Author Topic: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case [Packing]  (Read 296550 times)
Offline fancymans
Re: [GB]LUSTRO Aluminum + Acrylic Custom 60% Case
« Reply #250 on: Sat, 28 May 2016, 16:30:17 »
So I wanted to make a few changes to my order, how should I do this?
feel free to PM me ;)
Sent! :D Can't wait I'm so excited
Realforce 87U 55g 10th Silenced | HHKB Silenced | FC660C
Offline mattycee
« Reply #251 on: Sat, 28 May 2016, 18:33:24 »
are these colors going to anodized or do we have to specifically ask for it?
Current: Das 4 MX Blues,  Poker II MX Clears
Offline Khuya
« Reply #252 on: Sun, 29 May 2016, 04:10:08 »
We did try something else with the acrylic base, here is some thoughs and reasons why it look so basic:
Acrylic is a hard but brittle material so anything that weakening the structure are out of options, that led to part and feature need to be somewhat bulky to be reasonable sturdy. We tested out several design but too much bulkiness to four sides decrease the aesthetic too, and adding features to the back is not worth the effort since we not see them in use anyway. It not possible for the current 60, but I have something interesting for the up coming hhkb since I have more room to play on the front side.
And the side stands design are not fixed, there will be more option to choose in near future, it worth keeping the base low profile so it go well with many other bold stand design.
Finally, Lustro meant to be budget option of the line-up (Weaven cost more for snug-fit modular parts and excessive use of carbon and still nothing compare to some of our concepts). Any design that drive the cost up are carefully calculated before available for IC and GB.
I love talking about design so it maybe longer response than needed, haha.
PS we waiting for smokey prototype too.
just an idea, but what about a thin layer of diffusal at the bottom of the case for the clear/smoky acryic?
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #253 on: Sun, 29 May 2016, 08:41:45 »
The thick bottom did a great job already, but I will try some reflective sticker to keep the light bouncing, maybe?
KEYBOARD MACHINERY SERVICE SINCE 2015.
Website: triviumtek.com
Instagram: instagram.com/triviumkeyboard
Facebook: facebook.com/triviumtek
[GB] Weaven Housing Kit      [GB] Lustro Housing Kit
Offline Geekmie
« Reply #254 on: Sun, 29 May 2016, 09:12:11 »
Polycarbonate diffuser?
https://youtu.be/GYSfKGI63co
Offline WOMBO
« Reply #255 on: Sun, 29 May 2016, 15:04:48 »
I don't think that have a good anodization and a good quality acrylic case
Is that a GXS60RGB board? I ordered one off Aliexpress but couldn't find any info on it anywhere, any chance you know anything about it?
Edit: Disregard my question, I should haveread the last page before posting.
foggyflute since that was your friend: Any chance he has any info on that board or you perhaps.
Yes it is, we ordered a lot kind of 60% to study more about the layout and what you can do with it, resulting in we have a lot laying around so we just randomly pick one to put in the prototype :P
I don't know what info you want about the board, for functional it is an interesting practice of getting use of the RGB SMD LEDs for the switches without the need of using Cherry MX RGB one, the LED is placed on PCB's back side and illuminate the switch through a hole cut on the PCB, by that way it can be used with any clear cased Cherry MX compatible switches such as Gateron for example.
I wanted to know if it was programmable? Both the led effects as well as its firmware, perhaps tmk compatible?
Thanks for any info you can provide
I haven't assembled the board yet but high chance that it can be (programmable), TMK I'm not sure ;D
You're using the WKL pcbs right? Those are programmable with their client keymapper but not through TMK afaik (I have a B.Face)
Offline Ngt
« Reply #256 on: Sun, 29 May 2016, 16:55:55 »
Bazh, will you close the deadline on 30th evening?
Yes it is, we ordered a lot kind of 60% to study more about the layout and what you can do with it, resulting in we have a lot laying around so we just randomly pick one to put in the prototype :p
Are b.face usable with TMK firmware?
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #257 on: Sun, 29 May 2016, 23:12:49 »
Finally settled on colors; submitted. Another for the Deep Sky Blue.
Offline bazh
« Reply #258 on: Sun, 29 May 2016, 23:26:25 »
Order will be closed today at the end of the day, invoice to come all of you in a couple of days ;)
HHKB Pro2 white
Newbie again
Offline Jeu
« Reply #259 on: Sun, 29 May 2016, 23:40:57 »
Just submitted an order! Venturing into the custom KB world  ;D To make sure, last mentioned was no need to order Zealios separately and send Zeal the order #s for the Lustro and Zealios...correct?
Offline Jeu
« Reply #260 on: Mon, 30 May 2016, 00:18:20 »
Actually can you change my order to purple instead? sorry for being difficult! :p
Offline Ngt
« Reply #261 on: Mon, 30 May 2016, 03:10:45 »
Thanks for the info.
