Poll
Which profile this set should be?
DCS (standard filco-like caps)
38 (43.7%)
DSA (low spherical)
22 (25.3%)
SA (tall spherical)
27 (31%)
Total Members Voted: 87
Author Topic: [IC] ALL NEW Midnight SA set  (Read 246874 times)
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: [IC] ALL NEW Midnight SA set
« Reply #800 on: Wed, 16 July 2014, 00:31:06 »
I have one in my grabbag (right in between the Win and the Shamrock). Because it's translucent and SA is pretty thick, the plastic it doesn't look right. The edges bleed giving it a messy look.
Sorry bud from the pic you provided it looks clearly like a DCS, the standard profile from SP.
Just take a pic showing the sides then you'll know if it's SA because that baby will be quite large compared to any other SP profile.  Never show pics from above because all the profiles look similar, until you see them side ways.
« Last Edit: Wed, 16 July 2014, 00:33:51 by Elrick »
« Reply #801 on: Wed, 16 July 2014, 00:35:41 »
That cap looks SA to me.
Offline sakai4eva
Re: [IC] Midnight set
« Reply #802 on: Wed, 16 July 2014, 03:50:15 »
More testing. Please let me know if you spot any errors
please note there are no custom legends! The few novelty keys are all already available legends. The spacebars are x2 just as place holder. I will add spacebars in other sizes
PS: I don't remember if 2u backspace is available in row1. I have to check
Would be great if you can add the 1x1 modifier keys into the ergodox kit and also a 1800 layout kit, but I guess it's fine the way it is.
Nice work, though, and thanks for keeping my dreams of finally having a coherent SA set possible.
Offline Arcoril
« Reply #803 on: Wed, 16 July 2014, 10:46:00 »
In addition to the blank Ergodox set would it be possible to get a labeled set similar to what you did for the Granite Ergodoxian?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #804 on: Wed, 16 July 2014, 10:56:00 »
only if it's okay for you to have legends in the wrong orientation
Offline sakai4eva
« Reply #805 on: Wed, 16 July 2014, 21:26:51 »
Actually I feel that it's better to get the ergodoxian mods in blanks. Looking back into my old Granite order, I'm only using around 4-5 labelled keys, and now I need to get me some blanks from SP.
Offline Zebadule
« Reply #806 on: Wed, 16 July 2014, 21:46:22 »
It's not going to make or break my interest in the set (which is very much made), but I'd definitely get a set even if some of the legends were in the wrong orientation.
Offline Arcoril
« Reply #807 on: Wed, 16 July 2014, 23:07:08 »
I agree. I'd pick up a set even if the legends weren't in the right orientation. On top of that I'd also pick up a set of the blank Ergodox caps too.
Offline Data
« Reply #808 on: Thu, 17 July 2014, 08:38:21 »
Make that 3 of us (at least).
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #809 on: Thu, 17 July 2014, 08:43:32 »
can you guys make a list of all the keys you'd like to see in the ergodox kit?
Offline sakai4eva
« Reply #810 on: Thu, 17 July 2014, 09:24:12 »
1.5x - shift, ctrl,tab, backquote (`~), backspace, forward slash (|\), another shift and enter, vertical FN, vertical capslock, and two more vertical FN.
2x - space, enter, shift, space
1x - fn, win, alt, app/meta, ctrl
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #811 on: Thu, 17 July 2014, 09:34:41 »
thanks
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #812 on: Thu, 17 July 2014, 09:41:35 »
+1.5x - esc
+1.5x - 2 extra blanks
+2x - 2 extra blanks
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #813 on: Thu, 17 July 2014, 09:44:32 »
it would end up a pretty expensive set, but I can try to design it.
Offline skrooks
« Reply #814 on: Thu, 17 July 2014, 09:47:31 »
I thought the Granite Ergodoxian kit was great. The only key I thought was missing was a 2x Backspace, which I pulled it from the Granite Text Pro Modifiers kit (in this case it would be the Midnight alpha kit). Here's what I personally use. I think having some extra blanks would be great, just in case.
Offline Arcoril
« Reply #815 on: Thu, 17 July 2014, 10:54:47 »
In addition to what other people have listed, I'd also really like:
1.5x '/"
1.5x -/_
1.5x +/=
1.5x [/{
1.5x ]/}
2x backspace
2x delete
Offline Data
« Reply #816 on: Thu, 17 July 2014, 10:58:13 »
Everything from Granite Ergodoxian should be sufficient.
If I were to add anything:
  • 2x Alt (perhaps 2 of these?)
  • 1x Ctrl (2 again?)
