Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2263240 times)
Offline Loligagger
Re: GH60 Group Buy
« Reply #950 on: Sun, 14 April 2013, 19:54:48 »
Do you have a second batch of 61 whites? I'll trade you stems if so :)
I just have the 61 I pulled out of my poker and temporarily replaced with clears until the gh60 arrives. Found out that I like clears a lot more than whites once I did so. I would like to try ergo clears though.
Offline Jocelyn
  • 조셀린
Re: Re: GH60 Group Buy
« Reply #951 on: Sun, 14 April 2013, 19:57:25 »
By all means, see if WFD wants them first (he'll have clears to trade you soon). I'm sure he's going to want them, but I'll take them if he doesn't lol.
PS - I also have clears I can trade, but I'd rather see WFD get his whites first :)
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #952 on: Sun, 14 April 2013, 22:16:01 »
JD i just sent you a massive pm...sorry for the length and amount of questions...my mind is full of fug
Offline MKULTRA
  • telling it how it is
Re: GH60 Group Buy
« Reply #953 on: Sun, 14 April 2013, 22:28:48 »
GH60 MX Lock compatible?
Re: GH60 Group Buy
« Reply #954 on: Sun, 14 April 2013, 22:32:53 »
MX lock fits into the same footprint as the rest of MX... you mean the software?  The software is fully configurable
Offline MKULTRA
Re: GH60 Group Buy
« Reply #955 on: Sun, 14 April 2013, 22:39:22 »
Hmmm I should try to get some from 7bit.
Offline WhiteFireDragon
    • youtube
Re: GH60 Group Buy
« Reply #956 on: Sun, 14 April 2013, 22:45:02 »
MX lock is ok for any key EXCEPT capslock, in case that's what you were thinking. The key presses for capslock doesn't work exactly the same way as any other key.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #957 on: Sun, 14 April 2013, 23:22:23 »
I am going to try them out as the Fn keyswitch, since that is a key that works on key-down events and could be useful if it stays down for the WASD arrows on a Poker.  (It might also turn out to be completely annoying!)
It is really too bad the logic of Caps Lock gets all twisted around if you try to use a lock switch, since on the old typewriters and even some terminals that was exactly how they worked.
 - Ron I samwisekoi
Re: GH60 Group Buy
« Reply #958 on: Sun, 14 April 2013, 23:26:46 »
With the appropriate firmware, it could happen
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #959 on: Sun, 14 April 2013, 23:30:01 »
how would one type with an all mx lock board?  :confused:
Offline MKULTRA
Re: GH60 Group Buy
« Reply #960 on: Sun, 14 April 2013, 23:32:24 »
Caps lock haha
Nvm I just saw the rest of the posts.  Sad
Offline fl0w3n
Re: GH60 Group Buy
« Reply #961 on: Sun, 14 April 2013, 23:33:51 »
I ordered the Universal Plates...but now today after dealing with my first PCB mount Cherry Stabs on this WYSE board I was desoldering...I'm unsure about them :(
    • youtube
Re: GH60 Group Buy
« Reply #962 on: Sun, 14 April 2013, 23:38:58 »
Stabilizers aren't something that needs to be installed more than once, unlike keycaps. But you're right, for whatever reason you need to take them off, PCB-mounted cherry stabilizers are the hardest out of the 3 types if you have a plate on there. Desoldering is no fun either.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: GH60 Group Buy
« Reply #963 on: Sun, 14 April 2013, 23:39:15 »
Caps lock haha
Could use it for a shift lock and get approximately the same thing.
Offline MKULTRA
Re: GH60 Group Buy
« Reply #964 on: Sun, 14 April 2013, 23:40:54 »
Yeah I guess you could do two shifts and throw a lock on one eh?
Offline classicps
Re: GH60 Group Buy
« Reply #965 on: Mon, 15 April 2013, 00:00:07 »
I ordered one :) for now!
