Author Topic: [IC] DS ABS SA Profile Keycaps - GB IS LIVE  (Read 108910 times)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: [IC] DS ABS SA Profile Keycaps - Voting closed
« Reply #350 on: Sun, 01 September 2013, 20:44:34 »
Round 4 had stepped caps lock, so they have the mold :) (I just took these pictures):
Oh DAMN..... This has to go Officially into the GROUP BUY section as soon as possible.
I'm already into the Camouflage Jil_jil32's SA key-set and this Blue Dolch will be another one I'll fall for.  Mainly because I just love to see it with a stepped Caps Lock.
Bring this baby on down to Group Buy City  8) .
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #351 on: Sun, 01 September 2013, 20:58:07 »
If you look at the keys SA has in their SA family you can see they do have stepped caps, not sure about off center,  let me check.
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #352 on: Sun, 01 September 2013, 21:46:52 »
We're doing profiles like the Commando 23 set, which was discussed earlier in this thread. It's the easiest and best solution to the profile issue.
Here's an example.
Row 1 : Row 2 : Row 3: Row 3 : Row 3 : Row 4
So all of the alphas will be the same profile.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline nuclearsandwich
« Reply #353 on: Sun, 01 September 2013, 21:49:00 »
Here's an example.
Thanks for the clarification. I can get behind that!
Offline darkfire32
« Reply #354 on: Sun, 01 September 2013, 22:05:39 »
TBH, I got into this because each row had a different profile so that the caps created a shape for the fingers. If all the alphas have the same profile then it'd just make this a set of taller DSA caps. While I'm not necessarily out at this point, I am really hesitant to put down money for this.
Also, I don't know if anyone said this or not, but using Row 4 for the bottom row and possibly the spacebar is going to really hurt the thumbs.
Offline jonathanyu
« Reply #355 on: Sun, 01 September 2013, 22:10:04 »
SA profile... i don't like it much. but depend on the price, if it is cheap, i will still buy one  :D
Offline Halvar
« Reply #356 on: Mon, 02 September 2013, 00:28:05 »
I'm pretty sure that SP won't make new extra-thumbhurting row 4 spacebar molds exclusively for this GB and that space bars only exist in one profile in SA, so we will get that profile.
Offline darkfire32
« Reply #357 on: Mon, 02 September 2013, 00:59:32 »
Alright, well that's one less apprehension I have about this group buy.
Offline Elrick
  • Hype Master
« Reply #358 on: Mon, 02 September 2013, 04:58:16 »
When I read this, I reached for the lead pipe eager to convince you of your serious error in judgement.  How could you not like this Profile?
Only ingrates and idiots wouldn't like an SA profile.  Because they have never owned it before or heard something from someone else, who thinks it is unsuitable.  Relying on hearsay is dangerous as hell.
Besides for too many years most of the SP Group Buys have centered around DCS and nothing else.  Sick of that and would love to see more and more SA Love coming out of Signature Plastics.
  • Demon of the Fall
« Reply #359 on: Mon, 02 September 2013, 05:47:54 »
spacebar is not thumbhurty
Offline Latin00032
« Reply #360 on: Mon, 02 September 2013, 16:46:37 »
Is this going to have hhkb support.
For the gh60?
Row 2 profile esc key.
Row 3 profile delete key.
Etc...
Offline ohgodpleaseno
  • Nonononono please no
« Reply #361 on: Tue, 03 September 2013, 00:34:38 »
I'm super excited for this set. :D
Offline cassist
« Reply #362 on: Tue, 03 September 2013, 09:19:47 »
I'm not sure how I feel about all row3 but the legends and SA profile are very tempting!!
plu ml87, poker2
Offline Tarzan
  • formerly known as Greystoke
« Reply #363 on: Tue, 03 September 2013, 09:36:51 »
I was checking out the Wang terminal keyboard, the only one I have with SA profile caps, and it uses Row3 for the entire number block, plus all the stand-alone modifiers (Erase, Clear, Load, Run, etc.).  Unless you look closely, the different key profiles don't stand out, I think having multiple rows in Row3 profile would be fine.
33938-0
Offline darkfire32
« Reply #364 on: Tue, 03 September 2013, 13:49:52 »
Could you please post a side profile picture of the keyboard? It is a bit hard to see what you are talking about with the top down view.
Offline MOZ
  • Busy making stuff
« Reply #365 on: Tue, 03 September 2013, 21:01:22 »
this.
Offline Tarzan
« Reply #366 on: Wed, 04 September 2013, 10:49:25 »
this.
I'll work on this when I get home.  At the moment all the caps are off the keyboard, but it shouldn't take long to replace them for a few pictures.
It's a lovely keyboard, if it wasn't foam-and-foil under the hood I'd be tempted to try some sort of converter to make it  usable on a modern PC.
Offline Tarzan
« Reply #367 on: Thu, 05 September 2013, 10:07:11 »
Okay, some pics of SA profile keys on an actual keyboard.   ;D
First, some images of all profiles.
