Author Topic: [GB] "Hack'd by Geeks" Keyset - Full Contour SA (Shipping Corrections)  (Read 486201 times)
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: [GB] "Hack'd by Geeks" Keyset - Full Contour SA (Production)
« Reply #800 on: Fri, 24 April 2015, 17:54:08 »
I just received my set. Looks great! However, it seems as if the right shift key's stem has an issue. The shift key is slightly tilted in the plane of the keyboard, about -2 degrees tilt. Small but enough for me to notice. Possibly a manufacturing defect?
hey sir
sorry to hear that, if you could please take some pics of the issue and pm them to me, i dont have a set o nhand yet but ill get cody to compare it for me to what he has, if its a single key fault ill get it replaced for you, if its a more widespread issue ill speak to sp and see what can be done
It's no problem. I'll send a pic when I can. Hopefully if anyone else notices this issue they can make a note here too.
just occured to me to mention that the shifts are r3 and the rest of the keys on that row are r4, im assuming you know that and it isnt the issue, but just throwing it out there as something so you can check it against the other shift
The profile is fine. This is what I mean:
And here's the whole ANSI set on my Novatouch:
thats so odd, it looks like its lifting off the stab
is the fit snug?
and does the underside look uniform
Offline KHAANNN
« Reply #801 on: Fri, 24 April 2015, 17:58:59 »
If it's costar, and since it looks like a Varmilo it probably is, I would guess it's a mis-inserted stab-insert, one stab-insert inserted the other way around, but it's probably something else, and mine is just a basic guess
Offline Heliosphere
« Reply #802 on: Fri, 24 April 2015, 18:26:21 »
I had a suspicion that it could be due to SP's SA molds causing the misaligned stem, so I grabbed the long shift from my other SA sets (Pulse and Calm Depths) and compared them on my Novatouch and Royal Kludge. It seems my suspicions may be correct. See for yourself:
Left column is Novatouch, Middle Column is Royal Kludge, Top Right is Royal Kludge with stock shift keycap.
Unfortunately I don't have any other MX-compatible keyboards to do more comparisons. Anyone else with multiple SA keysets can test out and compare the long shift keys to see if it's not just me and my keyboards.
Offline KHAANNN
« Reply #803 on: Fri, 24 April 2015, 18:30:36 »
That's such an extremity, I've noticed that people just don't pay much attention to keycap alignments / mis-aligned switches/keycaps etc. But obviously the pictures you posted are extreme and very hard not to notice
Very curious what the result is going to be
Offline asdfjkl36
  • blue shirt guy
« Reply #804 on: Fri, 24 April 2015, 18:33:05 »
So strange
Interesting find.
Offline Heliosphere
« Reply #805 on: Fri, 24 April 2015, 18:37:16 »
It's only quite noticeable if one looks closely at near top-down angle. I only noticed it because I happened to put just the Enter and Shift key on first.
In any case it's a minor quirk and it doesn't detract from the SA sets as a whole.
Offline BunnyLake
  • X
« Reply #806 on: Fri, 24 April 2015, 18:53:45 »
i only have penumbra on hand so just checked mine and it was fine
very odd
ill certainly forward this to them
Offline BunnyLake
  • X
« Reply #807 on: Fri, 24 April 2015, 18:55:16 »
also i know this ounds odd
but have you got any non topre mx stem boards to try it on, maybe its a quirk of those boards rather than the set, cause i cant replicate it here
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #808 on: Fri, 24 April 2015, 18:56:08 »
Could be an SP manufactured defect  :o .  Usually when they pop the key out without waiting for the ABS to fully solidify and remain structurally stable.  Maybe due to the vast orders they started ramping up ejection times from the molds so they could finish the job quicker.  Seen this type of defect before at a factory in Sydney when they made up for lost time by just throwing out the pieces quickly into a collection bin and before you knew it hundreds of pieces had been deformed in some way.
