Author Topic: [IC] CF-LX Ultra-light Carbon Fiber 60% Case  (Read 63105 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« on: Wed, 31 December 2014, 11:13:56 »
DrHubblePhD
Interest Form
Specs:
- 1.5mm Carbon Fiber
- Skeleton style case (top/plate, bottom, standoffs in middle)
- Universally compatible plate
More renders:
Joey Quinn
« Last Edit: Fri, 01 May 2015, 17:52:26 by hwood34 »
Offline Ripudio
Re: [IC] CF60 Ultra-light Carbon Fiber 60% Case
« Reply #1 on: Wed, 31 December 2014, 11:31:53 »
I might be interested depending on the details. Can it be made so that switches are removable?
What about making a poker compatible plate out of CF?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #2 on: Wed, 31 December 2014, 11:35:38 »
Yep, one of the options on the IC form is for a notched switchplate. And the top would be compatible with a Poker, though I'm not offering just plates at this time
Offline Ripudio
« Reply #3 on: Wed, 31 December 2014, 11:53:07 »
Woops, didn't see the form. Thanks!
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #4 on: Wed, 31 December 2014, 13:04:34 »
Filled out the form.
Offline ideus
  • Björkö.
« Reply #5 on: Wed, 31 December 2014, 13:17:46 »
It would be clear to call the project "CF60% carbon fiber plates set". These are not "a case".
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #6 on: Wed, 31 December 2014, 13:19:30 »
These are "a case":
This is an interest check for a 60% case made out of carbon fiber, a durable and light material. The case will fit all standard 60% PCBs. It will consist of a top layer, also acting as the switchplate, and a bottom layer. In between the two will be spacers, similar to the JD40 case
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7 on: Wed, 31 December 2014, 14:13:00 »
It is still a case, albeit skeleton style but still a case.  If you haven't looked at manufacturing methods yet I would recommend waterjet, I am not sure if CF can be laser cut.  Even if it can I would venture to guess it gives off toxic fumes similar to acrylic when laser cut.  Also, from other materials I have seen both laser and waterjet cut, I much prefer the edge quality of the waterjet.  However, the roughness on the cut edge of laser cut plates greatly adds to the ability for the switch to grab a hold of the plate.
« Reply #8 on: Wed, 31 December 2014, 14:16:01 »
Carbon fiber burns by laser.  And will the carbon fiber have a core material it's built up around?  If you want to do some prototypes, I may be able to get my cousin to prototype since I know he has access to a waterjet at his work and has offered to do some stuff when he visited in September or October.
Offline heedpantsnow
  • Old enough to know better
« Reply #9 on: Wed, 31 December 2014, 14:20:23 »
I'm in. My full CF case project hit some snags
I'm back.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10 on: Wed, 31 December 2014, 14:26:23 »
Yeah, I found a place that does waterjet machining for the carbon fiber
Hmm, that sounds pretty cool. PM'd
« Reply #11 on: Thu, 29 January 2015, 06:34:23 »
Could you clarify how this is going to be made? Are you making a skeleton style case like the ones JD made and then using waterjet to cut out the switch holes?
So the carbon fiber will be made into two solid plates then cut after it's formed and solidified right? Because as is, cutting a sheet of carbon fiber with waterjet would be monumental overkill.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #12 on: Thu, 29 January 2015, 07:00:56 »
Pretty much yeah. I'm gonna sit down with swill's tool to make a CAD file to get a better price estimate
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #13 on: Tue, 24 February 2015, 21:49:00 »
anyone got the files for a 60% layout plate I could use for this? A full skeleton case would be even better ;)
« Reply #14 on: Wed, 25 February 2015, 00:47:14 »
Swill's plate maker would probably work, if you want something else I could probably make one tomorrow if I finish my research paper early.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #15 on: Wed, 25 February 2015, 22:23:29 »
I've had some issues with it, if it wouldn't be a problem that'd be awesome
« Reply #16 on: Wed, 25 February 2015, 22:39:38 »
Ok, I'll work on it tonight, what layout options do you want?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #17 on: Wed, 25 February 2015, 22:43:01 »
Any way it could be one of the ANSI/ISO multi compatible layouts?
« Reply #18 on: Wed, 25 February 2015, 22:45:20 »
Probably, just to be clear, am I making a JD style case or the bent infinity case?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #19 on: Wed, 25 February 2015, 22:46:24 »
the JD style :thumb:
« Reply #20 on: Wed, 25 February 2015, 22:53:34 »
Any idea what size you want the bezel to be?
