Author Topic: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case [Packing]  (Read 296544 times)
Offline bazh
Re: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case
« Reply #100 on: Wed, 18 May 2016, 12:09:12 »
Will round 2 be a thing? I need some time to decide if I need another keyboard, as this is super tempting.
It could be, but I still have many thing to play with on this case so maybe it'll be different in the future, says, different side design or something like that  :D
HHKB Pro2 white
Newbie again
Offline Prodigy46
« Reply #101 on: Wed, 18 May 2016, 12:10:19 »
Put my order in for 1 red stand set but I'll take 1 purple set also
Offline biocalves
« Reply #102 on: Wed, 18 May 2016, 12:12:21 »
I'd like to add a Gunmetal stand if it makes the MOQ. I assume it'll be darker than your poll count right?
Offline bazh
« Reply #103 on: Wed, 18 May 2016, 12:13:46 »
Two questions
1) To estimate the cost of the PCB on winkeyless.kr, should we be adding all soldered components as well (diodes, resistors, controller, RGB, LED's, etc)?
2) Would it be possible to have sip sockets installed instead of LEDs? If not, since your plate supports switch top removal, would it be possible to add these after assemble is complete?
1. Most likely the PCB will be purchased with controller components soldered, all other thing including diodes, resistor, LEDs (regular 2x3x4mm LED), RGB SMD LEDs will be ours to be done.
2. I don't have a source for sip sockets plus install those require extra efforts (removed switch tops, put in, then close switch tops) so it will be done by you if desired. Basically we don't provide custom switch work now. :D
Also, here's the color count, including order from Weaven Round 2 too
Note that this is just a visualized example using color fill from Google Sheets, it may not represent 100% accurate real color
There's also people with Dark Blue and Deep Sky Blue in the order sheet but I'm assuming that you all want a deep blue more like Navy blue so it will be basic option, no counts needed.
Is it possible to have diodes, RGB LED and resistors pre-soldered as well? There are options for those on Winkeyless, but not sure if that works for this GB.
So the default blue is the blue in the pictures of Weaven OP, right?
Though I'm fine with that blue, I would prefer some special blue. Cyan is a little too bright to me. Maybe we can find a color between cyan and blue?
BTW, gunmetal is appealing too
Is it the time for the poll now?
As long as you can find enough people to support your proposal, feel free to think of the color :D I think for now I will just keep inform you the quantity for each color first, since we know don't know how many more order it will end up with yet so I think we still have time to adjust the color options after order is closed. ;)
//You want the PCB only right, I can purchased with those options from winkeyless for you :thumb:
HHKB Pro2 white
Newbie again
Offline bazh
« Reply #104 on: Wed, 18 May 2016, 12:15:19 »
so that mean you're in for 2 set in total? :D
HHKB Pro2 white
Newbie again
Offline bazh
« Reply #105 on: Wed, 18 May 2016, 12:17:19 »
yeah it'll be, the gunmetal is more likely to make the MoQ so far :thumb:
HHKB Pro2 white
Newbie again
Offline biocalves
« Reply #106 on: Wed, 18 May 2016, 12:19:18 »
Very nice, both colors I've chosen so far haven't met MOQ so am a bit nervous, haha. Someone order 1 orange!
How's the smokey frosted case looking? If you manage to get it as an option I'd like that as well.
Offline Geekmie
« Reply #107 on: Wed, 18 May 2016, 12:22:35 »
Awesome, exactly what I want.
Please put that in the note: B.face with controller, diodes, RGB LED and resistors pre-soldered.
Thanks a lot!
Offline Prodigy46
« Reply #108 on: Wed, 18 May 2016, 12:46:40 »
Yessir   ;D only 1 sandblasted case though. Purple will also go nice with Hyperfuse and so many other sets.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #109 on: Wed, 18 May 2016, 12:48:38 »
Thanks for clarifying.
Offline Geekmie
« Reply #110 on: Wed, 18 May 2016, 14:52:19 »
I see quite a few "sky blue" in the order sheet. Wonder what sky blue it is in everybody's mind? Attached is a list of blueish colors in RGB table for your reference.
BTW, for me, I prefer the "deep sky blue" in the table.
« Last Edit: Wed, 18 May 2016, 14:53:50 by Geekmie »
« Reply #111 on: Wed, 18 May 2016, 14:54:50 »
as long as it's blue, man
Offline eyedrop
« Reply #112 on: Wed, 18 May 2016, 15:14:51 »
Deep sky blue is a nice color.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #113 on: Wed, 18 May 2016, 15:16:49 »
I agree. I'd be down for that.
