Author Topic: SIP sockets for faster removal of LEDs  (Read 96078 times)
Offline swill
  • builder & enabler
    • swillkb.com
Re: SIP sockets for faster removal of LEDs
« Reply #50 on: Thu, 02 January 2014, 21:32:02 »
Just for a reference for people.  Here is a switch with SIP sockets which have had the entire housing removed and an LED in place so it is ready to solder...
Edit: I did not check if the LED was in the correct orientation, it was just to illustrate the previous point...
what board is that? looks sexy
Filco Majestouch 2 TKL with browns with some no longer available IMSTO thick cherry PBT caps and the Banggood OEM RGB bottom row (space bar is from IMSTO).  I like OEM on my bottom row because they stand a bit higher and I found I was always reaching for the cherry bottom row.  They sit the same height as the cherry spacebar now.
Offline strict
  • TKL Zealot
« Reply #51 on: Sun, 09 March 2014, 10:38:25 »
This is awesome! Im definitely going to be adding SIP sockets to my phantom for scroll and caps after seeing this thread.
Does anyone have any part numbers for the rectangular LED's your using?
Offline Photoelectric
« Reply #52 on: Sun, 09 March 2014, 13:53:48 »
They are 2x3x4mm rectangular LEDs.
« Reply #53 on: Mon, 10 March 2014, 07:45:51 »
And most of the time you want to add water clear to that :D
« Reply #54 on: Mon, 10 March 2014, 13:40:00 »
Doesn't really matter actually, diffused should be okay too, as long as they are not dim.
Offline damorgue
    • Personal portfolio
« Reply #55 on: Mon, 17 March 2014, 09:31:05 »
I like matte/frosted/milky or whatever people call them. They distribute the light more evenly on the window if there is one and also around the key imo.
Offline Pacifist
  • on hiatus
« Reply #56 on: Wed, 26 March 2014, 20:23:20 »
Does anybody else have closing problems even without the black plastic? It won't close all the way and makes taking off caps a PITA
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #57 on: Wed, 26 March 2014, 20:24:59 »
I have not had that problem yet.  I have not done a whole board though...  Its the switch top you cant get to close correctly?
« Reply #58 on: Wed, 26 March 2014, 20:26:51 »
Yes, they don't fit perfectly because the black top part interferes:
Edit: added corrected area that seems to interfere.
Takes more effort to close the switches, and they don't close fully, though when they do close, there's no interference that I've noticed.  I've used them for my entire LightSaver's worth of switches, and it took a lot of extra time :(
« Last Edit: Wed, 26 March 2014, 20:40:46 by Photoelectric »
Offline Pacifist
  • on hiatus
« Reply #59 on: Wed, 26 March 2014, 20:29:44 »
Yea the switch tops won't close all the way. It may be because the SIP sockets aren't perfectly aligned, but I'm not exactly sure
Offline Pacifist
  • on hiatus
« Reply #60 on: Wed, 26 March 2014, 20:31:21 »
I circled the parts on the side, but I it might be more than that.  I need to do a test with teflon tape.  Takes more effort to close the switches, and they don't close fully, though when they do close, there's no interference that I've noticed.  I've used them for my entire LightSaver's worth of switches, and it took a lot of extra time :(
Yea I noticed those things and it was driving me crazy.
There is no interference when closed, but when taking off caps (esp tight ones) its hard to pull it off without taking the whole switch top and LED with it.
« Reply #61 on: Wed, 26 March 2014, 20:41:21 »
Redone the photograph to show the part on the top cover that interferes with the tops of the SIP sockets and doesn't allow for the top cover to close as tightly as it would without the sockets.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #62 on: Wed, 26 March 2014, 21:11:37 »
I had that problem before I completely removed the housing on the SIP sockets, but I have not had issues once I completely removed all the plastic.  I have not done a full keyboard yet though...
« Reply #63 on: Wed, 26 March 2014, 21:13:23 »
I removed all the pins from their plastic housing before installing them into switches.  Still had that issue.  Skipped switch stickers even to compensate somewhat.  Everything is fine and is in working order, and all the SIP sockets were aligned with LEDs inserted into them prior to soldering, but switch covers definitely did not close as well as they would have without the sockets.
Offline stancato9
« Reply #64 on: Wed, 26 March 2014, 21:43:10 »
Has anyone found some SIP sockets on eBay that work perfectly? Is there even any variation between the types you can buy?
Poker 2 - MX Red
Offline nuclearsandwich
« Reply #65 on: Fri, 25 July 2014, 03:16:55 »
When I install SIP sockets, even when inserting the switch fully into the PCB the ends of the sockets barely make it through the PCB holes. Is that everyone else's experience as well? It seems like it puts the connection to the LED at risk unless you really get in there with the solder.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #66 on: Fri, 25 July 2014, 07:05:46 »
Yes, on a 1.6mm PCB it will basically be flush with the bottom of the PCB.
I am using a sprit PCB, so the led holes are all the way through so there is lots of surface to solder to. No issues at all. Desoldering them is a bit of a PITA, but I think that is to be expected.
If you have a single sided PCB then I could see you maybe having some issues.
