Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 5743263 times)
« Reply #11600 on: Thu, 05 March 2015, 07:39:05 »
Does the Nerd 60 PCB (v2) support a split (1x1 + 1x1) Backspace?
It kinda looks like it does and it's also seems possible in the Nerdy GUI keymapper...
Would be aesome if someone could clarify!  :thumb:
I honestly have no idea but you can ask GON himself.
Edit: A quick search reveals the answer is yes:
Dustinhxc
Offline azhdar
  • Praise the AZERTY god
« Reply #11601 on: Thu, 05 March 2015, 12:58:26 »
Building a keyboard with a plate, should I cut the pegs of my PCb mounted switchs (they are gaterons if that matters).
And why should I ? should I not?
Azerty Propagandiste
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #11602 on: Thu, 05 March 2015, 13:02:57 »
Only cut them off if the PCB doesn't have holes for them.
Offline azhdar
« Reply #11603 on: Thu, 05 March 2015, 13:10:07 »
Ok thanks
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #11604 on: Thu, 05 March 2015, 15:37:36 »
I am figuring out what resistors I need for me next build.
I have read a bunch of this thread: https://geekhack.org/index.php?topic=44798.0
Here is what I have so far.
(5.05 - forward_voltage)/Amps = Ohms
The forward voltage of my LEDs are in the ballpark of 3, but I know this ranges all the way down to about 1.9 with some of the red and yellow LEDs.
I am trying to figure out how many milliAmps I am looking for.  I know that most of the LEDs 'support' up to 20mAmps, but I have heard that is crazy bright.  I think some people have been targeting closer to 6mAmps.  Is that in the right ballpark?
I am trying get an idea of how many mAmps is good for brightness on a keyboard.  Thanks...
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #11605 on: Thu, 05 March 2015, 17:13:05 »
BTW, I found this website which is pretty useful for figuring out what size resistors you want: http://led.linear1.org/led.wiz
I just need to figure out how many forward mAmps I should be targeting.  I believe it should probably be in the range of 1-6 mA.  If I remember correctly my Sprit boards had something like 2 mA forward voltage and it worked pretty well.  If I can get some validation that these numbers are realistic that would help.  :)
Offline FoC_Tow
  • Brokehlicious
« Reply #11606 on: Thu, 05 March 2015, 18:55:50 »
It was mentioned before tho that gateron switches might be slightly difficult to fit in which can for example be solved by sanding them just incase you have that issue...
For reference check the Gateron group buy thread] or some of the reviews linked there! =)
First off, everything about the smoothness was absolutely true. The blacks felt great, and the blues were soft. One thing to note though, as Zeal mentioned in his Gateron build thread, these are somewhat difficult to fit into the PCB, the problem seems to arise from the PCB mounting stabs being either too thick or too far apart, which can be solved by sanding them slightly. The plastic used in the housing seems to be more flexible than that used for Cherry switches; the clips on the tops were much easier to pry apart. Keycaps also fit very tightly to the Gateron stems, comparable to Alps switches.
Dustinhxc
Also thx a lot CPT! =)
I couldn't find any infos on this...
« Reply #11607 on: Fri, 06 March 2015, 09:04:01 »
https://geekhack.org/index.php?topic=50865.msg1116486#msg1116486
According to this thread, looks like 2mA is fine.
https://geekhack.org/index.php?topic=52831.msg1176133#msg1176133
This post might help you as well. I don't know what a normal value is but it seems like you're fine.
Offline asgeirtj
« Reply #11608 on: Fri, 06 March 2015, 16:13:46 »
I clipped all the cherry stabs on my cherry board but for some reason two of them still feel mushy.  I followed blubar's guide video on how to do it, any idea of what I could be doing wrong?  Is filing important?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #11609 on: Fri, 06 March 2015, 18:13:20 »
Take a picture and show us your work? Hard to say without seeing.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #11610 on: Sat, 07 March 2015, 10:34:20 »
Great. Thanks for those links, I had not read those.
I ended up buying 500x 1k ohm and 500x 750 ohm, so I should be good to go for a while.
Offline vivalarevolución
« Reply #11611 on: Sat, 07 March 2015, 13:23:16 »
Every few months I need some springs.  So where I can I get some springs without having to participate in a group buy?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #11612 on: Sat, 07 March 2015, 13:26:54 »
mechanicalkeyboards.com and zealpc.net
« Reply #11613 on: Sat, 07 March 2015, 13:34:14 »
Was there a numpad that matched "the cheat"?
Also, does anyone know if a pink "the cheat" does exist?
« Reply #11614 on: Sat, 07 March 2015, 13:41:30 »
i don't think so, no
i think i've seen one, but you could always just re-anodize
« Reply #11615 on: Sat, 07 March 2015, 13:54:13 »
Lame.
Yea, that's what they always say. Yet here I am with a "red" LZ GH.
