Author Topic: GH CAD Resources Hub  (Read 1019067 times)
Offline heedpantsnow
  • Old enough to know better
Re: GH CAD Resources Hub
« Reply #250 on: Mon, 15 June 2015, 06:03:23 »
Well I'm a huge CAD noob and I have a plate file from Beast. I just need the caps lock hole enlarged to allow for a left stem in addition to the center stem.
Can someone help me modify the file?
Yeah, I am not at my PC, but if you go to the Dropbox link in the 1st page, download the Plate Resources that JD made, and then you will find the correct holes. Take the 1u, like it up with the 'a' hole next to caps lock, place it there, get the off center caps, place it wherever, highlight it, click the move tool, place the movement on the bottom right of the bounding box, and place it on the bottom left corner of the a hole bounding box
Thanks I'll try it and let you know how it goes!
I'm back.
Offline EE-test
« Reply #251 on: Sun, 21 June 2015, 22:28:02 »
So, does anyone within driving distance of greater Los Angeles want to get together to actually "make stuff together"?  Alternatively, are there existing meet-ups?
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #252 on: Wed, 21 October 2015, 15:01:52 »
The cherry mx switch 3d model link is broken. Does anyone have the file still and want to re-upload it?
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline Pdub
« Reply #253 on: Sat, 24 October 2015, 15:42:24 »
Glad this was started. Thanks for sharing everyone.
Offline ocodo
« Reply #254 on: Tue, 01 December 2015, 05:54:52 »
A Git repo of SA profile keycap 3D models X in common sizes (all rows)
https://github.com/getclacking/SA-profile-keys-3D-models
Intended for use as a presentation aid for keycap designs.
Includes a TKL layout among other things.
All resources and steps taken from Signature Plastics profile guide pdf are included for your reference. Repo will grow to include a variety of layouts and modeling methods.
« Last Edit: Tue, 01 December 2015, 05:59:28 by ocodo »
Offline cwndrws
« Reply #255 on: Tue, 22 December 2015, 12:07:33 »
What is the proper thickness for a Cherry MX mounting plate?
Offline admiralvorian
  • DIY
« Reply #256 on: Tue, 22 December 2015, 13:40:40 »
~1.5mm depending on what material you use and who you're asking
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
Offline xondat
  • i'm not a star
« Reply #257 on: Tue, 22 December 2015, 14:00:49 »
Wish I knew this existed about 2 weeks ago...
Offline cwndrws
« Reply #258 on: Tue, 22 December 2015, 15:42:04 »
Acrylic. Would that change anything? Is there some kind of schematic that cherry has published for these kinds of specs?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #259 on: Wed, 23 December 2015, 10:24:20 »
Cherry spec sheets says 1.5mm. 1.5mm acrylic is quite flimsy, use 3mm+.
Offline redbanshee
  • actually Dade Murphy
« Reply #260 on: Sat, 23 January 2016, 14:08:44 »
I did this thread and many wikis/spec sheets over but I couldn't find any sort of spec sheet for the actual dimensions of the 2 parts involved in cherry pcb mount stabilizers. Anyone ever seen a stabilizer spec sheet? Not looking for mount hole sizes but the stabs themselves....
Offline fenwick
« Reply #261 on: Sun, 20 March 2016, 14:46:36 »
The link in the OP for the MX switch 3D model is dead, this link works but I can't validate the dimensions:
https://3dwarehouse.sketchup.com/model.html?redirect=1&mid=81cf92a3e03098a5cc90be332989df6e&id=81cf92a3e03098a5cc90be332989df6e
Offline FoC_Tow
  • Brokehlicious
« Reply #262 on: Sun, 27 March 2016, 15:32:03 »
Link for switch stickers is currently down.
If someone could hook me up Id appreciate it a lot.
Offline MOZ
  • Busy making stuff
« Reply #263 on: Sun, 27 March 2016, 16:08:45 »
Will upload to GitHub tomorrow morning, 11PM here.
Offline FoC_Tow
  • Brokehlicious
« Reply #264 on: Sun, 27 March 2016, 18:47:49 »
THX a lot MOZ, much appreciated!