Which PCB are you using and do the pads go through the PCB?
« Reply #67 on: Fri, 25 July 2014, 09:13:21 »
I've most recently been working on Duck PCBs, Butterfly keypad and Orion. That is a good note as I do my own PCB design. Are there SIP sockets that are extra long?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #68 on: Fri, 25 July 2014, 09:26:15 »
I have not run into any, but I have not looked either. I know you can get header sockets with longer pins, so it may be possible.
Offline Igthorn
« Last Edit: Fri, 25 July 2014, 09:56:45 by Igthorn »
Offline damorgue
« Reply #70 on: Fri, 25 July 2014, 09:56:36 »
Excellent information Igthorn. That would explain why some have had a harder time closing the switch housing than others. Someone should get a few of each and report back which profile works the best.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #71 on: Fri, 25 July 2014, 10:01:53 »
I think some people are not completely removing the housing as well.  When I didn't remove the housing I had problems closing the switch.  I tried to 'shave' the sip socket pair and that was just too tedious for me...
Offline damorgue
« Reply #72 on: Fri, 25 July 2014, 10:06:45 »
Someone should try out the "Ultra-low profile" type listed in the pdf and see if it is any better in that regard.
Offline blackbox
« Reply #73 on: Fri, 25 July 2014, 11:33:38 »
Nice mod! Might do it on my CM QF XT
The LAN table!
« Reply #74 on: Fri, 25 July 2014, 12:22:47 »
I got a few of the long tail ones to try in my next build. (A Lightsaver, I think is my next modern build.) I will report back with results in photographic form.
Offline damorgue
« Reply #75 on: Fri, 25 July 2014, 12:31:35 »
Longer leads might make them stick out more through the PCB, but I recon they wil be worse in the aspect of being able to close the switch housing easily. If your next build is delayed, please just try it in a switch and report back.
Offline Igthorn
« Reply #76 on: Fri, 25 July 2014, 13:32:41 »
TE's sip sockets have a taller upper section versus the Mill-Max ones, .180in vs .165in.  So there is difference between brands.
The difference between Mill-Max's standard and long is only in the pin length.
The ones I have fit completely inside the switch and have wiggle room when the plastic is completely removed.  When I left the plastic on, it fit perfectly.  I'm not sure which brand it is (got them ages ago), but the measurements are about the same as the Mill-Max.
Offline asdfjkl36
  • blue shirt guy
« Reply #77 on: Fri, 05 September 2014, 17:33:39 »
i asked previously but then I thought i fixed it.
Apparently not.
My girlfriend just told me "why dont you ask people on geekhack. They're pretty smart" and so here i am.
I have all the SIP sockets soldered in and i'm adding LEDs on there to test. I will slowly start adding LEDs and i will add one that will cause the other LEDs to dim.
Is there something i'm doing wrong?
« Reply #78 on: Fri, 05 September 2014, 18:15:19 »
Apparently not.
Your GF knows what's up.
What board is this? In some KBs (TG3 BL82) the LEDs are wired up differently and won't work at all unless there are a proper "pair" wired up.
In other KBs, the LED regulation isn't as good, and it will give less or more current to LEDs depending on load.
If it's a KB I have, I'll be happy to test it out.
Offline asdfjkl36
  • blue shirt guy
« Reply #79 on: Fri, 05 September 2014, 18:16:48 »
Apparently not.
She does. I'm just to stubborn to ask for help >.>
It's a Ducky Shine 3 TKL
Offline do_Og@n
« Reply #80 on: Wed, 24 September 2014, 23:59:01 »
I like this idea a lot! Well done good sir!
I have some GH60 pcb's that will be very happy with this mod.
Offline berserkfan
« Reply #81 on: Thu, 25 September 2014, 02:02:25 »
I'm having a problem after a SIP mod to make my Deck a Christmas tree. Everythyng worked fxcept one LED. Tried fixing and now - all leds won't light up. Lock lights work. There is actually a teeny bit of light from orange LEDs but not any other color. Light brightness controls don't cause any more light. I don't know what is going on. Thinking that maybe 2.2v leds are causing a problem I removed them and now have no light on this keyboard anymore.
« Reply #82 on: Wed, 29 October 2014, 10:51:03 »
It took me ages and ages, but I finally put the longer sockets in a keyboard, I vastly prefer working with them but they are $$$ compared to the regular ones.  I've added them to the 2x3x4 LED group buy to try and get a volume price from Mouser.
My good camera's been borrowed. I'll retrieve it today and put up some comparison pictures tonight.
Offline PocoLoco
« Reply #83 on: Sat, 13 December 2014, 10:09:51 »
sorry if this is a noobish question but wouldn't it be possible theoretically speaking to use sip sockets to mount your switches to the pcb ? to easily assemble & disassemble without needing to solder twice ?
Offline berserkfan
« Reply #84 on: Sat, 13 December 2014, 10:12:20 »
NO, not possible. The LED matrix is wired differently ie your switches will be physically attached to the board but not their electrical contacts, so the switches won’t be able to send signals to the keyboard controller. You'll wind up with a bright paperweight.
