Author Topic: [IC] Colors - Cherry Profile  (Read 55834 times)
Offline thesiscamper
    • Keyrenders
Re: [IC] Dark Alphas + Color Mods - Cherry Profile
« Reply #100 on: Mon, 02 November 2015, 16:20:04 »
I'm not very familiar with alternate keyboard layouts
A Tsangan kit and a 1.75 Row 3 Control key should suffice.
I'd like to know if people with standard layouts are fine with subsidizing these alternate layouts, is it widespread enough to consider adding to the kits?
They are usually sold as separate kits, for what I've seen.
I see, will add those to the mockup as a separate kit.
Thanks a lot for the suggestions by the way, really helps a lot
I should probably consider windowed caps too... just a thought.
« Last Edit: Mon, 02 November 2015, 16:25:17 by thesiscamper »
"haters are confused admirers"
Offline TalkingTree
    • My projects
« Reply #101 on: Mon, 02 November 2015, 16:26:10 »
You should, you really should. Your renders are so realistic that keycaps feel real. I bet it's time consuming to draw those mockups but that's how you get people attention.
Offline TalkingTree
    • My projects
« Reply #102 on: Mon, 02 November 2015, 16:27:38 »
I would buy them. Especially if you can get them doubleshot or dye sublimated.
Offline ideus
  • Björkö.
« Reply #103 on: Mon, 02 November 2015, 16:28:05 »
It is a shame this would not be GMK made, but I hope that your GB be fully successful.
    • Keyrenders
« Reply #104 on: Mon, 02 November 2015, 17:04:35 »
I'll still be asking for quotes and MOQ from GMK if possible.
Offline ideus
  • Björkö.
« Reply #105 on: Mon, 02 November 2015, 17:22:48 »
Aw, well, thank you for trying, there is still hope then.
Offline FrostyToast
  • Litshoard
« Reply #106 on: Mon, 02 November 2015, 17:25:37 »
Tsangan, ISO, stepped caps, short right shift, and maybe some others I have missed, are usually included in the default kit when MOQ is an issue.
If MOQ is not an issue, such as with SP group buys, then those kits are separate add-ons.
Looking forward to what you can do!  :thumb:
Quote from: elton5354
    • Keyrenders
« Reply #107 on: Tue, 03 November 2015, 07:20:01 »
Updated the legends, I hope it's close enough as I only have copy for a 60% layout and used Helvetica Rounded for the others.
edit:
added a closeup of the mockup
« Last Edit: Tue, 03 November 2015, 07:22:59 by thesiscamper »
Offline TalkingTree
    • My projects
« Reply #108 on: Tue, 03 November 2015, 07:59:19 »
Updated the legends
Nice, though a few things.
Your numpad is upside down.
Really no need for F5-F8 in the alphas since they are being included in the mod kit.
Pipe-Backslash should have a colored alternative (in the mod kit).
Numpad Enter usually has just text and it has no Return symbol.
Numpad plus is still center aligned. It should aligned to the left.
This is a 2D render so I assume "Sys Rq" and "Break" are gonna be printed to the side of their respective keys (PrtSc and Pause)
Pg Up and Pg Dn, shouldn't have a space, i.e. they should read "PgUp" and "PgDn".
The Winkey symbol should be also left aligned.
Some people prefer having Ctrl as legend instead of Control. You might wanna include both.
If you're going for international kits, you might want to change the numpad legends to symbols to reduce the number of total keycaps.
Maybe include a RC Control keycap?
Purple mod kit might look better with white legends.
That's it for now. Keep up the good work.
« Reply #109 on: Tue, 03 November 2015, 08:21:59 »
I'd love a stepped Caps Lock if possible.
Offline ideus
  • Björkö.
« Reply #110 on: Tue, 03 November 2015, 08:59:45 »
Is there another type of caps lock?
My board is build to get stepped caps lock, only. I cannot use centered stem ones.
    • Keyrenders
« Reply #111 on: Tue, 03 November 2015, 13:28:21 »
Updated the legends
Oh wow, I've only been using a TKL for a couple of months and I already forgot what a numpad looks like.  :))
You have a point about the F5-F8 keys, some people might like them but I think I'll just remove those.
About the "Page" keys and Win key and your other comments, I just based them off Hyperfuse's mockup here, I'll try to Google actual keyboard pics: https://geekhack.org/index.php?topic=68198.1750
What's an RC Control cap? Oh, and I'm not going to change legend colors, sorry... and there are already color mods that usually come with white legends.
