Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6278029 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #12150 on: Wed, 22 April 2015, 10:24:29 »
Where can I get a plate or drawing for a plate for this PCB?
A87
http://i.imgur.com/S7XYiTb.jpg?1
http://builder.swillkb.com/
https://geekhack.org/index.php?topic=65189.0
Use keyboard layout editor to get the layout for the plate builder, then Big Blue Saw can cut it for you.
If you are using the layout editor, make sure it actually matches up with the PCB, as I made one for the B87 layout, and when matching up with the one Monstermask made, it didn't line up, so I had to use autocad to line up the plate
What do you mean by line up? Are you talking about the top row gap/ spacing?
Yeah, but the spacing issues were only with the function keys in relation to the main part, and the TKL to the main part
Do you still have the measurements you used?
Not on me right now, I might be able to grab them later today, definitely tomorrow
« Reply #12151 on: Wed, 22 April 2015, 10:29:57 »
Thanks  :thumb:
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12152 on: Wed, 22 April 2015, 23:05:56 »
For Stab lube which Tamiya lube should I be using?
GP-383 flouropolymer grease? the OP-439 antiwear grease? Or something else?
Also on the off chance that someone knows, where can I get krytox or RO-59 here in Japan?
« Last Edit: Wed, 22 April 2015, 23:27:33 by Evo_Spec »
GON NerD TKL DTA Edition
Offline fi0x
« Reply #12153 on: Thu, 23 April 2015, 02:15:14 »
Does anyone know what keyboard this is? All I know is that its a ducky keyboard with white ducky keycaps, but I don't know what the keyboard/keyboard case is.
98255-0
~I̶ ̶a̶m̶ ̶n̶o̶t̶ ̶a̶ ̶k̶e̶y̶b̶o̶a̶r̶d̶ ̶g̶e̶e̶k̶ ̶(̶I̶ ̶w̶o̶u̶l̶d̶ ̶l̶i̶k̶e̶ ̶t̶o̶ ̶t̶h̶i̶n̶k̶ ̶I̶'̶m̶ ̶o̶n̶e̶)̶ I am a keyboard geek~
Offline spale
« Reply #12154 on: Thu, 23 April 2015, 02:47:27 »
I recently bought Cherry G80-3000 LSCEU-0, and I really like BLUE switches, but I need something stronger, like MX Greens.
So I have to ask is it possible (for someone who is not techical expert) to change MX blues to MX greens since current ones are PCB mounted ( thats what I heard please correct me)?
So blues for greens is it doable?
Offline azhdar
  • Praise the AZERTY god
« Reply #12155 on: Thu, 23 April 2015, 03:01:58 »
You can make yourself Ghetto greens, find yourelf stiffer springs, open up the switch top, swap the springs and that's about it, consider lube.
Aside from the color, blue stem is similar to the greens.
Azerty Propagandiste
Offline spale
« Reply #12156 on: Thu, 23 April 2015, 03:05:53 »
Ghetto greens, sounds legit :)
Nice suggestion, can you just point me to some store in Europe that has those springs I need?
I also saw this:
Spring force is measured by bottom out force, NOT actuation force.
Does it mean I need 80g springs or stronger/weaker?
Offline azhdar
« Reply #12157 on: Thu, 23 April 2015, 03:17:19 »
I also saw this:
Here's an interesting thread about spring weights: https://geekhack.org/index.php?topic=46449.0
You need springs that are above 80g in bottom out force. Remember the korean measure it at the bottom out.
Easiest option is probably to source them here: https://geekhack.org/index.php?topic=55888.0 , you could also get the spring from a mx black keyboard.
Offline spale
« Reply #12158 on: Thu, 23 April 2015, 03:36:29 »
Great man, thx for the reply, now I know what to do.
Cheers!
« Reply #12159 on: Thu, 23 April 2015, 07:43:57 »
Maybe it's this Shine II? You could also Look through this list and see if any other board looks similar. Ducky has a lot of boards and variants, many of which look the same to me, so I'm never 100% sure on IDing them.
I'd stay away from lubing clicky switches. I've not had good experience with lubed Blues. It seems to remove some of the click from them.
I think it's WASD who uses SuperLube on their stabilizers. So whatever the Tamiya equivalent is? Something thick. And I don't know anything about sourcing lube in Japan. I'm in the process of testing out some dry film Teflon lube for switches though so maybe you'd like to experiment with different lubes? Also Hasu may be able to help you.
« Reply #12160 on: Thu, 23 April 2015, 08:11:40 »
I think maybe it's a Shine 4.
Offline njbair
    • nickbair.net
« Reply #12161 on: Thu, 23 April 2015, 08:33:34 »
It's a Shine II. The media key legends on F1-F4 are the giveaway. The 3 and 4 moved the media keys to the navigation cluster.
