Author Topic: SS G80-1800 ANSI or ISO, G80-185x, G80-186x, & G80-3700 Plates [INVOICING]  (Read 83600 times)
Offline inlikeflynn
  • file not found
What you're ordering:
A 16 gauge (0.0625"), grade T304, 2b finished, laser cut, stainless steel 1800 (ANSI or ISO), 185x (ISO), 186x (ANSI), 3700 plate. These are based off design files from KBD and have been modified bt The_Beast to have phantom style cutouts to allow switch tops to be removed without de-soldering everything. A prototype plate design has been made and tested with the only issue being that the 2x stab switches didn't have their cutouts to allow top removal, which will be corrected before these are made
Prototype:
1800 plate on a keyboard. NOTE that you will have to cut out parts of the inside of your case for these or any 1800 plate to fit. I will have instructions on this later
Images:
image graphic of 1800 ANSI plate. This will fit any 101 key (winkeyless) 1800 with ANSI layout such as 1800/1813/1838
image graphic of 1800 ISO plate. This will fit any 102 key (winkeyless) 1800 with ISO layout
image graphic of 185x ISO plate. This will fit any 105 key (winkey) 185x with ISO layout
image graphic of 186x ANSI plate. This will fit any 104 key (winkey) 186x with ANSI layout such as 1863, 1865, & 1867 only
image graphic of 3700 numpad plate
1800/185x/186x Pricing:
still TBD for the larger quanties as the shop is very busy and we don't want to bug him a million times.
Remember these are big plates compared to a poker, so that is why they cost more.
FYI Each plate type has its own price tier, so I expect the 1800 to have many more orders than the 186x
1-2 plates are $33 each
10+ plates are less (TBD still)
20+ plates are even less (TBD still)
3700 Pricing:
I just put the starting price as around a poker plate price as it shouldn't be more than that and to have something there
1-2 plates are $20 each
Shipping:
Another TBD item here as I need to actually package up my other prototype plate and see. Again these are big plates and are harder to ship
Time Frame:
Orders are closed and I'm collecting payments now and hopefully enough are paid so that I can submit  the order early next week. The_Beast will pickup the plates in late July or early August when they are done and ship them to me and then i'll ship out to everyone else
Payment:
Payment by Paypal only, +4% Paypal fee.
How to Order:
Fancy Order Form
« Last Edit: Tue, 09 July 2013, 13:24:54 by inlikeflynn »
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline inlikeflynn
  • file not found
Re: Stainless Steel G80-1800 & G80-186x Plates
« Reply #1 on: Fri, 05 April 2013, 16:15:47 »
current order numbers:
Quantity 1800 ANSI plate (101key winkeyless)   = 14
Quantity 1800 ISO plate (102key winkeyless)     = 5
Quantity 185x ISO plate (105key winkey)         = 3
Quantity 186x ANSI plate (104key winkey)         = 7
Quantity 3700 plate                                    = 4
« Last Edit: Fri, 03 May 2013, 09:32:29 by inlikeflynn »
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline esoomenona
  • Gnillort?
« Reply #2 on: Fri, 05 April 2013, 16:18:49 »
WOooOooOoo! Let's do this!
Edit: 3700 plates?
« Last Edit: Fri, 05 April 2013, 16:20:36 by esoomenona »
Offline inlikeflynn
  • file not found
« Reply #3 on: Fri, 05 April 2013, 16:38:04 »
Ok order form link is fixed now
moose/turtle/troll/blower what r u talking about 3700 plates?
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline Dianoda
« Reply #4 on: Fri, 05 April 2013, 16:39:17 »
So will this plate will fit into my Dolch PAC case, too?  I know the PAC keyboards are a little different (lock LEDs are on a tiny daughter board for non-standard placement compared to the other G80-1800's I've seen), but if it will work, I'm in for one.
Edit - okay, so it looks like I'd probably have to mod the case a bit.  Sounds fun.
« Reply #5 on: Fri, 05 April 2013, 16:40:00 »
If we find me a dolch keyboard sans caps, I will get one of these plates!
Oh I think it would, I hope so.
Offline Michael
  • Formerly Bro Caps
« Reply #6 on: Fri, 05 April 2013, 16:40:27 »
Will you also post a guide on how to modify the case to support these?
« Reply #7 on: Fri, 05 April 2013, 16:41:08 »
Ordered!
Offline inlikeflynn
  • file not found
« Reply #8 on: Fri, 05 April 2013, 16:42:33 »
yea I think it will fit just fine in a dolch with the same spots needing to be cut out. inside of the case is the same except the LED's being horizontal or vertical
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline inlikeflynn
  • file not found
« Reply #9 on: Fri, 05 April 2013, 16:43:14 »
I sure will be
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #10 on: Fri, 05 April 2013, 16:43:50 »
Which cheap G81 do I need to buy on eBay to put my PAC62 board into?