Get Melissa to speak with the Q/A supervisor to rectify it, by re-making the keys again with stable curing times for each piece.
« Last Edit: Fri, 24 April 2015, 18:59:04 by Elrick »
Offline Heliosphere
« Reply #809 on: Fri, 24 April 2015, 18:58:55 »
Yeah that's the thing. I don't have any MX boards on me. I'm hoping someone else who receives their Hack'd set can verify.
What Elrick said is a possibility. The right shift key is very long so maybe there's a problem with the manufacturing process.
Offline KHAANNN
« Reply #810 on: Fri, 24 April 2015, 19:07:31 »
I also have the same impression, happens with 3d-printing a lot too, whatever the plastic type is, if you rush to remove the piece, it definitely gets warped if it's not entirely cold
Yet, they have been molding keys for quite some time, they obviously experienced these issues at extreme levels with the Dolch spacebars etc. so it's extremely illogical for them to re-make the mistake, since they mold plastic for years, one would expect the end result to be perfected 10's of years ago
« Last Edit: Fri, 24 April 2015, 19:17:31 by KHAANNN »
Offline BunnyLake
  • X
« Reply #811 on: Fri, 24 April 2015, 19:15:01 »
found a pic i had of calm from ages ago, which also doesnt seem to have the issue
i also found a few crap bag keys and none have the same issue
Offline Heliosphere
« Reply #812 on: Fri, 24 April 2015, 19:37:59 »
It's entirely possible my keyboards are the issue. I'm also thinking it might be possible that one of SP's molds have the misalignment such that only certain batches of SA sets have this problem, and I just happened to have sets all made from that mold. Whether other people have this issue with their sets will determine if it's just me or SP.
Offline BunnyLake
  • X
« Reply #813 on: Fri, 24 April 2015, 19:43:56 »
once again, sorry about that, it does seem mighty strange all round, i guess we will find out shortly as these start rolling in
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #814 on: Fri, 24 April 2015, 20:48:02 »
Probably just some gnomes that come into your house at night and mess stuff up for the sheer fun of it  :p
Offline Heliosphere
« Reply #815 on: Fri, 24 April 2015, 20:57:30 »
Damn gnomes messing with my keyboard stuff. Is nothing sacred?
Offline Sed8op8
  • Keyboard Padawan
« Reply #816 on: Fri, 24 April 2015, 21:18:02 »
Damn they always hide my undies and socks.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #817 on: Fri, 24 April 2015, 21:25:19 »
1. Collect underpants
2. ???
3. Profit
Offline Data
« Reply #818 on: Fri, 24 April 2015, 21:46:44 »
I don't know if this is helpful or not, but I checked my Varmilo TKL with Pulse installed and it does show a slight angle on the right Shift but not nearly as extreme as in your photo.  Could be a combination of SP's manufacturing tolerance AND something in your board(s) conspiring to mess up that key.
Offline ghostjuggernaut
« Reply #819 on: Fri, 24 April 2015, 21:49:49 »
Have you checked any other keys in that position? Not that they will fit perfectly, but you could see if the others are offset as well. That way you know if it is the key or the stem on the board.
Offline tom.smykowski
« Reply #820 on: Fri, 24 April 2015, 22:27:43 »
BunnyLake - I purchased one of the extra sets you had. I'm all paid up. Am I also part of this batch shipping? Super excited
sorry guys, havent been around all day and im a bit backed up on pms
about 70% of this has shipped, and has already been dropped to the post office
the remainder of the orders made on the site are being packed and shipped now and should all be completed tonight, and pm orders will follow shortly after
the above post should answer the question adequately enough, however cody didnt get to finish the other 30% last night in the end
so as with the posts i made a few above, thatll either happen tonight or this weekend
Thanks Bunnylake!
Offline luckynet
« Reply #821 on: Fri, 24 April 2015, 23:10:10 »
still possible to order??
