Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6011211 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #11750 on: Thu, 19 March 2015, 21:17:37 »
What are tuned cherry stabilizers? I know you can clip the stabs, but what else can you do? I see Duck and GON mentioning this.
clip the stabilizers, and lube them.  You can also "shave" the mold line too, but I am not sure GON and Duck do that or not.
lube them? not really sure beyond that
Thanks for the replies!
Here's the video I'm referring to.
it almost looks like #3 has a spring in it
« Reply #11751 on: Thu, 19 March 2015, 23:57:38 »
Is there any place outside of taobao that sells white costar stab mounts?
I only see white inserts. Also odd that there aren't black inserts either, even though I only want white.
Does no one else care to have matching stabs for all the Gaterons that were bought?
The Tex Yoda came with white costar stabilizers.
Offline FoC_Tow
  • Brokehlicious
« Reply #11752 on: Fri, 20 March 2015, 00:43:47 »
Do switch panel cutouts generally work with both Matias and Cherry switches? I ordered two Infinity keyboard kits--one hacker layout with Matias switches and one standard layout with Cherry switches. But I'm thinking about switching those around and doing the hacker layout with cherries.
In case of the Infinity that should work njbair, yes.  :)
Plate cut outs don't generally support both Matias and Cherry switches as far as I know,
but I'm pretty sure the Infinity uses hybrid style cut outs to support both Matias and Cherry switches.
Looking at the Infinity plate you can even see how the switch cutouts look slightly cross/plus (+) shaped which was done for
exactly this reason I guess.
« Reply #11753 on: Fri, 20 March 2015, 05:43:37 »
The plate cutouts need to be specifically designed to take both switches. The dimensions aren't the same.
What diameter and thickness shoud o-rings be for cherry keys? I just wanna get generic ones at a hardware store.
Check out this thread for more info.
Why don't you ask GON in his subforum? He's got a thread just for questions and is usually responsive.
Offline njbair
    • nickbair.net
« Reply #11754 on: Fri, 20 March 2015, 15:16:24 »
to practice soldering switches, i'm thinking of acquiring some cheap,
For $25 each (or less, if you are lucky):
Buy a Dell AT101(W) for a chassis and an Apple Extended Keyboard (or II) for a donor and do your practice soldering and de-soldering on the Apple.
You can take the Apple completely apart for practice, and after you are finished with the project, you will have a perfectly good working keyboard and partial set of spare Alps caps.
So let me get this straight...you buy a Dell AT101W and an AEKII on Ebay for super cheap, then desolder the switches from the AEK and replace the Dell's switches with the ones you removed from the Apple? And you end up with a Dell AT101W with nice Apple ALPS switches. Is that right?
My boards:
« Reply #11755 on: Fri, 20 March 2015, 15:19:43 »
Correct. Best ANSI layout (Dell AT101W) with nicer switches than black Alps.
Offline sypl
« Reply #11756 on: Fri, 20 March 2015, 23:26:38 »
Offline StinkyTheDonut
  • I like rubber domes.
« Reply #11757 on: Sat, 21 March 2015, 06:10:11 »
This guy knows what I'm looking for.
WAS keyboards has costar stabilizers.
I honestly couldn't care about matching stabilizer colors. Or even clear switch tops and stickers. Hard to care about something you'll see maybe once a month. Rest of the time it's covered by keycaps.
I'm trying to make one of those sandwich boards with the exposed plate as the top layer (not sure what they are called), so I will probably see the bottom row all the time.
I'm even considering backlighting the stabs if the white ones are translucent enough lol.
I don't think I've ever seen black costar inserts
On taobao apparently they have black or white for both inserts and mounts.
I actually had someone contact a taobao vendor for me, but I think they were ignored because it was such a small volume. =(
I'm not too fond of having accidents and confusion multiplied by a middleman, so I've given up on that method for now. That's why I'm trying to find another source.
I only have a washable keyboard.
Offline njbair
    • nickbair.net
« Reply #11758 on: Sat, 21 March 2015, 10:48:26 »
Is there any benefit to doing a bolt mod on a Model M if there are no broken rivets or should I just consider myself lucky?
My boards:
« Reply #11759 on: Sat, 21 March 2015, 10:53:32 »
https://geekhack.org/index.php?topic=54745.0
:D
« Reply #11760 on: Sat, 21 March 2015, 16:03:33 »
How old do MX browns have to be before they are considered vintage?
« Reply #11761 on: Sat, 21 March 2015, 16:57:40 »
"Vintage" doesn't matter, broken in does.
