Author Topic: SS G80-1800 ANSI or ISO, G80-185x, G80-186x, & G80-3700 Plates [INVOICING]  (Read 85064 times)
Offline rknize
    • metaruss
Re: SS G80-1800 ANSI or ISO, G80-185x, G80-186x, & G80-3700 Plates [INVOICING]
« Reply #100 on: Thu, 22 August 2013, 10:19:19 »
I'm fine with either B or C.
Russ
Offline esoomenona
  • Gnillort?
« Reply #101 on: Thu, 22 August 2013, 12:45:00 »
Run mine through your machine, Beast.
Offline Paranoid
« Reply #102 on: Thu, 22 August 2013, 13:57:36 »
Doesn't matter for me since I only ordered a 3700.
I'll be picking up the hardboard and cutting it today and will more than likely sanding them tomorrow unless there is a large out cry for another option. Invoicing will be Friday/Saturday if Flynn gets me who ordered them and shipping Monday. Please pay ASAP so I can get this done before I head back to school
Estimated Conus shipping: $13 (Priority)
Estimated Inter. shipping:$24 (First class)
Is only shipping the 3700 also this expensive international?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #103 on: Thu, 22 August 2013, 19:31:54 »
I doubt it will be $24 since that should be the price of 1 1800 plate + backer wrapped in packing paper and bubble wrap. I'll look at just shipping the 3700 plate later.
Offline inlikeflynn
  • file not found
« Reply #104 on: Thu, 22 August 2013, 21:17:43 »
so the good man Mr_Beast will be doing everyone a huge favor by shipping these out directly. Instead of all to me and then everyone waiting for slow old me. So the good is that you will get them much much sooner than otherwise.
please do let him know though if you would like option "B" or "C" done on your plates.
also he has access to the spreadsheet and all the info, so he will be invoicing you directly for shipping
thanks thanks thanks to The_Beast
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #105 on: Thu, 22 August 2013, 21:21:05 »
I'd really like to do everything at once. If you'd REALLY like option C, let me know before tomorrow morning (I'll be leaving for the shop around 9am CST) otherwise everything will be finished to option B
Again, since the 3700 plates are so small, they cannot be refinished by me or my laser cutter. You'll have to finish them yourself with some sand paper. (All this info should have been in the OP if it wasn't)
Offline codyeatworld
« Reply #106 on: Thu, 22 August 2013, 21:23:37 »
I'm fine with b or c, but whatever is most convenient for you guys.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #107 on: Thu, 22 August 2013, 21:51:46 »
I can tell you that when I had the prototype 3700 plate made, it took at least 1 hour (maybe 2) of wet sanding with a 220 grit sanding stone to take off the 2b finish  get a consistant brushed finish look. Granted, 60 grit would have been fast so, your results may vary.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #108 on: Sat, 24 August 2013, 17:45:32 »
Plates are sanded and packed. Invoicing for shipping will be happening soon
Offline The_Beast
  • I like wood ಠ_๏
« Reply #109 on: Sat, 24 August 2013, 18:52:37 »
Everyone should have been invoiced! Pay as soon as possible please since I want these out of my hair
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #110 on: Sat, 24 August 2013, 20:23:21 »
Just paid in full your requested amount.
Thank you for arranging this I can't wait to start removing all the switches off the pcb and placing them unto these plates.  Although I do need the pics on how to dremel out the casing of the 1800 so that it all sits in tight and comfortable.
Offline inlikeflynn
  • file not found
« Reply #111 on: Sat, 24 August 2013, 22:16:39 »
Ok here is a quick and dirty summary on what to cut out of your case to make the plate fit. I will re-do this with a beige case eventually so its easier to see, but for now here it is on the original black case
I'd strongly recommend using an X-acto knife and NOT a dremel  to make these cuts. The plastic is soft and easy to cut with a knife. The dremel will just melt the plastic and you'll have to clean it up with a knife anyways
In total there are 8 different spots you need to remove case material. Cuts #1 & #2 are the only tricky ones. The rest will not matter if you remove a longer section than needed
On all of the cuts you should remove about 1/3rd of the height to allow room for the plate
Close up of the cuts around the arrow keys (1,2,3 &4). Be extra careful with #1 & #2 to not cut off the corner or the removal will be visible from above and not look clean.
Close up of the cuts up between the LED's/alpha/numpad area:
Close up of the cuts up between the number row and the function row:
And then you are done! If you have the 2 screws for connecting the bottom half to top half of the case, i'd recommend installing those as well. With the plate + those screws it is like a tank
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline Elrick
  • Hype Master
« Reply #112 on: Sat, 24 August 2013, 23:50:36 »
Thank you so much for this visual presentation  :thumb: .  So it looks like the plate simply drops into position within the case structure (after making the modifications)?
Can't wait to try it out on one 1800 keyboard.  Hope not to stuff it up.
Offline Paranoid
« Reply #113 on: Sun, 25 August 2013, 03:26:26 »
Paid! Looking forward to trying out the plate :) thanks for doing this guys!
Offline rknize
    • metaruss
« Reply #114 on: Sun, 25 August 2013, 12:42:11 »
Paid.
