Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2298248 times)
Offline JonasDK
  • Let me poo on you
Re: GH60 Group Buy (PRODUCTION)
« Reply #2400 on: Wed, 07 August 2013, 17:24:17 »
So, will it support LEDS?
default i supports esc + wasd + poker arrows and maybe more.
the discussion above is about the addon module that will make it support full led backlighting.
So there will somehow be a support of backlighting???
Offline Leslieann
« Reply #2401 on: Wed, 07 August 2013, 17:37:56 »
That's the eventual plan, but until it's cone, there is no guarantee.
You could always lay some EL lighting under the keys.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline JonasDK
  • Let me poo on you
« Reply #2402 on: Wed, 07 August 2013, 17:51:20 »
You lost me at EL lighting, care to explain what it is, or give me some links to read up on  ;D ?
Offline domoaligato
« Reply #2403 on: Wed, 07 August 2013, 18:07:03 »
I am not trying to sound harsh but a large pool of resources and information about el lighting is available via google search and it would be best not to go that far off topic in this thread.
you could also open a new thread discussing el lighting and I am sure some members could explain it to you.
Offline Leslieann
« Reply #2404 on: Wed, 07 August 2013, 18:48:24 »
Look up EL Panel or EL wire, should give you all you need.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Dhell82
« Reply #2405 on: Wed, 07 August 2013, 20:30:44 »
Just joined GH recently and i really want to get one of these GH60s. Any idea if and when there will be another Group Buy like this one or if i can put in a late order for one ? Any info is appreciated. Thanks in advance.
Offline domoaligato
« Reply #2406 on: Wed, 07 August 2013, 20:36:29 »
people will have some in the classifieds after this is done.
Offline Icte
« Reply #2407 on: Fri, 09 August 2013, 04:40:02 »
Just out of curiosity, were there a lot of order of the GH60 ISO 1.25x variant?
Offline BlueBär
« Reply #2408 on: Fri, 09 August 2013, 04:50:30 »
Look in the first post at the order confirmation sheet, there's the list of who ordered what in which amount.
Offline nickwalt
« Reply #2409 on: Fri, 09 August 2013, 10:22:37 »
Regarding 1.25 ISO, if you're curious about why...
I like the poker style but wanted ISO equivalent.
Wanted a layout that works with a "tray" and doesn't need any top cover like WKL or HHKB layouts.
Will be using a mapping that makes the r-shift/win/menu/ctrl keys arrow keys using the Fn key.
Based on that, 1.25 seemed preferable to me, to keep the keys evenly balanced.
I ordered 2, I don't think I would have done that for a ready-made poker/pure but will use both in different locations.
There's definitely something about being able to say you made (at least some of) it yourself!
Offline Icte
« Reply #2410 on: Fri, 09 August 2013, 14:18:06 »
Actually reason I was curious was because I missed the sign-up for the GH60 and hoped some peopöe who bought extra of this particular model of GH60 would be willing to sell :) But awesome story nevertheless!
Offline acantha
  • Aure Entuluva
« Reply #2411 on: Fri, 09 August 2013, 15:22:32 »
I recently took over someone's order for a GH60 without assembly service. This will be my first time doing something like this. Is there existing documentation on how to assemble everything? or will some be provided? would hate to screw it up.
All the Happy Hacking Things
Offline MJ45
  • HHKB Pro
« Reply #2412 on: Fri, 09 August 2013, 15:53:45 »
If your PCB has pre - installed smd's its not hard to do the switches & led's. All you need is the basic soldering gear & experience. You can practice and get good skill by de-soldering and resoldering some junk-out dated electronics. Also there probably be a thread about the build some time soon.
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #2413 on: Fri, 09 August 2013, 15:54:18 »
Holy crap man, how did you get one? I'm trying so hard to :(
Offline do_Og@n
« Reply #2414 on: Fri, 09 August 2013, 16:02:04 »
Find some cheap Cherry boards on Ebay to practice Desoldering and re-soldering. They have 4 points to desolder which will give you a lot of practice. Plus you will get some switches and stabilizers while you're at it.
