Author Topic: GMK Mini packs (completed)  (Read 296602 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GMK Mini packs
« Reply #150 on: Tue, 12 November 2013, 10:22:25 »
Yes if you would like to add spacebar or otherwise update your order please submit the form again.
The spacebar colors will be chosen by GMK out of on hand plastic colors. I won't have any control over which colors and how many of each will be made. Your order will be filled in random fashion and no color requests.
Re: GMK Mini packs
« Reply #151 on: Tue, 12 November 2013, 10:23:26 »
:eek: that will be EPIC....I can see the space bar trading now.....
Offline esoomenona
  • Gnillort?
Re: GMK Mini packs
« Reply #152 on: Tue, 12 November 2013, 10:26:01 »
If I submit an order for spacebars, will my two orders be merged, or should I submit an entirely new order to replace my previous one with?
Also, thanks for doing all of this, lysol. I appreciate it, as I'm sure others do.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: GMK Mini packs
« Reply #153 on: Tue, 12 November 2013, 10:28:54 »
Damn you Ivan. I can see my order having like 20 space-bars on it now.
EDIT: Placed an updated order. Had to keep myself to 5 sets of space bars hahaha
« Last Edit: Tue, 12 November 2013, 10:35:14 by bueller »
Re: GMK Mini packs
« Reply #154 on: Tue, 12 November 2013, 10:38:43 »
Any new order will replace older order.
Re: GMK Mini packs
« Reply #155 on: Tue, 12 November 2013, 10:49:53 »
I submitted a new order with spacebars to overwrite my old order.
Also, as a side note Ivan, on the form the spot for spacebars is below the picture for the mods but above the text box entry for the mods, making it a bit awkwardly placed.
Re: GMK Mini packs
« Reply #156 on: Tue, 12 November 2013, 10:53:55 »
Hmn, I don't know how dafuq it got there... stupid googledocs.
Offline Jmneuv
Re: GMK Mini packs
« Reply #157 on: Tue, 12 November 2013, 11:18:22 »
Haha, you know how to spice it up!
Offline Danule
Re: GMK Mini packs
« Reply #158 on: Tue, 12 November 2013, 12:54:28 »
totally ordering and esc pack, these are great!  and they dont break the bank ;)
45g Brown Brown Blue
Offline baldgye
  • Will Smith Disciple
Re: GMK Mini packs
« Reply #159 on: Tue, 12 November 2013, 12:56:22 »
...you mean... SPACE TRADING!!!!! :O :O
Re: GMK Mini packs
« Reply #160 on: Tue, 12 November 2013, 12:57:32 »
If we started now we could call it trading future space!
Offline baldgye
Re: GMK Mini packs
« Reply #161 on: Tue, 12 November 2013, 13:10:01 »
Offline LechnerDE
Re: GMK Mini packs
« Reply #162 on: Tue, 12 November 2013, 13:35:25 »
Overwrote my initial order to add 5 spacebar packs
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
Re: GMK Mini packs
« Reply #163 on: Tue, 12 November 2013, 14:46:20 »
Submitted a new order. I just had to have an extra spacebar!
HHKB Pro 2   SmallFry Keyboard
Offline UniClown
Re: GMK Mini packs
« Reply #164 on: Tue, 12 November 2013, 14:54:15 »
Also reordered. Hope to get awesome spacebars.
Re: GMK Mini packs
« Reply #165 on: Tue, 12 November 2013, 15:40:34 »
I am totally banking on the possibility of a C,M or Y spacebar.
remade my order.
Re: GMK Mini packs
« Reply #166 on: Tue, 12 November 2013, 16:20:43 »
Ordered some spacebars and the ESC pack.
I'm excited.
Re: GMK Mini packs
« Reply #167 on: Tue, 12 November 2013, 16:30:00 »
This is starting to get too tempting to increase the order ...
The cut-off is currently 1st December, although order numbers are still fairly low.
Is there a chance that ordering (and thus invoicing) will be extended at all?
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
Re: GMK Mini packs
« Reply #168 on: Tue, 12 November 2013, 18:07:38 »
Resubmitted for the spacebars. :))
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: GMK Mini packs
« Reply #169 on: Tue, 12 November 2013, 18:26:52 »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: GMK Mini packs
« Reply #170 on: Tue, 12 November 2013, 19:21:09 »
Chances are good there will be more than one or two colors of spacebar right? Also is there an MOQ on spacebars or are they just throwing us a bone because we are helping them use up their excess plastic?
Offline stoic-lemon
Re: GMK Mini packs
« Reply #171 on: Tue, 12 November 2013, 22:08:53 »
Added a handful of spacebars to my order.
Offline Photoelectric
Re: GMK Mini packs
« Reply #172 on: Wed, 13 November 2013, 01:54:14 »
I'm thinking the most likely colors will be those already in production, like Beige, Black, Dolch Gray--does that seem reasonable?  Or do you think they'll actually make some new ones in less common colors?
And regarding the form, do we get a random spacebar length: 6.25 OR 7x?  Or is it $4 for both?
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: GMK Mini packs
« Reply #173 on: Wed, 13 November 2013, 02:21:34 »
выдающийся  работа !    Good Job !   Thank You,  Ива́н !
Offline Paranoid
Re: GMK Mini packs
« Reply #174 on: Wed, 13 November 2013, 03:41:11 »
Nice :) placed my order again with 4 spacebar packs ^^ I'm hoping the MOQ count increases exponentially!
