the top row which makes me believe that it wouldn't fit. But there are also places to get the proper PCBs for $20 something. One of my friends at school is a foreign exchange student from Korea. He was just there for the holidays, but I might get some stuff for him to bring back the next time to save on shipping. Not sure how much he could bring though :p
Offline byker
  • Literally Canada
« Reply #10991 on: Fri, 02 January 2015, 02:59:00 »
Yeah I was thinking that space by the upper row could cause some difficulties! Let me know if you are decide to go through with getting them someday and want to split shipping..
« Reply #10992 on: Fri, 02 January 2015, 14:16:44 »
Diffuses the light so that it's softer.
It's trendy right now.
« Reply #10993 on: Fri, 02 January 2015, 14:27:00 »
Did you click the links?  Every product shot is identical between the two...  The only difference in photos is what appears to be the make-up of the layers, though it's not clear without a solid translation what the difference is.  Or maybe I'm misinterpreting hwood's initial question.  :P
« Reply #10994 on: Fri, 02 January 2015, 14:30:17 »
of course i clicked the links
my ****ty korean skills got me to the answer that i gave
the "diffuser" is a frosted bit of acrylic that replaces some part of the case
that's why it's only $7 and not $14 like the whole case
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10995 on: Fri, 02 January 2015, 14:30:30 »
No, he had the right idea. I was asking because they used the same pictures for the diffuser as they did for the actual case.
And are there any pictures of the differences?
« Reply #10996 on: Fri, 02 January 2015, 14:32:07 »
i'd check kbdlab
i think i've seen some there
can't find them again tho
« Reply #10997 on: Fri, 02 January 2015, 17:04:43 »
What controller should I get to program my HHKB with dvorak?
Offline byker
  • Literally Canada
« Reply #10998 on: Fri, 02 January 2015, 19:40:47 »
I would look at hasu's controller.
« Reply #10999 on: Fri, 02 January 2015, 19:48:38 »
Thanks.
