Author Topic: Acrylic Tenkeyless Keyboard Casing for Phantom, Filco & QFR etc.  (Read 129179 times)
Offline BimboBB
Re: Acrylic Tenkeyless Keyboard Casing for Phantom, Filco & QFR etc.
« Reply #400 on: Thu, 06 February 2014, 09:08:29 »
Same here MOZ! :thumb:
You've shown a great deal of transparency in your other projects.  Besides, your TKL case is open source, right?  Those that have doubts (or access to a cutter) can just have the case cut themselves.
Should there ever be these open source files, I am going to find a cutter myself!  :) Still want a Phantom case which is open above the nav cluster.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #401 on: Thu, 06 February 2014, 12:43:15 »
The Phantom case (Check my sig) is almost complete, I've been a bit distracted by the Blox project recently, but I do intend to post the final files in the thread very soon.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #402 on: Thu, 06 February 2014, 13:24:01 »
honestly MOZ i think you have valid fears in starting a group buy considering just how much demand there will be.
But you have 2 huge advantages,
1. You have a established reputation on geekhack and you give regular status updates, EVEN  if that means you have BAD honest news such as you not being able to get your shipments out in time before you went on an extended trip. sure vad news can reflect poorly on you but running away like this dude did is much worse
2. you are making sure you have a design finalized with kinks worked out before you start any group buy or mass sale of any type/ this specific phantom/filco case group buy he was still working on the design of the case when he opened up orders and even invoiced people. I feel like a total dumbass for paying his invoice already knowing the case had not been finalized yet. never do that ever people, this is geekhack not kickstarter.
Offline nebo
« Reply #403 on: Thu, 06 February 2014, 14:07:14 »
I actually have one of your cases MOZ, only complaints were lack of instructions and not all the parts lining up perfectly for the middle teir (which doesn't really bother me + it was an early proto I think). :P
I figured it out in the end but with a few extra parts that I chose not to use.
« Reply #404 on: Thu, 06 February 2014, 14:10:32 »
^^ He got the one you made for me MOZ. I was glad to see someone put it to use!
Offline MOZ
  • Busy making stuff
« Reply #405 on: Fri, 07 February 2014, 01:00:26 »
Is it the one with the middle layers broken up into 4 puzzle pieces? :P
Offline nebo
« Reply #406 on: Fri, 07 February 2014, 01:24:40 »
That's the one. For the longest time I didn't think of using the standoffs to hold them in place and was trying to balance them while the plate barely fit. Probably wasted a hour before I thought, "I have like, 20 standoffs. Why would I nee-.....oh."
Offline MOZ
  • Busy making stuff
« Reply #407 on: Fri, 07 February 2014, 02:05:49 »
Haha, yeah that was not even a protoype, it was a test, and making such cases is going to to be a pain, so it was abandoned.
Offline nebo
« Reply #408 on: Fri, 07 February 2014, 02:26:52 »
Well then, in the GH spirit I'll hold on to it for a while then sell it as a super rare one of a kind for super profit. :P
« Reply #409 on: Fri, 07 February 2014, 04:04:27 »
Considering you effectively paid $25 for the case you could probably double your money! :P
Offline vampirepanda
« Reply #410 on: Wed, 26 March 2014, 12:18:22 »
does this case suits all tkl keyboard? im new to this. i have a ducky g2 pro tkl. will it fit to my keyboard?
Offline nebo
« Reply #411 on: Wed, 26 March 2014, 12:34:52 »
This case isn't going to happen. A lot of people sent in money but nobody has any goods. It's been a good 6+ months now.
Offline whiskytango
  • Don't touch the trim
« Reply #412 on: Wed, 26 March 2014, 15:05:36 »
actually some of us did receive a "case", but mine at least has required so much rework to be usable that you cannot in any way call it a finished product. I'm still not finished making adjustments.
My advice? DON'T SEND THE OP ANY MONEY
Offline Rayne
  • For Science!
« Reply #413 on: Thu, 27 March 2014, 18:21:38 »
seconded!
still trying to get mine to work somehow... im so sad about how all this turned out.
Offline whiskytango
« Reply #414 on: Thu, 27 March 2014, 21:25:49 »
I have finished mine. I just washed the individual pieces with soap and water and they are drying now. If I ever get time, I will post all of the modifications I have done to make this case work.
Basically, I drilled out all the holes in the bottom layers and added some M3 blind rivet nuts (from ebay) to have something to screw into. Then, I redrilled holes for the standoff locations since the holes were in the wrong place for me. They needed to be moved over a few mm. I went ahead and drilled the standoff holes bigger and I used blind rivet nuts there too. Basically, having the M3 screws screw directly into the acrylic was a bad idea. So everywhere that was the case, I drilled the bottom layer out bigger (5mm or 3/16" drill bit) and added a blind rivet nut.
Last, some of my keys on the left side were binding up on the top layer, so I used some 220 grit sand paper to removes some of the material so that the key caps would not bind.
I also figured out how to mount a sparkfun mini USB breakout board so that I could have detachable USB.
Offline lightsout714
« Reply #415 on: Thu, 27 March 2014, 22:36:40 »
So whats the deal with this anyways? THings when south and the OP bailed? I see he hasn't logged in since november. Did he keep peoples cash? Or just send out bunk cases?
I remember I almost got in on this.
