Author Topic: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case [Packing]  (Read 296547 times)
Offline Geekmie
Re: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case
« Reply #150 on: Fri, 20 May 2016, 19:11:37 »
Yeah, if there are enough people on board (looks like ~3 atm?) and bazh is ok with me changing my order a second time, I'd switch to dark turquoise.
Dark turquoise hype! Bazh I would like my blue changed to this dark turquoise as well if possible  ;D
Why not just go for sky blue AND dark turquoise~ Forget about gold. Be a diehard blue fan :P
Offline WOMBO
« Reply #151 on: Fri, 20 May 2016, 19:27:37 »
I have a couple of questions,
1. Does this case only fit winkeyless' PCBs?
this should fit any standard 60% since wkl pcbs are standard fitting.
Offline Gengarfan
« Reply #152 on: Fri, 20 May 2016, 19:32:56 »
I'm only getting gold if the smokey acrylic gets made... if I could I would just buy every option lol
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #153 on: Fri, 20 May 2016, 19:50:34 »
I agree about the gold and smoke. That was really the combination that I wanted the most. I'll be in for a sky blue and something else, just don't know what yet.
Offline Erysichthon
« Reply #154 on: Fri, 20 May 2016, 21:05:27 »
Awesome, thank you!
« Reply #155 on: Fri, 20 May 2016, 22:25:31 »
****ty pic but what would match this plate
cuz that's what i'm putting in it. I'm torn between the cyan and deep sky blue right now, leaning towards the cyan a little.
Offline Gengarfan
« Reply #156 on: Fri, 20 May 2016, 22:43:39 »
We are trying to get the cyan people to unify enough to get "dark turquoise" and it would be really helpful if you chose that if you went the cyan route but no pressure there. Both the dark turquoise and sky blue would look really nice with that plate probably. I don't know if you could go wrong with either.
« Reply #157 on: Fri, 20 May 2016, 22:58:36 »
I don't prefer dark turquoise so if that makes it and cyan doesnt then I'll just go with the deep sky blue, no problems here :P
Offline bazh
« Reply #158 on: Sat, 21 May 2016, 03:39:32 »
Here's the post on Weaven thread, what do you think?
well the color appears to me look very much like a darker shade of cyan, no tone different, perharps we can compromise on that with 'Cyan' people ? A medium shade between the 2 is kind of work for me.
Dark cyan works for me I guess. You can group us together, but the final color can be still open for discussion later. We have other teal people on the list. Wonder how their thoughts on this are~
If you're ok with that then the color is secured MoQ :thumb:
HHKB Pro2 white
Newbie again
Offline murkey
    • murkey's alpaca farm
« Reply #159 on: Sat, 21 May 2016, 04:18:57 »
Dark light-greenish-blue ftw!!! Seriously though, I can't wait for this. I think I'm going to call it "Happiness and Cyan"
Offline Ngt
« Reply #160 on: Sat, 21 May 2016, 04:46:58 »
Do you know approximately how much will the case weigh?
Concerning the plate, as you separate ISO and ANSI, does your ANSI plate allow for 1u RShift? I use ANSI but I need that 1 extra key that ISO layout has there.
Do you have a picture for the difference between sandblasted and waterclear? Is sandblasted = frost?
EDIT: No need to answer the last question, I got the answer from the thread. I didn't read it thoroughly enough. But a smoked finished instead of a waterclear acrylic polished finish sounded better as others proposed.
« Last Edit: Mon, 23 May 2016, 07:55:09 by Ngt »
Offline Geekmie
« Reply #161 on: Sat, 21 May 2016, 09:54:21 »
It's a beautiful plate~ Sky blue will just match it gorgeously :D
« Reply #162 on: Sat, 21 May 2016, 16:10:17 »
I actually just switched to purple, I'll use the sky blue plate in a different build. But I have a long time project I need to complete!
Offline Ngt
« Reply #163 on: Sun, 22 May 2016, 15:18:45 »
Is an HHKB style plate is possible (I forgot to ask earlier as I misread the OP)? I mean a top plate with a bottom row without the CTRL key holes. Which would give some like that 1-1.5-7-1.5-1 with a 7u space bar.
