Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009035 times)
Offline yasuo
  • spanengan puyeng newbie
« Reply #10500 on: Sat, 08 November 2014, 00:10:19 »
is cherry kibord have tkl/ssk i see all are fullsize?
Logitech MK220 Colemak DH
« Reply #10501 on: Sat, 08 November 2014, 00:58:57 »
G80-5000 is the Cherry keyboard closest to TKL, unless there's some really obscure model that comes closer.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #10502 on: Sun, 09 November 2014, 07:41:28 »
Are SMD or DIP diodes better?
I'm getting a GON 60% NerD PCB.
« Reply #10503 on: Sun, 09 November 2014, 07:44:52 »
I don't think there's a difference in function between the two types so neither would be "better". Looks like the PCB will take either kind. I prefer to use DIP diodes because they're easier to handle than those tiny SMD diodes. Plus I haven't taught myself how to SMD solder yet.
I guess the usual decision for me is can I use DIP diodes and not have them interfere with anything else? My Leeku 1800, I don't think I can do DIP diodes and I'm forced to use SMD. There's no holes for the DIP diodes that won't interfere with the LEDs.
« Last Edit: Sun, 09 November 2014, 07:46:23 by CPTBadAss »
Offline Karura
  • SKidata life.
« Reply #10504 on: Sun, 09 November 2014, 08:08:20 »
Thanks for the replies like always :)
I guess whatever is easier and poses no cons.
Offline yasuo
« Reply #10505 on: Mon, 10 November 2014, 09:41:38 »
is this right old cherry keyboard not use stabs but two switch? :)
« Last Edit: Mon, 10 November 2014, 09:43:14 by yasuo »
« Reply #10506 on: Mon, 10 November 2014, 09:43:42 »
I've never heard that before.
« Reply #10507 on: Mon, 10 November 2014, 09:44:46 »
Do you mean Cherry branded? If so, no. They use stabilisers. The only one I can think of that uses a switch as a stabiliser is this : http://imgur.com/a/ukoPH [look at the large enter - it has a stabliser + switch with no spring]
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #10508 on: Mon, 10 November 2014, 09:54:01 »
60% keyboard screws.
For mounting everything to the tray/case. What are the screws?
I got boards.
« Reply #10509 on: Mon, 10 November 2014, 09:54:56 »
The poker ones are listed in the OP.
Offline yasuo
« Reply #10510 on: Mon, 10 November 2014, 09:57:40 »
i read someone say in reddit but no pics unfortunately :-X
yeah almost like that & i curious SP have keycap 2u with 2mount i think its mean
i've tried use 2switch is alternative for diy kb with plate 2mm++ thick
feel is stiff at least with reds not really, there any custom spring >20g?
  • Dungeon Dweller
  • Get back to work!
« Reply #10511 on: Mon, 10 November 2014, 09:59:14 »
POS boards have multiple switches under the caps.
I got boards.
Offline yasuo
« Reply #10512 on: Mon, 10 November 2014, 10:01:31 »
ah yeah i've seen pos board with 2switch may SP make it for POS
caps&enter use 2switch
« Last Edit: Mon, 10 November 2014, 10:08:35 by yasuo »
  • Dungeon Dweller
  • Get back to work!
« Reply #10513 on: Mon, 10 November 2014, 10:16:09 »
POS boards are programmable, so you sort of make the layout with the keycaps - and if you have a cap that sits over two switches, you just effectively turn one of them off in the programming of the board, so in effect only 1 of the 2 switches send a scan code/whatever.
I got boards.
Offline azhdar
  • Praise the AZERTY god
« Reply #10514 on: Mon, 10 November 2014, 10:24:06 »
While working on mx clear pcb mounted , I was wondering , why is it so hard to pull the keycaps ofc mx clear stems ?
I find myself using a screwdriver to hold the switch otherwise I end up pulling the stem and spring with the cap (PBT keycaps).
Azerty Propagandiste
  • Dungeon Dweller
  • Get back to work!
« Reply #10515 on: Mon, 10 November 2014, 10:35:38 »
I think the stem is literally just a bit bigger, like the thickness of the cross shape. Don't know why that's the case.
This is why notched plates are the work of the devil.
I got boards.
Offline azhdar
« Reply #10516 on: Mon, 10 November 2014, 10:39:18 »
make sense I'll compare it .