« Reply #262 on: Mon, 30 May 2016, 03:23:04 »
Nice :D wallet is not ready though :(
Offline bazh
« Reply #263 on: Mon, 30 May 2016, 03:50:31 »
correct!
Green and Maneta are the only 2 not made it to MoQ so far :(
HHKB Pro2 white
Newbie again
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #264 on: Mon, 30 May 2016, 09:39:31 »
Hey bazh, can you change my secondary color from gold to gunmetal?
Offline Ngt
« Reply #265 on: Mon, 30 May 2016, 11:34:54 »
Is golden the Orange mentioned in the calc picture he showed before?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #266 on: Mon, 30 May 2016, 12:13:07 »
The gold I was referring to is from the OP. But I want gunmetal instead.
Offline Ngt
« Reply #267 on: Mon, 30 May 2016, 12:23:32 »
I think i'm going for the same color. Is gunmetal the "silver" option in the form or do you have to specify "gunmetal" in the "other" field?
Offline graefeln
« Reply #268 on: Mon, 30 May 2016, 12:26:36 »
Gunmetal was a voted for color - more grey than silver - so you would probably need to specify it in the 'other' field...
Offline Ngt
« Reply #269 on: Mon, 30 May 2016, 12:28:03 »
Alright thanks. So the silver color would be more like the first pictures in the OP right?
Offline graefeln
« Reply #270 on: Mon, 30 May 2016, 12:34:06 »
That's the assumption I would make. Silver was one of the default choices and, as far as I know, they didn't actually get samples of any of the 'custom' colors yet - so I do believe that would  be anodized silver (I suppose an untreated aluminum sample is possible however).
Offline Ngt
« Reply #271 on: Mon, 30 May 2016, 12:58:12 »
Alright thank you.  :thumb:
Offline Ngt
« Reply #272 on: Mon, 30 May 2016, 16:20:31 »
Just submitted the form. Hope it is not too late.
Offline mattycee
« Reply #273 on: Wed, 01 June 2016, 16:47:52 »
is this still alive? :p
Offline fancymans
« Reply #274 on: Wed, 01 June 2016, 16:51:14 »
Think they're sorting out the orders and prepping. Bazh said we'll be getting emails for invoices a few days after GB closes when I PM'd him a few days back.
Offline Ngt
« Reply #275 on: Thu, 02 June 2016, 09:56:58 »
I remember reading something like that in the thread as well. As Fancymans said, this takes work to organize a GB even though we are not hundreds. Be patient a bit. ;)
Offline graefeln
« Reply #276 on: Thu, 02 June 2016, 11:19:10 »
I switched over to Weaven, but it ended the same as this, so it's probably still relevant. I received my PayPal notice early this morning, so things are moving. Two buys ended together and there is probably a lot to sort through - just try to be patient. I know it sucks, but it takes time...
Offline biocalves
« Reply #277 on: Thu, 02 June 2016, 11:26:58 »
It's nice to know people are starting to get invoices. Eager to get my own!
Offline graefeln
« Reply #278 on: Thu, 02 June 2016, 11:50:42 »
Not going to lie, I have been waiting quite impatiently myself - I even thought about posting yesterday to ask if anyone else had been invoiced.
It came about 0130 (CST); the 'message from seller' was as follows in case anyone is curious (emphasis mine):
This is invoice for your order of Weaven keyboard case Round 2:
- Winkeyless version
- Purple-Gunmetal-Purple color
- ANSI plate
Estimating turn over time less than 8 weeks. You'll get a notification when the case is ready to ship.
Please check the order detail above and only pay if it's right.
Looks like we may be looking at early August if not a little sooner. Hoping for mid-July myself - just in time for my birthday (it'll help my justify the expense to myself)!
Offline biocalves
« Reply #279 on: Thu, 02 June 2016, 11:57:35 »
- ANSI plate
There's a lot of the waiting game in this hobby so I'm totally ok with it, but always nice to hear about updates. I'm waiting to throw Leandren's latest GB onto this so the sooner the better, but it'll come when it comes so I found it best to distract myself by spending more  money on other projects to pass the time.  :p
Offline graefeln
« Reply #280 on: Thu, 02 June 2016, 12:25:14 »
Yeah, I was actually a little surprised by how fast this will seemingly be done - and they seemed to have been pretty good about scheduling for round 1.
My thing about group buys has always been the communication. Once that falters, it seems like everything is all doom and gloom.
I am going to throw a GH60 into mine - no need for lighting really, not on the Weaven, along with some R3 Zealio (so I am waiting on those anyways).
Really want to see what everyone's looks like once they're built.
Offline fancymans
« Reply #281 on: Thu, 02 June 2016, 15:00:25 »
Cool beans. I was thinking about switching to the Weaven too, but then I decided not to because the Lustro has those cool looking stands. I'm going for a Mirror's Edge theme on my keyboard, so all white/red with white LEDs. :) Too bad the Zealios are purple, but it's worth it for the feelios.
