Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278054 times)
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #12000 on: Mon, 06 April 2015, 19:54:17 »
I have acquired a Phantom style TKL plate (after a LOT of searching) and have Gaterons and springs in on the way. Should I put the plate in my Filco or is there a "better" option around/on the horizon that I should save the TKL plate for?
« Reply #12001 on: Mon, 06 April 2015, 19:55:32 »
I mean TKL is a really popular layout so there's a very good chance something cool will come out.
Offline greath
« Reply #12002 on: Mon, 06 April 2015, 19:58:16 »
I'm not super familiar with custom boards. I'd love something like a KMAC. Do customs generally come with plates that allow switch top removal? If not do you think there is a good possibility that the phantom plate would fit into such a custom?
« Reply #12003 on: Mon, 06 April 2015, 20:01:57 »
1) Do customs generally come with plates that allow switch top removal?
2) If not do you think there is a good possibility that the phantom plate would fit into such a custom?
1) Many Korean customs don't allow for switch top removal because they feel that it feels more solid to keep the switch holes square.
2) Um...I don't know. I know that the Phantom PCB was specifically designed to fit in a Filco case. I believe my TKL plate will fit in a Leopold but I don't know about customs.
Offline njbair
    • nickbair.net
« Reply #12004 on: Mon, 06 April 2015, 20:02:22 »
So there are two TKL customs coming up for GB soon, the Orion V2 and the Hubble Mira. Both come with a plate. I think that's pretty normal.
My boards:
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #12005 on: Mon, 06 April 2015, 20:52:56 »
Why leeku pcb not working on 64 bit?
Mine works fine for me
 Can you show me?
Um, I mean I can take a picture of aquakeytest for you but I just plugged mine in and it had the basic firmware loaded. And my leeku is at work so you'd have to wait. I'm not sure how else I can help since I've never had any problems with it.
I am very stupid, my bad. I forgot restart my computer after I connected PS2. Lol  :p
« Reply #12006 on: Mon, 06 April 2015, 20:55:17 »
 Can you show me?
But I love easy fixes! No need to feel stupid! Glad it's working :)
  • Frenzy Classic.
« Reply #12007 on: Mon, 06 April 2015, 20:58:59 »
 Can you show me?
Yes. I am very happy because it is working. Anyway, thanks.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #12008 on: Tue, 07 April 2015, 01:05:39 »
Has anyone done a group buy with Unicomp for a set of custom legends caps?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12009 on: Tue, 07 April 2015, 05:05:00 »
Hey guys, so yesterday I asked if I could test the smd led's on my nerd TKL with a power bank but when I tried none of the lights turned on so I think they're set off.
So my question is, does anyone know what the key stroke is to turn them on? I'm pretty sure it can be done hardware wise and not only a computer right?
Try Pause and Escape. That's how my Leeku's PCB changes the LED lighting mods. Or maybe insert. Seems like a lot of customs utilize the mostly "useless" keys. But I'm not 100% sure.
Thanks for the answer, I tried escape and pause and I'm pretty sure I tried escape and insert (after re-reading your message I'm not sure XD) but they didn't work so I'm just gonna go to work early tomorrow and use the computer laptop lol.
My NerD TKL is not assembled yet but you should take a look at that video (~3:23) :
Try FN1 key (*) + S
(*) by default it's your right Windows key
Thanks man, I'll try this out and report back later.
Reporting back, success!!!
I also found after watching another video that fn1 + F is for the top LED's probably for, "Front LED's" since S is for side led's
I actually also brought it to work and put the led's to breathing mode while screwing up the other modes but it's fine since I'm pretty sure I could watch this thing all night.....
Thanks LPWL, I'm done mine now so you can start your XD
GON NerD TKL DTA Edition
« Reply #12010 on: Tue, 07 April 2015, 05:49:18 »
I know mkawa worked with them to make the Red Alert and Olivetti colorways available as well as the Geekhack side legend caps. And I thought someone did media keys with them like play and pause.
Offline njbair
    • nickbair.net
« Reply #12011 on: Tue, 07 April 2015, 06:59:55 »
They're single piece caps, not two pieces right?
My boards:
« Reply #12012 on: Tue, 07 April 2015, 07:35:49 »
The Geekhack caps I have are two piece caps.
Offline Melvang
« Reply #12013 on: Tue, 07 April 2015, 07:36:49 »
Thanks CBA, I was debating on seeing if they would be willing to do something like this on a set of caps.  Plus it looks like they are getting the ability to do single piece keys.
As far as I know all Unicomp keys are two piece aside from stabilized keys.
Offline njbair
    • nickbair.net
« Reply #12014 on: Tue, 07 April 2015, 07:55:02 »
Wow I didn't realize this. That's pretty cool to hear. So then I am most likely going to order a custom replacement set for my SSK.
My boards:
Offline Lain1911
  • God of the Wired
« Reply #12015 on: Tue, 07 April 2015, 13:56:48 »
When dealing with PS/2 hookups, is it normal for a keyboard not to work in a combined mouse/keyboard hookup compared to a separate mouse and keyboard hookups?