#NOPLATE_YOLO
« Reply #10517 on: Mon, 10 November 2014, 10:41:16 »
That's why everyone should have one of these hamblet keypullers. It's like a prybar for caps, never had an issue removing caps.
« Reply #10518 on: Mon, 10 November 2014, 10:42:22 »
I think that this thread is a great resource in answering your question.
Offline azhdar
« Reply #10519 on: Mon, 10 November 2014, 11:05:12 »
Oh , I never noticed those notches , very interesting read , thanks CTPBadAsss .
Offline klaxhu
« Reply #10520 on: Mon, 10 November 2014, 14:36:34 »
Hi all: my ducky shine 3 TKL'US layout has developed a strange problem: I have to press ' key I have to press it twice as on the first press nothing happens and then it appears double(after I pressed it twice) (this is after re-installing windows as I rebuilt my waterloop/cooling), it was working fine before.
I have so far updated the firmware to the latest, reset the settings to default, tried other USB ports with no success. Anything else I could try before I contact Ducky?
« Reply #10521 on: Mon, 10 November 2014, 14:42:35 »
I have to press ' key. I have to press it twice as on the first press nothing happens and then it appears double(after I pressed it twice) (this is after re-installing windows as I rebuilt my waterloop/cooling), it was working fine before.
Sounds like you have either a bad solder joint or need to replace the switch. If you have a multimeter, open the board up, and then check the solder joint. If the joint checks out to be ok, then the switch contacts inside could be messed up and you may want to try swapping out the switch.
Or it could be that somehow, the PCB is somehow shorting and causing your switch to not read properly. My PCB was touching the bottom of the case which was causing problems. I had this on two of my boards and solved it but putting some drawer liner from Target in between the PCB and bottom part of the case.
If you're under warranty (bought recently), I'd talk to Ducky. If you're past that time window, I suggest talking to dorkvader to see if he'd troubleshoot your board.
« Last Edit: Mon, 10 November 2014, 14:46:04 by CPTBadAss »
Offline klaxhu
« Reply #10522 on: Mon, 10 November 2014, 14:45:07 »
thanks. It's still under warranty, bought it 3 months ago :-(
will talk to ducky about it, let's see what they say
Offline klaxhu
« Reply #10523 on: Mon, 10 November 2014, 14:51:46 »
actually, I take some of that back. just realised that the same happens with the `/ ~ key. one press doesn't do anything and pressing it again comes up double. so definitely a fw or other problem... it would be strange for both these keys to start doing this after I re-installed windows ..and it was working fine before :(
« Reply #10524 on: Mon, 10 November 2014, 14:54:20 »
Check your manual to see if there's a dipswitch switch setting that's causing this? Shine 3 has dipswitches I think... My previous guess still stands until I think of something else. But if you've already flashed the firmware and your dipswitches are setup right, I'd at least contact Ducky at see if they can answer your question or help you out. They're responsive on their Facebook page if you've got an account on Facebook.
Offline klaxhu
« Reply #10525 on: Mon, 10 November 2014, 14:59:51 »
yep, did just that, seems to be in order, they are all on off as standard.
yup! thanks :) doing that now.
just wrote them an email actually ...I'm curious if the fact that I bought it from Holland and been using it in UK will affect me and the warranty somehow (hope not!!). I hate the UK layout with the short shift on the left so I had to have the US one :-)
« Last Edit: Mon, 10 November 2014, 15:01:36 by klaxhu »
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #10526 on: Mon, 10 November 2014, 16:04:09 »
You may try unplugging the keyboard. Then, flipping all the DIP switches up, and then back down. Plug the keyboard back in.
This may help...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline Elocutive
« Reply #10527 on: Mon, 10 November 2014, 21:27:48 »
What is OTD red alert 2.0 and 2.1? is it 2 sets, or one with addons?
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline colomb
« Reply #10528 on: Mon, 10 November 2014, 22:52:43 »
Now that I have a Realforce 87U, I'd like to get some colored keycaps on it. Other than a couple classified posts here I can't find anything. Where does one purchase Topre keycaps?
« Reply #10529 on: Mon, 10 November 2014, 23:48:37 »
There are very few places still selling these keycaps.
You could try: http://stores.ebay.com.au/widebasket
Offline BlueBär
« Reply #10530 on: Tue, 11 November 2014, 03:17:13 »
2.1 is an addon set for RA2.0, which is just the second round of Red Alert.
  • Dungeon Dweller
  • Get back to work!