Thank you for your help!
Offline pyrolovesmoney
« Reply #112 on: Tue, 03 November 2015, 13:30:08 »
I would be super interested in that red and grey. is there any chance that these would get made for lovers of backlighting??
    • Keyrenders
« Reply #113 on: Tue, 03 November 2015, 13:54:19 »
I guess if Vortex makes them, yeah there's a possibility, not sure about the others like GMK.
Should the Tilde key have a colored alternative too?
« Last Edit: Tue, 03 November 2015, 14:01:40 by thesiscamper »
« Reply #114 on: Tue, 03 November 2015, 17:46:44 »
Eww... Who puts tildes and backslash as mod colors? Gross.
    • Keyrenders
« Reply #115 on: Tue, 03 November 2015, 17:48:01 »
Wouldn't it be weird to have a colored pipe key but not a colored tilde key?
Offline TalkingTree
    • My projects
« Reply #116 on: Tue, 03 November 2015, 17:51:09 »
An alternative keycap to Caps Lock, which is Row C (RC) or Row 3 in other standards, with the legend "Control". This example explains it better. Look at R3, you see Caps Lock and Control as alternative keycap.
That's fine, that was just and idea.
Yeah, I think so, for fullsize or TKL keyboards' simmetry.
I don't know yet if you're planning international kits, but bear in mind that the Tilde is strictly ANSI, other layouts have a different key in that place.
    • Keyrenders
« Reply #117 on: Tue, 03 November 2015, 17:52:27 »
I see... I'll consider those points. Thanks :)
« Reply #118 on: Tue, 03 November 2015, 18:02:13 »
It's weird to have them both colored!
But, alas, some people like them and so they're usually default in custom sets.
Offline ideus
  • Björkö.
« Reply #119 on: Tue, 03 November 2015, 20:28:26 »
Nor back slash neither tilde are modifiers, there is no reason to have them in both colors, having them duplicated just increased the overall cost of the set for everyone joining in.
    • Keyrenders
« Reply #120 on: Fri, 01 January 2016, 23:35:03 »
Will people prefer colored caps, or colored legends on dark modifier?
edit: Might as well add this:
« Last Edit: Fri, 01 January 2016, 23:53:04 by thesiscamper »
« Reply #121 on: Fri, 01 January 2016, 23:38:40 »
Colored legends on dark mods!
Offline slickmamba
« Reply #122 on: Fri, 01 January 2016, 23:44:30 »
like others have said, some of these alphas are already made, your best bet is probably to make some mods like we've been seeing recently
Hi :)
    • Keyrenders
« Reply #123 on: Fri, 01 January 2016, 23:47:17 »
Yes I understand, it's easier for me to render the whole thing with the alphas (I'm lazy these days). Like what has been suggested this might become a mod pack, but nothing is finalized. There really is no theme here, just a simple base set with interchangeable mods. :)
Offline mrboovn
« Reply #124 on: Sat, 02 January 2016, 00:08:18 »
Those blue and red legends on black  :thumb:
Offline Pwner
  • soon™
« Reply #125 on: Sat, 02 January 2016, 02:47:37 »
Ughhh.. I want that as a full set!
Offline ideus
  • Björkö.
Re: [IC] Colors - Cherry Profile
« Reply #126 on: Sat, 02 January 2016, 10:38:49 »
@thesiscamper, the first of your renders look really good with cyan on dark gray, it looks a little bit like the modifiers on HF.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #127 on: Sat, 02 January 2016, 11:38:12 »
I would definitely prefer the coloured mods, as the coloured font on dark keys is a bit too much like other sets to my liking.
    • Keyrenders
« Reply #128 on: Sat, 02 January 2016, 17:13:24 »
Maybe colors that (I think) haven't been done, like red, purple(?), yellow, etc.
    • Keyrenders
« Reply #129 on: Sat, 02 January 2016, 22:08:12 »
Original idea, dark alphas and color mods. Arranged by poll results in descending order:
Offline TalkingTree
    • My projects
« Reply #130 on: Sun, 03 January 2016, 03:59:58 »
In my opinion, contrast is too high.
Although "carbon" alphas would match great with the black mods with colored legends. Give it a go.
Also, on a side note, legends for the app and win keys should be left aligned as well.
