Author Topic: Which one is better?  (Read 5840 times)
Offline Kenefick
« on: Wed, 22 July 2015, 14:43:17 »
I've got a question for all of you mechanical keyboards geeks out there...
Since I'm pretty new to it.
I'm considering of getting one of the two following keyboards, and i wanted to ask which one would YOU guys suggest and why.
Option one: Steelseries 6Gv2 Mechanical keyboard black switches
Option two: Ducky Channel Zero DK2108SZ Gaming Red Switch
Thank you guys for help!
Offline trees
  • I like bagels.
Re: Which one is better?
« Reply #1 on: Wed, 22 July 2015, 14:46:25 »
Ducky Zero. Better more solid built, and has standard keys so you can replace the caps.
B.Face HHKB - B.mini - Black/Purple Custom
« Reply #2 on: Wed, 22 July 2015, 14:46:53 »
Ducky.  No question.  It's not the absolute best, but still better than a Steelseries board by a long shot.
Offline Kenefick
« Reply #3 on: Wed, 22 July 2015, 14:49:42 »
Steelseries keys aren't standard?
Because in-case i'm getting the steelseries my plan was then to just get alphanumerical keys with the letter of my language aswell and replace it.
« Reply #4 on: Wed, 22 July 2015, 14:50:58 »
Look at the bigass enter on the steelseries.  The Ducky is still better.
Offline trees
  • I like bagels.
« Reply #5 on: Wed, 22 July 2015, 14:51:17 »
They are not, look at the enter key, it has what is called a 'big ass enter' which is very non-standard.
I would go for the ducky.
Offline Kenefick
« Reply #6 on: Wed, 22 July 2015, 14:57:05 »
Enter key isn't alphanumerical so it doesn't really matter. But I get your point, having a keyboard that you can't change every single button on it is dumb,
better to have full control of the keyboard.
« Reply #7 on: Wed, 22 July 2015, 14:59:14 »
If you want to swap keycaps, you won't find any aftermarket sets with that enter key.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Wed, 22 July 2015, 15:08:45 »
« Last Edit: Wed, 12 August 2015, 08:10:47 by esoomenona »
Offline Kenefick
« Reply #9 on: Wed, 22 July 2015, 15:09:38 »
That enter key is the only issue?
« Reply #10 on: Wed, 22 July 2015, 15:10:10 »
HHKB
Offline esoomenona
  • Gnillort?
« Reply #11 on: Wed, 22 July 2015, 15:11:21 »
« Last Edit: Wed, 12 August 2015, 08:09:55 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #12 on: Wed, 22 July 2015, 15:11:40 »
« Last Edit: Wed, 12 August 2015, 08:09:43 by esoomenona »
« Reply #13 on: Wed, 22 July 2015, 15:13:13 »
HHKB
Also, this. Just skip all the keyboards mistakes.
Similar to children. Keyboard mistakes cost you money.
« Last Edit: Wed, 22 July 2015, 19:11:57 by demik »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14 on: Wed, 22 July 2015, 16:06:14 »
« Reply #15 on: Wed, 22 July 2015, 16:34:08 »
HHKB
Similar to children. Keyboard mistakes cause you money.
If they cause you money it sounds like I need to make more.
And HHKB is love.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #16 on: Wed, 22 July 2015, 16:40:31 »
HHKB
And HHKB is love.
Spread that seed.
Offline Kenefick
« Reply #17 on: Wed, 22 July 2015, 19:08:00 »
Also, even if you don't think it's a big deal and wouldn't want to change every cap, it matters to other people, and if you ever find yourself in a situation where you'd like to let that keyboard go for another, or whatever reason, you'll have an easier time with the Ducky than with the Steelseries, for all the reasons people have given you in this thread.
With that being said, if you find the above situation a possibility, then you may want to consider another option than the Ducky, because even those aren't easy to get off your hands at times. A Filco may be a better option, albeit without any backlighting.
Or, if none of this is a concern, get whatever you like the most, since that's all that really matters.
The Enter key, the right shift key, and the \| key next to the right shift key, from what I can see.
So if we ignore the key replacement issue, I mean which keyboard is better for using,
more comfortable, feels good to use and such.
« Reply #18 on: Wed, 22 July 2015, 19:12:11 »
HHKB
And HHKB is love.
I'm retarded
« Reply #19 on: Wed, 22 July 2015, 19:17:34 »
Again OP, the Ducky.  I've seen so many complaints about the Steelseries.  It sounds like you may have already sold yourself on one though.
HHKB
And HHKB is love.
I'm retarded
The first step is admitting it.
« Reply #20 on: Wed, 22 July 2015, 19:24:56 »
Well OP, your first mistake is picking linear switches. If you're going linear why waste your money? Just pick up a ****ty dell keyboard as you'll get the same feeling for less money.
Problem número dos, that horrible big ass enter and small ass right shift. That's some commie lay out. Why? Pick up the ducky sucky and turn off the annoyed backlighting.
Problem number 3, full size. It's 2015, nobody uses the number pad. And those that do are wrong.
Offline Kenefick
« Reply #21 on: Wed, 22 July 2015, 20:25:38 »
I use the numpad all the time, the numbers above are simply not comfortable.
Offline jukaduke1184
« Reply #22 on: Wed, 22 July 2015, 21:16:28 »
Ducky Zero.
Offline Polymer
« Reply #23 on: Wed, 22 July 2015, 22:31:06 »
You probably don't...you use it when you shouldn't...so for example, when you're typing out 2015 are you taking your right hand off the keyboard and moving it to the numberpad?
The only people that need a numberpad are ones that are doing heavy spreadsheet/number crunching stuff....
But for everyone else, TKL is just a superior format and provides a better mouse position...
The reason you dislike that idea is because you aren't used to it...but you'll eventually get there..you just don't realize it yet..
Offline False_Dmitry_II
« Reply #24 on: Thu, 23 July 2015, 00:39:03 »
Unless you get some kind of RSI, which seriously isn't everyone - probably not even most, I don't think that matters at all. At most all you are doing is removing a very small amount of cardio by no longer moving the right hand to the numpad. So what?
« Reply #25 on: Thu, 23 July 2015, 00:40:52 »
If you do get a TKL keyboard and find that you need a number pad, you can always get a separate numpad.
Offline Kenefick
« Reply #26 on: Thu, 23 July 2015, 04:36:25 »
I'm playing FPS games, and the numpad is something that you can't play without, everything is binded to the numpad lol.
« Reply #27 on: Thu, 23 July 2015, 05:08:21 »
I've never used a numpad when playing FPS.
Offline jerue
  • (Whenever that happens :P)
« Reply #28 on: Thu, 23 July 2015, 07:31:11 »
The Ducky Zero is the better board of the two. But it uses red switches, if you're light handed you may like the significantly lighter feel compared to MX Blacks. If you're heavy handed, I'd recommend the blacks over the reds.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #29 on: Thu, 23 July 2015, 08:19:59 »
Neither have I Oo. UT 99 control layout, always.