Re: GMK Mini packs
« Reply #175 on: Wed, 13 November 2013, 10:01:39 »
Spacebar you get 2 spacebar one of each size 6.25 and 7. These could be in any color plastic they have, and I can't say with any certainty what colors will be given. It could be any of 24 stock colors or even leftover custom color from other customer. It still have 400 quantity but I don't think it will be a problem.
As said before the current end date was so we could have production and delivery before the holiday period. If MOQ is not met it will go open end until it is met.
« Last Edit: Wed, 13 November 2013, 10:04:04 by IvanIvanovich »
Offline esoomenona
  • Gnillort?
Re: GMK Mini packs
« Reply #176 on: Wed, 13 November 2013, 10:03:34 »
Will both spacebars be the same color or both random in a set?
Re: GMK Mini packs
« Reply #177 on: Wed, 13 November 2013, 10:04:57 »
I will pull a spacebar of each size out of a sack and place it in your order. Depending on the draw it could be different or same.
Offline esoomenona
  • Gnillort?
Re: GMK Mini packs
« Reply #178 on: Wed, 13 November 2013, 10:05:30 »
Ah, okay. Cool.
Offline Dubsgalore
Re: GMK Mini packs
« Reply #179 on: Wed, 13 November 2013, 10:07:15 »
random colored spacebars? yes please
ordered 2x
Offline GeorgeK
Re: GMK Mini packs
« Reply #180 on: Wed, 13 November 2013, 11:18:52 »
How would you like me to change my order to add spacebars?
Re: GMK Mini packs
« Reply #181 on: Wed, 13 November 2013, 11:20:48 »
 :thumb:
Offline IPT
  • Formerly projectD
Re: GMK Mini packs
« Reply #182 on: Wed, 13 November 2013, 11:28:11 »
double shot spacebars!!! lol j/k
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: GMK Mini packs
« Reply #183 on: Wed, 13 November 2013, 12:30:08 »
I can't believe that retro mod pack hasn't taken more orders yet, do you guys realize how dope that is?
and btw: yay for scoops!
« Last Edit: Wed, 13 November 2013, 12:32:44 by digi »
Offline muad
Re: GMK Mini packs
« Reply #184 on: Wed, 13 November 2013, 17:02:23 »
We need more space homeboy!!! I'm gonna link over to reddit to try and drum up the moq!
Re: GMK Mini packs
« Reply #185 on: Wed, 13 November 2013, 17:47:36 »
Resubmitted to add spacebars.  Will sell my soul for shades of pink or cyan/teal.
Offline stoic-lemon
Re: GMK Mini packs
« Reply #186 on: Wed, 13 November 2013, 18:34:04 »
Yeah, you can't really lose with these spacebars. You're bound to end up with something cool looking, or at the very least a high quality black spacebar.
Re: GMK Mini packs
« Reply #187 on: Wed, 13 November 2013, 18:57:40 »
I posted it in the weekly thread last week and there was a bit of a number jump, but you'll still have to wait a while.
Offline jonathanyu
Re: GMK Mini packs
« Reply #188 on: Wed, 13 November 2013, 19:45:34 »
Resubmitted for adding space bar :)
Offline digi
  • elite af tbh
Re: GMK Mini packs
« Reply #189 on: Wed, 13 November 2013, 19:49:01 »
How to add to the space bar kit to my previous order? Will it overwrite my previous order?
Offline yearn4
  • formerly known as 4en
Re: GMK Mini packs
« Reply #190 on: Wed, 13 November 2013, 19:50:43 »
need more function and retrooo
Offline bueller
  • MX baller
Re: GMK Mini packs
« Reply #191 on: Wed, 13 November 2013, 19:51:15 »
If you haven't saved the URL of your original order to edit it just put in a complete new order.
Re: GMK Mini packs
« Reply #192 on: Wed, 13 November 2013, 21:30:52 »
If I get anything resembling cyan or magenta I'm keeping it, but if I get a straight up Barbie pink I'll definitely trade with you.
Re: GMK Mini packs
« Reply #193 on: Wed, 13 November 2013, 21:42:56 »
Awesome.  I highly doubt that those colors will be made anyway, unless IvanIvanovich mentions it--after all, we're using those colors for the Esc pack sets.  If I get black spacebars, I'll be trading those, because I have zero black colored sets in use.
Offline gh_pp
Re: GMK Mini packs
« Reply #194 on: Wed, 13 November 2013, 22:22:01 »
But if one were to order 3 spacebars, will it have a higher chance of getting different colors?
Of course if GMK gave you a very skewed distribution, there isn't much you can do about it.
Thanks
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline Dubsgalore
Re: GMK Mini packs
« Reply #195 on: Wed, 13 November 2013, 22:22:59 »
Imagine a huge gmk spacebar trading thread pop up in a few months  :))
I'm down for that..
Offline bueller
  • MX baller
Re: GMK Mini packs
« Reply #196 on: Wed, 13 November 2013, 22:23:08 »
Thanks
How long is a piece of string? I'm sure Ivan will try and distribute them as evenly as possible but it all depends on what GMK sends him.
Offline GeorgeK
Re: GMK Mini packs
« Reply #197 on: Thu, 14 November 2013, 04:11:10 »
 :thumb:
Thanks - yesterday was a looooong and crazy day...
Will reorder later :)
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: GMK Mini packs
« Reply #198 on: Thu, 14 November 2013, 04:13:45 »
Ivan, I didn't read the thread and just made a new order for the space bars. Hope that is ok :|
Offline LechnerDE
Re: GMK Mini packs
« Reply #199 on: Thu, 14 November 2013, 04:21:36 »
Did you order something before? If yes, this was overwritten with your new order...