« Reply #12016 on: Tue, 07 April 2015, 14:00:03 »
Not sure exactly what your asking but do remember typically you always have to restart for PS/2 to be recognized as it isn't plug and play like USB.
Offline Melvang
« Reply #12017 on: Tue, 07 April 2015, 14:22:26 »
Are you referring to having both a PS/2 mouse and keyboard plugged into the same port on the PC, or their respective ports individually.  Also, do not hot plug PS/2 devices, there is a risk of frying the device, lesser risk these days then years ago, but still possible.
And like spamray mentioned, PS/2 is not plug and play.
Offline njbair
    • nickbair.net
« Reply #12018 on: Tue, 07 April 2015, 17:46:34 »
I've never had to reboot while using a USB adapter. I hotplug all the time. I'm not arguing but just curious if you can actually confirm this remains an issue with some PS/2 over USB adapters.
I have never heard of any kind of risk like that when using a USB adapter, I would assume since USB ports tend to be pretty well-regulated power sources. FWIW, as I mentioned above, I regularly hotplug my Model M's and other PS/2 boards into my USB adapter without any trouble. Should I stop this habit ASAP?
My boards:
Offline Melvang
« Reply #12019 on: Tue, 07 April 2015, 18:26:36 »
If you are using a USB adapter then you are ok.
« Reply #12020 on: Tue, 07 April 2015, 18:43:18 »
I never had any issues with either one.
Offline ctm
  • Hello, world!
« Reply #12021 on: Tue, 07 April 2015, 20:20:56 »
How is the shift combined characters (e.g. !@#$%, from shift with number keys) sent? Does the keyboard determined what character it is and send the character? Or does the keyboard only sends shift and the original key, and the OS determines what character that is?
Coming:
Ellipse Model F F62.
Offline user 18
« Reply #12022 on: Tue, 07 April 2015, 20:30:32 »
The keyboard sends shift and the scancode for the key pressed. Note that shift is sent as a modifier, rather than having a "shift scancode" sent to the computer.
Avatar by ashdenej
Offline Melvang
« Reply #12023 on: Tue, 07 April 2015, 21:27:08 »
The keyboard sends shift and the scan code for the key pressed. Note that shift is sent as a modifier, rather than having a "shift scancode" sent to the computer.
I just want to add to this, I have an orbweaver, and a naga epic with the 12 buttons on the side of the mouse.  These show up as a keyboard to the computer, and there is a switch to allow either number row or number pad scan codes.  Modifiers will cross devices, IE if I have the naga buttons set as number row, hold shift on the orbweaver, and press 2, I get @ on the computer.  Same works from the regular keyboard to the orbweaver or naga.  Works with all modifiers and caps lock.
Offline Eszett
« Reply #12024 on: Tue, 07 April 2015, 23:47:08 »
Hi! question: when I have a mini keyboard without function key row, where F1 is accessed via Fn+"1", F2 via Fn+"2" ... etc., does that mean the combination of Alt + Fn + 4 succeeds in resolving to Alt-F4? Or is this a naive fallacy?
« Last Edit: Tue, 07 April 2015, 23:50:13 by Eszett »
Offline Zustiur
« Reply #12025 on: Tue, 07 April 2015, 23:58:10 »
It should work. My ergodox handles alt f4 that way.
Offline Eszett
« Reply #12026 on: Wed, 08 April 2015, 00:02:58 »
Hi there Zustiur. Thanks, I hope so!
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #12027 on: Wed, 08 April 2015, 00:32:08 »
My V60 mini works the same way with Ctrl + Alt + Fn + Backspace
Offline JWK
« Reply #12028 on: Wed, 08 April 2015, 11:52:16 »
There are people in this community working behind the scenes to bring Korean-quality offerings to GH, but it takes a little while to get those things started. Hopefully, once those projects start to become reality, we will see even more of them coming along.
This has also been enabled by the availability of CAD tools that tightly integrate with the manufacturer.  I've been impressed with with speed, quality, and price of the prototype PCBs, plates, and cases posted on this board.
Offline Ludovician
« Reply #12029 on: Wed, 08 April 2015, 13:48:41 »
So, for once I see someone selling a bunch of keyboards and I was wondering if these were mechanical. I'm obviously certain that the Microsoft and Lenovo ones aren't, but how about the Wyse and Sun ones? http://i.ebayimg.com/00/s/MTE5OVgxNjAw/z/tfEAAOSweW5VJQgl/$_20.JPG
Unfortunately this is the best picture the seller has of those two.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
« Reply #12030 on: Wed, 08 April 2015, 13:54:09 »
I don't know about Sun. The WYSE one doesn't like the normal ones that have the MX Blacks in them. I'd go with no.
« Reply #12031 on: Wed, 08 April 2015, 13:54:52 »
Pretty sure those are all rubber dome.
Offline Ludovician
« Reply #12032 on: Wed, 08 April 2015, 14:01:55 »
Well, it was worth checking out.
Thanks, guys. On another note, I saw someone selling a 1988 Model M missing keycaps for $35 AUD. Unfortunately he's in another state so I'll have to see if he's willing to post it. Wish me luck.
