Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2298014 times)
Offline Muffet
  • Man of many paths
Re: GH60 Group Buy (PRODUCTION FOR REAL)
« Reply #3250 on: Wed, 12 March 2014, 11:43:04 »
Pics or it didn't happen. ;)
Just for you. ;)
picture taken with an actual potato. :thumb:
57214-0
Remaning operations: mill edges to final thickness. mill USB slot. mill bevel on bottom. tap standoff holes.
     Painted QFR    Cherry ML for Work
Offline BlueBär
« Reply #3251 on: Wed, 12 March 2014, 11:47:38 »
Just for you. ;)
Looking good! What's the current weight of it? Will you get it anodized?
Offline Muffet
  • Man of many paths
« Reply #3252 on: Wed, 12 March 2014, 12:07:31 »
Not sure the weight on it right now, but it will of course be lighter anyways when it is finished.
For now I think will sandblast it. i would love to anodize it, but my budget for this project has been emptied long ago.
Offline GhostofHarry
« Reply #3253 on: Thu, 13 March 2014, 06:35:54 »
Sorry...
I have tried to find info of the PCB in production  but as the thread is too long i can't really get the answer for my question
Is the PCB in production a rev. c board with full led support which does not require external wiring?
« Last Edit: Thu, 13 March 2014, 06:38:26 by GhostofHarry »
Offline BlueBär
« Reply #3254 on: Thu, 13 March 2014, 07:24:29 »
Yes, it requires a separate module though which is not made yet.
« Reply #3255 on: Thu, 13 March 2014, 07:38:35 »
Thx for your reply! :D
So when I have received the pcb, without any other modules, I can only have my led at the 11 spots turned on?
(esc, caps, wasd and poker arrow)
Offline BlueBär
« Reply #3256 on: Thu, 13 March 2014, 07:58:25 »
Yes. The module will be directly attached to the PCB btw.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #3257 on: Thu, 13 March 2014, 07:58:27 »
Anything you want to know is here!
Offline BlueBär
« Reply #3258 on: Thu, 13 March 2014, 08:53:01 »
I don't know if there's much info (if any at all since it's mostly about Rev A. as far as I can see) about the addon module though?
« Reply #3259 on: Thu, 13 March 2014, 09:03:04 »
I would classify the LED backlighting add-on module as Vaporware™ at the moment. I don't think komar has had time to work on its design just yet. :)
But to answer the question, yes, only those 11 LEDs will function with a "stock" GH60 PCB (final revision).
  • Kitteh Overlord
  • Say WHAAT...
« Reply #3260 on: Thu, 13 March 2014, 15:50:00 »
oops...  :-[
Offline JayKthnx
« Reply #3261 on: Thu, 13 March 2014, 22:05:05 »
on a side note, can anyone give me a bill of materials for the smd's? if you don't want to post it here, a pm is perfectly acceptable. thanks in advance!
Can anyone help me out with this?
Offline whiskytango
  • Don't touch the trim
« Reply #3262 on: Thu, 13 March 2014, 22:29:01 »
There is a bom here but not sure which revision it's for
 https://github.com/komar007/ghkb
Offline JayKthnx
« Reply #3263 on: Fri, 14 March 2014, 02:36:47 »
Should be accurate enough for a rough estimate on costs. Thanks a lot!
Offline Dsan
« Reply #3264 on: Mon, 17 March 2014, 07:16:58 »
Giving the fact that the pcb fits every poker case it should also work with the universal plate and a duck v2 case right? :D
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #3265 on: Mon, 17 March 2014, 07:47:36 »
From the Duck Mini V2 group buy thread:
Now, you may use Poker 1 PCB, and if the shape of Poker 2 PCB is the same as Poker 1, you may use Poker 2 PCB too. However, since the dip switch hall is not through out the case, you need to detach PCB from the case to adjust dip switch mode.
(link)
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #3266 on: Mon, 17 March 2014, 09:42:50 »
More than enough, IMHO.
ty JD
Offline Muffet
  • Man of many paths
« Reply #3267 on: Wed, 19 March 2014, 11:11:23 »
I posted some finished pictures of my case over here
http://geekhack.org/index.php?topic=56071.new#new
and one teaser
Offline komar007
    • komar's blog
« Reply #3268 on: Wed, 19 March 2014, 11:39:25 »
Looks good, I hope it'll fit;)
Offline Muffet
  • Man of many paths
« Reply #3269 on: Wed, 19 March 2014, 13:48:33 »
Me too! Luckily I still have the ability to make adjustments if need be. I would just have to refinish it, as clamping would scratch the sandblasted finish.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #3270 on: Wed, 19 March 2014, 21:36:20 »
Geez!!! I like it!
Offline tbc
« Reply #3271 on: Thu, 20 March 2014, 00:38:09 »
oh wow.  that things looks awesomely hefty.  let us know the weight when you have time please
Offline komar007
    • komar's blog
« Reply #3272 on: Thu, 20 March 2014, 01:48:16 »
Update:
There seems to be no delay in production, the ETA is still the 28th of March.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #3273 on: Thu, 20 March 2014, 03:17:09 »
Update:
Cheese and crackers!!!
They've ordered the stainless (they needed a lot more to fill are order) and they said no more then two weeks to finish... so
« Reply #3274 on: Thu, 20 March 2014, 06:29:06 »
everybody share the excitement!
