Author Topic: geekhackers.org store testing -- lube kits and PS2 -> USB adapters!  (Read 26132 times)
Offline Glissant
  • Trade Count: (0)
Lube me up, sir ;).
Offline mkawa
  •  No Marketplace Access
  • Trade Count: (0)
  • (ツ)@@@. crankypants
7 (?) sets left.
Offline Tarzan
  • formerly known as Greystoke
  • Trade Count: (0)
Just as a data point, I got the USB adapters today - northern Virginia.
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
HOLD THE PRESSES FOLKS
i've just discovered that IF YOU EAT 3.7 TIMES YOUR BODY MASS IN KRYTOX OIL, YOU HAVE A FIFTY PERCENT CHANCE OF DYING
be careful out there guys.
wow shoot I better be care
request: pic of sifo 50% dying
Did someone request a pic of sifo dying?
TOO BAD FOR YOU
              Phantom 62g MX Whites
  • Trade Count: (0)
or sifo dyeing
31719-0
Offline MOZ
  • KING OF THE NEWBIES
  • Trade Count: (0)
  • Busy making stuff
or sifo dyeing
Epic LMAO!
Offline Xenderwind
  • Trade Count: (0)
Got my lube kit today.  Everything arrived safely, at least I think.  I have not fully unwrapped the lube yet since I saw small amounts of lube on the wrapping at I got further down (and I don't have any gloves).  But I'm going to attest that to either a really really small leak, or the fact that you probably have lube everywhere in your house.  The syringe is safe as well.  I can take pics if needed, but trying to eat atm :D.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline codyeatworld
  • Trade Count: (0)
Got mine today, a little bit leaked out and got on the wrapping and the skinny bottles. but not a lot from what I can tell.
Its not a  big deal, just thought you should know.
Thanks a lot mkawa.
Offline mkawa
  • Trade Count: (0)
or sifo dyeing
YYEESSSSSssssssssss.......
umm, yes, the vials are slippery because i literally have krytox everywhere in my apartment, and myself. basically 24/7. if it's not clear that a significantly amount got out of the vial (the oil vial would be like half empty most likely), it was probably either a slight pressure issue or just the grease that was on all the grease vials migrating with heat cycles in hot trucks. i have one report of a straight up smashed oil vial, but that was with those damned 3x4 envelopes that i won't be using ever again. for anything.
  • Trade Count: (0)
Mwaka what is the procedure for washing this stuff off?
Offline Xenderwind
  • Trade Count: (0)
There was actually a part of the note that was included that states:
There are exactly seven solvents that dissolve krytox products and:  six of them cause cancer, and the last one is the chemical equivalent of an anti-krytox, except it costs three times as much and is nearly impossible to purchase.  Also, it may cause cancer.  You have been warned.
Offline mkawa
  • Trade Count: (0)
i buy the big packs of microfiber cloths from costco and wipe everything down. when a towel is saturated with krytox, i rinse it out and dry. after enough cycles of this, the towels become pretty useless and have to be tossed.. the costco microfibers are about 0.4USD each, so it ends up working out. all future shipments will come with at least one pair of disposable gloves (the note actually states that every pack comes with a pair of gloves, but i doofed and forgot the gloves for the first 10 shipments or so.
there are 5 or 6 beta kits left. after this, prices go up, so if you want krytox in the US, now is a pretty good time. more niceties will come in later packs, but they will have to cost more.
there will be super cute heart stickers though. hat tip to jocelyn for that one.
note that the problem with trying to dissolve krytox polymers is that you release flourine. flourine unbonded is an extremely nasty, corrosive substance. hence, badness. the least toxic solvent for krytox is actually another PFPE that is designed to attract the PFPE base in krytox products and bond to them, and then there's some chemical magic that I don't understand. However, even this product has a max exposure of 750 PPM; ie, it is toxic.
krytox itself is completely, wildly non-toxic. so the best cleanup procedure is probably some rags and time. yes, eventually everything you own will have a trace amount of krytox on it, but i've been living in trace amounts of krytox all week/end and it's not so bad -- everything is just slightly less frictiony. also, it's odorless and tasteless. so basically, i'm unable to tell via the usual methods that there is krytox everywhere. i just know because there has to be.
one should also note that the reason i have krytox everywhere is because i did a horrible job trying to pack the beta kits and i have 20-30lbs of it in my living room. the few grams in each kit won't get nearly as far, frankly.
