Author Topic: [SPRiT] MX ALPS Springs/ LSS Lube/ Stabilizers/ Cherry RGB Clear (CLOSED!!!!!!!)  (Read 1493135 times)
Offline Fnzzy
Re: <SPRiT Edition> * Gold Springs = (Production) (Extra Orders OPEN)
« Reply #750 on: Thu, 07 August 2014, 16:06:42 »
Any update on when the next wave is going to hit EU?
Offline Charlie S
« Reply #751 on: Fri, 08 August 2014, 06:57:33 »
I know the title says orders are still open, but just to clarify, if I order now would I still be able to get them shipped via proxy or is it too late for that? Would probably save a fair chunk of change since epzy and I are in the same country.
Offline Zeal
    • Zeal Generation Inc.
« Reply #752 on: Fri, 08 August 2014, 08:24:31 »
Still on schedule as the rest of the world, around Aug 18 onwards.
Yes, you can still place your order for proxy shipping.
Offline Fnzzy
« Reply #753 on: Fri, 08 August 2014, 08:40:43 »
I should read... Thanks  :D
Offline Charlie S
« Reply #754 on: Fri, 08 August 2014, 09:31:43 »
decided to spring (excuse the pun) for an order of these, will be eagerly anticipating their arrival :)
Offline halodub
    • 420PraiseIt
« Reply #755 on: Sun, 10 August 2014, 15:34:02 »
Just put in an order for some of the 120g springs. Hopefully they can take 3000+ hours of CS:GO better than these stock MX Black springs >.>
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #756 on: Mon, 11 August 2014, 00:57:16 »
I highly doubt 3000 hours of a game did anything to the switches.
Considering that Cherry switches are rated for 50M keypresses, I think this is the McRip effect if anything.
Mmm... machined aluminum
Offline user 18
« Reply #757 on: Mon, 11 August 2014, 15:40:50 »
Which of the springs would be closest to a stock MX green, for reference?
Avatar by ashdenej
Offline Xenderwind
« Reply #758 on: Mon, 11 August 2014, 15:46:23 »
I believe "ghetto" greens are made using black springs with blue stems.  With that logic, the info on the OP says he thinks 75g springs are closest to current mx blacks.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #759 on: Mon, 11 August 2014, 16:54:28 »
stock greens are 80g cherry which translates to roughly 100g korean
Offline HPE1000
  • Keycap Paparazzo
« Reply #760 on: Mon, 11 August 2014, 17:04:31 »
80g korean springs are used to make "ghetto" green switches.
Offline halodub
    • 420PraiseIt
« Reply #761 on: Mon, 11 August 2014, 21:16:01 »
Thats what I thought too, but I can definitely notice a difference in my WASD keys vs the other lesser used keys (like Pause and keys like that). Who knows, maybe it's just in my head too lol. Either way it'll be nice to have heavier springs :3
Offline archer
« Reply #762 on: Mon, 11 August 2014, 22:09:39 »
Order placed, thanks!  :thumb:
« Reply #763 on: Mon, 11 August 2014, 22:18:52 »
it absolutely makes a difference
my QFR blacks feel very different than the ones in my DS3
Offline Lurch
« Reply #764 on: Tue, 12 August 2014, 09:00:09 »
Order placed! :thumb:
Quote from: Flyersfan1
Offline phatdood9
« Reply #765 on: Tue, 12 August 2014, 13:46:04 »
just made an order
hope it still works  :D
Offline mikew0w
« Reply #766 on: Tue, 12 August 2014, 23:30:25 »
When should first round USA folks expect delivery?
Offline jorgenslee
« Reply #767 on: Fri, 15 August 2014, 03:31:52 »
Is this still open? Also, I would like to ask if how much is shipping to philippines?
Thanks
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #768 on: Fri, 15 August 2014, 03:49:22 »
Thanks
Sure, because extra qty will be produced.  ;)
Offline sprit
« Reply #769 on: Fri, 15 August 2014, 03:53:13 »
Update  -    August 14th
- Productions  :  Standard Stainless versions Produced,  Moving to the Gold-Plating factory,  Need more time due to Factory schedule, etc
- Shipping  : When I got them, Inspection & packing,  Shipping Starts  from  August 28th ~
Offline jorgenslee
« Reply #770 on: Fri, 15 August 2014, 05:41:35 »
Thanks
Cool. Can you quote me on the shipping fee? Im trying to find a cheaper route. :)
Offline paobit
« Reply #771 on: Fri, 15 August 2014, 13:56:34 »
Hey sprit just a heads up I put an order  :p
Offline archer
« Reply #772 on: Fri, 15 August 2014, 15:58:26 »
Hey SPRIT, just sent you a PM about LEDs.. let me know what you think!
Offline Synjin
« Reply #773 on: Fri, 15 August 2014, 22:04:32 »
Just ordered twice, could you kindly cancel the first order? I noted on the comment of the second order just as a reminder, thanks ^_^
Offline Dog
  • Bark
« Reply #774 on: Sat, 16 August 2014, 20:52:10 »
Does anyone know how the springs in stock clear compare to stock green? I got some green and clear switches to experiment with, but was a bit confused looking at the deskthority wiki for them. The green is listed as having an actuation force of 80cn, and the clear is listed as 65cn. Looking at the springs compared on this post though mx black (deskthority wiki lists as used in ghetto green) is listed as 75g, while clear is listed as 85g.
