Author Topic: Ray's Hack Attack a.ka. SpAmTaStIc: How Not To Customize a QFR Top  (Read 9733 times)
« on: Fri, 06 September 2013, 14:52:35 »
34398-0
34400-1
....soooooon  ::)
Re: Ray's Hack Attack a.ka. SpAmTaStIc: How Not To Customize a QFR Top
« Reply #1 on: Fri, 06 September 2013, 15:21:43 »
Oh boy.
Offline thebeargentile
« Reply #2 on: Fri, 06 September 2013, 15:29:02 »
You forgot the lube.
« Reply #3 on: Fri, 06 September 2013, 15:33:06 »
Your right, I've never seen anybody lube a case before. :eek:
perhaps I should contact mkawa and get one of those ps2 adapters while I'm at it.
« Reply #4 on: Fri, 06 September 2013, 15:35:00 »
Do you need a USB -> PS/2 adapter? I've got 3.
« Reply #5 on: Fri, 06 September 2013, 15:35:59 »
Nah, I've got 2 already. Just going to support mkawa's efforts.
« Reply #6 on: Fri, 06 September 2013, 15:37:10 »
 :D  Maybe if you get 2, you can get TWICE the nkro!
Honestly, though, looking forward to seeing what you come up with!
« Reply #7 on: Fri, 06 September 2013, 17:14:58 »
Well technically I've got 7 tops. One is a filco and will be left alone. One I'm sending to another member. So I'll have 5 to 'work' on!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #8 on: Fri, 06 September 2013, 20:28:04 »
the best use of the ps2 adapters i've found is to hardwire them to M controllers. no more of that ps2 junk at all. YESssss
Offline mkawa
« Reply #9 on: Fri, 06 September 2013, 20:28:42 »
also i think the stainless steel brush is going to remove a bit more material than you may want ;)
« Reply #10 on: Sat, 07 September 2013, 10:32:19 »
I'm thinking of modding my G80-1800 to use detachable usb  :thumb:
have you not read the title....destroy all the covers....for keyboard science....muhahahaha  :o
« Reply #11 on: Mon, 09 September 2013, 21:11:12 »
I had about two minutes to try out my new hacksaw.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #12 on: Tue, 10 September 2013, 01:15:25 »
When I saw your post in danielucf's custom Phantom sale thread, I knew I could expect this from you on this thread.
« Reply #13 on: Tue, 10 September 2013, 07:03:09 »
Here it is installed. It looks pretty crappy but was literally a hack job!  :thumb:
34877-0
Offline MOZ
  • Busy making stuff
« Reply #14 on: Tue, 10 September 2013, 07:07:50 »
You can improve on that, take a file to it, and then some sandpaper of various grit.
« Reply #15 on: Tue, 10 September 2013, 17:10:19 »
That is an interesting layout!
« Reply #16 on: Tue, 10 September 2013, 17:37:13 »
Bootleg Quickfire TK.
« Reply #17 on: Sat, 21 September 2013, 17:55:40 »
Something, something, PAINT!
Offline Photoelectric
« Reply #18 on: Sat, 21 September 2013, 17:57:49 »
What is that? o.o  Looks like layered large metal flake of some sort!
Offline mkawa
« Reply #19 on: Sat, 21 September 2013, 18:46:14 »
woah! is that from a rattle can? that's awesome!
« Reply #20 on: Sat, 21 September 2013, 18:46:27 »
I figured it'd be hard to mess up.  I didn't spend but a minute or two on it.
« Reply #21 on: Sat, 21 September 2013, 18:47:02 »
In other words my QFR top got hammered.
« Reply #22 on: Sat, 21 September 2013, 18:53:31 »
:)  It took a beating and managed to come out looking good!
« Reply #23 on: Sat, 21 September 2013, 19:37:12 »
Lookin' good!
Offline mkawa
« Reply #24 on: Sat, 21 September 2013, 20:35:52 »
that's pretty cool. is this just your primer or are you leaving it there? that flake would look awesome under some color and nice smooth clearcoat
« Reply #25 on: Sat, 21 September 2013, 20:46:48 »
Right now I'm just experimenting!
Also this paint is textured.
Offline mkawa
« Reply #26 on: Sun, 22 September 2013, 12:27:19 »
the texture should come through future layers. UNLESS you layer a LOT over it and then smooth the upper layers with an abrasive. that's going to be seriously sweet looking if you can find some complimentary colors and then a gloss coat. i vote to leave it textured.
« Reply #27 on: Sun, 22 September 2013, 15:04:38 »
+1 textured, otherwise it might turn out to be Das SpAmRaYboard.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #28 on: Mon, 23 September 2013, 08:00:53 »
It's a keyboard from the Bronze Age! Looks great Ray.
Quote from: Samuel Adams