« Last Edit: Wed, 14 August 2013, 20:01:57 by mkawa »
  • Trade Count: (0)
You could kill a tiny baby with that.  If you force fed it to them.
  • Trade Count: (0)
So basically don't use krytox to moisturize the cat.
Unless they are stuck somewhere, then it might come in handy.
« Last Edit: Wed, 14 August 2013, 21:12:53 by SpAmRaY »
Offline mkawa
  • Trade Count: (0)
cats are already pretty slippery little critters. i really don't think they need it.
Offline korrelate
  • Trade Count: (2)
  • iubeo stultum esse libenter
PMed!
Topre REALFORCE
Offline actionbastard
  • Trade Count: (0)
Got mine today, mine was pretty much same as Cody's. vial's were closed but a little oily.
Didn't get around to messing with the lube today though, my ErgoDox also came in and I spent literally 6 or 7 hours putting it together. But it's done, and works. :thumb:
Offline mkawa
  • Trade Count: (0)
awesome!
Offline MOZ
  • Trade Count: (0)
  • Busy making stuff
I've wished more times than I can remember that I was in the US this week.
  • Trade Count: (0)
But then you couldn't do all the awesome stickers, acrylic keys, etc!!! ;)
Offline boost
  • BOSTMOBILE
  • Trade Count: (0)
  • NY Giants!!!
Got my kits in!!!!
anyone wanna "test" the lube by lubing 500 switches for me ;)
-Enzo Ferrari
Offline Xenderwind
  • Trade Count: (0)
Got my kits in!!!!
I'm still debating if I want to relube mine.  I just used the cheap teflon stuff last time but that was only a couple weeks ago.  I'd hate to have to desolder all the switches and open them again, but at least I have a switch tool this time.
Offline MOZ
  • Trade Count: (0)
  • Busy making stuff
Got my kits in!!!!
Send it my way! :P
I know, I had this discussion int he PM with HoffmanMyster, and said what I said earlier and in the same line, what you mentioned.
  • Trade Count: (0)
Got my kits in!!!!
all at once :o
just put all the switches in a BIG zip lock bag then dump in lube and shake...
  • Trade Count: (0)
You'll just have to come visit around the time of KeyCon 2014!  :D
On topic: can't wait to receive my kit!  Should get it by this weekend when I go home.
Offline mkawa
  • Trade Count: (0)
4 kits left. last chance to get yours shipped before i leave for keycon
Offline Dubsgalore
  • Trade Count: (0)
lubed recieved
thanks dood
accidentally touched the plastic wrapping around the bottles, and now my keycaps are greasy x_x
Offline Glissant
  • Trade Count: (0)
All the lube showed up intact with scary latex gloves that made me think I was dealing with death in tiny syringes.
Love the instructions too. Maybe just give a link to an online document with that information in the invoice or receipt to save paper?
Offline mkawa
  • Trade Count: (0)
1) they're nitrile gloves, so safe if you have a latex allergy!
2) at some point the geekhackers storefront will have all this documentation. this was something i wrote up in the rush to get the beta kits out. i wanted to personally thank everyone who was willing to try out my first effort at this personally, and that's why you always leave a note.
Offline Glissant
  • Trade Count: (0)
Exceptionally serious reply to a warm and joking post. I'll go back to not posting now :).
Offline mkawa
  • Trade Count: (0)
IT WAS ALL JUST EXCUSE FOR THE ARRESTED DEVELOPMENT REFERENCE
Offline domoaligato
  • Trade Count: (0)
If I was to say... spill some of this. what is the best way to clean it up? dawn dish soap? isopropyl alcohol?