Russ
Offline The_Beast
  • I like wood ಠ_๏
« Reply #115 on: Sun, 25 August 2013, 18:31:22 »
Dianoda
esoomenona
BimboBB
ApocalypseMaow
binge
dorkvader
Quick list of unpaid. I'll be shipping paid orders tomorrow
« Last Edit: Sun, 25 August 2013, 23:45:31 by The_Beast »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #116 on: Sun, 25 August 2013, 23:40:12 »
Paid, sorry for the delay. Was away from computers all weekend but figured you couldn't ship until Monday anyways :p
Offline The_Beast
  • I like wood ಠ_๏
« Reply #117 on: Sun, 25 August 2013, 23:45:24 »
I just printed labels..... :(
I'll just have to print yours in the morning
Offline BimboBB
« Reply #118 on: Mon, 26 August 2013, 08:28:56 »
Will pay tonight.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #119 on: Mon, 26 August 2013, 08:50:31 »
No rush I won't have my custom 1800 PCB from Korea for several weeks
Offline Dianoda
« Reply #120 on: Mon, 26 August 2013, 09:10:45 »
Paid, thanks.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #121 on: Mon, 26 August 2013, 12:59:18 »
Oops... I'll send the moneys now!
HEY!!! Where you getting those...  ;D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #122 on: Mon, 26 August 2013, 13:16:07 »
Unpaid:
BimboBB
binge
dorkvader
Unshipped:
ApocalypseMaow
ApocalypseMaow, if you would have paid like 15 minutes early than you did, I would have shipped today :(
Please pay shipping by Thursday since I'll be moving back to school this Saturday!
  • Kitteh Overlord
  • Say WHAAT...
« Reply #123 on: Mon, 26 August 2013, 13:36:01 »
No worries Beast! Sorry for the late payment.
P.S. I'm drop off the poker plate for bending this week. I'll keep you posted!  ;D
Offline The_Beast
  • I like wood ಠ_๏
« Reply #124 on: Mon, 26 August 2013, 13:36:39 »
P.S. I am excite!
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #125 on: Mon, 26 August 2013, 14:30:35 »
Trade nice things to Koreans :(
wish there was an easier way or that I had better hookups.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #126 on: Mon, 26 August 2013, 15:08:39 »
Bummer... Thanks for reply Dan! Sorry for the OT here Beast, but yeah. Pumped to see how it turns out!!!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #127 on: Mon, 26 August 2013, 16:38:42 »
I have no problem with OT post (to an extent). I am excited too!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #128 on: Wed, 28 August 2013, 00:32:20 »
The remaining plates will be shipped today!
BimboBB
binge
dorkvader
ApocalypseMaow
Plate arrived safely. Packaged very well! Looks awesome.
« Reply #130 on: Wed, 28 August 2013, 21:11:21 »
I received my plate today, as well. Nice job with the sanding, Beast. :)
Now where did I pack that Dolch PCB when I moved?...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #131 on: Wed, 28 August 2013, 21:19:14 »
Not sand blasted. It's the same machine the laser place has but much much smaller (they have a surface sand with a digital thickness gauge, I just have a surface sander that is manual). They only do one pass and that's why my plates tend to be bowed a bit. I did 5-6 lighter passes and they shouldn't be bowed nearly as much. They also may use a higher grit than I did, I used 60, I think they may use around 80 or 120 since the grain of there's is much finer
Offline inlikeflynn
  • file not found
« Reply #132 on: Thu, 29 August 2013, 23:38:05 »
I got my plates too :)
I'd like to say thanks yet again to The_Beast as without him this GB could have never happened!!!!
Also thanks to jdcarpe for helping with the ISO plate cad files
and of course KBD for the original plate designs
and somebody needs to hook me up with one of these korean 1800 PCBs......kinda strange how mr. 1800 will be the one without one  :-\
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #133 on: Thu, 29 August 2013, 23:39:29 »
I too would like to at least see what the custom PCBs have to offer!
Offline inlikeflynn
  • file not found
« Reply #134 on: Thu, 29 August 2013, 23:41:49 »
single PCB, USB, 6KRO, LED's on every switch & programmable is my understanding of what they offer
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Let's just make our own 1800 PCB's
Offline The_Beast
  • I like wood ಠ_๏
« Reply #136 on: Thu, 29 August 2013, 23:42:28 »
Oh wow! Now you have to find one for the both of us!
Offline inlikeflynn
  • file not found
« Reply #137 on: Thu, 29 August 2013, 23:43:09 »
that was one of the phases in my 1800 world domination master plan....maybe it will continue more this winter or maybe not
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #138 on: Thu, 29 August 2013, 23:44:42 »
Should have ran plates and PCBs at the same time!
Offline esoomenona
  • Gnillort?
« Reply #139 on: Fri, 30 August 2013, 00:58:56 »
I'm in for a PCB.
  • Kitteh Overlord
  • Say WHAAT...
Offline Tarzan
  • formerly known as Greystoke
« Reply #142 on: Wed, 04 September 2013, 07:43:46 »
Posting this here for exposure
http://geekhack.org/index.php?topic=48078.0
Offline Elrick
  • Hype Master
« Reply #143 on: Wed, 04 September 2013, 19:25:36 »
Very smart.  Looks like the 1800 is finally being recognized in 2013.  I hope I can still fit the Stainless Plate into this keyboard housing?
Offline Paranoid
« Reply #144 on: Sun, 08 September 2013, 11:00:01 »
Received my 3700 plate last week. Perfect as always :)
Now to find time to sand it and build it into my 3700 ^^
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #145 on: Sun, 08 September 2013, 12:06:04 »
Would users be interested in this? http://geekhack.org/index.php?topic=48221
« Last Edit: Sun, 08 September 2013, 12:12:54 by MOZ »
Offline ruckyzomg
« Reply #146 on: Mon, 09 September 2013, 06:57:49 »
There wouldn't happen to be any spares left for the 1800 right?  :-X
Offline kaiserreich
  • HHKB Elite
« Reply #147 on: Sat, 14 September 2013, 12:55:10 »
Got the plates.
Not sure what switch should i replace the Dolch PCB with.
Offline Elrick
  • Hype Master
« Reply #148 on: Sun, 15 September 2013, 07:41:10 »
YES, this user is interested  8) .