« Reply #21 on: Wed, 25 February 2015, 23:02:24 »
92036-0
For reference this is a 1cm bezel, not sure what the JD40 is but I think it's a bit larger.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #22 on: Wed, 25 February 2015, 23:08:55 »
That should work. I'm looking for it to be a pretty small, lighter case
« Reply #23 on: Wed, 25 February 2015, 23:13:46 »
The only thing that restricts the bezel size is the size of the bezel on the pcb, if you make the plate too small the standoffs will hit the pcb.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #24 on: Wed, 25 February 2015, 23:15:31 »
So then what would be the smallest bezel that would work with a standard 60% PCB i.e. Poker II
« Reply #25 on: Wed, 25 February 2015, 23:32:16 »
No clue, I actually just sold mine, this could be answered very easily if someone is willing to make a measurement for me. I need the distance from the center of the mx switch to the edge of the pcb. I need x, someone my know it. If no one knows or measures it I'll just use the dimensions of the GH60 because I already have those files.
92038-0
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #26 on: Thu, 26 February 2015, 08:05:27 »
So the GH60 measurements should be fine
« Reply #27 on: Thu, 26 February 2015, 11:30:26 »
Sounds good.
Offline Ngt
« Reply #28 on: Thu, 26 February 2015, 16:04:17 »
I didn't get what the bezel is. Is it the thickness of the plate?
Offline Ngt
« Reply #29 on: Thu, 26 February 2015, 16:07:03 »
I submitted. I'm definitely interested in this. I'm curious to know what companies you need to contact for that to be real. I mean which manufacturers, providers and so on.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #30 on: Thu, 26 February 2015, 16:34:42 »
I'll be using Big Blue Saw for waterjetting
The width of the plate that extends past the PCB on the sides and top
Offline Ngt
« Reply #31 on: Thu, 26 February 2015, 17:06:24 »
Ok thanks. Do they provide the CF too?
Thanks. I think it could be added to the GH glossary :D.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #32 on: Thu, 26 February 2015, 17:25:06 »
I'm not actually sure. It seems like they do though
Offline Ngt
« Reply #33 on: Thu, 26 February 2015, 17:27:58 »
Thanks. I think it could be added to the GH glossary :D .
Fair enough. How many entries do you have so far in IC?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #34 on: Thu, 26 February 2015, 19:12:17 »
about 45. But that might go up once I get a more definite price and stance on this whole thing. And IC numbers are usually a good deal lower than actual GB orders
Offline cmadrid
« Reply #35 on: Fri, 27 February 2015, 01:07:57 »
Never any TKL cases >_<
Offline Ngt
« Reply #36 on: Fri, 27 February 2015, 08:06:10 »
I guess you needed the IC numbers to contact the manufacturers and tell them at least how many you'll be interested for. Am I right? If yes, when do you plan on contacting them for that more precise price information?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #37 on: Fri, 27 February 2015, 08:07:58 »
Well, once I get the CAD files for the case, they have an auto price estimator on their website. If I get a little more interest, I'll start up the buy. But that all depends on what the actual price ends up being.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #38 on: Fri, 27 February 2015, 08:08:54 »
Depending on when this finishes up, whether it works or not, I'll look into doing a TKL case
Offline Ngt
« Reply #39 on: Fri, 27 February 2015, 08:10:41 »
Fair enough. Have you tried to see how much it would be with just a standard 60% CAD file even though it might not be the final CAD file?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #40 on: Fri, 27 February 2015, 08:12:42 »
Well, since all the files I found lacked plates, I just got an estimate for one of those and added a decent amount to it since all the small adjustments involved in making plates can add up quickly
Offline Ngt
« Reply #41 on: Fri, 27 February 2015, 08:15:29 »
I think I might not be sure that I understood what a CAD file is. Isn't the file that describe the structure of the plate?
Oh that's where the $50-80 price range comes from?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #42 on: Fri, 27 February 2015, 13:09:13 »
Yep
Offline Ngt
« Reply #43 on: Sat, 28 February 2015, 05:15:34 »
Yep
So if the CAD is the file that describes the plate, how could you find such files lacking the plate?
« Reply #44 on: Sat, 28 February 2015, 07:16:02 »
Could you post a list of those interested?  I can't remember if I already signed up.
I'm back.
Offline Ngt
« Reply #45 on: Sat, 28 February 2015, 07:35:26 »
He could just tell you if you are in the list rather than naming everybody. :)
« Reply #46 on: Sat, 28 February 2015, 07:37:16 »
Or that
I'm back.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #47 on: Sat, 28 February 2015, 07:53:14 »
Or that
I actually forgot to include a username field in the form
Offline ideus
  • Björkö.
« Reply #48 on: Sat, 28 February 2015, 12:04:38 »
Just filled the form. Will the plate fit both, the Poker X and the Infinity keyboard? I require both.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #49 on: Sat, 28 February 2015, 12:11:07 »
Poker, yes. Infinity, doubt it, has the different layout problem