Realforce 104U - HHKB Pro 2 dental band - HHKB Pro 2 Hasu's bluetooth controller - CM novatouch silent mod - Royal Kludge Topre clones
Filco Magestouch 2 Brown - Duckyshine 9008s Brown - QFR white - Plum MX 96 Blue - KBT Race Red - SS 7G Black - Poker blue - ducky shine 69
IBM Model M SSK
Matias quiet pro - V60 matias clicky
Offline Heliosphere
« Reply #822 on: Fri, 24 April 2015, 23:44:50 »
That's a good idea, not sure why I didn't think of that. I just tested out the left shift and enter on the right shift position and they seemed fine. I then tried putting the right shift keycap on the spacebar position, and the skew is still apparent. So this confirms that it's the shift keycap's stem that's the issue, not the keyboard.
« Reply #823 on: Sat, 25 April 2015, 01:21:17 »
Interesting. So the stem itself is rotated, not the stabs. I doubt the mold is the problem, but it is strange that you have 2 nearly identical misprints. Maybe the cooling/setting process is the culprit of random deformation...
Offline zah
« Reply #824 on: Sat, 25 April 2015, 09:54:30 »
dont think its just him. also noticed the right shift while i was putting keys on but didn't think much of it
edit: mine was also on a novatouch
however, I am missing a row 1 "1" key and have an extra row 1 "0" key
otherwise, set looks great  :thumb:
« Last Edit: Sat, 25 April 2015, 10:07:46 by zah »
Offline BunnyLake
  • X
« Reply #825 on: Sat, 25 April 2015, 10:01:18 »
thanks very much sir, ill get that replacement key sorted for you, and forward this shift info on to sp and see if they will replace them for us
sp are normally good at rectifying issues for us, although with the guy who found it first, he seemed to have the issue with every SA set some maybe its just a mould issue, either way ill get on to them and see what they can do
« Last Edit: Sat, 25 April 2015, 10:12:56 by BunnyLake »
Offline SL89
« Reply #826 on: Sat, 25 April 2015, 10:12:38 »
did all the shipping notifications go out for PM sales?
Offline BunnyLake
  • X
« Reply #827 on: Sat, 25 April 2015, 10:14:32 »
no
as with the update above
30% left to go out
cody says he is going to the office tonight to finish it off
if the handful of people with an order via pm can confirm there shipping details via pm to me, that would help me out
Offline SL89
« Reply #828 on: Sat, 25 April 2015, 10:25:32 »
no rush, sorry for asking again, im on mobile and totally missed the update  :-[
Offline BunnyLake
  • X
« Reply #829 on: Sat, 25 April 2015, 10:42:25 »
totally understandable sir, i get equally excitable about this stuff, trust me when i say i bother cody about my stuff as well
Offline neverused
« Reply #830 on: Sat, 25 April 2015, 13:47:27 »
Just got a notification that my at has arrived... 45 minutes away at my office.
Looks like I won't be seeing these beauties until Monday.
Offline KHAANNN
« Reply #831 on: Sat, 25 April 2015, 14:44:27 »
Arrived at the shipito warehouse, saw the package, won't be able to see them for probably weeks :)
Honestly, it's a bit selfish but, I'm glad I will be using a 1.75 key instead of the 2.75 shift, I wouldn't be able to handle the crooked keycap
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #832 on: Sat, 25 April 2015, 15:47:13 »
Just got my caps today! Loving them! Didn't get to put them on my board yet though. Slight issues with the numpad 3 key and the left shift. Otherwise though all caps are here.
Offline BunnyLake
  • X
« Reply #833 on: Sat, 25 April 2015, 15:55:10 »
seems like sp didnt do enough qc this time, pm me the issues ill get em sorted
Offline techmattr
« Reply #834 on: Sat, 25 April 2015, 16:21:24 »
I just checked Calm Depths, PuLSE, Nuclear Data and Hack'd by Geeks and all of mine have a titled right shift. It's extremely bad on the Novatouch but barely noticeable on Cherry stabs. I'm also missing a .> key and have an extra ,< key. Anyone have an extra .> and missing a ,<? I also possibly have two extra arrow keys? A down and a right.
