Author Topic: DIY PCB (Happy Hacking Fox)  (Read 14135 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« on: Sun, 24 November 2013, 11:10:01 »
To try something different instead of the usual hand-wiring I opted for a home made, one of the kind, super handcrafted PCB.
This is the HHFox project (still on going)
The procedure involves handling of dangerous materials. Do not try it at home :P If you really have to, ALWAYS wear safety glasses and gloves. I'm not responsible for any damage blah blah blah
Let's start from the beginning.
1) Cut a piece a vanilla copper PCB
2) Drill switch (and diodes) holes with zen monk precision
3) I used inkscape to draw my PCB trails (since I'm no good with kicad and such
4) Draw the trails on the PCB with a waterproof marker and (just to be sure) with liquid silicone. Put the wannabe PCB into acid (ferric chloride)
5) A couple of hours later...
6) All diodes in position, soldered and ready to diodize
7) All switches soldered
7b) Naked front
8 ) Teensy ready
9) It's alive! ... or... look ma' no screws!
10) Swear! The keyboard is not 100% functional and I need another day of debug. The whole process took about 16 hours.
I'll post better shots as soon as I debug this beauty. Stay tuned :)
Re: DIY PCB (Happy Hacking Fox)
« Reply #1 on: Sun, 24 November 2013, 11:12:53 »
You're crazy and I love you for it. I want to make my own PCB now!
Offline BlueBär
« Reply #2 on: Sun, 24 November 2013, 11:39:42 »
16 hours for a whole keyboard including a PCB? Not bad! Does that include the case as well?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #3 on: Sun, 24 November 2013, 11:48:12 »
16h just for the PCB and soldering part... but I will probably have to spend another couple of hours on it. The case was laser cut few months ago.
« Reply #4 on: Sun, 24 November 2013, 12:04:07 »
Beautiful! I always love these foxy projects. :D
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #5 on: Sun, 24 November 2013, 14:14:55 »
Matt30... this is insane. Great layout too!
Offline AGmurdercore
« Reply #6 on: Sun, 24 November 2013, 15:15:15 »
This is AMAZING  :eek:
You are officially my idol now i wanna be like you when i grow up :X
I will try to make one like this for my project although i am not sure that i will be able to. How did you mark the spots to drill btw?
What the hell am I even doing
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #7 on: Sun, 24 November 2013, 15:18:22 »
It is glorious!
And that keycap set is the gift that keeps on giving. So versatile. ;)
« Reply #8 on: Sun, 24 November 2013, 15:19:36 »
very cool matt3o!
« Reply #9 on: Sun, 24 November 2013, 15:23:12 »
Brilliant!  Very well done - like magic :)
Offline Dubsgalore
« Reply #10 on: Sun, 24 November 2013, 15:51:09 »
This thing is really badass, nice work matt3o!
« Reply #11 on: Sun, 24 November 2013, 16:00:40 »
Next time someone says you can't make a PCB, I'll tell them about the mad keyboard scientist who made it look easy!
Offline McWilloughby
« Reply #12 on: Sun, 24 November 2013, 16:18:40 »
Absolutely love this, the DSA retro set gives it a very post apocalyptic look imo..
« Reply #13 on: Sun, 24 November 2013, 16:23:54 »
Very nice!  I was contemplating attempting something like this, but determined that I don't have the skills to drill my own PCB.  Looks like that wasn't an issue for you.  :P
Congrats on such a beautiful board!
« Reply #14 on: Sun, 24 November 2013, 16:27:10 »
Wow great job sir! I wish I could build a board!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #15 on: Sun, 24 November 2013, 16:39:33 »
thank you guys! It has been a very interesting project.
To make precise holes I took the CAD file I used for the plate and added the switch holes to it. Then printed and sticked to the raw copper PCB. With a hand drill I made just a 1mm dent for each hole and then used a standard drill to make the holes. They came out surprisingly well. It was such a please to slot the switch in the plate and see that it fit perfectly into the PCB :)
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« Reply #16 on: Sun, 24 November 2013, 17:51:29 »
Very interesting. My hats off to you for those precise holes. Can you explain a little moar please?