« Reply #10531 on: Tue, 11 November 2014, 04:33:59 »
Isn't that just US international layout set in windows? You should be able to make it happen by pressing ' and then pressing space, means you have to double space though. Makes lot of special characters easier to do than altgr + combo's etc. like if you press ' and then press e afterwards, you get é. If you don't like it then change it to US in windows.
I got boards.
Offline colomb
« Reply #10532 on: Tue, 11 November 2014, 12:08:46 »
Perfect, thank you.
Offline jackalope
  • Now with 20% more soul.
« Reply #10533 on: Tue, 11 November 2014, 14:44:05 »
Is their a reason that you normally see topre as being dental band modded instead of o rings , and is it possible to mod cherry keycaps for topre?
eh o well
« Reply #10534 on: Tue, 11 November 2014, 14:47:44 »
orings don't fit on topre switch stems and no, however the new CM novatouch is a topre board that uses cherry keycaps
Offline jackalope
« Reply #10535 on: Tue, 11 November 2014, 15:09:32 »
Thank you much.
eh o well
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10536 on: Tue, 11 November 2014, 20:51:18 »
Can someone point me to some UV/purple, NOT PINK, leds please.  They can be rectangular or round.  That part doesn't matter as the switch tops are getting modded so I can swap stems and springs without pulling the LEDs or installing sip sockets.
These are going to be for the wifes GH36.  If I can get this thing built she will finally put her Filco on her desk for daily use instead of just dismissed as a spare in the laptop bag.
Offline jackalope
« Reply #10537 on: Tue, 11 November 2014, 20:54:29 »
Like this?s
http://www.frozencpu.com/products/5540/ele-235/3mm_PurpleUV_LED.html
eh o well
Offline Melvang
« Reply #10538 on: Tue, 11 November 2014, 21:00:29 »
Yeah but something from a site like digikey or mouser would be better.  I am pretty sure that I can get some cheaper than 50 cents each plus so price breaks for bulk.  Nothing wrong with that site as I have ordered from them before but would like a better price.  Plus, I am going to have to get other parts as well and would rather order all from one site at once to save shipping costs.
« Reply #10539 on: Tue, 11 November 2014, 21:02:29 »
http://ledmuseum.candlepower.us/ledvio.htm
The above website has some good info. I used it as a reference when I was looking for purple LEDs.
Offline 00zeRO
« Reply #10540 on: Tue, 11 November 2014, 21:46:29 »
Brian Blessed is back!  :thumb:
Offline jackalope
« Reply #10541 on: Tue, 11 November 2014, 23:13:15 »
Would a QFR tkl top case fit on a Ducky shine 3 or a Filco mj 2 tkl?
« Last Edit: Wed, 12 November 2014, 00:50:17 by jackalope »
eh o well
« Reply #10542 on: Wed, 12 November 2014, 00:18:04 »
Are all cherry PCB mount stabs the same. What I mean is will there be a difference between buying them from Imsto vs Gon?
« Last Edit: Wed, 12 November 2014, 00:20:03 by Joey Quinn »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10543 on: Wed, 12 November 2014, 00:19:55 »
Is anyone here a Taobao agent? I'd like to order something from there, but I can't read Chinese and don't live in China.
« Reply #10544 on: Wed, 12 November 2014, 00:29:32 »
Feng, Qtan
Offline intelli78
« Reply #10545 on: Wed, 12 November 2014, 00:32:09 »
Well, you have to order the right size (obviously) but there should be no further differences to be aware of.
Offline Veridis
« Reply #10546 on: Wed, 12 November 2014, 02:22:25 »
It seems that WASD keyboards and Keypop are selling novelty keycaps like the Look Of Disapproval keycap.
Who makes the best version of it? Also, is it OEM profile?
Thankyou.
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #10547 on: Wed, 12 November 2014, 02:45:58 »
Just that there are clip-on PCB mount stabs and screw-on. But those last ones are fairly hard to come by and don't really make a difference in most cases. They are simply firmer and feel more solid.
|||My other keyboards :
x
Offline BlueBär
« Reply #10548 on: Wed, 12 November 2014, 04:12:57 »
Nope, most likely not.
WASD only does pad printing, Keypop sells doubleshots from SP. Doubleshots are better than pad printed caps.
Both are OEM profile.
Offline Veridis
« Reply #10549 on: Wed, 12 November 2014, 04:14:22 »
Thank you! Gonna get some from Keypop soon :)