But I think the point is, if you want a board with a similar look, you want some iteration of the Ducky Shine.
My boards:
Offline admiralvorian
  • DIY
« Reply #12162 on: Thu, 23 April 2015, 11:01:42 »
Has anyone tried gateron browns? I see lots of reviews for almost all the other types. I'm a tactile switch fanatic - ergo clears and 45g topre. Would love it if there were gaters i could hype on.
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
Offline azhdar
« Reply #12163 on: Thu, 23 April 2015, 11:04:06 »
sadly you can't, they're slightly better than the mx but still not as tactile as ergos or Topre.
I wish gaterons made them browns ergo-like :/
« Reply #12164 on: Thu, 23 April 2015, 11:05:12 »
I regret not ordering some to try out. :(
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12165 on: Thu, 23 April 2015, 12:55:05 »
yep, right now browns are the only tactile switch gater manufactures. I can't see that being the case for very long though
Offline trigun0x2
  • Potato Potato
    • HearthStats
« Reply #12166 on: Thu, 23 April 2015, 13:27:59 »
A87
Any updates on the numbers? :D
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12167 on: Thu, 23 April 2015, 17:04:23 »
A87
Completely forgot, thanks!
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12168 on: Thu, 23 April 2015, 17:09:46 »
A87
Gyazo of what it looks like, and it is 4.76mm where it is off on both areas
Offline nightdriver
  • life is like t. rex
« Reply #12169 on: Thu, 23 April 2015, 19:20:46 »
the plate on a white / beige filco is still black, right?
« Reply #12170 on: Thu, 23 April 2015, 19:34:58 »
I'm pretty sure it is yes.
« Reply #12171 on: Thu, 23 April 2015, 19:43:15 »
A87
So the offset between the blue and white is 4.76mm? Also I assume the blue is the A.87 plate.
« Last Edit: Thu, 23 April 2015, 19:46:23 by Joey Quinn »
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12172 on: Thu, 23 April 2015, 19:44:20 »
A87
B87, but I assume? the plates are the same, and yes, that is where the offset is
« Reply #12173 on: Thu, 23 April 2015, 19:45:14 »
Can you guys please more tag those huge quotes in the future?
« Reply #12174 on: Thu, 23 April 2015, 19:45:56 »
Yeah, sorry
Offline njbair
    • nickbair.net
« Reply #12175 on: Thu, 23 April 2015, 19:48:16 »
Is there a place to buy Gaterons on demand or do I have to wait 100 years for Massdrop?
My boards:
« Reply #12176 on: Thu, 23 April 2015, 19:49:11 »
Like the Massdrop GB and the Gateron GB hosted by hwood34 and Shadovved, you get to wait like the rest of us.
Offline njbair
    • nickbair.net
« Reply #12177 on: Thu, 23 April 2015, 19:51:25 »
Well then is there a place where I can buy a replicator?
My boards:
« Reply #12178 on: Thu, 23 April 2015, 19:52:36 »
Now *that's* a ****ing good question. If you find an answer, PM me ;)
Offline ghostjuggernaut
« Reply #12179 on: Thu, 23 April 2015, 19:54:21 »
Not the one you are looking for, but hey, it's a replicator.
http://store.makerbot.com/replicator
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #12180 on: Thu, 23 April 2015, 19:54:21 »
Yep it is.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #12181 on: Thu, 23 April 2015, 19:54:51 »
No this is an A.87 so if the measurements have are for a B.87 they might not work for this.
Offline njbair
    • nickbair.net
« Reply #12182 on: Thu, 23 April 2015, 19:55:11 »
If I find one I'll replicate it, and then replicate a teleporter and beam the replicated replicator to you.*
* No guarantees on items replicated by a replicated replicator.
My boards:
« Reply #12183 on: Fri, 24 April 2015, 09:29:09 »
Thanks to sprit, it seems like there is a 1688 site where you can buy these. I cannot confirm if the site is legit though.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12184 on: Fri, 24 April 2015, 10:45:27 »
There was one CONUS vendor that put in a sizeable order, I'm sure you'll hear about it when they officially stock them
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #12185 on: Fri, 24 April 2015, 14:37:52 »
Where to I get a PCB for a G81-1138  HAU case, ANSI & winkeyless? Do I have to find a G80 and use this PCB? Am I right that there where new replacement PCBs out there with some new and fancy features?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12186 on: Fri, 24 April 2015, 14:42:43 »
leeku makes boards for these cases
« Reply #12187 on: Fri, 24 April 2015, 14:44:09 »
Yup, you can either find a G80 PCB that fits or a Leeku PCB. But the Leeku 3000 PCBs are a bit hard to find.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #12188 on: Fri, 24 April 2015, 14:46:21 »
Thanks! What is harder to find then? A G80 ANSI PCB or Leeku PCB?
