Author Topic: [GB] Granite Set ~ Sublimated Full PBT (spacebar included)  (Read 2489106 times)
Re: [GB] Granite Set ~ Sublimated Full PBT (spacebar included)
« Reply #450 on: Thu, 03 April 2014, 21:45:39 »
Is there a site I can see all of the different key cap colour codes on. Not just the ones in this group buy, but all the different colours. I would like to see what would like to see which of the blank mod kits I should get if the blank pro set does not tip.
http://keycapsdirect.com/colors.php
Thanks, I briefly looked around on their site, but I didn't find it. I might have just been blind though.
there's also a thread on here somewhere that tried to scan and color correct the color chips
« Reply #451 on: Thu, 03 April 2014, 21:47:38 »
http://geekhack.org/index.php?topic=45743.0
Offline Vibex
  • Love y'all
« Reply #452 on: Thu, 03 April 2014, 21:47:42 »
I'll look around for it.
Offline wuqe
« Reply #453 on: Fri, 04 April 2014, 00:30:59 »
Definitely interested! But as a modified keyboard n00b, I have a few questions:
I'm building an Ergodox to use with my Mac, so I was wondering what set of text modifiers would I need, 1u, 1.25u, or 1.5u on the Apple Kit?
And would this cover all of the keys I need?:
- Common Kit
- Ergodoxian
- Apple Kit
- Text modifiers
Thank you for your help & I'm looking forward to this!
Maybe someone can tell you what you need to know, just based on your description. But, I think it may be better if you post a picture (image, or mockup) of the Ergo's layout you want to dress up with this set.
1.5u mods for the outside keys and the vertical inside keys, 1u anywhere else. Note that the Text Modifiers kit is all funny sizes that won't match Ergodox, except the 1.5u Tab key (and the 1u PgUp and friends keys, of course), but looks like the Apple kit has what you'll need. (I'm getting the Pro Modifiers kit for the 1u and 1.5u mods.)
I think your proposed kit looks able to cover your board, though a 1.5u Backspace from Pro Modifiers kit is one you might want to consider... :grin:
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #454 on: Fri, 04 April 2014, 02:00:39 »
I just tipped the Blue Enter kit to $11.25
Get it while it's hot, girlies!
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #455 on: Fri, 04 April 2014, 02:35:59 »
We discussed the kits forever. I changed them one hundred times and still it seems I can't make it right. Maybe next time I'll do as pasph says: 3 standard kits and and no IC :P Or like 7bit does (basically 1 key per kit).
Anyway this is the current status.
I guess at this point who really wanted the set already got it and we will stall until the very last moment when we'll get the undecided.
  • Keyboard Hipstar
« Reply #456 on: Fri, 04 April 2014, 02:39:39 »
C'mon Icon RGB...
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #457 on: Fri, 04 April 2014, 02:50:05 »
Common set just reached 53.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #458 on: Fri, 04 April 2014, 02:53:52 »
people place order right after I post the status update... gotta post it more often :)
Offline tbc
« Reply #459 on: Fri, 04 April 2014, 02:55:40 »
PLEASE BUY MOAR WINDOWED KEYS.
just because it's windows doesn't mean linux and mac people can't join in the love. honest. :)
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #460 on: Fri, 04 April 2014, 02:56:07 »
I know.  Ever single time you have posted a status update.
WTB/WTS/WTT ---->
Offline Curetia
« Reply #461 on: Fri, 04 April 2014, 05:09:31 »
Order submitted. Will hope that the price will go down, else I have to cancel my order :(
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #462 on: Fri, 04 April 2014, 05:09:59 »
Idea for a keycap in the nerdom:
« Reply #463 on: Fri, 04 April 2014, 05:15:46 »
Brilliant!  Why has no-one ever thought of doing this before?!?
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #464 on: Fri, 04 April 2014, 05:19:48 »
Yes.  Love all of them.
« Last Edit: Fri, 04 April 2014, 05:29:29 by CommonCurt »
WTB/WTS/WTT ---->
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #465 on: Fri, 04 April 2014, 05:27:56 »
Only problem is that I need some time to vectorialize the switch correctly and I don't have much time.
Does anyone has a very high resolution lineart image of the switch?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #466 on: Fri, 04 April 2014, 05:54:25 »
Ideas so far:
Offline Photoelectric
« Reply #467 on: Fri, 04 April 2014, 05:57:18 »
I like the top view switch outline,  space invader, and the Sun logo.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #468 on: Fri, 04 April 2014, 05:58:12 »
Ideas so far:
Really like the switches. Never seen it on a cap before.
WTB/WTS/WTT ---->
  • Keyboard Hipstar
« Reply #469 on: Fri, 04 April 2014, 06:09:27 »
Ideas so far:
The top-view switch outline, is great.
Really like that one.
Sun logo, obviously.
The beaker(tumbler?) key is quite nice, as well.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #470 on: Fri, 04 April 2014, 06:32:58 »
ok. the missing key will be the MX top view.
I might also change the glider. Keep posting your suggestions.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #471 on: Fri, 04 April 2014, 07:11:31 »
Love the top view MX, great choice.
Offline drrtyrokka
« Reply #472 on: Fri, 04 April 2014, 07:30:50 »
You mean the flask? My suggestion, I really want to use it on F1 as Help key, as unfortunately matt3o removed the 'help' key from lost+found...