1. What type of pcb laminate and how thick? I cant able to find such a long pcb here in ol USA.
2. How did you draw? Pen method or printer paper heat press, or any other? direct printing with CNC?
thanks.
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
« Reply #17 on: Mon, 25 November 2013, 01:40:53 »
thanks.
He explained what he used to draw in the OP.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #18 on: Mon, 25 November 2013, 01:50:46 »
thanks.
1. it's a 300x200mm board, 1.6mm thick. I'm sure you can find it on ebay.
2. the drawing is done with plain old carbon paper :)
Offline phoenix1234
« Reply #19 on: Mon, 25 November 2013, 03:17:34 »
This is such an amazing piece of work indeed. :thumb:
Can't wait to see the final working keyboard.
I like linear switches
Offline blueSmoke
« Reply #20 on: Mon, 25 November 2013, 03:37:08 »
thanks.
Still not sure...
You noted:
I got the software side, i.e. inkskape. But how did you use the carbon paper with waterproof marker and liquid silicone? It seems you hand drew?
I am curious to try this method. Can you elaborate please?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #21 on: Mon, 25 November 2013, 03:44:02 »
print the schema you did on inkscape. use a pencil to copy the drawing from paper to the pcb using carbon paper. Use a waterproof marker to go over the trails.
Offline redskull
« Reply #22 on: Mon, 25 November 2013, 05:58:07 »
OMGWTFBBQ great job Matt3o. give those korean custom tuners a kick in the behind.  :))  :thumb:
« Reply #23 on: Tue, 26 November 2013, 20:11:44 »
It's projects like this that have convinced me I need to learn how to do a circuit diagram for my own keyboard.  This is awesome.  Absolutely love it.
And after seeing your traces, I really want to make an art of them.  Don't necessarily go for the most efficient traces, but make them look fluid and organic, like a piece of art.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #24 on: Wed, 27 November 2013, 01:25:09 »
thank you guys, looking forward to seeing your creations!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #25 on: Mon, 02 December 2013, 05:40:26 »
Keyboard finally finished!
Just a pinch smaller than Filco Minila Air!
I'm now trying to get used to the HHKB layout (with some important variations actually).
All switches are MX Blue except for the right FN which is Red. After a while working on it I found a little tiring to pinky-press it, so I softened it a bit with a MX Red.
Home/End are on < and > instead of L and .
It feels much more natural to me this way.
The Hyper key is actually a second FN key. very useful to reach the function layer with the left hand. The C64 is for firmware update. Everything else is very close to the HHKB.
This is by far the most complicated, long to build, swear-prone, keyboard I've ever build... But it's also definitely the best one! :)
Stay tuned for the next custom keyboard :) (I've got an ALU poker case so I might end up doing something with it)
« Reply #26 on: Fri, 06 December 2013, 07:51:25 »
Please tell me it's Alps :D
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #27 on: Fri, 06 December 2013, 14:32:45 »
supercool!
congrats!!!
perfect hadcrafting skills Matt3o
Offline Photoelectric
« Reply #28 on: Fri, 06 December 2013, 14:49:48 »
This is so very cool!  I had no idea that you could make a PCB like that out of a sheet of copper.  A few things were a surprise, such as that silicone does not dissolve in acid and leaves the drawn trails shiny.  Also does the reaction with acid produce a thick enough "salt" layer on both sides to avoid conducting electricity inside the PCB and scrambling all the signals?  That's the most non-straightforward part for me in this experiment.
« Reply #29 on: Fri, 06 December 2013, 14:52:44 »
It's not just a sheet of copper, it's copper PC board. :)
You just etch the copper off the parts where you don't want pads or traces.
« Reply #30 on: Fri, 06 December 2013, 14:54:35 »
Ohh I see now, I was so confused, because I thought it was an actual sheet of copper, as per the wording in the OP: I read it as "cut a PCB sized-shape out of a sheet of copper."
« Reply #31 on: Fri, 06 December 2013, 14:58:45 »
I found a neat article about pcb's that might interest visitors to this thread
http://www.robotroom.com/PCB.html
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #32 on: Fri, 06 December 2013, 17:01:21 »
yeah bad wording, sorry. it's a sheet of epoxy glass covered by few micron of copper layer. Acid attacks copper only that's why silicone is not affected.