  • 1.5x Home
  • 1.5x End
  • 1.5x Pg Up
  • 1.5x Pg Dn
  • 1.5x Tab
... Unless any of these might appear in a Tsangan or Alt Mods kit.
You mentioned the legends being the wrong orientation, is that because these are Cherry replica?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #817 on: Thu, 17 July 2014, 11:06:21 »
SA doesn't have cherry font. this would be with standard SP font.
the wrong orientation is because this is 2-shot (and not sublimated).
Offline cjhard
  • Claudia the Magnificent
« Reply #818 on: Thu, 17 July 2014, 11:08:43 »
Matt3o, can we have a couple MiniLa keys? 3x "space" (I won't even care if it's convex or concave), 1x shift, 2x shift?
http://geekhack.org/index.php?topic=46620.0
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #819 on: Thu, 17 July 2014, 11:16:49 »
find me another interested buyer and I'll add them :D
Offline cjhard
« Reply #820 on: Thu, 17 July 2014, 11:23:34 »
Aww I was figuring you could just dump them to an oddmod pack and make everyone subsidize my dumb keyboard layout that I totally didn't consider replacement keysets when buying.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #821 on: Thu, 17 July 2014, 11:36:19 »
mind you. I have a minila :)
Offline Data
« Reply #822 on: Thu, 17 July 2014, 12:08:24 »
OK, I think I understand.  Thanks.
Offline SL89
« Reply #823 on: Thu, 17 July 2014, 12:11:31 »
no polycarb. SP discourages SA+PC. I might add glow in the dark though.
I guess that makes sense about the PC. The glow in the dark was one of the reasons i was keen on the Midnight set. Thank you for considering that option Matt3o.
Offline Zebadule
« Reply #824 on: Thu, 17 July 2014, 14:46:47 »
Others have already listed every key I could possibly want in the ergodoxian set. But, you could always add a 2x E key and claim to be the first group buy ever to fully support the Malt layout :P
Offline brybell
  • Time you enjoyed wasting is not wasted time
« Reply #825 on: Thu, 17 July 2014, 16:00:08 »
Im sorry if this is a n00b question, but I know that the midnight set in DCS already happened. Is this for SA now? Cuz that is awesome.
"Did you ever wonder if the person in the puddle is real, and you're just a reflection of him?"
~ Calvin and Hobbes
Offline Arcoril
« Reply #826 on: Thu, 17 July 2014, 19:11:08 »
The set was originally going to be SA but was switched to DCS as a result of a vote. However, it looked like the DCS version wasn't going to tip and Matt3o decided to bring the idea back to its roots and start over with SA. Then the DCS version tipped thanks to some divine intervention, but the SA hype train kept on rolling. So now it's looking like we get to have both.
« Last Edit: Thu, 17 July 2014, 19:13:15 by Arcoril »
Offline brybell
« Reply #827 on: Thu, 17 July 2014, 20:05:46 »
Awesome! Thanks for the info. I am definitely on board with SA!!!  ;D
~ Calvin and Hobbes
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #828 on: Fri, 18 July 2014, 02:04:16 »
just remember that Nuclear data has to complete first.
« Reply #829 on: Fri, 18 July 2014, 08:14:08 »
 :cool:
Offline sakai4eva
« Reply #830 on: Fri, 18 July 2014, 09:13:48 »
I DON'T CARE ABOUT NUCLEAR DATA :|
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #831 on: Fri, 18 July 2014, 09:19:35 »
okay. I'm now leaning towards the following profile:
I already suggested something like this few pages ago, but it didn't receive much love. Now I see that even Filco chose this profile for its high profile set, so I wish to push it back to your attention.
Offline sakai4eva
« Reply #832 on: Fri, 18 July 2014, 09:23:37 »
I'm probably headed towards the uniform profile (SA row 3) style since it'll be rotated between my TKL/Lightsaver/Ergodox.
Nonetheless, it is an intriguing idea. I've never used SA profiles extensively except what can in my grab bags.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #833 on: Fri, 18 July 2014, 09:27:50 »
considering that the slanted rows are just the f-row and the #-row that shouldn't be a big issue. All alphas would be still on row 3.
« Reply #834 on: Fri, 18 July 2014, 09:33:06 »
I have a Filco set (2 actually), and it's not a terrible compromise. But it feels like it could use more "sculpting." Personally, I would go for 3-1-2-3-4-3 profiles from top down. I just wish SP would get off their asses and make Row 4 shift keys.
I'm not buying Nuclear Data, specifically because it's all-row-3. And I wouldn't buy this one either, in that scenario.