    • Keyrenders
« Reply #131 on: Sun, 03 January 2016, 04:38:27 »
Thanks, but legend alignments are confusing, most Cherry profile sets I see online have the win and app key centered.
Offline xondat
  • i'm not a star
« Reply #132 on: Sun, 03 January 2016, 10:01:41 »
These look amazing, down for pink/orange/yellow. Think I prefer the colored legends a tad more due to how bright the renders make the colored modifiers look.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #133 on: Sun, 03 January 2016, 10:08:27 »
The yellow/grey is actually pretty nice
Offline KoalaKaiser
  • I make onions cry.
« Reply #134 on: Sun, 03 January 2016, 10:19:37 »
I'm all about this! If there was a darker colored blue I'd be on that so fast. Regardless definitely interested in one or two of these sets.
Offline katushkin
  • Just the guy
« Reply #135 on: Sun, 03 January 2016, 10:47:19 »
I reeeeally like the green, orange and yellow...
You should definitely do the alphas and the mods as separate kits. That way some of us can buy one or two sets of alphas and like a million mods
    • Keyrenders
« Reply #136 on: Sun, 03 January 2016, 18:32:06 »
Offline Steezus
  • Keeper of Facts
« Reply #137 on: Sun, 03 January 2016, 18:36:01 »
Started a Massdrop poll, I hope I did it correctly.  :))
https://www.massdrop.com/vote/-Community-Which-modifier-colors-are-you-most-interested-in
I wonder how long it'll be before another user adds a Corsair board or an unobtainable set into the voting mix, it seems to happen for most polls. :p
I sent my votes in! :thumb:
    • Keyrenders
« Reply #138 on: Sun, 03 January 2016, 18:38:23 »
Haha yes, I'm expecting Penumbra, Carbon or some other set to show up :D
Offline qwack
« Reply #139 on: Sun, 03 January 2016, 19:42:25 »
I'd get purple and cyan in a heartbeat. I prefer colored legends on dark mods, but I may be in the minority.
« Last Edit: Sun, 03 January 2016, 19:49:09 by qwack »
Pure Pro w/MX Red - [review]
Offline justnits
« Reply #140 on: Sun, 03 January 2016, 21:00:12 »
i'm in the same boat as you, i prefer the dark legend on light alpha + colour legends on dark mods.
but to thesiscamper, i haven't been able to go through thoroughly on the whole thread, why not colour legends on dark alpha?
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
    • Keyrenders
« Reply #141 on: Sun, 03 January 2016, 21:31:11 »
Because of similarities with existing sets... I will try to ask Bunny and others like Karura.
« Last Edit: Mon, 04 January 2016, 00:52:47 by thesiscamper »
Offline Steezus
  • Keeper of Facts
« Reply #142 on: Sun, 03 January 2016, 21:39:33 »
Lol you guys got the quoting all messed up now
    • Keyrenders
« Reply #143 on: Sun, 03 January 2016, 22:02:14 »
Lol, I blame Tapatalk.
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #144 on: Mon, 04 January 2016, 00:38:59 »
Man some you men out here are afraid of some pink. Every color on here has been beaten to death except purple, cyan, and pink.
Let's make 2016 another creative year with the community having a larger color palette.
Offline Steezus
  • Keeper of Facts
« Reply #145 on: Mon, 04 January 2016, 01:07:38 »
I'm definitely in for purple and cyan, in fact my only other vote was for red.
Offline Data
« Reply #146 on: Tue, 05 January 2016, 15:54:54 »
Digging the purple and blue.
Offline lashiel
« Reply #147 on: Tue, 05 January 2016, 17:32:41 »
Have you considered gamer kits?
I definitely like the look of some of these.
I'm also curious (more in a theoretical sense) what might "Color" novelties look like? Obviously novelties aren't an option with GMK, but if you did SP DCS, it might be fun to toy around with. That said, I get this is supposed to be a simpler set, so maybe better to just not deal with that.
Offline Steezus
  • Keeper of Facts
« Reply #148 on: Tue, 05 January 2016, 17:51:33 »
This meant for the GMK modifiers, no gamer kits or novelties.
    • Keyrenders
« Reply #149 on: Tue, 05 January 2016, 21:16:37 »
The initial plan includes gamer kits, but no novelties.
I want these to be Cherry profile but not specifically by GMK, although I based the colors off their swatches. Nothing's set in stone and I'm exploring all options. :)