Offline mkawa
  • Trade Count: (0)
disposable microfiber cloth
Offline domoaligato
  • Trade Count: (0)
nevermind I see this now. it sounds like trolling though. :(
edit: wow.... this stuff is crazy. lol must get some.
« Last Edit: Sun, 18 August 2013, 20:23:32 by domoaligato »
Offline mkawa
  • Trade Count: (0)
Offline mkawa
  • Trade Count: (0)
... and i think we're all out of beta kits now! thanks for your orders everyone!! :)
on wednesday i will retrieve the last of the parts for the pre-RTM kits (i think there's one more thing i want to include in the final final-ish kits -- a larger diameter needle for suction-filling with the plunger... but i'm still trying to decide if it will actually help or just drive up the cost of the kits for no good reason. 5ccs just doesn't give you that much vacuum unfortunately..).
matt3o has been hard at work on the storefront and i'm hoping at least a beta version will go up by next week so that kits can be ordered properly. i also have dyesubbed spacebars from imsto coming in at some point that i know a number of you have been waiting patiently for, and something something i can't remember).
ok anyway, if you've contacted me with an order in the last couple days, i will get back to you by wednesday pacific time at the latest.
Offline JPG
  • Trade Count: (0)
  • Model F is my new passion!
I got my lube today. Seems okay, a little oil evaporated, but it's very few. The package did it's job!
Thx Kawa  :thumb:
Offline mkawa
  • Trade Count: (0)
yes! through canuck customs!
Offline mkawa
  • Trade Count: (0)
oh by the way, nothing evaporated. i left a little room in each vial because the density of the oil and grease lower slightly when heated (by quite a bit, but you never know with mail)
Offline korrelate
  • Trade Count: (2)
Received my beta package yesterday. Very timely shipping. Thanks mkawa!!
Topre REALFORCE
  • Trade Count: (1)
Got my ****, but u already know it Gucci
Offline thadood
  • Trade Count: (0)
Glad I was able to place a finish line order!
Offline n0rvig
  • Trade Count: (0)
Got my shipment yesterday. It probably arrived earlier but I only just checked the mailbox.
Love the instructions. My muscles are tired because I'm a geek.
  • Trade Count: (0)
Mine arrived today - thanks!
Only 12 days - that might be a record.
Offline mkawa
  • Trade Count: (0)
yes!
i have 16 pre-RTM kits packed. these are the same as the beta kits with a few exceptions: ALL of them contain gloves. i have included a swizzle stick for mixing and moving around the grease (beta+ kits also have this). finally, the grease vials have a much wider mouth which makes them quite a bit easier to work with. Price on these is 16$ USD. Same shipping restrictions as before. I will not ship into china or SE asia, as they still come with hypodermic needles, and i don't want anyone to get put in jail (yeeps!)
Offline mkawa
  • Trade Count: (0)
rowdy didn't order any lube by the way. still need to test lube packs into australia. anyone in australia need krytox? :D
Offline MOZ
  • Trade Count: (0)
  • Busy making stuff
rowdy in australia
rowdy gets krytox lube
rowdy didn't order krytox lube
need to test shipping to australia
Now I am confused.
I really want to get some lube, however I am a MX Blue fan and lube will dampen the feel I love. What to do. First world problems.  :-\
  • Trade Count: (0)
Rowdy received three PS/2 to USB adaptors, and in the spirit of transparency, Rowdy did not receive any latex gloves, although there was a nice instruction leaflet included that said something about wearing the gloves while using the rest of the package.  Rowdy was a bit worried to plug a PS/2 keyboard in without the gloves.
Offline affect656
  • Trade Count: (0)
Picked it up yesterday but I think it got there like a week earlier. Package was fine
I like linear.
Offline MOZ
  • Trade Count: (0)
  • Busy making stuff
Finely sense creeping back to the thread.