Row1 - Row2 - Row3 - Row4
34190-0
Some more shots
34194-1
34196-2
Images of Row3 only - you may be able to see the difference against the regular rows in the background.
Numpad with all Row3
34192-3
(I think that zero key is upside-down...)
34198-4
34200-5
Full keyboard shot
34202-6
Edit: the PCB for this keyboard is not fully aligned with the top case, in the shots of the number pad you can see the PCB is lower towards the front of the case.
« Last Edit: Thu, 05 September 2013, 10:28:15 by Greystoke »
Offline Tarzan
« Reply #368 on: Thu, 05 September 2013, 10:26:35 »
I also took a few shots with the proposed keys swapped - substituting Row3 for Row4.
Stock version:
34204-0
IC version with dual Row3 caps:
34206-1
Couple more shots with the swapped Row3 cap:
34208-2
34210-3
Offline Latin00032
« Reply #369 on: Thu, 05 September 2013, 10:30:33 »
Stock version:
I love the retro look.
Offline Tarzan
« Reply #370 on: Thu, 05 September 2013, 10:47:10 »
Stock version:
As do I!
I've been trying to cast some replicas of these, with regular Cherry stems, but that's still a work-in-progress.  Massive keys, especially those two-row FN keys and odd-ball Return keys.  Look like they could withstand a nuclear bomb and still work.   :p
Offline darkfire32
« Reply #371 on: Thu, 05 September 2013, 13:36:17 »
Thanks for the pictures. The differences between using row 3 for all alphas and using regular rows are really small. That took away a lot of the apprehension I had.
  • Demon of the Fall
« Reply #372 on: Thu, 05 September 2013, 15:01:54 »
And doing it this way takes away a lot of the issues with matching profiles, as SP doesn't have modifiers in every profile and opens up opportunities for swapping around the alphas for different layouts.
Offline darkfire32
« Reply #373 on: Thu, 05 September 2013, 15:24:09 »
Great. Now no rush or anything but what is the current situation with the group buy?
  • Demon of the Fall
« Reply #374 on: Thu, 05 September 2013, 15:31:02 »
I was hoping it'd be a surprise, but I'll be posting it when I get off work tonight. About 12 hours from now.
Though I do need to get with MOZ for some of the minor changes.
Offline Latin00032
« Reply #375 on: Thu, 05 September 2013, 15:52:43 »
I thought we weren't going all row 3? Im fine with going all row 3, but I think many other people will have a problem with that.
Offline ___q
« Reply #376 on: Thu, 05 September 2013, 16:00:51 »
All row 3 for the three alpha rows only -- different rows for numbers/function keys/ spacebar row mods/ etc.
This is what the commando GB is doing as well, and it let them get correctly-sized keys for all the mods (R4 had short shifts/enter).
« Last Edit: Thu, 05 September 2013, 16:02:36 by ___q »
Offline darkfire32
« Reply #377 on: Thu, 05 September 2013, 16:11:09 »
Awwww sorry man. I didn't hear anything and will be totally surprised when it comes up tonight.
  • Demon of the Fall
« Reply #378 on: Thu, 05 September 2013, 16:18:00 »
Thank you for clarifying. I'll repost the pictures to emphasize.
Here are the different profiles for SA
Here are how we will be using the different profiles
And here's an example of it on a keyboard
Offline Latin00032
« Reply #379 on: Thu, 05 September 2013, 16:47:42 »
Hopefully, a row 2 esc key is included for poker type boards.
  • Demon of the Fall
« Reply #380 on: Thu, 05 September 2013, 16:50:45 »
DAMNIT
I already got final quotes.
Guess I'll email Melissa again.
Offline Latin00032
« Reply #381 on: Thu, 05 September 2013, 17:25:11 »
DAMNIT
I brought this up before on this thread. Twice I think.
Same error happened on the commando gb until I brought it up.
  • Demon of the Fall
« Reply #382 on: Thu, 05 September 2013, 17:25:50 »
I must've missed it before.
Offline Latin00032
« Reply #383 on: Thu, 05 September 2013, 17:28:43 »
Are you including a grey "\|" key, too? For pokers. I think you are, right?
Edit: First post says you did. Sorry. I missed it.
  • Demon of the Fall
« Reply #384 on: Thu, 05 September 2013, 17:30:22 »
Yeah, both the Alpha set and the Mods set has ~`, \|, space bar, and f1-f12
Offline n0rvig
« Reply #385 on: Fri, 06 September 2013, 20:34:26 »
This is looking like a pretty exciting set! Can't wait for it.
  • Demon of the Fall
« Reply #386 on: Fri, 06 September 2013, 21:35:24 »
GB is live. Go get on that shiz.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
Re: [IC] DS ABS SA Profile Keycaps - GB IS LIVE
« Reply #387 on: Tue, 15 October 2013, 12:35:41 »
Calm, anyway you could post the color schemes that were voted on, and their accompanying images? I'm putting together an archive of color schemes -- I'd love to include the ones that got discussed in this thread.
Quote from: Samuel Adams