Oh well, I didn't need to look for new stuff anyway.
Offline asgeirtj
« Reply #11616 on: Sat, 07 March 2015, 14:35:16 »
I put some lube on it and it seemed to fix it, thanks!.
Another question: I see mechanicalkeyboards.com now has springs in stock, but they have the nonkorean measurements on them.  What would be a 55g korean spring, a 45g with them?
And since I managed to break one of my stabiliser during my last mod I need a replacement.  Is mouser the only place to get cherry stabilizers? The shipping is horrendous.
This how my checkout with mouser looks:
MERCHANDISE TOTAL:
 1,59 €
DELIVERY CHARGE:
20,00 €
 ORDER TOTAL:
 21,59 €
Pretty brutal.
Offline Melvang
« Reply #11617 on: Sat, 07 March 2015, 14:43:53 »
MERCHANDISE TOTAL:
 1,59 €
DELIVERY CHARGE:
20,00 €
 ORDER TOTAL:
 21,59 €
Pretty brutal.
On the springs you are most likely correct.  Korean springs are measured at bottom out, but cherry measures it at the actuation point.
Offline whentheclouds
« Reply #11618 on: Sat, 07 March 2015, 14:51:08 »
get the 40g springs. 45g is 62g on Korean scale
Offline ghostjuggernaut
« Reply #11619 on: Sat, 07 March 2015, 14:57:30 »
Is it possible to find Realforce key sets at retail, or close to anymore? If so, where?
How can I get my hands on an OTD board? Do they still run new models, or are they mostly older ones still in circulation?
« Last Edit: Sat, 07 March 2015, 15:21:20 by ghostjuggernaut »
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #11620 on: Sat, 07 March 2015, 17:17:36 »
When you bottom out on MX switches, what is the keycap actually hitting? I'm guessing it's either the keycaps hitting the plate (on a keyboard with a plate), and not the keycaps hitting the switch?
« Reply #11621 on: Sat, 07 March 2015, 17:47:01 »
It's the bottom of the stem hitting the bottom of the switch housing.
Edit: Actually, it seems that it's the underside of the keycap hitting the top of the switch housing.
« Last Edit: Sat, 07 March 2015, 17:48:38 by jdcarpe »
Offline vindaon
« Reply #11622 on: Sat, 07 March 2015, 23:40:51 »
Is this Hammer plate the only universal 60% plate that supports switch top removal without getting one cut yourself?
I looked at the one on GON's website and it looks like it has some shallow cuts on the top and bottom. But the notches don't look like any other plate I've seen with switch top removal or on swill's plate building tool.
« Reply #11623 on: Sun, 08 March 2015, 00:30:16 »
GON's doesn't support switch removal. There are other 60% plates that will support it including The_Beast's.
« Reply #11624 on: Sun, 08 March 2015, 10:53:53 »
So the multimeter reads  _0.85_ Amps on the 10Amp setting..  but I had it on 200ma setting by mistake, and it still gives me a reading, an _8.5_    , Is that a meaningless measurement?
« Reply #11625 on: Mon, 09 March 2015, 07:34:28 »
No it's reading correctly. The markings correspond with the prefix you want the reading to be in. So on the 10A setting, you're reading the value in Amps. On the 200ma setting, you're reading in microamps. Hence the change from .85 to 8.5.
Offline phoenix1234
« Reply #11626 on: Mon, 09 March 2015, 07:56:02 »
Something was wrong, .85 A = 850 mA > 200 mA limit, so I think it was a meaningless measurement, but the good thing is that the fuse was not burnt because the current exceeded the limit of that setting.
« Last Edit: Mon, 09 March 2015, 07:58:26 by phoenix1234 »
I like linear switches
« Reply #11627 on: Mon, 09 March 2015, 07:58:59 »
Something was wrong, .85 A = 850 mA > 200 mA limit, so I think it was a meaningless measurement but the good thing is that the fuse was not burnt because the current was exceed the limit of that setting.
Thanks phoenix1234. I can't math or work a multimeter :(
Offline phoenix1234
« Reply #11628 on: Mon, 09 March 2015, 09:57:56 »
Not a big deal :thumb:
Offline asgeirtj
« Reply #11629 on: Mon, 09 March 2015, 11:18:57 »
http://i.imgur.com/hLiBcyn.jpg
This guy got hisesc key from originative and doesn't know why his esc is higher profile than the rest.  Does Originative have a batch of esc keys which are F profile?
« Reply #11630 on: Mon, 09 March 2015, 11:20:39 »
Could simply be that he didn't sit the keycap down all the way.
Offline azhdar
« Reply #11631 on: Mon, 09 March 2015, 11:24:53 »
Pictures are from zennasyndroxx you could ask him/her.