« Reply #11762 on: Sat, 21 March 2015, 16:59:15 »
So ~10yrs old and used enough to shine cherry double shots should be good then.
« Reply #11763 on: Sat, 21 March 2015, 17:01:13 »
Probably.  If they actually feel good, they're broken in.
Offline jonathanyu
« Reply #11764 on: Sat, 21 March 2015, 17:08:34 »
The brown in my MX5000 actually feel different and better than other brown, but I don't thank the board have been used more than 20 hours, so I think there is some different between the old one and new one
« Reply #11765 on: Sat, 21 March 2015, 17:26:22 »
And I've had "vintage" Brown boards that felt like crap.   Until someone does an analysis of the lube and lube points and of the plastics I'll still stand by the "vintage" placebo claim.
Offline domoaligato
« Reply #11766 on: Sat, 21 March 2015, 23:49:51 »
I have what I would call "vintage" clears. they were dry also and in need of some lube. after lubing I can not tell the difference between "vintage" clears and new ones.
Offline njbair
    • nickbair.net
« Reply #11767 on: Sun, 22 March 2015, 15:31:08 »
Does anyone know where I can buy a brand new Cherry G80-1800? As much as I would love a Dolch PAC version, I'm willing to settle for new and maybe just have the case powdercoated, etc. to look more custom.
I see this one on Amazon but it's been out of stock for a while.
My boards:
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #11768 on: Sun, 22 March 2015, 15:47:16 »
That amazon link is in stock, and you are going to get plastic powder coated?
Offline njbair
    • nickbair.net
« Reply #11769 on: Sun, 22 March 2015, 15:53:56 »
Well it says it will be in stock on April 21. But last time they put an in-stock date, the date came and went and they moved it back to April 21. And regarding powdercoating, I spoke carelessly. I meant clear-coating like a body shop does. Clear coating is clear I know, but painting it first was implied.
My boards:
Offline cannonking
« Reply #11770 on: Mon, 23 March 2015, 08:27:26 »
How do I put my replacement Filco feet in my board. I don't want to force it and have to buy another pair. Do I have to open the keyboard or am I just silly?
« Reply #11771 on: Mon, 23 March 2015, 08:33:07 »
You don't have to open the keyboard. They just press fit in there. :)
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #11772 on: Mon, 23 March 2015, 15:05:18 »
Don't know if you'd be interested but just saw these on /r/mechmarket.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11773 on: Mon, 23 March 2015, 15:10:52 »
They are overpriced on MechMarket, would not recommend buying them from him.
Offline greath
« Reply #11774 on: Mon, 23 March 2015, 15:17:51 »
What would you say is a fair price and where could I find one around said price? Pretty much all the ones I've seen run $120+ so I figured that $150 was close to par for the course.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11775 on: Mon, 23 March 2015, 15:19:54 »
You just have to wait it out, I bought a dolch pac computer off of eBay for 130 and it came with the keyboard I think there is one on eBay right now
« Reply #11776 on: Mon, 23 March 2015, 15:55:02 »
« Last Edit: Tue, 24 March 2015, 09:50:14 by SpAmRaY »
Offline njbair
    • nickbair.net
« Reply #11777 on: Mon, 23 March 2015, 16:06:54 »
I'll hold off for now...I've got some other irons in the fire on Ebay and I don't want to overextend my wallet. If he's still looking to sell in a month or so maybe I can ask for a better price than $150. We'll see. But thanks for the link!!!
My boards:
Offline hoankinhcan
« Reply #11778 on: Mon, 23 March 2015, 19:13:42 »
Can I ask a simple question: KPB V80 or Ducky Shine 3 TKL 2nd ? Thanks.
Offline njbair
    • nickbair.net
« Reply #11779 on: Mon, 23 March 2015, 19:21:33 »
I can vouch for Ducky. My full size Shine 3 is built like a tank, but slightly heavier.
My boards:
« Reply #11780 on: Tue, 24 March 2015, 11:05:11 »
I've not tried the V80 so I can't say anything good or bad. I will say that Ducky's keyboards have impressed me in the past and I think the Shine 3 would be a solid pickup.
I've found new in package and new in box Cherry keyboards on eBay before. Takes a little hunting though. I don't know where else to look but perhaps Photekq or IvanIvanovich may know. You could try PMing them.
Offline trigun0x2
  • Potato Potato
    • HearthStats
« Reply #11781 on: Tue, 24 March 2015, 11:08:21 »
I want to get started with building my own boards. Is there a list of things I can buy or should I just buy a kit? (which is cheaper?)