Offline inlikeflynn
  • file not found
« Reply #12 on: Fri, 05 April 2013, 16:46:35 »
this guy usually is the cheapest and they are new:   http://www.ebay.com/itm/CHERRY-NEW-PC-KEYBOARD-G81-1800LUMUS-0-16-USB-/140937937377?pt=PCA_Mice_Trackballs&hash=item20d08e41e1
I'm also working on a write up on how to change a dolch 1813HFX into a normal 1800 in one of these cases
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #13 on: Fri, 05 April 2013, 16:50:02 »
Got one. Now to order a PS/2 cable from MiMiC...
Offline codyeatworld
« Reply #14 on: Fri, 05 April 2013, 17:02:34 »
Just ordered one from him! A rose pink one!  :)
And just filled out the form for a 1800 plate!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #15 on: Fri, 05 April 2013, 17:16:33 »
Edit: 3700 plates?
I haven't tested the G80-3700 plates yet, but I don't know why it wouldn't work since it came with the other plates
Flynn can add it if he wants
« Last Edit: Fri, 05 April 2013, 17:25:28 by The_Beast »
Offline esoomenona
  • Gnillort?
« Reply #16 on: Fri, 05 April 2013, 17:27:28 »
They were mentioned in passing to possibly be included with this buy.
I'm willing to take the risk, Beasty. What's the worst that could happen?
Offline WhiteFireDragon
    • youtube
« Reply #17 on: Fri, 05 April 2013, 17:37:16 »
These look massive compared to the plates we're use to seeing.
Offline Tarzan
  • formerly known as Greystoke
« Reply #18 on: Fri, 05 April 2013, 17:45:29 »
Ach, you're fookin' killin' me!  Didn't you just finish the Poker plate GB?!  Must... have... moar... plates...
Order placed.  I'll eat beans and rice for a month, but I'll have plates for the G80 on the way.
Offline G.C.W.
  • Formerly t!ng
« Reply #19 on: Sat, 06 April 2013, 02:32:53 »
So i can just build this in by desoldering all switches and resoldering them?
Premium pouches for premium peripherals at www.wegner.design
Offline kaiserreich
  • HHKB Elite
« Reply #20 on: Sat, 06 April 2013, 06:41:50 »
What next, a G80-1800 PCB group Buy?
Offline esoomenona
  • Gnillort?
« Reply #21 on: Sat, 06 April 2013, 07:20:46 »
Yes, and modifying the case, which flynn will let us know how to do.
I'd be in.
Offline kaiserreich
  • HHKB Elite
« Reply #22 on: Sat, 06 April 2013, 08:31:16 »
I'd be in.
Somebody would probably make a G80-1800 Alu case too.
Wallethack at it's best
Offline rindorbrot
« Reply #23 on: Sat, 06 April 2013, 08:50:50 »
No love for ISO?
I'd be interested in a 3700 plate if they are offered.
Offline inlikeflynn
  • file not found
« Reply #24 on: Sat, 06 April 2013, 09:15:47 »
I'd be in.
master plan for 1800 world domination :
phase1 = 1800 specific keys, put on hold due to lack of interest & high cost: http://geekhack.org/index.php?topic=39731.0
phase2 = 1800 plates in this thread
phase3 = custom 1800 PCB to get rid of stupid jumper requirement with diodes on PCB for NKRO (with controller support of course) and maybe LEDs
phase4 = custom 1800 controller to support NKRO/6KRO, LEDs, & other TBD features.
phase5 = custom case
phase5 though is the only one which isn't a sure thing as the cost there will be through the roof. phase3/4 will likely not be until next winter, but will happen and then anyone can have an 1800 without the difficulty of finding one in the US
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline inlikeflynn
  • file not found
« Reply #25 on: Sat, 06 April 2013, 09:17:41 »
oh yea, I forgot we had the files for 3700 too (and well 3000's as well). I'll add 3700 plates into this GB as well then later this weekend.
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline esoomenona
  • Gnillort?
« Reply #26 on: Sat, 06 April 2013, 09:17:55 »
flynn, do you think a 1800 case that is made sort of how the LZ cases are made (the top piece is the most intricate, the bottom just being a plate) would be possible and possibly cheaper than one that has two milled pieces, top and bottom?
Offline esoomenona
  • Gnillort?
« Reply #27 on: Sat, 06 April 2013, 09:18:44 »
When you add the 3700 plates, just go ahead and add one to my order.
Offline inlikeflynn
  • file not found
« Reply #28 on: Sat, 06 April 2013, 09:19:54 »
instead of a BFG you can think of these as a BFP  ;D
only thing larger would be a 3000 plate
lol. well the poker plates was Beast's GB, which in a way this is as well as he is the magic man who gets them made
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline inlikeflynn
  • file not found
« Reply #29 on: Sat, 06 April 2013, 09:23:06 »
it might be. the bottom part on an existing 1800 case is pretty basic to begin with. the top part though with its size and cutouts and angles is what will be so expensive to get made i suspect. i haven't thought about this part much as its the last phase of the master plan
ok will do
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline inlikeflynn
  • file not found
« Reply #30 on: Sat, 06 April 2013, 09:28:55 »
No love for ISO?
only reason I don't have ISO on here is because we don't have the files made. I see WFD has made ISO phantom plates, so maybe if he can share the file or dimensions with The_Beast, then I can get him to modify one of these into ISO. No promises but I will ask these guys about that
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
« Reply #31 on: Sat, 06 April 2013, 09:35:17 »
No love for ISO?