« Reply #835 on: Sat, 25 April 2015, 16:36:18 »
The arrows are good but you have them both upside-down - one's a backspace and the other is a different row up arrow as it's more comfortable (try it and you'll agree :) )
p.s that USB cable is perfect - where's it from?!
« Last Edit: Sat, 25 April 2015, 16:38:21 by suicidal_orange »
Offline KHAANNN
« Reply #836 on: Sat, 25 April 2015, 16:54:24 »
Connecting the dots, he makes the cables himself
I'm going to receive the set in 2-3 weeks, it will go through relatively a painful import process, these issues really demotivate me, If I have a missing key, it would probably delay my setup ~2 weeks more
Offline BunnyLake
  • X
« Reply #837 on: Sat, 25 April 2015, 17:07:26 »
sorry about that, sp sort the sets, ill get that key replaced for you
ps, that top pic looks sensational
« Last Edit: Sat, 25 April 2015, 17:11:21 by BunnyLake »
Offline techmattr
« Reply #838 on: Sat, 25 April 2015, 17:19:42 »
Hah! Totally forgot about the 1u backspace. Threw me off since it's the same row as the arrow. Thanks!
Yeah I made the cable. I have three colors I planned on using for Hack'd:
Thanks! Should I send the extra ,< to Cody?
Offline BunnyLake
  • X
« Reply #839 on: Sat, 25 April 2015, 17:22:31 »
nah all good sir dont worry about, but if anyone is missing some arrows i may drop you a line
Offline atectatifern
« Reply #840 on: Sat, 25 April 2015, 17:25:43 »
Got mine today -- they look awesome on the Novatouch! Thanks, BunnyLake and Cody!
Offline BunnyLake
  • X
« Reply #841 on: Sat, 25 April 2015, 17:28:45 »
great to hear sir
hope you enjoy
Offline deci
« Reply #842 on: Sat, 25 April 2015, 19:13:02 »
Got mine as well.
The colors and font couldn't look better!  :thumb:
Thanks for a great \set Bunny!
*I can confirm having the same issues as everyone else on the right long shift key being crooked on Novatouch.
Offline BunnyLake
  • X
« Reply #843 on: Sat, 25 April 2015, 19:24:34 »
Got mine as well.
great to hear sir, glad you like it
its a real shame about this crooked shift issue, ill be compiling some pics and stuff this weekend and emailing sp on monday to see what if anything can be done about it
Offline BunnyLake
  • X
« Reply #844 on: Sat, 25 April 2015, 19:27:17 »
thanks to everyone who pm'd me their pm order details
cody is leaving to get to the office now, to conclude the site orders and work through the pm orders
    • WTB/WTTF Thread
« Reply #845 on: Sat, 25 April 2015, 19:33:06 »
On another note are the F and J keys meant to be deep dish? Mine are not but I can't remember if they are supposed to be.
« Reply #846 on: Sat, 25 April 2015, 19:36:03 »
The mockup on CTRLALT would lead me to believe they are supposed to be deep dish. Can anyone confirm? Is there a chance that it is very sleight?
Offline BunnyLake
  • X
« Reply #847 on: Sat, 25 April 2015, 19:36:38 »
and we confirmed it with sp, so if they arent, sp will replace those for us free of charge
Offline KHAANNN
« Reply #848 on: Sat, 25 April 2015, 19:38:11 »
I'm glad this F/J issue occurred, if it's indeed the case, hate deep dishes, didn't pay attention in the first place :)
Offline BunnyLake
  • X
« Reply #849 on: Sat, 25 April 2015, 19:39:28 »
they did this to us once before on penumbra as well
glad it worked otu for you but many people need them
so ill get sp to knock em out right away