Offline Dihedral
  • Mostly Harmless
« Reply #11782 on: Tue, 24 March 2015, 11:12:27 »
You can do either. Some kits come with some stuff, some kits come with all the stuff, sometimes you just buy everything separately.
« Reply #11783 on: Tue, 24 March 2015, 11:12:33 »
Here's a rough price estimate of a DIY keyboard from the OP. I suppose it depends on what you want from your board. A kit isn't necessarily cheaper but it does save you from spending a lot of time designing and troubleshooting.
Offline trigun0x2
  • Potato Potato
    • HearthStats
« Reply #11784 on: Tue, 24 March 2015, 12:06:21 »
Thanks! That helps a lot!
Offline Corey
« Reply #11785 on: Tue, 24 March 2015, 17:10:55 »
I have a Model M2 in the mail, recently refurbished by the previous owner but it is lacking the kick out feet. I'm not even sure how they work, or if I will use them, but it would be nice to know whether they are replaceable and if so where to get them.
Thanks in advance.
Offline njbair
    • nickbair.net
« Reply #11786 on: Tue, 24 March 2015, 17:12:11 »
Thanks in advance.
You're going to have to find a broken M2 for sale for parts on Ebay or something. Nobody makes those things new...
My boards:
« Reply #11787 on: Tue, 24 March 2015, 18:00:18 »
Thanks in advance.
You sure about that njbair? Have either of you guys tried emailing Unicomp to see if they have anything in stock?
Offline njbair
    • nickbair.net
« Reply #11788 on: Tue, 24 March 2015, 18:41:44 »
Thanks in advance.
For an M2? Those are different from the Model M feet, no?
My boards:
« Reply #11789 on: Tue, 24 March 2015, 18:43:15 »
Right, they could be different. But Unicomp has a lot of random IBM stuff and shooting them a quick email can't hurt. Or you can send them a message in their customer service page.
Offline njbair
    • nickbair.net
« Reply #11790 on: Tue, 24 March 2015, 18:47:43 »
You're right, couldn't hurt. Shouldn't have admitted defeat so quickly...
^ Listen to this guy, OP.
My boards:
Offline Kady955
« Reply #11791 on: Tue, 24 March 2015, 19:25:06 »
The Rapid-i case can be painted like the old qfr?
« Reply #11792 on: Tue, 24 March 2015, 19:35:33 »
I don't see why it couldn't be.
Offline Kady955
« Reply #11793 on: Wed, 25 March 2015, 03:13:26 »
I've heard its rubberised
« Reply #11794 on: Wed, 25 March 2015, 04:45:41 »
Sand the rubberised coating off first.
Offline oledome
  • not batman
« Reply #11795 on: Wed, 25 March 2015, 08:21:48 »
The Cherry G81-1800 has Cherry MY switches, the G80-1800 has MX. I want to use the housing to make my own MX ISO board. I can get a G81 for a lot less than a G80.
- Would a PCB for MX switches fit both G80 and G81 housings the same?
- What are my 1800 PCB ISO options right now?
- Is modding an existing G80 PCB an option? More expensive for the keyboard but I don't have to look for a PCB if that is the case.
I was a bit put out the 1800 group buy PCB is not ISO compatible.
« Reply #11796 on: Wed, 25 March 2015, 08:55:46 »
1) Would a PCB for MX switches fit both G80 and G81 housings the same?
2) What are my 1800 PCB ISO options right now?
3) Is modding an existing G80 PCB an option? More expensive for the keyboard but I don't have to look for a PCB if that is the case.
1) Maybe, it really depends on the case. For example, a G80-8XXX PCB wouldn't fit in a a G81-3XXX case.
2) Only PCBs I know of are ISO 1800s. There's no aftermarket PCBs besides the Leeku one.
3) Yes. Check this thread out from DT or Infiniti's thread out
I suggest reading through this. Covers what to do if the top is rubberized.
Offline joey
« Reply #11797 on: Wed, 25 March 2015, 13:36:56 »
Let's talk stabs:
TypePlate MountPCB Mount
CostarYN
CherryNY
What else do I need to know?
« Reply #11798 on: Wed, 25 March 2015, 13:42:03 »
Let's talk stabs:
CostarYN
CherryYY
I corrected one thing, there are Cherry plate mount stabilizers.
Do you have a more specific question?
« Last Edit: Wed, 25 March 2015, 13:47:53 by CPTBadAss »
Offline joey
« Reply #11799 on: Wed, 25 March 2015, 14:14:40 »
Let's talk stabs:
CostarYN
CherryYY
I'm just trying to understand what I need to know when designing a PCB and Plate, I guess you can design a PCB that works with all 3 types? The plate would have to be specific to the type, I assume.