A Wyse PCE keyboard will work too but they only have 2 desolder points and the spacebar stabilizer isn't compatible with the GH60.
Offline acantha
  • Aure Entuluva
« Reply #2415 on: Fri, 09 August 2013, 16:13:04 »
thanks for the advice! guess i'm off to ebay to find something to de and re solder.
Offline MKULTRA
  • telling it how it is
« Reply #2416 on: Fri, 09 August 2013, 19:49:14 »
My first soldering experience was on my a.87 lol.  It really isn't hard.  I screwed up one of the pads on the LED's but besides that all is well.
Offline mauri
« Reply #2417 on: Sat, 10 August 2013, 12:57:07 »
Only soldering I've ever done was a pcb 1/8 the size of the gh60 and it was back in elementary school :d
I AM BABAR KING OF THE ELEPHANTS
Offline Defying
  • (suffer on)
« Reply #2418 on: Sat, 10 August 2013, 13:12:34 »
Just curious, did anyone buy extra Poker plates? Seems like I'm too late to pick one up, and I can't find plates anywhere else.
Offline gnubag
« Reply #2419 on: Sat, 10 August 2013, 13:45:02 »
I may have a beast poker plate left after everything gets here.
Offline kekstee
« Reply #2420 on: Sat, 10 August 2013, 14:40:00 »
Oh, btw, I realized I probably need to make myself a 7unit space wire for cherry stabs, since i only ordered 6.25 (yes, that was stupid). What thickness is the wire and where can i get the required dimensions?
Offline jonathanyu
« Reply #2421 on: Sat, 10 August 2013, 14:46:41 »
is there any one have a extra pcb and plate?  :( i really want one
Offline BlueBär
« Reply #2422 on: Sat, 10 August 2013, 16:23:16 »
This should help you. Works very similar for Cherry stabs, too.
Classifieds.
Offline tricheboars
  • Keyboards are Important!
« Reply #2423 on: Sun, 11 August 2013, 02:00:00 »
some awesome person should post a pic of the pcb. you know for drooling purposes.
Offline komar007
    • komar's blog
« Reply #2424 on: Sun, 11 August 2013, 03:11:33 »
Check this out: http://blog.komar.be/gh60-evolution/ for graphical comparison between rev. A and rev. B and hi-res renders. Rev. A pictures are available in various threads (http://geekhack.org/index.php?topic=41464.0, http://geekhack.org/index.php?topic=37570.msg717519#msg717519), and rev. B pictures don't exist yet!
Offline tricheboars
« Reply #2425 on: Sun, 11 August 2013, 13:54:38 »
yea the rev. b photos is what i be after!
Offline madderoftime
« Reply #2426 on: Sun, 11 August 2013, 17:47:39 »
Where is the like button?  ;D
Keep up the good work! Getting excited here.
GH60 Nevermore
Offline GeeGee
  • ㅈ ㅈ
« Reply #2427 on: Mon, 12 August 2013, 08:21:42 »
Hey guys,
I was wondering if anyone will be selling these in the future, since I missed the deadline.
Thanks
Ducky Shine 2 with Blues
Poker 2 with Reds
KMAC Korean Custom with Clears
ReΛlforce 87u 55g
456GT
Offline Qipz
« Reply #2428 on: Mon, 12 August 2013, 08:23:26 »
You should check the classifieds after people received theirs, there are plenty people who bought a butt load of GH60's and dont plan to keep them all
Offline GeeGee
  • ㅈ ㅈ
« Reply #2429 on: Mon, 12 August 2013, 08:25:52 »
Thanks for the advice :D
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #2430 on: Mon, 12 August 2013, 08:31:22 »
Awesome work Komar007!!!
Thanks very much man!