Offline whiskytango
  • Don't touch the trim
« Reply #85 on: Sat, 13 December 2014, 11:11:15 »
I think theoretically yes. But, it would not be very sturdy. You'd have to use a plate. But then you'd also have the SIP socket sticking up off the PCB so your distance between plate and PCB would be greater than usual (the switches are normally flush with the PCB). So you'd have a thicker package overall and depth of your case might become an issue. Also you'd have to find the correct SIP sockets to accept the blade shaped contacts found on MX switches. And if I'm not mistaken the switch contacts are actually two different sizes, one is stiffer than the other on each switch.
I think there is a company that made a keyboard using this concept though. Can't remember the name right now. Something Chinese maybe?
Offline 0100010
  • Not Sure
« Reply #86 on: Sat, 13 December 2014, 13:36:06 »
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #87 on: Sat, 13 December 2014, 14:37:26 »
OT: Wow, whiskyTanog, I haven't seen you post since forever, good to see brother!
Offline whiskytango
« Reply #88 on: Sat, 13 December 2014, 19:04:59 »
We had a baby. He is two months. I'm still around, just don't have much free time these days, ha. It's getting better though.
Offline MOZ
  • Busy making stuff
« Reply #89 on: Sun, 14 December 2014, 00:27:47 »
Congratulations on becoming a father. I hope you have started to pass on the keyboard knowledge and passion.
Offline rpeterclark
  • RPTR ❌
« Reply #90 on: Thu, 09 July 2015, 14:18:22 »
An alternative to Swill's flush cutter method is to just grab the socket and push it up through the housing. It's quick and easy and I've not yet mangled any SIPs like I did when cutting them out.
Apologies for the necro, but this seemed like the right place!
Offline thesiscamper
    • Keyrenders
« Reply #91 on: Fri, 11 March 2016, 03:59:25 »
Great tip, I'm expecting a few next week. Thanks.
"haters are confused admirers"
Offline juahenza
  • DoSmallThingswithGreatLove
« Reply #92 on: Sun, 24 July 2016, 03:10:56 »
currently installing LEDs on these sockets in my switches. my fingers are crying blood  :'(
456GT | TGR Jane CE | Dolphin v2 | Whale | 360c | LZ FE | LZ IRON | TX-CP | Varmilo VA87M | HHKB P2 | IBM SSK P.1397681| IBM Industrial SSK P.1395682 | VE.A | Realforce 87u | Datamancer Streamline TKL | Datamancer Mechinist TKL | TANK v1 | RAMA M-4 | Realforce 108UW-HIPRO
Offline Xantus
« Reply #93 on: Wed, 30 November 2016, 05:05:40 »
Hi Geeks,
I'm planning to build my first Diy Mechanical Keyboard, a GH60 (Rev. C) with white Gateron Switches. I've found alternative source for SIP Socket but Im not sure about these. Will these work for SIP Modding?
https://www.reichelt.de/IC-Sockel/SPL-64/3/index.html?ACTION=3&GROUPID=7429&ARTICLE=19401&OFFSET=16&SID=93WD294KwQATIAAHs@BQga7d5eaf29114b26554eec9470c9a604d&LANGUAGE=EN
https://www.reichelt.de/Sockets-IC/MPE-006-1-050/3/index.html?ACTION=3&LA=2&ARTICLE=119951&GROUPID=7429&artnr=MPE+006-1-050&SEARCH=%252A
Best Regards
X.
« Last Edit: Wed, 30 November 2016, 05:07:41 by Xantus »
Offline DillonHightower
  • Formerly DillonHighsmith
« Reply #94 on: Thu, 23 March 2017, 22:36:41 »
Sorry im late , but im wondering if something like this would work with the gateron switch ? I dont have one handy to compare to the mx switch.
Offline rpeterclark
  • RPTR ❌
« Reply #95 on: Fri, 24 March 2017, 06:37:45 »
Yes, it works with Gateron switches.
Offline Bi0
« Reply #96 on: Wed, 26 April 2017, 04:06:12 »
Question on this did anyone ever figure out the best ones to use?  I see a couple of others mentioning the Mill Max ones: http://www.mouser.com/ProductDetail/Mill-Max/311-43-164-41-001000/?qs=sGAEpiMZZMs%2fSh%2fkjph1tjJZclYmfaNPJ3I9Z5RDf1I%3d
I'm getting one of the new Sabers and want to try this on the mod switches.   ^.^
« Last Edit: Wed, 26 April 2017, 14:38:57 by Bi0 »
Offline deadall127
« Reply #97 on: Sat, 30 September 2017, 11:37:53 »
Offline tuxkey
« Reply #98 on: Sun, 15 April 2018, 15:28:35 »
interesting post / topic..
Could you please elaborate on what you said
"the MX lock is unsuitable unfortunately "
What does this mean exactly ??
i know this is an old post but as it's not that long and still current a far as i'm concerned i see no reason to start a new topic.
Keeping all the info in one place is way more valuable..
Thanks for youre help guys..
Offline TalkingTree
    • My projects
« Reply #99 on: Sun, 15 April 2018, 15:37:30 »
The Cherry MX Lock switch has the LED hole shifted to the right and it won't align with the PCB pads that are usually centered.