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #966 on: Mon, 15 April 2013, 01:18:05 »
Caps lock haha
actually a decent idea for an hhkb layout on the right shift :P
Offline 7bit
  • MX1A-G1DW
Re: GH60 Group Buy
« Reply #967 on: Mon, 15 April 2013, 05:14:51 »
 - Ron I samwisekoi
It should be possible to program the correct logic into the controller software.
If Caps Lock is down, send a signal to the computer once and then keep silent until the status changes to "Caps Lock up".
Another way would be to use Shift or program the complete logic Caps Lock has in the computer into the controller software ...
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline cusx
Re: GH60 Group Buy
« Reply #968 on: Mon, 15 April 2013, 05:16:22 »
hmm, I've got a few questions:
1) Are casing sold separately from this thread or from this thread ? I really like the CNC casing, but I think it's completely sold.
2) As someone who has never soldered anything before, is it possible for someone like me to assemble the keyboard ? Just soldering the switches and stuff, not the smt.
Thanks !
GH60 Group Buy
« Reply #969 on: Mon, 15 April 2013, 05:19:41 »
Thanks !
1-yes they are. In the OP, you will see a list of cases and links where to get them
2-yes! It's not hard, just read up a bit, ask questions, and you'll be good!
Offline cyberwave
Re: GH60 Group Buy
« Reply #970 on: Mon, 15 April 2013, 05:46:22 »
if i wanted to build a 'Samwisekoi' layout  but with 2.25x L-shift, i'd have to get a universal plate?
Offline fl0w3n
Re: GH60 Group Buy
« Reply #971 on: Mon, 15 April 2013, 09:40:15 »
Ducky dk-1087 uses PCB mount cherry stabilizers right?
I'm just worried about sacrificing a solid rigid feel to the key presses by going with them.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #972 on: Mon, 15 April 2013, 09:41:41 »
Caps lock haha
Unforunately the computer will register any key-up event on the other shift and release the shifted state, leaving you with the shift button locked down and the computer unshifted.  Try it on your computer by holding one shift key down and pressing and releasing the other, while typing with a third ? hand.
 - Ron I samwisekoi
Offline mkaito
Re: GH60 Group Buy
« Reply #973 on: Mon, 15 April 2013, 09:45:02 »
Caps lock haha
 - Ron I samwisekoi
... or you could use your pinky fingers.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #974 on: Mon, 15 April 2013, 10:01:53 »
Caps lock haha
 - Ron I samwisekoi
Or that.
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #975 on: Mon, 15 April 2013, 10:03:09 »
you could use your pinkey fingers yea
but meh probably won't get one haha :)
Offline osxoep
Re: GH60 Group Buy
« Reply #976 on: Mon, 15 April 2013, 10:23:24 »
 - Ron I samwisekoi
I tried it and everything was still shifted...
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline mkaito
Re: GH60 Group Buy
« Reply #977 on: Mon, 15 April 2013, 10:35:43 »
 - Ron I samwisekoi
Depends on how the OS handles the keyup event. My guess is that Windows would unshift as described. I'm on Linux, and it doesn't unshift if I hold one shift, then press and release the other.
Offline whiskytango
  • Don't touch the trim
Re: GH60 Group Buy
« Reply #978 on: Mon, 15 April 2013, 10:54:25 »
 - Ron I samwisekoi
Yeah, I just tried this on Win 7 32 bit machine using QFR and a Rosewill 9000 and it did not un-shift. Not sure why this wouldn't work?? I'm also looking for something cool to do with my 2 mx locks
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GH60 Group Buy
« Reply #979 on: Mon, 15 April 2013, 12:02:18 »
I have lock on my right shift, when engaged it is shifted. Pressing the other shift does not cause lower case.
Offline Glissant
Re: GH60 Group Buy
« Reply #980 on: Mon, 15 April 2013, 12:15:44 »
Windows 8 does not "unshift" on my GH60. Works perfectly fine on my Poker too. I don't feel the need to check my Filcos.
I'm starting to wonder if I made the right plate choices. Hmmm...
GH60 Group Buy
« Reply #981 on: Mon, 15 April 2013, 12:24:45 »
Just order MOAR! You can get more plates than PCBs if you want... :)
Offline esoomenona
  • Gnillort?