« Last Edit: Fri, 18 July 2014, 09:34:42 by jdcarpe »
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #835 on: Fri, 18 July 2014, 09:56:29 »
I hate those row 3 shift keys! :D
Offline Arcoril
« Reply #836 on: Fri, 18 July 2014, 11:49:37 »
My current plan is to get a row 3 set for an Ergodox and a mixed set for use on a 60% board. I won't lie though--the mismatched shift keys would bother the hell out of me. :)
Offline Data
« Reply #837 on: Fri, 18 July 2014, 14:08:21 »
I like it, but I'm still trying to figure out how well it would work with Ergodox.
Admittedly I am still new at this.
Offline Arcoril
« Reply #838 on: Fri, 18 July 2014, 16:34:54 »
It should work just fine with an Ergodox since all the alphas would be R3. All the modifiers are either 1.5x or 2x and would also come in R3. The only issue I can see is if you decided to use the ESC somewhere or decided to put the function keys along the bottom row of the Ergodox.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #839 on: Fri, 18 July 2014, 17:10:44 »
esc would be available in R3 too
Offline Arcoril
« Reply #840 on: Fri, 18 July 2014, 23:39:53 »
Sounds good! And a 1.5x ESC as part of the Ergodox legend set would give us a huge amount of flexibility. :)
Offline agodinhost
    • Dr Ian O Xaman
« Reply #841 on: Sun, 20 July 2014, 12:45:33 »
+1
Offline myrddin
« Reply #842 on: Sun, 20 July 2014, 16:36:43 »
Do you mean only offering a single profile, or just changing the slanted option to only be fn+numrow?
If the latter idgaf, but the former would break compatibility with dvorak by changing the slant on "?/" and "=+" which are qwerty row vs "[{" and "]}" which become numrow.
I seem to be the only one who keeps poking for that though :(
I don't *think* colemak swaps anything around on the numrow, but I don't use it so I could be wrong.
Wouldn't ergodox have the same issue?
« Last Edit: Sun, 20 July 2014, 16:42:13 by myrddin »
Offline Cods
  • Penumbra SA Mark II please?
« Reply #843 on: Sun, 20 July 2014, 19:16:44 »
I assume you mean that you'd still offer all of the following from your latest image:
1 - Midnight SA Common Kit (ALL ROW 3)
2 - Midnight SA All Row 3 Kit
3 - Midnight SA Variable Rows Kit
but that the Midnight SA Variable Rows Kit would have the profile that you posted most recently.
Is that correct?
FWIW my preference and intention is to buy All Row 3, but (wallet winces) I reckon I'd be mighty tempted to also add the Variable Rows Kit for variety and 'just in case'.
Model M Industrial, SSK, Unicomp 104, Code TKL MX Green, FC660M MX Green + Clear + White + Grey, FC660C Topre 45g, MagicForce 68 USB and Bluetooth, Whitefox, some optical switch 65% Bluetooth split spacebar thing ... wait, I think I need an intervention. Too late, there�s a couple of new Model Fs on the way.
Too much SA is never enough.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #844 on: Mon, 21 July 2014, 02:06:31 »
the idea would be to use the Filco layout + all row3 option.
but I'm not sure yet.
Offline Elrick
  • Hype Master
« Reply #845 on: Mon, 21 July 2014, 04:55:34 »
Definitely need all Row3 for weird Cherry keyboard setups like the 1800 series.
Also having an option of a full variable row set would be purchased for the standard 87 or 104 keyboard.  Why not offer both so that everyone has a choice or goes for both in the final buy up?
Shall get both due to having keyboards that need them so desperately  :thumb: .
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #846 on: Mon, 21 July 2014, 06:11:46 »
I don't think there's enough interest to offer all options.
Offline Elrick
  • Hype Master
« Reply #847 on: Mon, 21 July 2014, 19:23:35 »
Didn't we hear that when you started the DCS profile, that it wouldn't tip?  The rest is now history.
Just offer it because the vast amount of people here know who and what you are Matt3o, the DESIGNER of unique key-sets that everyone wants a piece of  :thumb: .
Just waiting for you and Bunny to get together and start producing something truly astounding that everyone throughout the world will want to own.  You my dear Matt need a little more confidence in your ability to attract interest in your designs.
Offline Oobly
« Reply #848 on: Fri, 01 August 2014, 02:42:32 »
I'd be interested in a common kit, variable rows kit and additional mods!
I want my contoured SA, doggonnit!
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #849 on: Fri, 01 August 2014, 08:05:08 »
I agree Oobly. With the Nuclear GB, I'm gonna need a contoured SA set and this would be prefect.
