Author Topic: Best non-mechanical keyboard?  (Read 15022 times)
Offline SOROBORU88
« on: Mon, 05 August 2013, 05:24:41 »
Hello everyone, I have non-mechanical question for you.
My father recently threw his fifth keyboard to the dumpster. Says letters smears off very quickly, and the response isn't great. He used wired and wireless keyboards. But no keyboard last more than few months.
What is the best value, most durable and comfy to use keyboard? But has to be non-mechanical keyboard. I offered him my Keycool 87 and played him sounds of all the swithes, but he told me he hates the sound of my keyboard and the other switches are even worse :D I use black switches.
Thank you very much.
Re: Best non-mechanical keyboard?
« Reply #1 on: Mon, 05 August 2013, 05:36:32 »
Any keyboard with Topre switches?
Offline Grim Fandango
« Reply #2 on: Mon, 05 August 2013, 05:37:11 »
If you do not mind spending money you could go Topre. Not "exactly" non-mechanical though.
« Reply #3 on: Mon, 05 August 2013, 05:38:20 »
Capacitive rubber dome.
Offline RougeR
« Reply #4 on: Mon, 05 August 2013, 05:53:19 »
he will like other switches....hes just being stubborn.
Buckling spring warrior!
Offline SOROBORU88
« Reply #5 on: Mon, 05 August 2013, 06:49:18 »
Thank you for your answers. Topre keyboards are super rare around here and it would be very expensive to buy them from outside my country. Plus, my father doesn't speak English, so he needs keyboard, which manufacturer supporst CS layout.
Offline Jesterfox
« Reply #6 on: Mon, 05 August 2013, 10:17:41 »
Buy him a Cherry G80 with MX Clear and don't tell him its mechanical ;-) or just try a G86 (or G83) from Cherry.
Gaming Keyboard: Corsair K70 MX-Red // Typing Keyboard: Filco Majestouch Metallic Blue MX Blue
NEO // G80 1000 HAD 07 // G80 3000 LQCDE-02 // Raptorgaming K1 // G84 4700  // G84 4400 PRBDE
G85 Barracuda XT // G83 13000 Cybo@rd // Cherry STRAIT // FSC KBPC PX // needs repair: HP Vectra KBD
Avatar by Amaroq
« Reply #7 on: Mon, 05 August 2013, 10:44:27 »
If I had to use a non-mechanical I would definitely go with Logitech K750, it is a scissor switch and feature wireless connection and is solar powered.
Offline Lupizza
  • Kung av Sverige!
« Reply #8 on: Mon, 05 August 2013, 12:28:44 »
Screen keyboardd  :thumb:
Left geekhack 2013-08-24, because of rude and arbitrary moderators.
Offline Carter
  • CM Storm Rep
  • * Commercial Vendor
« Reply #9 on: Mon, 05 August 2013, 13:41:07 »
Sidewinder X4
Offline SOROBORU88
« Reply #10 on: Mon, 05 August 2013, 14:26:00 »
Screen keyboard? :D My father refuses to buy smartphone and I would force to use whole compouter with touchscreen :D I would rather teach Miley Cyrus to sing than this :D
Scissor switch? Never heard of it. I believe it is something notebook keyboards usually use?
Offline Xenderwind
« Reply #11 on: Mon, 05 August 2013, 14:44:57 »
Yep, scissor switches are what laptop keyboards use.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #12 on: Mon, 05 August 2013, 16:05:15 »
Scissor switches aren't that bad. I just don't like how small the caps are and sometimes it feels like you are repeatedly tapping your finger on a desk which can be a bit stressful on your fingers. If you get good at using one, you can type pretty damn fast on them.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #13 on: Mon, 05 August 2013, 16:13:40 »
Microsoft Ergonomic 4000
Offline SOROBORU88
« Reply #14 on: Mon, 05 August 2013, 16:56:39 »
I like microsoft comfort 3000, it looks good and feels sturdy and comfy (my cousin has it). But both comfort 3000 and 4000 are curved. Dad doesn't like curved (keyboards). I don't think scissor switches would be fine, since my father writes only with his two pointing fingers. Therefore he smashes the keyboard, hard.
Offline Lastpilot
  • Power stance
« Reply #15 on: Mon, 05 August 2013, 17:01:37 »
I've tried a couple spring loaded rubber domes and those were pretty good. I forget the brand name though...
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #16 on: Mon, 05 August 2013, 17:17:04 »
The old Dell Quietkey keyboards were pretty good.
Offline SOROBORU88
« Reply #17 on: Mon, 05 August 2013, 17:19:55 »
I saw some of those http://www.czc.cz/dell-kb212-b-quietkey/95364/produkt in my father's job. What are they? I use to have Dell Vostro 1310 and it didn't perform well :(
Offline brialona
« Reply #18 on: Mon, 05 August 2013, 17:26:24 »
i dont think he was referring to that quietkey.
i think he was referring to this one
http://s3.amazonaws.com/kpsurplus_images/e9e51be7ff0814b9202fd59d2ed01a3b17909851.jpg
ozil
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #19 on: Mon, 05 August 2013, 17:35:54 »
Offline lazerpointer
  • ya gotta stay phresh
« Reply #20 on: Mon, 05 August 2013, 17:41:23 »
E8HKG-0917 (made by Chicony)
We have white and black versions of these at work (the white ones are wired, black ones are wireless with USB dongle.) --- I took the key caps from one of either type and swapped them. The outcome is sexy, and they aren't bad for rubber dome boards.
