Author Topic: HHKB Pro 2 Landing Pad Mod  (Read 3538 times)
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« on: Thu, 09 July 2015, 22:33:30 »
Hey guys,
So I have the soft landing pads from EH coming in the mail sometime next week, and I'm really anxious about doing the landing pad mod. Not anxious in the excited way, but in the "what if I mess up?" kinda way.
From anybody who's had the experience or knowhow, what are the things that I should be looking out for that could go wrong when I do the mod?
One of the things I read about is that it's really easy to unseat the rubber dome and spring combo when you take apart the plate and the PCB. How easy is it to reseat the dome and spring back properly?
There's also the issue of taking out the sliders. Some guides I've seen suggested cutting the little tail at the top that sticks out and prevents it from coming out of the hole, while some other guides suggest popping the slider out from the bottom using a screwdriver and skipping the tail entirely. Are any of the two ways bad for the keyboard?
Lastly, there's also the issue of the modifiers. Being larger, their sliders are harder to take out. How likely is it that I'll end up breaking one of these?
Apologies for being such a worrywart. I love my HHKB Pro 2 to death and I don't want to accidentally destroy it from the inside when I'm doing this silencing mod.
So for convenience, my questions were:
1. How easy is it to properly reseat an unseated rubber dome?
2. Screwdriver or cut the tail thing?
3. How hard is it to break the modifier sliders?
4. Any additional helpful tips for anyone who's done the mod? :D
Thanks for all the help guys!  ;D
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline derb2k2
  • Something of a Topre ****..
Re: HHKB Pro 2 Landing Pad Mod
« Reply #1 on: Fri, 10 July 2015, 07:58:27 »
Will detail my experience when i get to a keyboard. :)
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #2 on: Fri, 10 July 2015, 08:07:38 »
I just popped out the sliders via screwdriver.. I have never heard of the other way :o.
And the modifier sliders are not easy to break, just lift up the wires and they drop out for the most part.
I did a whole dome transplant and it was generally pretty easy. just put the dome on the back of the sliders and put the pcb on top of the sliders, and it'll be all fine.
  • Formerly temence
« Reply #3 on: Fri, 10 July 2015, 11:25:13 »
  • Formerly temence
« Reply #4 on: Sun, 12 July 2015, 02:57:52 »
Thanks for the tips! I'm quite excited to do the mod now, so it's just a waiting game for the landing pads to arrive. Got a few tips from derb2k2 as well.
Last question, is there a guide (like a circle) on the PCB to let you know where the dome should go? Just incase? I can't seem to tell from the photos in the guides, since the domes are all resting on the PCB.
Offline Air tree
« Reply #5 on: Sun, 12 July 2015, 12:32:39 »
There are little circles on the PCB, IRRC.
But like I said, just lay the domes down on the bottom of the sliders and place the PCB ontop and then close the case up.
  • Formerly temence
« Reply #6 on: Sun, 12 July 2015, 12:41:36 »
Cool thanks for the info! :D
Offline Gaspar
« Reply #7 on: Sun, 12 July 2015, 13:06:59 »
Here's a few links, you probably know those threads but just in case.
https://geekhack.org/index.php?topic=49046.0
https://geekhack.org/index.php?topic=40582.0
Offline awhitedev
« Reply #8 on: Sun, 12 July 2015, 15:16:48 »
I have these same reservations as I'll be doing this mod to my novatouch next weekend. Interested to hear what you guys have to say.
  • Formerly temence
« Reply #9 on: Sun, 12 July 2015, 16:05:38 »
My pads should arrive early this week so I'll let you know how my mod goes.