Offline TheBestUkester
« Reply #265 on: Fri, 08 April 2016, 15:50:05 »
Looking to utilize some of these great resources. Any update on GitHub?
Offline MOZ
  • Busy making stuff
« Reply #266 on: Sun, 24 April 2016, 11:05:55 »
I've uploaded everything to the GitHub repo, here: https://github.com/mohitg11/GH-CAD-Resources
I've just dumped the DropBox folder to GitHub. I'll give them meaningful names and add a relevant ReadMe later.
Offline 0100010
  • Not Sure
« Reply #267 on: Wed, 21 September 2016, 09:26:51 »
Necro bump.
Is it OK to position the stabilizer holes in a plate above the spacebar instead of below, as is normally done (when using plate mount Cherry or Costar stabs)?
Offline bpiphany
« Reply #268 on: Sat, 24 September 2016, 02:49:47 »
Cherry stabilizers can be mounted rotated 180° (upside down) if that is what you mean. Costar stabilizers need to be mounted the correct way around relative to the switch or the switch won't be able to travel all the way to the bottom.
Offline 0100010
  • Not Sure
« Reply #269 on: Sat, 24 September 2016, 19:59:10 »
Really?  Why is it the costars cant be inverted?
Offline bpiphany
« Reply #270 on: Sat, 24 September 2016, 20:00:36 »
They can, but you better turn the switch around as well. The costar stabilizer bar/wire is sitting above the plate, while the one on the cherry stabilizer is below the plate and out of the way.
Offline 0100010
  • Not Sure
« Reply #271 on: Sat, 24 September 2016, 20:47:04 »
I see, you are saying the upper half of the switch housing interferes with the Z bend part of the stab wire.  Inverting the switch along with the stab holes keeps wverything normal.
Offline bpiphany
« Reply #272 on: Sun, 25 September 2016, 03:42:33 »
Yes, that works. I found my old pictures from a very very old argument on the subject.
149143-0
149145-1
Offline 0100010
  • Not Sure
« Reply #273 on: Sun, 25 September 2016, 20:54:59 »
Thanks for the pics!
I'm thinking of getting a GH60 PCB, and manually drilling new holes to invert the spacebar switch, then running short jumpers to connect the pins to the original pin locations, that way I can use a plate with inverted costar stab holes for the space bar.
Offline tk
« Reply #274 on: Mon, 06 February 2017, 22:08:46 »
This isn't CAD, but another member suggested i post this here:
tl;dr: I built a Pok3r Keyboard in C4D (https://tee-kay.github.io/KeyCapTester/), complete with Xpresso to make texturing and trying different combinations a breeze. You can download and use it for free. (http://gen.rs/JQqy)
After lurking for a while, the beauty and simplicity of the 60% layout was too much. I broke down and bought a Pok3r to replace my beloved Mac keyboard with numpad (yes, the chiclet one and yes, I still kind of miss how thin it is but I'm adjusting).
But those caps — oh the caps. And the lack of available caps, at least cap sets that I like. That mixed with my impatience on waiting for the perfect first set to show up (*just* missed Mito's Canvas set), I started looking into PimpMyKeyboard's custom DSA options. I'm a visual person though, and wanted to see what the full board would look like given the limited options. So I built a model in C4D, then got ambitious and decided to rig it with some Xpresso. The model isn't perfect, but I was more concerned with those sexy keys so it's close enough for now. I may revisit the model one of these days. Included are materials (estimates based on their images) for all the available PMK PBT colors for custom DSA keys.
Check it out here(https://tee-kay.github.io/KeyCapTester/), and download the .C4D scene and textures here - dropbox(https://www.dropbox.com/s/385s720wiz2yvkr/KeycapsRig.c4d?dl=0) or for the genero.us(http://gen.rs/JQqy) among you. Hope you enjoy and would love to see what comes out of it.
Offline xondat
  • i'm not a star
« Reply #275 on: Mon, 20 February 2017, 07:47:40 »
I just figured out how to quickly and efficiently make Cherry MX specification plates to full accuracy (swillkb does this, but has numbers like 13.99993 and not 14 for lines etc).