It's just such an allrounder, like it. Please go for it :)
BTW: I don't really like nerv and blue sun because i'm no fan of these series... can't they be changed too? How high is the demand after these caps?
Offline ideus
  • Björkö.
« Reply #473 on: Fri, 04 April 2014, 09:12:56 »
Top view MX, SUN logo, and the Erlenmeyer flask.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #474 on: Fri, 04 April 2014, 09:34:54 »
no, those can't really go away :)
Offline ideus
  • Björkö.
« Reply #475 on: Fri, 04 April 2014, 09:53:59 »
Could you please post a draft of the current Nerdom set caps?
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #476 on: Fri, 04 April 2014, 10:18:53 »
Zooooooork!!!! (sound of hope fading)
Quote from: Samuel Adams
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #477 on: Fri, 04 April 2014, 10:38:26 »
current Nerdom
my robot can be replaced, if we really want
Offline ideus
  • Björkö.
« Reply #478 on: Fri, 04 April 2014, 10:41:48 »
current Nerdom
Not at all, the robot shall stay. So the sun logo is not gonna be in the set?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #479 on: Fri, 04 April 2014, 10:44:50 »
glider (the 5 dots) is another key that could be replaced. Suggestions welcome.
Offline ideus
  • Björkö.
« Reply #480 on: Fri, 04 April 2014, 10:46:32 »
Maybe you could consider to replace it with the sun logo. It is way too awesome to not have it in this nice set.
Offline justnits
« Reply #481 on: Fri, 04 April 2014, 10:52:32 »
how about letting your wife have another go?  ;D
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #482 on: Fri, 04 April 2014, 10:59:58 »
I would prefer to avoid company logos actually.
she says: "godzilla"
Offline ideus
  • Björkö.
« Reply #483 on: Fri, 04 April 2014, 11:01:34 »
Godzilla has copyright protection  :))
Offline Elias Camber
« Reply #484 on: Fri, 04 April 2014, 11:40:35 »
howdy,
first of all, I think this GB is a blast. Thanks for doing this.
Also for offering multilanguage sets, a true statement to an international comunity.
Will be posting the layout I'm buying for later on,
but for now I've got an Idea for that open cap... how about this:
Offline xlt0rqu3lx
« Reply #485 on: Fri, 04 April 2014, 12:57:28 »
So the spacebar that will come with the common kit will fit the Poker II correct?
Offline ideus
  • Björkö.
« Reply #486 on: Fri, 04 April 2014, 13:29:37 »
Poker II takes any standard 6.25u spacebar. Thus, the one included in the common set will fit it.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #487 on: Fri, 04 April 2014, 13:56:43 »
There you go. Poker 2 icon modifiers.
can't do better than that with my limited 3d skill and time
Offline ideus
  • Björkö.
« Reply #488 on: Fri, 04 April 2014, 13:59:04 »
Better than this the real thing only. Thank you very much for the render.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #489 on: Fri, 04 April 2014, 14:04:04 »
These produced already? Oh, wait, whaaaaaat!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #490 on: Fri, 04 April 2014, 14:21:23 »
and status update. GO Granite!
Offline MOZ
  • Busy making stuff
« Reply #491 on: Fri, 04 April 2014, 15:08:44 »
Looking to get this for my 40%, but the price of the icon mods :(
Is there some other option I have here that does not utilize text mods or blanks to populate my 40%, some kit that could hopefully be gotten for around $20 or less. I need 2x 1u, 4x 1.25u, 5x 1.75u.
Thanks.
Offline xlt0rqu3lx
« Reply #492 on: Fri, 04 April 2014, 15:27:36 »
Wonderful! Thank you will definitely order!
Offline Vibex
  • Love y'all
« Reply #493 on: Fri, 04 April 2014, 15:28:28 »
Thanks.
This is the same problem I've been trying to solve. I wanted to get the blank pro mod set, but only 2 have been purchased so far.
Offline mougrim
« Reply #494 on: Fri, 04 April 2014, 15:32:27 »
Hmm.... Maybe Zorro sign?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline mashby
    • Mashby
« Reply #495 on: Fri, 04 April 2014, 15:32:58 »
My problem is I keep finding more-and-more sets that I "have" to have.
"Oooh. The Text Pro Modifiers would allow me to setup an HHKB layout"
"Oooh. There three kits would allow me to do an Ergodox (which I don't even own yet)
I know I've said it before, but matt3o has really knocked it out of the park with this GB. It's so flexible and looks so great!
Offline mougrim
« Reply #496 on: Fri, 04 April 2014, 15:35:46 »
Basically, if I want full set for my Poker II, it's enough to buy common kit + icon or text modifiers? Or I'll need Pro modifiers too?
Offline mashby
    • Mashby
« Reply #497 on: Fri, 04 April 2014, 15:50:46 »
All you need is the common kit and a basic modifiers (icon or text) and you'll be all set.  :thumb:
Offline mougrim
« Reply #498 on: Fri, 04 April 2014, 15:53:12 »
Thank you! I'll need cyrillic set too, but that pretty much it.
I've got my Poker II yesterday and it looks I've gonna be paid next week, so I think I'll not miss this GB :)
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #499 on: Fri, 04 April 2014, 16:07:39 »
current Nerdom
Oh man that top down Cherry switch... please don't make me add more to my already huge order  :p
Also, go go Cyrillic kit! You know you wanna order it - do it!
KEYBOARDS >>
MICE >>
COMPUTER >>