Offline whiskytango
« Reply #416 on: Thu, 27 March 2014, 22:46:36 »
I don't think anyone really knows what exactly happened. OP became increasingly less communicative. Finally just stopped even pretending to try it seems. Curse of the phantom I guess. It seems a lot of the phantom related group buys went sour.
Some of both. I was lucky enough to actually receive something from him. I think a few people never got anything.
Offline nebo
« Reply #417 on: Fri, 28 March 2014, 00:15:57 »
Yeah, I'm out around $130, got nothing no matter how much I tried.
« Reply #418 on: Fri, 28 March 2014, 00:23:33 »
That sucks guys.
Offline MOZ
  • Busy making stuff
« Reply #419 on: Fri, 28 March 2014, 01:40:54 »
I've said time and time again, direct screwing into acrylic is a bad idea, unless you want to do it once and forget about it.
Offline baldgye
  • Will Smith Disciple
« Reply #420 on: Fri, 28 March 2014, 03:31:37 »
He set up a thread in the classifieds selling coloured sets of caps for TKL boards and also asked to buy TKL cases... Sad thing is that many people bought the sets from him :/
Offline berserkfan
« Reply #421 on: Fri, 28 March 2014, 09:52:33 »
Now he's into nude photography.
http://www.straitstimes.com/breaking-news/singapore/story/police-arrest-man-who-strips-naked-mrt-train-20140314
The police interviewed him over photographing a naked man in the subway. (The online version is a much shorter version of the print article, and the extra details in the print version confirm it's indeed Takaki. Too bad I don't subscribe to the official propaganda rag so I only read it at the doctor's, or I should have scanned it here.)
Offline MOZ
  • Busy making stuff
« Reply #422 on: Fri, 28 March 2014, 10:09:27 »
LOL
Offline SpectrumPrime
« Reply #423 on: Wed, 02 April 2014, 15:40:20 »
Hello guys, really excited to push this into group buy. To cut things short, let's go into the details.
I have three questions:
1. Is this group buy still open?
2. Does this fit a Ducky Shine II TKL?
3. Is the Ducky Shine II TKL Plate mounted or not? If not mounted, then it should be fairly easy to remove and place inside the case in which case I'm interested.
I have no clue whether this is easy or not. I want to change the case on my Shine II TKL; as far I know I don't have to solder or desolder anything, my only pressing issue is whether the plate is mounted or not.
« Reply #424 on: Wed, 02 April 2014, 15:43:02 »
Bro walk away this was an epic fail/scam.
Offline whiskytango
« Reply #425 on: Wed, 02 April 2014, 15:45:25 »
Just start from this post and read backwards through the thread. I think you will find your answer. In short, there is no official "this buy is open or closed" answer, but if you send the organizer any money after actually bothering to read this thread, then you're crazy  :p
« Reply #426 on: Wed, 02 April 2014, 16:00:29 »
Well either way the question still stands, if I wanted to buy an acrylic case or any case at all for that matter, could you answer my questions? :)
« Reply #427 on: Wed, 02 April 2014, 16:01:58 »
I appreciate the heads up. :)
Offline whiskytango
« Reply #428 on: Wed, 02 April 2014, 17:48:53 »
Sorry, I'm not familiar with ducky tkl. Maybe the vortex case that mechanicalkeyboards.com sells would work? You could ask that in their vendor forum. However, as far as I know, all ducky mx boards have plates. But I only have a full size and that's my only experience. Maybe someone else can chime in.
As for acrylic cases, I don't think there are any active buys for them right now. The one MOZ is designing may work, but I don't think he is going to run a group buy for them so you would have to take the files and get your own case cut. I think the thread about that one is in "making stuff together"
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #429 on: Sat, 04 October 2014, 16:57:44 »
Are these still available?
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #430 on: Sat, 04 October 2014, 17:03:11 »
Alright, can we just lock this thread already?
Offline wes1099
« Reply #431 on: Sat, 04 October 2014, 17:38:38 »
Lol I probably should have read a little more carefully before asking such a stupid question...
        [May 20, 1987]
Offline Latin00032
« Reply #432 on: Sat, 04 October 2014, 17:52:39 »
I wanted to forget about this GB.
Here it is again.
Sad face.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #433 on: Sat, 04 October 2014, 18:02:16 »
np, almost a right of passage for newbies, necroing long dead gb's :p
Offline nebo
« Reply #434 on: Sun, 05 October 2014, 15:41:52 »
Here it is again.
Sad face.
****. I could use the $110 or whatever it was for a GON right about now.
Offline berserkfan
« Reply #435 on: Sun, 05 October 2014, 19:02:21 »
The people who were scammed first time round, you have my sympathies.
The people who came along, didn't bother to read the thread and simply bumped it up asking to buy stuff from OP - you don't have my sympathies if anything happens to you.
Offline Glod
    • YouTube Channel
« Reply #436 on: Sun, 05 October 2014, 22:07:33 »
I was trying to hide the scar tissue from this, it never really healed. that's money that is lost forever.
plz lock
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #437 on: Mon, 06 October 2014, 06:26:57 »
MODERATION NOTE:
THIS DID NOT WORK OUT.
PLEASE READ THE COMMENTS FROM HERE:
http://geekhack.org/index.php?topic=44896.msg1044921#msg1044921
SHOULD YOU HAVE AN UPDATE REGARDING THIS, PLEASE PM A MODERATOR OR ADMINISTRATOR TO REQUEST FOR UNLOCKING.