Offline bazh
« Reply #164 on: Mon, 23 May 2016, 03:46:49 »
Hi guys, I'm just back online after a long flight yesterday, havent got time yet so just so you now I'll reply all the mesages and post tonight, no worry if you have any :thumb:
HHKB Pro2 white
Newbie again
Offline muon
« Reply #165 on: Wed, 25 May 2016, 14:14:20 »
Hey, welcome back! How many slots are left in the GB?
Also, do you happen to have any more pictures of an assembled Lustro?  :thumb:
« Reply #166 on: Wed, 25 May 2016, 14:16:14 »
Yeah has there been a picture of an assembled one with underglow active? That's what I'd like to see :o
Offline Ngt
« Reply #167 on: Wed, 25 May 2016, 14:55:44 »
According to the OP, there are 3 slots left.
That's definitely something I'd like to see as well.
I'm waiting for an HHKB plate style confirmation before I jump on it. Hope I'll get the answer before the 30th.
Offline Geekmie
« Reply #168 on: Wed, 25 May 2016, 15:00:32 »
Well, that might not be updated. There are a lot more than 30 orders in the spreadsheet already. Don't know if there is an upper limit though.
Offline Ngt
« Reply #169 on: Wed, 25 May 2016, 15:02:58 »
The OP states that there are a 30 orders cap. If we have already gone through it and it wouldn't be extended then ...  :'(  Perhaps there will be a 2nd round with HHKB style plate.
Offline pear_voz
« Reply #170 on: Wed, 25 May 2016, 15:11:50 »
Wew, the rumor said that the GB will be no limit in number of order, just make sure that you join it be4 the deadline :3
Trivium Keyboard Co.
Offline Ngt
« Reply #171 on: Wed, 25 May 2016, 15:18:30 »
Alright so I'd better ask him directly about my questions then. Do you know if the sandblasted will be a smoked acrylic or the rubbed version? I read earlier that bazh was looking into it but didn't remember reading an update about it.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #172 on: Wed, 25 May 2016, 15:21:38 »
The way I read it is that the deadline is May 30 and if there were not 30 orders by then, it would be extended until there was.
Order deadline is 2 weeks, or when 30 orders is up  :thumb: Currently just keep in mind that deadline will be May 30th.
Offline Ngt
« Reply #173 on: Wed, 25 May 2016, 15:26:10 »
Oh ok, didn't get it that way at all. If that's the case, they were all good! :D Thanks for clarifying.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #174 on: Wed, 25 May 2016, 15:27:46 »
That's how I took it anyway. I guess we should wait for @bazh to confirm.
Offline Ngt
« Reply #175 on: Wed, 25 May 2016, 15:28:31 »
Of course, but after reading it again your point makes sense.
Offline bazh
« Reply #176 on: Thu, 26 May 2016, 01:15:54 »
At first I expected a much slower order so 30 is my estimation for quick run, but it turned out we passed that in just one day so we're not doing order cap anymore :P
HHKB Pro2 white
Newbie again
Offline tomboy
« Reply #177 on: Thu, 26 May 2016, 02:26:59 »
What are the outer dimensions of the case/stands?
(I'm interested to see if I can put this over a 15" mbp's keyboard without touching the keys.)
Offline bazh
« Reply #178 on: Thu, 26 May 2016, 03:09:15 »
I put it on a 13" one and it did just fine :thumb:
Update on colors:
HHKB Pro2 white
Newbie again
« Reply #179 on: Thu, 26 May 2016, 03:27:07 »
Looking at the full kit that you offer, I guess you will be ordering b.faces from wkl.kr? Can we order b.faces from you without the assembly service and have them shipped along with our cases?