Offline graefeln
« Reply #282 on: Thu, 02 June 2016, 15:17:42 »
The best part about the Lustro (IMO) is that it is modular - I am looking forward to seeing what other stands come up in the future! To a lesser degree, it is the same with the Weaven (hoping for a brown/purple HHKB setup eventually).
Red/White is a nice color scheme - I am assuming red stands; what set of caps you trying to throw on there? The stems will be covered, so no one will see your purple secret - wish I could have them on display though! On a side note, grab a couple green blanks/artisans and you'll have a nice set up to run during Christmas too!
Offline fancymans
« Reply #283 on: Thu, 02 June 2016, 15:25:03 »
Was going to get blank DSA caps from Signature Plastics. Red modifiers, white for alphanumeric. I'll see what others profiles are available in terms of caps. Do you know if the stabilizers will be Cherry or Costar? Or does the CF plate support both? Costar doesn't play nice with some of my PBT caps.  :(
Offline graefeln
« Reply #284 on: Thu, 02 June 2016, 15:34:10 »
I think both are supported, but if they are building it for you, I would expect Cherry PCB. They are easier to find in general and are what Winkeyless sells, so I assume they are going to go that way. I am really hoping Zeal gets his stabs out soon, but ordered a set of Cherry (separately) just in case - haven't decided if it would be worth all the (de)soldering to change out stabs after the fact, but will certainly pick up a set anyways.
I bought a set of blank dark grey Gateron off MechMarket to tide me over for a bit, but am really wanting to get in on Skeletor when it moves forward. I even thought about going purple/sky blue on the Weaven to compliment it, but figured gun metal would be 'interchangeable' if I ever decided to use different caps.
Offline Weiss
  • Impulse buying at its finest
« Reply #285 on: Thu, 02 June 2016, 17:24:04 »
Could always try to find some Linear Zeals if you want the quality that Zeal switches have but still fit the White/Red theme. Obviously won't be the same as the Tactiles, but hey.
Offline fancymans
« Reply #286 on: Thu, 02 June 2016, 23:55:32 »
Haha yeah, but I'm not a fan of linear switches. They feel weird to me.
Offline Gengarfan
« Reply #287 on: Sat, 04 June 2016, 14:49:49 »
Any updates?
Offline Khuya
« Reply #288 on: Sat, 04 June 2016, 19:12:14 »
I wonder what happen to this?
Offline foggyflute
  • Amateur Maker
    • Triviumtek
« Reply #289 on: Sat, 04 June 2016, 19:31:35 »
Any updates?
We are working on orders shorting, invoice will be sent out to each group with same type of order in next week.
But as we usually do, production always started ahead ;)
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #290 on: Sat, 04 June 2016, 19:42:52 »
Any updates?
Oh man. So shiny =]
Offline bazh
« Reply #291 on: Sat, 04 June 2016, 21:30:25 »
Hi guys, sorry for miscommunicate the last couple of days, my laptop's broken so things getting slow down a bit.
About invoicing progress: so far all of people who order winkeyless Weaven are the only to receive invoice. Next in plan is the rest of the Weaven and the Lustro order that does not come with assembling parts, people with assembling parts will be last since I have to calculate the total cost for parts too, sorry for that I hope you understand :(
Hope we can get the invoicing and payment done in next week ;)
HHKB Pro2 white
Newbie again
Offline nickysan92
« Reply #292 on: Sun, 05 June 2016, 11:51:17 »
Great! Can't wait to get my hands on one :D
Any updates on the likelihood of seeing the smoky acrylic for this round?
Offline Jeu
« Reply #293 on: Sun, 05 June 2016, 13:50:19 »
Really hoping so but it didn't seem like the smoky was sneaking through this time.
Offline pear_voz
« Reply #294 on: Sun, 05 June 2016, 15:41:43 »
Oh, the smoky acrylic might be available with an extra cost (very little imo), if it happen, it will happen next week :3
Trivium Keyboard Co.
Offline Khuya
« Reply #295 on: Sun, 05 June 2016, 17:56:54 »
hopefully it will come with the color acrylic options...that deep red acrylic with red case is amazing..
Offline Ngt
« Reply #296 on: Sun, 05 June 2016, 18:02:45 »
Any updates?
Wow so cool! That must be quite an investment doing it without invoicing people beforehand! Correct me if I'm wrong but that's the stands as before anodizing, am I right?
Thanks for letting us know btw.
Offline biocalves
« Reply #297 on: Sun, 05 June 2016, 18:27:12 »
This is most welcome news!
Offline bazh
« Reply #298 on: Mon, 06 June 2016, 00:50:57 »
Any updates?
yes it is before anodizing of course :thumb:
HHKB Pro2 white
Newbie again
Offline Ngt
« Reply #299 on: Mon, 06 June 2016, 01:57:50 »
Will the smocky acrylic be an option for those who ordered frosted?
Any updates?
At first I thought it was the silver standing but then I noticed there are too many of them, that's why I asked. :) Thanks for answering.
