Author Topic: [IC] CF-LX Ultra-light Carbon Fiber 60% Case  (Read 63106 times)
Offline ideus
  • Björkö.
Re: [IC] CF60 Ultra-light Carbon Fiber 60% Case
« Reply #50 on: Sat, 28 February 2015, 12:14:20 »
Just filled the form. Will the plate fit both, the Poker X and the Infinity keyboard? I require both.
Poker, yes. Infinity, doubt it, has the different layout problem
There are some ways to make cuts for splitted and single switch backspace and right shifts, I think.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #51 on: Sat, 28 February 2015, 12:29:56 »
hmm, I might look into that then.
« Reply #52 on: Sat, 28 February 2015, 12:39:48 »
I have a feeling that JD can help with this.
« Reply #53 on: Sat, 28 February 2015, 13:07:34 »
If ultra-light is a goal for this case is it safe to assume that the stabilisers will be plate mount?  PCBs weigh lots too, I'd be interested in handwiring one :)
Offline ideus
  • Björkö.
« Reply #54 on: Sat, 28 February 2015, 13:46:59 »
The picture below shows what appears to be universal cut outs - GH60, Poker, Infinity, ANSI, ISO -
« Reply #55 on: Sat, 28 February 2015, 13:49:31 »
Is it possible for a cutout to be pcb cherry and costar compatible, I don't use costar but I know some people do.
Offline ideus
  • Björkö.
« Reply #56 on: Sat, 28 February 2015, 14:00:09 »
This plate does not support plate mounted stabs.
Offline Ngt
« Reply #57 on: Sun, 01 March 2015, 17:07:01 »
Do you know if it will be the case for this CF60 case?
Offline Asininity
« Reply #58 on: Sun, 01 March 2015, 21:40:52 »
Sounds interesting! My final verdict would be based on the price. Having a carbon fiber plate just sounds cool! Would love to see a prototype.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #59 on: Sun, 01 March 2015, 22:07:57 »
this will use PCB mount stabs
« Last Edit: Sun, 01 March 2015, 22:10:17 by hwood34 »
Offline Ngt
« Reply #60 on: Mon, 02 March 2015, 02:25:47 »
Ok thanks for the answer. I'm new to DIY stuff. I apologize if I ask stupid questions. For the PCB mount stabs to be used with the top CF plate, does the plates holes just need to be wide enough for the stabs to come through?
Offline ideus
  • Björkö.
« Reply #61 on: Mon, 02 March 2015, 04:29:44 »
Yes, the plate should have cut off to allow the PCB stabilizers to come through, like sprits acrylic plates.
Offline Ngt
« Reply #62 on: Mon, 02 March 2015, 06:08:54 »
Ok thanks.
Offline Natemiester
« Reply #63 on: Fri, 06 March 2015, 19:31:32 »
Could one of you fine people explain to me the difference between the notched and unnotched cases? The form says that an unnotched plate forces you to desolder the switch to get the top off. Why is that?
Offline ideus
  • Björkö.
« Reply #64 on: Fri, 06 March 2015, 20:44:39 »
The notches allow the top of the switches to be removed through the plate, with no need for desoldering and unlocking the full switch. It serves for the purpose of changing the springs or lubing the stems.
Offline Natemiester
« Reply #65 on: Fri, 06 March 2015, 21:44:14 »
Ohhh. I get it. Thanks!
Offline nandop
  • May your keystrokes always be true.
« Reply #66 on: Sat, 14 March 2015, 23:48:13 »
I'd be really interested in a 60% Carbon fiber plate!
Sprit 60%, White MX 78g Au | Planck Ortholinear 40% Clear MX | Phantom TKL Browns 110g Au
« Reply #67 on: Thu, 02 April 2015, 13:47:20 »
And we're back!
Here's the plates, it'll support every GH60 layout possible.
Here's the first render with brass standoffs. I'll make others with different standoffs and adjust the light so the carbon looks better. The carbon model in inventor is really bright for some reason.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #68 on: Thu, 02 April 2015, 23:47:13 »
Thanks for all the help Joey Quinn! For some reason Big Blue Saw is acting funny and won't let me get an automated estimate for carbon fiber, so I've sent a request for one. But to give everyone an idea of price, polycarb was around $45 for 10-100 orders and aluminum was low $50s
Offline heedpantsnow
  • Old enough to know better
« Reply #69 on: Thu, 02 April 2015, 23:50:50 »
I priced some 1.5mm cf plates from them; they were $56/each for 10+ I believe. Yeah their automated tool doesn't list cf.
I'm back.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #70 on: Fri, 03 April 2015, 00:21:10 »
ah, well that's not bad at all
« Reply #71 on: Fri, 03 April 2015, 00:27:23 »
Yeah you should be good. Good luck with the project bro!
I'm back.
Offline DrHubblePhD
  • I am star stuff
« Reply #72 on: Sat, 04 April 2015, 22:18:02 »
If the price is sub $70 or so, im so in. CF is a great material  :thumb:
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #73 on: Tue, 07 April 2015, 06:47:27 »
added pricing. little more than I hoped for unfortunately
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #74 on: Tue, 07 April 2015, 09:35:09 »
So I'm also looking into the prices for unnotched plates. I doubt I'll actually go through with that considering how almost everyone in the IC form wanted the more expensive notches.
