Author Topic: [IC] Colors - Cherry Profile  (Read 55837 times)
Offline Suembeaux
Re: [IC] Colors - Cherry Profile
« Reply #200 on: Tue, 26 April 2016, 01:56:29 »
Is there any chance of any price drops past the 100 MOQ? I was under the impression that it was going to be a modifier set, and not a full set. I love the colors, and Varmilo's profile, but the price is a bit steep.
A bunch of stuff. Someone teach me how to properly solder.
/u/Shartastical
Offline thesiscamper
    • Keyrenders
« Reply #201 on: Tue, 26 April 2016, 02:40:11 »
Hi, I'm not really sure but I don't expect it. Like I said in the discussion page, this is a proof of concept with a new vendor so options and support for other layouts might depend on how this drop goes. I decided against doing just the mods, since we can't provide other colors anyway.  I imagine if we did that, the complaints will be "how am I supposed to use this I don't have a low profile set".
Sent from my MI NOTE Pro using Tapatalk
"haters are confused admirers"
Offline Suembeaux
« Reply #202 on: Tue, 26 April 2016, 23:07:50 »
Yeah, I can see those complaints as well. I will have to consider it more, I hope it hits MOQ. One last question, Varmilo's dye-sub font does not look anything like the renders, are they going to use the font they have used in the past, or are they developing a more GMK style font for these?
Varmilo font:
/u/Shartastical
    • Keyrenders
« Reply #203 on: Wed, 27 April 2016, 07:40:16 »
I chose Helvetica for this set, so it's going to use a different font from the one Varmilo uses.