Typing speed:
My collection:
Pending:
Infinity kit
Offline Rose
« Reply #12033 on: Wed, 08 April 2015, 21:27:51 »
First Question
I realize that my matrix wiring may be cleaner if I rotate a couple switches so there pins are along a different edge.  These switches will go under 1 x 1.25 DSA PBT keycaps.  Will rotating the switch necessarily rotate the key?  i.e. Can a keycap be popped off, rotated 90 degrees, and put back on?  The switches are Cherry MX.
Second Question
Does everyone always wire their matrix so that the columns receive the signal and the rows transmit it back if a key is pressed?  Does it make a difference which is connected to receive and which is sending back to the controller?
« Reply #12034 on: Wed, 08 April 2015, 21:30:24 »
First Question
Second Question
1) Yes, you can rotate the switch and it will not affect how the keycap sits on the switch.
2) I'm not sure but I would guess that it does matter.
Offline user 18
« Reply #12035 on: Wed, 08 April 2015, 22:38:13 »
First Question
Second Question
It shouldn't matter, so long as you have your firmware set up to match your matrix. You're just closing a circuit, when the switch is down the circuit is closed regardless. You do need to have your diodes in the proper orientation, to match the direction of current flow.
Avatar by ashdenej
Offline hasu
  • @tmk
« Reply #12036 on: Thu, 09 April 2015, 04:19:26 »
First Question
Second Question
Right, but you should note some keycaps are very tight on 90 deg rotated switches. Komar's GH60 rev.A PCB had 90 deg switches but he removed those from later versions due to this problem.
My cheap PokerX keycaps had no problem but precious genuine Dolch keycaps were very tight on rotated switches and I didn't want to use them on the PCB :D
Offline Eszett
« Reply #12037 on: Thu, 09 April 2015, 05:39:09 »
I'm trying to open a PCB-mount MX Switch and plastic is bending and breaking, does the LED prevent the switch from opening?
« Last Edit: Thu, 09 April 2015, 05:51:44 by Eszett »
« Reply #12038 on: Thu, 09 April 2015, 06:28:24 »
Absolutely. You need to desolder the LEDs first. There should be nothing in the disassembly process of a keyboard that is so hard to take apart, things are breaking.
Offline Eszett
« Reply #12039 on: Thu, 09 April 2015, 06:35:59 »
Oh my god. For what reason did you do that, Cherry? And I bought this PCB-mount-keyboard in the hope to get an easy solution. :-(
« Reply #12040 on: Thu, 09 April 2015, 06:37:57 »
I'm sure Cherry didn't think of the enthusiasts when they made these. Probably didn't anticipate people modifying boards like we do.
Offline Eszett
« Reply #12041 on: Thu, 09 April 2015, 06:47:56 »
You are probably right, it's sad. Anyway, thank you, Captain Badass!
Offline ctm
  • Hello, world!
« Reply #12042 on: Thu, 09 April 2015, 08:46:45 »
How is fn combination sent? From what I know the keyboard controller sees that fn and the other key are both pressed and then send the corresponding character to OS. But why some remap software able to make use of fn key?
Coming:
Offline jonathanyu
« Reply #12043 on: Fri, 10 April 2015, 00:18:10 »
What program and tools do I need to draw a plate for pcb?
« Reply #12044 on: Fri, 10 April 2015, 00:32:31 »
I use autocad but Swill's plate builder will work.
https://geekhack.org/index.php?topic=65189.0
« Reply #12045 on: Fri, 10 April 2015, 06:22:27 »
Autodesk Inventor, FreeCAD, ProEngineer, and SolidWorks are all options too. Inventor and FreeCAD are free. But swill's tool is probably easiest.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #12046 on: Fri, 10 April 2015, 17:46:11 »
I am thinking about getting a Ducky YOTH Mini, is there another 60% available now with a nice case like that for under 170$? I was considering the normal mini but can not find the gray case version with browns in stock.
« Last Edit: Fri, 10 April 2015, 18:44:18 by nickheller »
Offline Firebolt1914
  • POM Overlord
« Reply #12047 on: Fri, 10 April 2015, 18:02:15 »
Should all(or most) old terminal wyse keyboards have vintage blacks? I'm thinking about grabbing one for that purpose.
Offline njbair
    • nickbair.net
« Reply #12048 on: Fri, 10 April 2015, 18:13:17 »
I'm wondering the same thing about AEKII's and orange Alps.
My boards:
« Reply #12049 on: Fri, 10 April 2015, 19:32:08 »
My experience has been that approximately the first half of the production run of AEKs (not AEK2s) 0 > 1/2M are orange and the 2nd half 1/2M > 1M are salmon (aka pink) Alps.
Apparently, some or all of the earliest AEK2s (1989 copyright) are salmon, the bulk (1990 copyright) are dampened cream, and the last (1995 copyright) are dampened white.
These are all fuzzy approximations, don't get mad at me if they are wrong.
The M0116s that I have had were also orange, but you don't get a full set.
- D Trump 2026-10-24