« Reply #12189 on: Fri, 24 April 2015, 14:48:29 »
I've never hunted for a G80 ANSI PCB but I know I bought the last Leeku 3000 PCB I've seen on the classifieds. And that was sometime last year. Dorkvader wasn't able to find one.
Edit: I didn't realize that Kin25 was selling Leeku PCBs and plates right now. Apologies.
« Last Edit: Fri, 24 April 2015, 15:23:31 by CPTBadAss »
Offline njbair
    • nickbair.net
« Reply #12190 on: Fri, 24 April 2015, 19:16:18 »
I very recently ordered a 3000 PCB from kin25 as part of the TX1800 buy. As of 2 weeks ago it was not too late. Might be worth checking with him.
Edit: I didn't realize you were correcting yourself as I was correcting you!
My boards:
« Reply #12191 on: Sun, 26 April 2015, 01:28:10 »
Apparently it is a "Ducky shine 2 special edition white keycaps on black frame".
http://linustechtips.com/main/topic/121999-sexiest-keyboard-ever/page-2#entry1653291
« Reply #12192 on: Sun, 26 April 2015, 14:24:28 »
Could someone please school me on alps stabilizers? My next two keyboard projects will be alps and I know nothing about their stabs; plate mount, pcb mount, whatever's out there.
Offline Rose
« Reply #12193 on: Sun, 26 April 2015, 15:03:00 »
What kind of resistor do I need to connect an indicator LED to a Teensy?  I tried using the online resistor calculator at ledcalc.com .  The required parameters are Supply Voltage, Voltage Drop Across LED, and Desired LED Current.  I'm using these LEDs and the only thing I can find about them is 3-3.2 Volts which I am guessing is that second parameter, the voltage drop.  I didn't find anything on the Teensy website that resembled a supply voltage.  As far as the desired current, the only thing I've found that might be related is "Luminous Intensity : 2000-4000MCD" on the LED specs.  That online calculator mentions that 20mA works for most LEDs.
I can't find any resources or information about hooking up an indicator light.  Is there an example online somewhere that I can use to see how it should be connected and grounded?
Offline njbair
    • nickbair.net
« Reply #12194 on: Sun, 26 April 2015, 15:10:12 »
Alps stabs are historically very confusing but modern Alps sets from Matias use a pretty standard setup. From what I understand they are slightly taller than costar stabs but it is apparently possible to produce a plate which will work with both. Mr. Matias furnished a mockup of such a plate in the vendor forum (https://geekhack.org/index.php?topic=45483.msg1364703.msg#1364703). If you don't want to mess with a custom plate you can feasibly bend your own wire stabs that fit the costar spacing and the Alps cap stab mounts.
Signature Plastics produces Alps caps with cherry stab mounts. This is simplest if you can manage to get a set of SP Alps caps produced, which is currently proving very difficult.
My boards:
Offline user 18
« Reply #12195 on: Sun, 26 April 2015, 15:19:46 »
Supply voltage will be 5V, as that's what comes out of USB ports on a computer.
Current is dependent on how bright you want the LED to be -- brighter LEDs have more current flowing through them, up to a limit. Unfortunately, I don't know of a way to know for sure how your particular diodes will react to different amounts of current.
There's a wiring diagram on the led calculator that shows up after you enter all the relevant information, although it uses a battery. You want current to run from one of the digital output pins on your teensy, through the resistor (which can be hooked up in either direction), through the LED (which can only be hooked up in one direction), then to a ground pin on the teensy.
Take a look at this graphic, it might help
Avatar by ashdenej
Offline hasu
  • @tmk
« Reply #12196 on: Sun, 26 April 2015, 19:46:26 »
I use CERA GREASE HG but I don't know whether this is better or not.
If you are in Japan SHIMANO and other bike companies may be another big sources of lub. I think they have various chemicals for cycles. I had used a their top brand DURA ACE cup grease for my stabs :D
This company is supplier of RO-59 in Japan and you can buy 260ml small bottle of it from them.
http://www.tafco.co.jp/
http://www.tafco.co.jp/contact_order.html
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12197 on: Sun, 26 April 2015, 20:19:07 »
Thanks hasu!
I think I'll use the Tamiya lube for the stabs since I have a hobby shop near by that has a good selection of greases
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #12198 on: Mon, 27 April 2015, 05:58:19 »
What kind of caps does a G81-1800HAG use, and how much would be a decent price?
Offline Hzza
« Reply #12199 on: Mon, 27 April 2015, 06:26:57 »
HAG is usually UK ISO.
http://deskthority.net/wiki/Cherry_article_numbers
Not sure of the price, probably better to try the price check thread...I'm not sure how the OP feels about price checks in here.