Offline Prodigy46
« Reply #114 on: Wed, 18 May 2016, 16:39:53 »
Sorry bazh I didn't make myself totally clear. I see you put that I wanted a clear case along with my sandblasted case, but I would only like the sandblasted. In total: 1x Red Aluminum, 1x Purple Aluminum, 1x Sandblasted Case. Thanks!
Offline Gengarfan
« Reply #115 on: Wed, 18 May 2016, 17:57:44 »
Would also be down for that!
Also Bazh, is there a difference between sandblasted and frost (sandblasted)?
Offline beehatch
  • baehatch
« Reply #116 on: Wed, 18 May 2016, 20:37:34 »
I'd be down to changing my color from Gold to either Purple or Blue. Just not sure which is going to make it :P
Offline murkey
    • murkey's alpaca farm
« Reply #117 on: Wed, 18 May 2016, 20:57:27 »
I'm in! Purple stand and frosted case, can't wait!
« Last Edit: Wed, 18 May 2016, 21:12:43 by murkey »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #118 on: Wed, 18 May 2016, 22:16:19 »
So if we specify it in the comments, can we get the Smokey Acrylite instead of clear/frosted?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #119 on: Wed, 18 May 2016, 22:25:44 »
I've been debating on whether or not to join this. Only, because, I just spent so much lately (hhkb,Jelly key constellation,krap,etc..) what is the possibility of Round2 for this? if there is no round 2.... I'll scavenge some money to join this.
Also, is there a way we can put weights to make this heavier? I am just concerned it might start sliding all over the place because the legs dont have any rubber feet under them (or do they).
Offline Khuya
« Reply #120 on: Thu, 19 May 2016, 01:46:27 »
pink + smoke acrylic please
« Reply #121 on: Thu, 19 May 2016, 01:49:25 »
true
Offline bazh
« Reply #122 on: Thu, 19 May 2016, 02:30:06 »
I'll edit it :thumb:
HHKB Pro2 white
Newbie again
Offline bazh
« Reply #123 on: Thu, 19 May 2016, 02:38:05 »
Everyone, smoke up until now still need testing, we'll post update in the thread later, so for now just stick to the clear or sandblast option. :thumb:
I think it's just only wording, the goal is to have the finishing which create light diffusing effect :D
HHKB Pro2 white
Newbie again
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #124 on: Thu, 19 May 2016, 04:25:00 »
There is a difference between clear acrylic that's been actually sandblasted (has a rough finish), and a semi-translucent acrylic (which can have a smooth finish).
Clear acrylic that has a rough finish might become shiny/clear with oil from fingerprints, etc. and won't really diffuse the light as well as semi-translucent acrylic.
Offline Geekmie
« Reply #125 on: Thu, 19 May 2016, 07:32:47 »
So my little promotion works I guess :D
Should I say "Deep Sky Blue" meets the MoQ? Cos' there are five here already including me~
Now here we go, a real sample~
Offline bazh
« Reply #126 on: Thu, 19 May 2016, 07:47:19 »
hmm, let me take a look on that, for me in this buy I mean clear acrylic with rough finish, see if I can find supply for the other one and price stuff too :thumb:
HHKB Pro2 white
Newbie again
Offline bazh
« Reply #127 on: Thu, 19 May 2016, 07:48:07 »
Yeah taking your "deep sky blue" is the same with other sky blue in the form, it's pretty much secure :thumb:
HHKB Pro2 white
Newbie again
Offline Geekmie
« Reply #128 on: Thu, 19 May 2016, 07:58:48 »
Like bazh mentioned, the goal would be to make a nice and equally distributed diffusion. The "frost" option on Winkeyless is good enough IMO (top one in the following image)
[top : matte frost, middle : matte white, bottom : white(opaque)]
link: http://winkeyless.kr/case-color/
Offline bazh
« Reply #129 on: Thu, 19 May 2016, 08:18:33 »
Color count updated :P
HHKB Pro2 white
Newbie again
Offline kawasaki161
« Reply #130 on: Thu, 19 May 2016, 08:48:04 »
Still waiting on words about 60% case compatability of the 62/60, hopefully we get some info about it before this GB runs out.
Also sad that there is no green yet. No one has some love for green in this community -.-
Offline murkey
« Reply #131 on: Thu, 19 May 2016, 10:50:18 »
Oh snap! Cyan made it in? Can I change from purple to cyan on my order? HYPE
Offline Khuya
« Reply #132 on: Thu, 19 May 2016, 10:55:52 »
I asked for green in the IC thread!