Re: GH60 Group Buy
« Reply #982 on: Mon, 15 April 2013, 12:27:58 »
Or you can get more PCBs than plates!
Offline Glissant
Re: GH60 Group Buy
« Reply #983 on: Mon, 15 April 2013, 14:10:13 »
Or I could get more of both! I'm trying to avoid having to desolder anything once it's done ;). Desoldering is a PITA.
Offline esoomenona
  • Gnillort?
Re: GH60 Group Buy
« Reply #984 on: Mon, 15 April 2013, 14:12:41 »
If you went PCB mount, you would only have to desolder a minimal amount of switches to switch layouts.
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #985 on: Mon, 15 April 2013, 14:31:56 »
Attention everybody. The price of GH60 assembled PCB goes down to $30. WFD, could you update the op, please?
Offline fl0w3n
Re: GH60 Group Buy
« Reply #986 on: Mon, 15 April 2013, 14:34:48 »
Fantastic news!
Maybe that means 1 more for only $20 more than I already budgeted...
Offline aggiejy
Re: GH60 Group Buy
« Reply #987 on: Mon, 15 April 2013, 14:37:55 »
I don't suppose the DIY goes down a little too? Or is this just an assembly efficiency?
Offline esoomenona
  • Gnillort?
Re: GH60 Group Buy
« Reply #988 on: Mon, 15 April 2013, 14:38:05 »
WOOOOOOoooooooo0o0oOOo00oo00oOOO0o00oooo
Offline Glissant
Re: GH60 Group Buy
« Reply #989 on: Mon, 15 April 2013, 14:39:43 »
Well that makes it a whole lot easier to add another PCB and plate :D. I'll do that tomorrow!
Offline MKULTRA
Re: GH60 Group Buy
« Reply #990 on: Mon, 15 April 2013, 15:19:48 »
Good news!  Savin me some money.
GH60 Group Buy
« Reply #991 on: Mon, 15 April 2013, 15:23:28 »
Only $5 more for predone SMD hell? I'll have to change my order!
Offline ter_
Re: GH60 Group Buy
« Reply #992 on: Mon, 15 April 2013, 15:23:39 »
I ordered one but How do I know my order went through?
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #993 on: Mon, 15 April 2013, 15:45:58 »
It did.
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #994 on: Mon, 15 April 2013, 15:51:34 »
The DIY prices will hopefully go down as well, though everybody who orders them has to understand that these boards were designed for automatic assembly and you do need at least some experience and hardware to solder them correctly.
WFD and me are currently estimating the cost of parts (checking Europe and America).
There have been suggestions to enlarge the pads for X1, but I'm not really keen on this idea. I'm using recommended land patterns. Enlarging them together with solder paste layer means more solder and possibly solder blobs, enlarging keeping the solder paste as it was means solder pouring over the whole larger pad and potentially not enough to mount the part well. Except for that, this is the most sensitive area of the board, so the less exposed conductor the better.
    • youtube
Re: GH60 Group Buy
« Reply #995 on: Mon, 15 April 2013, 16:02:10 »
It could go down just a tad. We're sourcing the cheapest parts from the US and Europe for the DIY kit. I'm composing the BoM for the SMD components this evening.
Re: GH60 Group Buy
« Reply #996 on: Mon, 15 April 2013, 16:06:36 »
Would it be possible to update the OP with all of the new info?  Thanks for all your hard work guys!
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #997 on: Mon, 15 April 2013, 17:03:54 »
i can order two now!!!  :D :p
Offline Winther
Re: GH60 Group Buy
« Reply #998 on: Mon, 15 April 2013, 19:36:30 »
dang.. just changed my order to one PCB instead of the two I originally ordered, and then I find out its gone down in price.. :P
If I change my order again, do you guys think it would be easy to sell one (PCB or maybe with switches..) if I decide I only need one efter getting the board?
Offline Tarzan
  • formerly known as Greystoke
Re: GH60 Group Buy
« Reply #999 on: Mon, 15 April 2013, 19:37:32 »
Yes.