Not TKL, but the closest I could get with rubber domes around here.
i type, therefore i geekhack
Offline smknjoe
« Reply #21 on: Mon, 05 August 2013, 18:08:16 »
Technically, all rubber domes are mechanical. They just use rubber as the mechanism, but for the sake of GeekHack they are not referred to as mechanical.
SSKs for everyone!
Offline SOROBORU88
« Reply #22 on: Mon, 05 August 2013, 18:18:07 »
Well, all your suggestions are very helpful. I would buy them for myself. But I have to work out the keyboard, which has czech letters. What about the dell I've already posted?
Offline Leslieann
« Reply #23 on: Mon, 05 August 2013, 18:36:13 »
Personally, one of the best non-mechanical to me, is the Logitech Illuminated.
Keys lasted a long time, especially for a backlit, feels nice, it's quiet... It uses scissor switches, which I like better than traditional rubber dome.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline SOROBORU88
« Reply #24 on: Tue, 06 August 2013, 08:27:33 »
Problem is, that when I buy logitech illuminated, the czech letters are either non-backlit or poorly backlit, depending on the version a I don't have a possiblity to check this in the store. I have to order everything online. Support for czech language is very poor througout all the manufacturers. Even microsoft Sidewinder X4, which is backlit and my father seems to like it (on the picture), the reviews of the layout are horrible, since the czech letters are small and poorly backlit. The czech letters are made here, not in the factory with US keyboards. And my father smeared letters from all keyboards he had, except his toshiba laptop.
The genius luxemate 202 or so has similar keycaps like the toshiba A660 pro notebook. But I consider genius accesory as budget category.
Offline cactux
  • Topre Knight
[FS]☠ The temple lol ->HERE<-
Offline SOROBORU88
« Reply #26 on: Tue, 06 August 2013, 11:05:35 »
Looks good :) Is it a good value concerning the quality and durability? And is bluetooth reliable? I thought it's only a laptop thing. But my father talks about buying AiO PC, so...
Offline davkol
  •  Post Editing Timeout
« Reply #27 on: Tue, 06 August 2013, 11:21:44 »
Cherry G81. Seriously. Cherry MY are supposed to be nice for hunt'n'peckers, and it's possible to get Czech keycaps (someone sold those at Deskthority a while ago).
Otherwise, I'd like to get rid of some KeyTronic and *old* Dell QuietKey keyboards, all of them have Czech lettering.
Offline Larken
« Reply #28 on: Tue, 06 August 2013, 11:26:38 »
actually it sounds like your dad doesn't have a problem with the feel of the keyboards, but rather with the letters fading off after extended usage. This is going to keep happening with most keyboards (esp. since your dad appears to be going through them at one keyboard every three months). What you need is double shot, or dye subbed keycaps, which can be gotten - albeit not cheaply. The main problem would be the czech layout - which according to
http://geekhack.org/index.php?topic=13693.0
is either extremely rare, or never produced at all.
laser etched or pad printed are eventually going to wear out, no matter what. What you might think about doing is to get a mechanical keyboard, and use relegendables - and print out your own labels for those czech layout specific keys. It's a very costly solution, but it would probably last you a lot longer than buying new keyboards again and again.
Just wondering about one thing: obviously your father has to either be using the keyboard almost 24 hours a day (or be sweating acid through his fingers) to wear through a keyboard that fast; does he really need those legends? I would imagine he could touch type if he'd been going through that many keyboards so far. If he didn't need the czech specific legends, I imagine a doubleshot keycap set would serve him quite nicely for a few years.
| Ergodox #1 | Ergodox #2 |
Offline SOROBORU88
« Reply #29 on: Tue, 06 August 2013, 11:38:35 »
Yeah, my father can't touch type since he has very small hands due to illnes. And the smearing is parttly the problem of the cheapest boards he buys and partly by that he is RC modeller and has a PC next to his hobby room. Simetimes he types (looks for something on the internet quickly) with fingers covered with glues and chemicals :D And also he types like a cat, he bumps the keys with tips of his fingers and scratches the keys with fingernails.
When I type on my mechanical keyboard, I always wash my hands first :D
He is currently using laptop and the letters looks good so far. I had that notebook for three years and I used it nonstop for 18 hours a day (law faculty). But before he used Logitech K360 with which he was very satisfied, but sometimes he had problems with range so I thought I will buy him wired keyboard.
Offline davkol
« Reply #30 on: Tue, 06 August 2013, 11:40:00 »
Laser etching without infill is fine.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #31 on: Tue, 06 August 2013, 11:51:11 »
i don't know, but i am still pretty fond of my "dell quiet key" and "olivetti" i would think that the model m rubber dome is pretty good as well although i have never tried one
i did take my dell sometime ago apart, cleaned, blacked part of the face plate out and spruced it up some so it would not be so vanilla.
i like old boards, so i am sure i am in the minority
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Larken
« Reply #32 on: Tue, 06 August 2013, 11:57:37 »
Ah I see. In that case, barring being able to find those specific doubleshots/dye subbed keys, you might just have to go for quantity over quality. The Dell Quietkeys mentioned by davkol are a favorite for a few geekhackers (though I never used one personally) when it comes to rubber domes, and should be a good buy, even if they're used.
Since they have czech lettering and your dad isn't really into the feel of the cherry switches, I imagine that it would make a nice match, and much more affordable to boot.
Otherwise, look into relegendables.