 :D
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #2431 on: Thu, 15 August 2013, 09:27:39 »
Is there an ETA on when we expect these to ship?
« Reply #2432 on: Thu, 15 August 2013, 09:47:55 »
Did the latest prototypes end up working out??
Offline T0ken
« Reply #2433 on: Thu, 15 August 2013, 11:23:44 »
Komar mentioned in the blog post that the latest prototype ships to him on August 22; then there is testing and verification before final manufacturing. I too can hardly  wait,  but as with any group buy we've gotta be patient guys...
« Reply #2434 on: Thu, 15 August 2013, 11:26:54 »
Need to find this blog!! Thanks for posting, had no idea.
Offline agor
« Reply #2435 on: Thu, 15 August 2013, 11:49:21 »
KBD8X II - MX 5000 - Realforce 88UB - Phantom - GH60
« Reply #2436 on: Thu, 15 August 2013, 11:50:06 »
« Reply #2437 on: Thu, 15 August 2013, 11:54:04 »
That was such a good read...the diagrams and adding in all the considerations we've asked for? Incredible. Great work guys. :D
* CPTBadAss is so excited
« Reply #2438 on: Thu, 15 August 2013, 12:26:00 »
Thanks guys!!
Komar is a cool guy!! That flash drive mod....sweet.  :thumb:
Offline Neal
  • Skype: iNewbcake
« Reply #2439 on: Thu, 15 August 2013, 13:53:33 »
Sweet read, didn't know you had a blog. :(
Offline komar007
    • komar's blog
« Reply #2440 on: Thu, 15 August 2013, 15:41:31 »
Thanks guys! You're bumping up my pageviews count;)
As for prototypes, pcbcart have already amazed me with their speed and making stuff way before the scheduled date, but this time it seems it's not the case. So we're still waiting.
Offline Jhors2
« Reply #2441 on: Thu, 15 August 2013, 21:28:53 »
Is this still open for orders?
Duck Blackbird | Duck LSv3 | Duck Unicorn X Legend |  TX-75 | Mira SE | LZ-CP | LZ Iron | LZ Ergo | Duck Jet Fire | OTD 360 Corsa Apple Silver | TGR-910 CE
Incoming: Zeal Zephyr | Duck TC-V3 | Singa R2 | LZ GH v2 | Noxary 280 S | Noxary 220 S
Offline gnubag
« Reply #2442 on: Thu, 15 August 2013, 21:35:14 »
no
check classifies for left overs.
Offline nil
« Reply #2443 on: Fri, 16 August 2013, 16:30:19 »
I'm purchasing a mini-B USB cable for the GH60 since I don't have one at the moment, and I'm getting confused by the number of necessary "pins". Looking at Monoprice, would this cable work?
Keyboard: On the perpetual, holy grail quest for my own GH60.
Offline domoaligato
« Reply #2444 on: Fri, 16 August 2013, 16:37:16 »
yes. but you can get a 15ft black one for less here...
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816059
Offline nil
« Reply #2445 on: Fri, 16 August 2013, 16:53:15 »
@domoaligato: Thanks for the quick reply and suggestion. I'm gonna go with Monoprice however because I want it white and 6ft is the exact length I want. :)
Offline debt4lyfe
  • time puts a gun in every hand
« Reply #2446 on: Thu, 22 August 2013, 16:57:01 »
i'm really upset that i missed this. is there likely to be a big markup when people start selling their extra boards? i don't know how these things usually go.
Offline gnubag
« Reply #2447 on: Thu, 22 August 2013, 17:22:51 »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2448 on: Thu, 22 August 2013, 18:39:23 »
There will be some that try to profit, but most will sell it for what they have into it. At least that's what I've seen from other group buys. There are bound to be people who bought one (or more) PCBs too many.
Offline domoaligato
« Reply #2449 on: Thu, 22 August 2013, 19:25:37 »
you might see the prices range a little because the sellers will include the price they paid for shipping to them in the sale cost. but most won't try to profit from them.