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #75 on: Tue, 07 April 2015, 09:39:07 »
Love it but no 60% board atm
Please come back when you have a custom transparent case that would take the Ducky Shin 3 TKL PCB
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline DrHubblePhD
  • I am star stuff
« Reply #76 on: Tue, 07 April 2015, 09:49:56 »
Wat
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #77 on: Tue, 07 April 2015, 10:23:58 »
FYI, unnotched plates would be ~20% cheaper
« Reply #78 on: Tue, 07 April 2015, 11:46:20 »
I'll add some renders with corrected carbon and other spacer colors later today.
As far as notches are concerned I don't really care. I've never felt the need to swap stems. Do you want me to make a case with different notch styles or the notches removed?
Offline exitfire401
  • The Force is Re/\l
« Reply #79 on: Tue, 07 April 2015, 11:50:42 »
I'd probably be alright buying 1 at that price. I really would just rather have the notched top with how often I **** with switches.
Offline ccarlitos2
« Reply #80 on: Tue, 07 April 2015, 11:55:18 »
Sent in a form. Honestly with or without the notched plate I'm in for a board :D
« Reply #81 on: Tue, 07 April 2015, 13:29:41 »
Corrected carbon texture and SS standoffs.
I may post more if anything looks cool while I'm messing around.
« Reply #82 on: Tue, 07 April 2015, 13:49:53 »
Anyone have a purple standoff hookup? When this case happens I'm gonna need some.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #83 on: Tue, 07 April 2015, 17:05:11 »
Since the price tiers have pretty little variance, I'll be starting this soon. One idea, since I doubt we'll get enough orders to get great discounts on standoffs, I might include an option for varying colors. I'll have to research the options first
« Reply #84 on: Tue, 07 April 2015, 17:14:01 »
McMaster Carr can get us bulk of everything fairly cheaply.
Offline derezzed
« Reply #85 on: Tue, 07 April 2015, 22:36:04 »
DrHubblePhD
Dolch on this case would bring a man to tears.  I've seen so many remarkable custom designs since I've joined GeekHack, it seems like GeekHack is ushering in the dawn of a keyboard renaissance.
Offline Ngt
Re: [IC] CF60 (CF-LX?) Ultra-light Carbon Fiber 60% Case
« Reply #86 on: Wed, 08 April 2015, 14:03:03 »
Indeed it seems a little more expensive that the prediction. The break after 10 ordered is not that high as I thought it could be. HHKB or this case, damn too many decisions to make when you are on Geekhack. :D
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #87 on: Wed, 08 April 2015, 15:32:54 »
I mean, how much nicer does carbon fiber look than some plain old plastic ;) (plus MX :thumb:)
Offline Ngt
« Reply #88 on: Wed, 08 April 2015, 15:44:58 »
I mean, how much nicer does carbon fiber look than some plain old plastic ;) (plus MX :thumb: )
Geekhack aka "How to spend your lifetime money". It is not the soul that it sucks out but your wallet and bank account. haha
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #89 on: Wed, 08 April 2015, 23:20:47 »
Depending on the interest, I may also be offering a mid piece as an add on that would fit right on the standoffs for an easy switch to a sandwhich design
Offline exitfire401
« Reply #90 on: Wed, 08 April 2015, 23:38:18 »
I'm already probably in for 1 case, so I wouldn't mind plunking down a little more for that too
Offline Den441
« Reply #91 on: Thu, 09 April 2015, 00:42:38 »
Nice, I have been waiting for something like this for awhile. I just love it when new materials start emerging in my hobbies. I saw the same thing happen in the ecig market with carbon fiber mods. One really cool thing I saw come out of that was an ecig made from a red and black carbon fiber. I think it may have been some kind of Carbon fiber/Kevlar hybrid material. That same material could probably be used to make cases as well. Then you could have colors like red/black, blue, yellow/black, etc. Just an idea for the future.
Custom Wrist Rests, Artisan Keycaps, and more - http://battlestation.io
Sales Thread - https://geekhack.org/index.php?topic=74835.0
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #92 on: Thu, 09 April 2015, 06:15:08 »
Yeah, I've seen that stuff and it does look really cool. Unfortunately, all big blue saw offers is regular carbon fiber. A red acrylic mid piece may look interesting though
« Reply #93 on: Thu, 09 April 2015, 10:20:39 »
How many have signed up so far?
I'm back.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #94 on: Thu, 09 April 2015, 11:24:35 »
around 50 have expressed interest. Since the price difference is really negigable past 10 orders, I'm not really worried about numbers
Offline vindaon
« Reply #95 on: Thu, 09 April 2015, 12:54:43 »
Interested in 1, maybe 2. :thumb:
Offline Ngt
« Reply #96 on: Thu, 09 April 2015, 14:55:24 »
You catched my attention here.
Pretty much like a Nerd NS 60 housing, differences being that it is not made of aluminum?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #97 on: Thu, 09 April 2015, 14:56:11 »
Yessir
Offline Ngt
« Reply #98 on: Thu, 09 April 2015, 18:52:48 »
Yessir
OUUUUUUHHHH. Hesitation is growing now haha! Would you have a price tag in mind for such a beauty?
Offline Melanic
« Reply #99 on: Thu, 09 April 2015, 19:47:30 »
Very interested in this project. Any estimate for when it will go live?