Offline Gengarfan
« Reply #180 on: Thu, 26 May 2016, 03:32:40 »
Update on colors:
Just a heads up, I think a few people including myself voted for dark turquoise from that one color sample posted awhile back :)
Offline bazh
« Reply #181 on: Thu, 26 May 2016, 03:38:53 »
Update on colors:
**** I forgot, your order is now 1 golden and 1 sky blue so which one you want to change? :(
HHKB Pro2 white
Newbie again
Offline bazh
« Reply #182 on: Thu, 26 May 2016, 03:41:00 »
Totally, I can include some PCB as well when we order from wkl. :thumb:
Quick phone potato pics:
More quality photos tomorrows :thumb:
HHKB Pro2 white
Newbie again
Offline Gengarfan
« Reply #183 on: Thu, 26 May 2016, 03:43:56 »
Update on colors:
I think Just the dark turquoise with the frosted sandblasted case will be enough. We can cross off the other two. Thanks for changing my order so many times haha
Offline bazh
« Reply #184 on: Thu, 26 May 2016, 03:52:29 »
Update on colors:
also just a reminder, dark turquoise will now be list as cyan as I explained earlier :thumb:
HHKB Pro2 white
Newbie again
Offline Ngt
« Reply #185 on: Thu, 26 May 2016, 04:43:44 »
**** that's really nice!
Do you know if that's possible to have an HHKB style plate (without the CTRL key holes)?
EDIT: Plus does your ANSI plate allow for split RShift? As in an ISO plate.
EDIT2: And do you know the weigh of the case + standoffs?
Sorry for all the extra questions.
« Last Edit: Thu, 26 May 2016, 04:47:34 by Ngt »
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #186 on: Thu, 26 May 2016, 06:10:49 »
Lookin really good. Is that the clear or the frosted acrylic?
Offline Ngt
« Reply #187 on: Thu, 26 May 2016, 07:47:56 »
I'd say frosted IMO.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #188 on: Thu, 26 May 2016, 08:14:35 »
It's kind of hard to tell since it's so fuzzy.
Offline Geekmie
« Reply #189 on: Thu, 26 May 2016, 08:23:49 »
Doesn't matter. It looks just AWESOME~
Offline Ngt
« Reply #190 on: Thu, 26 May 2016, 08:27:01 »
Yep you got it!
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #191 on: Fri, 27 May 2016, 04:14:52 »
The most requested stuff...
Still prototype version, final one will be more polished.
The thick bottom really help.
Now, non-blinker photos:
KEYBOARD MACHINERY SERVICE SINCE 2015.
Website: triviumtek.com
Instagram: instagram.com/triviumkeyboard
Facebook: facebook.com/triviumtek
[GB] Weaven Housing Kit      [GB] Lustro Housing Kit
Offline theoriginal123123
« Reply #192 on: Fri, 27 May 2016, 04:57:08 »
What's the weight of the case? Being used to the Pok3r's aluminium case, I'm a little worried as to just how stable it actually would be on the desk...
Offline Ngt
« Reply #193 on: Fri, 27 May 2016, 05:12:55 »
Just wow! Love it. Must have it! <3
Thanks for the pictures btw!
Offline nickysan92
« Reply #194 on: Fri, 27 May 2016, 05:19:19 »
Welp, that looks sick.
Is that the smokey acrylic or the normal acrylic?
Offline fancymans
« Reply #195 on: Fri, 27 May 2016, 06:00:15 »
Hi Bazh, just joined in for the GB. I'm still pretty new to all this, so I have a few questions.
1. Are the LEDs SMD or 1.8mm switch mounted?
2. Is there an option to have RGB LEDs? If so, SMD or switch mounted?
3. I want winkey, do I need to specify winkey or winkeyless in the order?
Realforce 87U 55g 10th Silenced | HHKB Silenced | FC660C
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #196 on: Fri, 27 May 2016, 06:33:46 »
1. We use 2x3x4 switch mount led like this one.
2. RGB led will require a pcb that supported it, wkl.kr doesn't have any pcb with it. If you know any board that do it currently in stock, we can buy and assem for you with that one.
3. Currently there's only winkey version for Lustro, so no need for any specification.
Offline Geekmie
« Reply #197 on: Fri, 27 May 2016, 08:08:05 »
Just one word:
Supercalifragilisticexpialidocius!!!
Offline nguyenkimtam
  • Shin
« Reply #198 on: Fri, 27 May 2016, 08:26:46 »
I don't think that have a good anodization and a good quality acrylic case
« Last Edit: Fri, 27 May 2016, 08:29:24 by nguyenkimtam »
Offline Ngt
« Reply #199 on: Fri, 27 May 2016, 08:32:15 »
I have no expertise in the matter to distinguish if you are just using irony or doing genuine complains. Which one is it?  :D