Offline asgeirtj
« Reply #11632 on: Mon, 09 March 2015, 13:22:20 »
[/quote]
http://www.reddit.com/r/MechanicalKeyboards/comments/2ydx4o/silver_grey_duck_octagon/
I already asked him here
his answer:
This is still a question I have no answer to. I got this red ESC from originative, maybe one profile higher? :l but other gmk escape I have is on the same profile
I'm asking cause I really want and R0/F row gmk keys on my 75% so they are easier to reach fast when playing starcraft 2, if there is indeed a batch of F row esc keys with originitive I will surely buy a whole lot of them to fill my top row :D  (Would be weird that he had F row gmk keys and I wouldn't have heard about it before though)
« Last Edit: Mon, 09 March 2015, 13:24:35 by asgeirtj »
« Reply #11633 on: Mon, 09 March 2015, 14:00:18 »
his answer:
I am not aware of any profile differences that Sherry had made. Billnye and photekq might be able to chime in though. I do know that Sherry was fond of making some unique stuff to make his personal mark on things.
Offline Flyersfan1
  • Hi!
« Reply #11634 on: Tue, 10 March 2015, 19:48:29 »
Sorry this is an off topic simple question:
How do I get my avatar to appear in the upper left of the homepage? It used to be there, but it hasn't appeared in a long time, thx!  ;D
Quote from: Photekq
« Reply #11635 on: Tue, 10 March 2015, 20:45:40 »
I'm on Tapatalk right now haha. Isn't there a collapse triangle you can click to expand it?
Offline Flyersfan1
  • Hi!
« Reply #11636 on: Tue, 10 March 2015, 21:46:39 »
This is such an amazing idea. I sure wish something like this existed when i joined GH.
Oh my god, you have no idea how big of an idiot I feel right now. Thank you so much JD!!!!!!!
Quote from: Photekq
Offline radio_killah
  • Chinchillin'
« Reply #11637 on: Tue, 10 March 2015, 22:41:24 »
Is there a setting to make it so that you don't auto watch topics when you reply to them?
Offline Melvang
« Reply #11638 on: Tue, 10 March 2015, 23:02:14 »
No.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #11639 on: Wed, 11 March 2015, 00:32:09 »
Are international shipping rates pretty standard no matter the country?
Offline Melvang
« Reply #11640 on: Wed, 11 March 2015, 00:34:10 »
Varies mostly by weight from when I shipped out my batch of enablers.  When I got my estimate, all countries were the same based on the same weight though.  This was my experience though.  I had stuff going to places ranging from Canada and Mexico to Europe, to Australia and New Zealand.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #11641 on: Wed, 11 March 2015, 00:35:55 »
Alright, thanks
« Reply #11642 on: Wed, 11 March 2015, 07:43:46 »
From the US? Yes. The only exception being that shipping to Canada is slightly cheaper.
Offline stoic-lemon
« Reply #11643 on: Wed, 11 March 2015, 08:40:40 »
If I'm bending spacebar stabilizer wires myself with one of those fancy bendy tools I bought but have never used, how do I now where to make the 2 bends?
« Reply #11644 on: Wed, 11 March 2015, 08:53:43 »
Use a pre bent one as a guide and experiment?
« Reply #11645 on: Wed, 11 March 2015, 08:55:27 »
http://deskthority.net/wiki/Space_bar_dimensions
Offline stoic-lemon
« Reply #11646 on: Wed, 11 March 2015, 10:14:23 »
Thanks guys!
Offline choc
« Reply #11647 on: Wed, 11 March 2015, 12:09:08 »
Excuse me, but what is the stabilizer?
I am new here and don't understand this terminology which is common in geekhack.
I've seen so many people say sth like costar stabilizer, cherry stabilizer, and so on :confused:
Offline FoC_Tow
  • Brokehlicious
« Reply #11648 on: Wed, 11 March 2015, 13:05:45 »
Stabilizers are used on wider keys like the spacebar to keep the keys from tilting sideways when pushed on the sides, so their job is pretty much as the name suggests stabilizing keys and providing a uniform feedback on the hole key. =)
Think of a non stabilized spacebar with only one switch in the middle for example which would probably tilt like hell (and eventually not even reach actuation point of the switch) if you don't hit it dead center.
A stabilizer is much like a lever on each side of the key connected by a metal rod, so technically one side cant move more then the other without a twisting on the metal rod connecting them.
Therefore even if you apply pressure on for example the very left of the space bar it should (be forced to) stay pretty much horizontal while being pressed.
« Reply #11649 on: Wed, 11 March 2015, 14:01:03 »
In addition to FoC-ToW's great explanation, that's why the stabilizers are called "leveling kits"  by Cherry.
Costar and Cherry are 2 different types of stabilizers for MX. Cherry stabilizers then come in PCB or plate mount.
From the GH60 OP, here's a picture of them.
« Last Edit: Wed, 11 March 2015, 14:03:01 by CPTBadAss »