I'm mainly curious because I was surprised by just how nice the green felt with a clear spring in it, but I don't really know how much of a difference there is. I gave a stock green, green w/ clear spring, and stock clear to two friends and asked them to choose their favorite. One is into keyboards, and the other is not. Both of them chose the modded green over the two stocks. I'm starting to think I may want to get some blue switches and put in springs similar to mx clears.
« Last Edit: Sat, 16 August 2014, 21:02:42 by Dog »
Offline ComradeSniper
  • HHKB Pro
« Reply #775 on: Sun, 17 August 2014, 22:01:51 »
Order submitted, thanks.
Offline drrtyrokka
« Reply #776 on: Mon, 18 August 2014, 07:37:26 »
Hey guys, is it still possible to order 62g and 65g springs? Is it possible to order the normal ones or are there only gold ones left?
If I just order a sampler kit, is it still possible to order again, after they arrive here in germany? How long will this take approx. ?
« Last Edit: Mon, 18 August 2014, 07:42:26 by drrtyrokka »
Offline Zeal
« Reply #777 on: Mon, 18 August 2014, 09:18:52 »
You can still place an order for R2. Both regular and gold plated springs are available in 62g and 65g weights. Sampler kit will ship with your spring orders, and the GB / (proxy ship) would be closed by then so no extra individual direct shipments would be made from this GB.
« Last Edit: Mon, 18 August 2014, 09:21:07 by Zeal »
Offline drrtyrokka
Re: &lt;SPRiT Edition&gt; * Gold Springs = (Production) (Extra Orders OPEN)
« Reply #778 on: Mon, 18 August 2014, 09:19:40 »
Thank you very much :)
Send my order for 62 65 and 68 springs in standard. I'll choose the best for my ergo clear mod.
How will payment work?
Will I get a invoice or something?
And the last question: When will this be shipped and arrive?
« Last Edit: Mon, 18 August 2014, 09:51:01 by drrtyrokka »
Offline GL1TCH3D
« Reply #779 on: Mon, 18 August 2014, 19:38:23 »
I put a request in! Hopefully I'm still in time
Offline Zeal
« Reply #780 on: Mon, 18 August 2014, 20:16:12 »
You'll receive a PayPal invoice shortly.
Springs are being gold plated. You can expect the springs to ship this month.
Offline Synjin
« Reply #781 on: Mon, 18 August 2014, 21:38:17 »
I just paid off my invoice that was sent to me earlier today by Sprit. When do you think my gold plated springs will be shipped to me?
Offline GL1TCH3D
« Reply #782 on: Mon, 18 August 2014, 22:08:17 »
Was hoping if possible to adjust the order (add a few samplers)
« Reply #783 on: Tue, 19 August 2014, 00:15:04 »
They'll make their way to the proxies soon (they haven't been shipped by sprit yet), and then it should be a quick turnaround to you guys.  I'll be the person shipping your springs out.  ;)
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #785 on: Tue, 19 August 2014, 17:47:28 »
I request a dinosaur be drawn on my package.
« Reply #786 on: Tue, 19 August 2014, 17:48:55 »
Oh man.  I am the worst.  You do not want me to draw you anything.
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #787 on: Tue, 19 August 2014, 18:04:59 »
Dinosaur or riot, Hoff.
« Reply #788 on: Tue, 19 August 2014, 18:25:30 »
I don't know if riot wants me to draw his likeness on a package.   :rolleyes:
I will try to draw a dinosaur!  But it will be the worst.
Offline Synjin
« Reply #789 on: Tue, 19 August 2014, 22:32:42 »
Draw me something an engineer would for my box =)
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #790 on: Tue, 19 August 2014, 22:50:10 »
Offline asdfjkl36
  • blue shirt guy
« Reply #791 on: Tue, 19 August 2014, 23:06:19 »
If you're taking requests, I'd be up for any drawing  :p
The worse, the better  ;D
Offline drrtyrokka
« Reply #792 on: Wed, 20 August 2014, 03:41:55 »
Still didn't get an invoice... What's up?
Offline Zeal
« Reply #793 on: Wed, 20 August 2014, 05:33:21 »
You should be receiving one shortly. :)
Sprit's a busy man, and is doing his best with getting R1 keyboards shipped & invoicing for his other GBs.
Offline sod4
« Reply #794 on: Wed, 20 August 2014, 15:08:25 »
Is it still possible to get in on this order?
Offline Zeal
« Reply #795 on: Wed, 20 August 2014, 18:54:51 »
Yes. Submit and order, and you should receive an invoice shortly.
Offline GL1TCH3D
« Reply #796 on: Wed, 20 August 2014, 19:28:06 »
Got my invoice and paid in full!
Can't wait to start modding when I get them =]
Offline sod4
« Reply #797 on: Thu, 21 August 2014, 12:09:32 »
Invoice received and paid. Excitement!
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #798 on: Sat, 23 August 2014, 12:51:44 »
Sprit, can you add the following to my order 1680:
200 gold 65g springs
100 gold 62g springs
I've already paid the invoice, but maybe you can just send out a new one or I can pay the difference.
Offline Gloomy Moonie
« Reply #799 on: Sat, 23 August 2014, 13:05:45 »
Are orders for samplers still open? If not, what sets are still available?