  • Make a 19.05x19.05 squares, put a line through them, and make a 14x14 internal square. Copy and paste to make as many as you need for one row (in this case 11).
  • Duplicate this as many times as you need (I did it 4 times), and then align them on their relevant rows by creating a 14x14 based around the center of the hole on the PCB. Move the row you just made and align however many you need.
  • To do the odd keys, make 14x14 squares using the center of the mounting holes from the PCB. Then fill the outer spaces using the rows you already made.
  • Create the stabilizer cutouts by making a 1x7 rectangle around each stabilizer cutout. Fill the remaining space with a 14.24x7 rectangle. Extrude those rectangles and cut the cutouts from the plate you made.
  • Tada! You now have a Cherry MX Specification plate to perfection. Of course you can change the stabilizer cutouts as you please, but if you just want PCB mount then these will work perfectly.
In my example (my favorite layout), no stabilizer cutouts overlap with switch cutouts, but if they do then it shouldn't be a problem, so follow step 4 as noted.
Album with transparent and non-transparent images here.
« Last Edit: Mon, 20 February 2017, 07:50:22 by xondat »
Offline Dodgy
  • I specialize in bird law.
« Reply #276 on: Sun, 26 February 2017, 21:39:43 »
I'm trying to put a render together for a keyboard, is there anywhere I can find a file containing a 60% plate and PCB with switches and caps?
Hi, what's your favorite color?
I'm making keycaps, take a look if you give a damn.
Sale Thread
Offline Tiramisuu
« Reply #277 on: Sat, 22 July 2017, 19:29:04 »
Thread resurrection... I'm looking for a G20 Keycap model for blender.  My blender fu is fu so I'm hoping to find a premodeled keycap rather than do 10 hours of tutorials.
thanks.
T
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline TalkingTree
    • My projects
« Reply #278 on: Sat, 13 January 2018, 04:10:50 »
Yet another necro to ask a question:
When interlocking parts, like plate and case or weight and case, should there be any gap between the two?
My plate has tabs and I'm making recesses in my bottom half of the case to have it flush.
Thank you.
Offline sinusoid
  • fd > ESC
« Reply #279 on: Mon, 15 January 2018, 04:12:29 »
Yet another necro to ask a question: [...]
Yes, otherwise they won't fit. There should be specs for different kinds of materials online. Or you could ask Kurplop :D
Also, different materials have different temperature expansion properties. Depending on your design, getting too snug of a fit can cause them to undergo tensioning and reshape the whole thing slightly as the temperature changes.
@Tiramisuu
Did you find these?
Offline TalkingTree
    • My projects
« Reply #280 on: Mon, 15 January 2018, 05:39:11 »
Marvellous, thank you for your reply.
Offline ojrask
  • juuh elikkäs
« Reply #281 on: Sun, 18 March 2018, 08:50:47 »
The stabilizer length for a 7u spacebar is ~4.5 inches. How long should it be for a 6.25u spacebar? Can I just remove 0.75u and interpolate inches from that? None of the MX tech sheets mention 6.25u stabilizer sizing, only 7u.
EDIT: from my interpolation 6.25u stabilizer holes should be 4.02 inches apart, is this anywhere near the correct value?
EDIT2: it seems that it should be 100mm from wire to wire, or 3.94 inches.
« Last Edit: Sun, 18 March 2018, 08:59:37 by ojrask »
Current:
Coming up:
IC/GB:
Offline TalkingTree
    • My projects
« Reply #282 on: Sun, 18 March 2018, 09:00:13 »
3.96'' (100.58mm) center to center of the two stabilizers for 6u and 6.25u wires (for they are the same).
Offline xondat
  • i'm not a star
« Reply #283 on: Sun, 18 March 2018, 09:33:30 »
Cherry stabilizers work like this:
So you can work it out as such: (Size of spacebar - 1) x 19.05
The spacing for 7u is 6 units apart, which is 114.3. 6.25u is 100.0125 (5.25u), and 6u is 95.25 (5u).