Please change mine from Pink to Magenta :)
« Last Edit: Thu, 19 May 2016, 11:29:56 by Khuya »
Offline bazh
« Reply #133 on: Thu, 19 May 2016, 11:01:30 »
Oh crap, I forgot that there is actually 1 green, jump in people :P
//color change request edited :P
« Last Edit: Thu, 19 May 2016, 11:09:19 by bazh »
HHKB Pro2 white
Newbie again
Offline Geekmie
« Reply #134 on: Thu, 19 May 2016, 11:04:28 »
bazh, could you also update the color of "sky blue" in this table so it would be similar to the "deep sky blue" in the color table I previously posted? I think people here sort of agree on that color I proposed. Thanks.
FYI, the hex value for that color is #00BFFF to be exact
« Last Edit: Thu, 19 May 2016, 11:06:09 by Geekmie »
Offline bazh
« Reply #135 on: Thu, 19 May 2016, 11:06:41 »
let me see if Google sheet have that color available, anyway I get the idea of the color so worry not, the table is not 100% the color will be made :thumb:
//done
« Last Edit: Thu, 19 May 2016, 11:09:41 by bazh »
HHKB Pro2 white
Newbie again
Offline Geekmie
« Reply #136 on: Thu, 19 May 2016, 11:20:14 »
Color count updated
//done
You can do that by selecting custom option under color and type in the hex code #00BFFF
Anyway, you got the idea. Thanks!
Offline murkey
« Reply #137 on: Thu, 19 May 2016, 11:21:11 »
Thank you bazh, I'm impressed how organized this is and how well you're staying on top of everything! :D
Offline Geekmie
« Reply #138 on: Thu, 19 May 2016, 11:45:10 »
Once again, bazh, you're awesome  :thumb:
Now that the sky blue is set. I want to promote some colors for the Teal/Cyan/Other blue (and potentially green?) camp.
How about "turquoise", "dark turquoise" and "medium turquoise" in the attached image?
Offline JDragon
« Reply #139 on: Thu, 19 May 2016, 13:56:03 »
Any chance of a TKL form factor case in the future? Would love to be able to swap out the stands to my other keyboards depending on what keysets they're wearing.
Offline WOMBO
« Reply #140 on: Thu, 19 May 2016, 17:35:36 »
+1 for pink, if it's anything like the rose gold on iPhones these days; otherwise can we get rose gold as an option?
Offline Gengarfan
« Reply #141 on: Fri, 20 May 2016, 00:54:25 »
Love your devotion to this buy :)
I compared these colors to hyperfuse and sky dolch and it seems "dark turquoise" best fits from those samples
Offline dannrawr
« Reply #142 on: Fri, 20 May 2016, 02:14:16 »
hopefully theres a round 2 :'(
WTF any Bruce, Cosmonauts
Offline murkey
« Reply #143 on: Fri, 20 May 2016, 02:25:30 »
I initially wanted something to match the cyan legend geekkeys caps. On my computer they are almost identical to dark turquoise. Kinda hard to tell if that will match reality though... Hmm
Offline bazh
« Reply #144 on: Fri, 20 May 2016, 05:24:17 »
just remember that each screen shows color differently due to calibrating and setting modes so comparing 1:1 screen light to real life object may not be accurate for everyone :P
HHKB Pro2 white
Newbie again
Offline Geekmie
« Reply #145 on: Fri, 20 May 2016, 08:43:59 »
That's very true. Hopefully we can a close enough result. I wonder if any sample would be made and shown here before "massive" production?
Thanks, buddy! I guess this is what it takes to make your ideal color meet the MoQ :p
It's also a fun experience to unify a color among guys :D
So tell me you're sold on it~
I'm planning to change the side bar color in my Weaven order to this "dark turquoise" and make it a candidate. If you guys like it, please join the camp! Thanks!
Offline Erysichthon
« Reply #146 on: Fri, 20 May 2016, 10:27:09 »
I have a couple of questions,
1. Does this case only fit winkeyless' PCBs?
2. What is the best way to go about changing my order?
Offline Gengarfan
« Reply #147 on: Fri, 20 May 2016, 11:44:50 »
Very true! I like to believe that my monitor has good color reproduction though since it's an IPS monitor. The MG279Q is amazing!
Offline murkey
« Reply #148 on: Fri, 20 May 2016, 15:18:43 »
Yeah, if there are enough people on board (looks like ~3 atm?) and bazh is ok with me changing my order a second time, I'd switch to dark turquoise.
Offline Gengarfan
« Reply #149 on: Fri, 20 May 2016, 19:04:10 »
Dark turquoise hype! Bazh I would like my blue changed to this dark turquoise as well if possible  ;D