« Last Edit: Thu, 20 March 2014, 06:33:00 by SpAmRaY »
Offline BlueBär
« Reply #3275 on: Thu, 20 March 2014, 06:53:24 »
58077-0
Offline KyesaRRi
« Reply #3276 on: Thu, 20 March 2014, 07:43:40 »
Offline abtrout
« Reply #3277 on: Thu, 20 March 2014, 08:22:29 »
lol that wrestler is so excited
Offline okwchin
« Reply #3278 on: Thu, 20 March 2014, 09:20:20 »
Wow, guess who's late to the boat!
This thing looks awesome!
I think it would be safe to assume its too late for me to get into this GB… :))
Would my next best bet be to pick up something on the classifieds after its all done and dusted? or anyone who has already changed their minds?
Offline BlueBär
« Reply #3279 on: Thu, 20 March 2014, 09:24:18 »
Some people already have sold their orders, but yes, generally keep your eyes on the classifieds.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #3280 on: Thu, 20 March 2014, 09:31:17 »
BlueBar is right. Give it about a month and you should start seeing them pop up on the classifieds.
Offline geniekid
« Reply #3281 on: Thu, 20 March 2014, 09:35:41 »
Also, there are rumors mechanicalkeyboards.com MIGHT eventually have them - http://geekhack.org/index.php?topic=40501.msg1227564#msg1227564
Offline BlueBär
« Reply #3282 on: Thu, 20 March 2014, 09:38:49 »
I think it has actually been confirmed somewhere in the thread.
Offline tricheboars
  • Keyboards are Important!
« Reply #3283 on: Thu, 20 March 2014, 14:52:36 »
Offline 1pq
  • Hipster Doofus
« Reply #3284 on: Thu, 20 March 2014, 14:56:54 »
How long after they ship to GHers before they start popping up on mk.com?
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline v4mp1
« Reply #3285 on: Fri, 28 March 2014, 08:40:14 »
Offline sth
  • 2 girls 1 cuprubber
« Reply #3286 on: Fri, 28 March 2014, 09:54:57 »
Offline r3dx
« Reply #3287 on: Fri, 28 March 2014, 10:56:53 »
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline v4mp1
« Reply #3288 on: Fri, 28 March 2014, 18:09:55 »
Offline kekstee
« Reply #3289 on: Sat, 29 March 2014, 07:47:18 »
Plates will be aluminium, right?
Offline Glissant
« Reply #3290 on: Sat, 29 March 2014, 08:13:56 »
From the first post.
Plate
Plates will make your keyboard will feel more solid overall and help disperse some of the typing stress. They’re optional, but most people do prefer it. Each layout will require a different plate. HHKB and winkeyless layouts can use any ANSI or ISO plate with 1.5x modifiers. I designed these so the top switch housing is removable without desoldering, which helps with swapping switches, springs, stems, lubing, or stickering later on. All the plates offered in here are stainless steel. They can be directly dropped in to existing cases. More details on this in the next post.
« Reply #3291 on: Sat, 29 March 2014, 08:20:03 »
Plate
Of course WFD isn't getting the plates made anymore, not sure if that changes anything.
This is the guy getting plates and he said stainless :thumb: http://geekhack.org/index.php?topic=41464.msg1265702#msg1265702
« Last Edit: Sat, 29 March 2014, 08:26:55 by SpAmRaY »
Offline Glissant
« Reply #3292 on: Sat, 29 March 2014, 08:37:53 »
*Sigh*
Offline kekstee
« Reply #3293 on: Sat, 29 March 2014, 08:39:06 »
Woops, completely missed that information, thanks.
So no anodizing of that Poker plate I ordered^^
  • Kitteh Overlord
  • Say WHAAT...
« Reply #3294 on: Sat, 29 March 2014, 08:41:30 »
*Sigh*
Deep breaths.
 *pats on the back
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #3295 on: Sat, 29 March 2014, 08:54:05 »
Is there a thread which outlines the current state of production, or is this it?
Something like:
Electrical Components: waiting to order / ordered / received
Switches: waiting to order / ordered / received
Stabilizers: waiting to order / ordered / received
Plates: waiting to order / ordered / received
PCBs: waiting to order / ordered / received
Offline Glissant
« Reply #3296 on: Sat, 29 March 2014, 08:57:17 »
Offline GeorgeK
« Reply #3297 on: Sat, 29 March 2014, 12:10:51 »
Something like:
Nope - that would be this thread, all 3296 posts of it...
Offline BlueBär
« Reply #3298 on: Sat, 29 March 2014, 13:01:30 »
Something like:
Switches: received
Plates: ordered (I think? Prototype has been done, ApocalypseMeow probably knows more)
PCBs: ordered
Don't know about the rest.
Offline komar007
    • komar's blog
« Reply #3299 on: Sat, 29 March 2014, 14:08:10 »
Okay guys, so a status update:
The PCBs have been produced and the US/Canada part is being shipped to tjcaustin. imsto's package is on its way too, directly from China.
The plates have been ordered, and they should take another week to finish production, according to ApocalypseMaow.
Since I'm responsible for everything that isn't USA or Canada, here's an extra status update for those people:
I thought I'd manage to ship the plateless orders before the ones with plates, but I won't. This has to do with our European taxes, and my beautiful country's taxes in particular. I will wait until the plates are ready to be shipped to me and then ask our PCB fab to send the boards, so that they come more or less at the same time. I won't go into details, but this is because I'd have to pay extra tax if my whole process takes too long.