Offline ojrask
  • juuh elikkäs
« Reply #284 on: Sun, 18 March 2018, 11:04:28 »
Oh did not know it was a standard sizing scheme. Though that they were just random values. Thanks!
Current:
Coming up:
IC/GB:
Offline xondat
  • i'm not a star
« Reply #285 on: Sun, 18 March 2018, 11:48:30 »
Yeah it doesn't seem well know, but 1 unit is 19.05mm. It means you can work the size of 1.5u by 19.05 x 1.5 etc.
The only thing I haven't worked out is centre to centre for the normal stabilizer spacing as it's 11.938mm.
Offline redbanshee
« Reply #286 on: Fri, 06 April 2018, 14:44:38 »
Today I have for you guys a stabilizer model measured from the real thing (cherry stabs) using digital calipers. I started this thinking I wanted to make an improved design for the current cherry stabs that we use today, but after modifying this design and then getting tooling quotes and realizing i would have to sell a cubic assload of stabs, I gave up. I just dont have the time beyond my professional life to worry about or coordinate the sale of these. So here you guys go, use as you wish but if you were to use this model in some form of production, please give credit to me where it is due.
Offline eulaly
« Reply #287 on: Thu, 14 June 2018, 09:45:02 »
Just wanted to thank everyone for this thread, esp the github page. Will be trying an acrylic cutout of the phantom ANSI 125 mounting plate.
Offline Eszett
« Reply #288 on: Sat, 21 July 2018, 14:51:01 »
Hi guys, I need the dimensions, or a DWG file, for the plate cutouts that work with PCB mount stabs (see photo below). Are there any in GH CAD resources hub?
« Last Edit: Sat, 21 July 2018, 14:53:19 by Eszett »
Offline redbanshee
« Reply #289 on: Sun, 22 July 2018, 16:58:18 »
7mm x 15mm-19mm
if you want to make something more universal, do 19mm and center.
less then 19mm alignment depends on if north or south facing stabs
also, http://builder.swillkb.com/
Offline Eszett
« Reply #290 on: Mon, 23 July 2018, 05:04:18 »
Glad you are around, redbanshee. If I get it right, does this drawing match to what you are saying? ( My intention is that the switch cutout holds the switch tight, and the stab cutouts lets PCB mount stabs get through the plate. )
« Last Edit: Mon, 23 July 2018, 05:06:50 by Eszett »
Offline redbanshee
« Reply #291 on: Mon, 23 July 2018, 08:38:50 »
if you want the switch the tightest possible, do the stab/switch holes like this https://i.imgur.com/iGzIZuB.jpg (look at enter key)
Offline Eszett
« Reply #292 on: Mon, 23 July 2018, 08:51:51 »
alright, can you tell me the dimensions for this alternative?
Offline redbanshee
« Reply #293 on: Mon, 23 July 2018, 12:35:54 »
here, this should help
Offline Eszett
« Reply #294 on: Mon, 23 July 2018, 14:54:03 »
redbanchee: cool, I owe you a pint!
Offline redbanshee
« Reply #295 on: Mon, 23 July 2018, 19:25:43 »
no problem! sometimes its quicker to do the work then to type the answer.  :thumb:
Offline Eszett
« Reply #296 on: Wed, 25 July 2018, 07:47:31 »
Another question, I calculate a keycap as 18 * 18 mm for 1U, so standard safety gap between edges (of keycaps, or keycap-caseing) is 1,05mm, but is that really necessary? I'm looking for the balance between "as much as necessary, but not more".
« Last Edit: Wed, 25 July 2018, 08:28:23 by Eszett »
Offline packman86
  • Morning Coffee
« Reply #297 on: Sun, 05 August 2018, 22:50:03 »
I am working on some case renders that are hopefully entering GB stage soon. We are missing GMK keycaps on the renders, though.
Are GMK (with legends) CADs available anywhere?
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #298 on: Fri, 08 May 2020, 07:41:24 »
Thank you SO much for this. Didn't use it in production or anything, it just helped me greatly with measuring :)
You the MVP
Offline Eszett
« Reply #299 on: Fri, 08 May 2020, 11:56:43 »
Nice, redbanshee, can you show us the model with your improvements, too?