If you send me the plate drawing, I can swap an ISO enter and short left shift in there.
Offline inlikeflynn
  • file not found
« Reply #32 on: Sat, 06 April 2013, 10:14:33 »
No love for ISO?
I don't have the files, so I asked Beast if he would have time todo this himself or send them to you if not.  thanks for offering to help jdcarpe!
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
    • youtube
« Reply #33 on: Sat, 06 April 2013, 11:54:27 »
Beast already has my Phantom plate files. He can do it himself or send this G80 plate file to me or jdcarpe.
Offline tricheboars
  • Keyboards are Important!
« Reply #34 on: Sat, 06 April 2013, 14:08:55 »
I don't own g80 but I think it's layout is cool.  Do these not come plate mounted?  This buy is pretty rare no?  It would be fun to build a custom g80 no doubt but I really do not need this at all. Not even a little bit. So I will order ASAP.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #35 on: Sat, 06 April 2013, 19:22:00 »
Flynn, just found this GB plates going, FOR A G80-1800  :p   Placed my order.
Nice to finally see the 1800 series get some more loving here on Geekhack.  And a BIG YES if you ever decide to make PCB's and/or FULL Aluminum Cases for these wonderful creations.
This is were money needs to be spent on.  Filco's, poker's, KMac's and LH-GZ's already get so much attention but the 1800 keeps getting ignored on here, but I was right about you Flynn.  If there is going to be a huge renaissance with the Cherry 1800 series, it'll always start with you.  8)
Thank you so much for this.
Offline Tarzan
« Reply #36 on: Sat, 06 April 2013, 19:50:36 »
If anyone needs a project board - donor G80-1800 - to use this steel plate with, they're currently on Ebay.de for about $13.00.
http://www.ebay.com/itm/120985659205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Shipping to the US will probably triple the price, but you may be able to work a deal with someone to defray the costs/share shipping.  I ordered one of these, waiting to see if I win another auction before getting it shipped to me.
Offline Elrick
  • Hype Master
« Reply #37 on: Sat, 06 April 2013, 19:54:27 »
Damn fine price there. Interested in buying a couple to do some mods with.  How much to ship it to a Prison Colony known as Australia, that's if it's available?
Offline Tarzan
« Reply #38 on: Sat, 06 April 2013, 19:59:22 »
You'd have to check with the seller.  I'm having a proxy in Germany buy it for me, ship it plus some other board(s) in a DHL package.  Be aware these are "refurbished," that can mean "rather grubby."  I think this link is to the units with USB connections, they're also selling PS/2 cabled units for one Euro less.  Pics at the link from someone who bought one from this seller;
http://deskthority.net/marketplace-f11/cherry-g80-1800-refurbished-for-14-t5501.html
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #39 on: Sun, 07 April 2013, 00:19:17 »
In for one plate since I only have one 1800, but if someone wants to sell me another 1800 I'm interested and I'll get an additional plate.
Offline inlikeflynn
  • file not found
OP has been updated with new plate options
-3700
-1800 ISO (102key winkeyless)
-185x ISO (105key winkey)
big thanks to jdcarpe for agreeing to modify the ANSI files into ISO
moose I added a 3700 to yours as requested
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline esoomenona
  • Gnillort?
Sweet. Thanks, flynn, Beast, jd, WFD, and everyone else who had a hand in these plates coming to fruition.
Offline inlikeflynn
  • file not found
pretty much all Cherry branded boards are PCB mounted. there is one super rare terminal board one that has a plate. But anything recent like 1800s or 3000s are PCB mount
I like your logic on deciding to order or not :) sounds a lot like myself
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline inlikeflynn
  • file not found
thanks for the kind words my friend from down under :)
I just added the ISO option to the op, so now there actually is a plate you can use on the ISO boards you linked
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline The_Beast
  • I like wood ಠ_๏
I just remembered. On the G80-3700's, since the plate is so short, it cannot go through the large deburring/sanding machine so the don't really have the brushed look like all the other plates I've done. They can be ground by hand (angle grinder) by the laser shop, but the finish isn't nearly as consistent as if it had gone through the sanding machine (even the machine isn't 100% consistent, but it's miles ahead of the hand ground).
Just a word of warning!
Offline inlikeflynn
  • file not found
image's of ISO plate design added to OP and order numbers updated!
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline Tarzan
Sent in a new order (hoping this replaces my older order...), to get one of each of the 18xx variations.  No idea which board I'm going to use these on, so I'm covering all my bases.   :D
Offline The_Beast
  • I like wood ಠ_๏
By the way, I installed my G80-3700 plate and there is one thing that needs to be changed so that it will allow you to change the two 2u vertical keys. Also, the case does need a bit of filing/cutting since there is a rib on the top of the case that doesn't allow you to close the case without filing.
Offline esoomenona
  • Gnillort?
Would it be possible for the plate to be adjusted to add a slot/place for that rib?
Offline The_Beast
  • I like wood ಠ_๏
No. If I did then it would be a 2 piece plate
